So I am trying to make my own custom theme. So far I have managed to change backgrounds. But now I'm getting to the point where I want to change some of the menu options and I'm having trouble figuring it all out. I've looked around the forums for a few hours trying to find my answers but with little luck.
1. What menu options are removed when I set it to "Simple" mode?
2. How do I remove certain options like "search" "more games and options" "multimedia" and "exit/shutdown?" My machine is designed to work in festival environments and I dont want random people being able to access features that use the internet and I also dont want them to be able to leave GameEx. I know I can set special key combinations that will enable only me or my crew to leave the program.
3. Can I move certain options to other menus? For example, I want to have the "Jukebox" and "Karaoke" functions in the main menu.
4. On that same note, can I make additional menus? I want to have the "Play Random Game" in its own menu so when I leave the machine on it, the only option that can be chosen is "Play Random Game," I also would like to know if I can link the back to that menu when I leave the random game I just played.
5. How do I disable the visualizer and album artwork that appears in the rest of the menus when I set the jukebox to play automatically. i dont want to see the song and squiggly lines. I just want to hear it.
6. How can I rename objects on the field? For example, I want the title for the start menu to read "Tiki's Artcade" instead of "Start.."
Essentially I want my start menu to look like this
Most Played
Last Played
Favorites
Games
Play Random Game (Linked to its own menu)
Jukebox
Karaoke
You may need to explore the Custom Menus application for organizing/managing your menus outside of GameEx out of the box standard. That is something not controlled via Theme Editor. The visualizer you can turn off via the Setup Wizard.
That answers everything except for what features are disabled when I set it to simple mode. Also, how do I get rid of the album artwork from showing up on the start page?
