[RESOLVED] daphne 1.0.2.2.11 wont load in gameex
o.k here it goes im a newbie on here and never asked online for help so if im doing this post wrong im very sorry.
i not new to gameex and have it going ,mame, sega,play station,ect
i got daphne all working from the loader version 1.0.2.2.11 figured out how to get the command line from it..through the web.copyed it from the loader and put it in gameex.
here is the log file from daphne it works fine there.
--DAPHNE version 1.0.12
--Command line is: daphne.exe lair vldp -framefile C:\Daphne\framefile\lair\lair.txt -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir C:\Daphne -bank 0 11111001 -bank 1 00100111 -noissues -noserversend -sound_buffer 2048 -x 640 -y 480
--CPU : AuthenticAMD 1750 MHz || Mem : 1024 megs
--OS : Windows XP/.NET || Video : RADEON 7000 SERIES
--OpenGL: Compiled In
--RGB2YUV Function: MMX
--Line Blending Function: MMX
--Audio Mixing Function: MMX
Setting alternate home dir:
C:\Daphne
Setting sound buffer size to 2048
Setting screen width to 640
Setting screen height to 480
Set 640x480 at 32 bpp with flags: 0
Initializing sound system ...
GI Sound chip initialized at 2000000 Hz
No joysticks detected
Remapping input ...
Loading compressed ROM image dl_f2_u1.bin...8192 bytes read.
Loading compressed ROM image dl_f2_u2.bin...8192 bytes read.
Loading compressed ROM image dl_f2_u3.bin...8192 bytes read.
Loading compressed ROM image dl_f2_u4.bin...8192 bytes read.
Framefile parse succeeded. Video/Audio directory is: C:/Daphne/framefile/lair/
YUV overlay is hardware accelerated.
Booting ROM ...
Play
LDP : disc is already playing, play command ignored
Play
Display disable received
Search to 323 received - [25] Attract Mode, Sequence 0 Attract Mode
NOTE: converting FPKS from 23976 to 29970. This may be less accurate.
search succeeded d0
Play
Search to 306 received - [25] Attract Mode, Sequence 0 Attract Mode
Freeing memory used to store audio stream...
search succeeded d0
LDP NOTE: ignoring seek because we're already on that frame
search succeeded d0
search succeeded d0
Search to 1424 received - [ 0] Introduction, Sequence 0
search succeeded d0
Play
Search to 1823 received - [ 0] Introduction, Sequence 3
search succeeded d0
Play
Search to 9181 received - [ b] Closing Wall, Sequence 0
search succeeded d0
Play
Search to 9301 received - [ b] Closing Wall, Sequence 4 Death Scene
search succeeded d0
Play
Search to 18226 received - [18] Drink Me, Sequence 1 Resurrection Scene
Shutting down sound system...
Shutting down video display...
here is the log from gameex..
05:06:19.0 4/25/2012: Opening Configuration File
05:06:19.0 4/25/2012: GameEx: Version 12.56: Starting Log
05:06:19.0 4/25/2012: Operating System Platform: Win32NT
05:06:19.0 4/25/2012: Operating System Name: Windows XP
05:06:19.0 4/25/2012: Operating System Version: 5.1.2600
05:06:19.0 4/25/2012: AMD Sempron™ Processor 3100+, 1023MB
05:06:19.0 4/25/2012: 1.81Ghz
05:06:19.0 4/25/2012: Running Randomize()
05:06:19.1 4/25/2012: Loading PlugIns
05:06:19.1 4/25/2012: Checking for applications to Launch On Startup
05:06:19.1 4/25/2012: Running Misc startup tasks
05:06:19.1 4/25/2012: Setting Menu types
05:06:19.1 4/25/2012: Getting Configuration Values
05:06:19.1 4/25/2012: Using Theme: Default - Eye Candy
05:06:19.1 4/25/2012: Checking for alternate Image Directory for Theme: Default - Eye Candy
05:06:19.1 4/25/2012: Launching HideOS.exe
05:06:19.1 4/25/2012: Initialising Video/MNG DLL's
05:06:19.1 4/25/2012: GameEx will check for media insertion (may affect performance)
05:06:19.1 4/25/2012: Hiding Taskbar
05:06:19.1 4/25/2012: Is Media Center running?
05:06:19.1 4/25/2012: Checking/Creating LCD Registry values
05:06:19.1 4/25/2012: Check Media Center Exit/Start Mode
05:06:19.1 4/25/2012: Media Center Mode 2
05:06:19.2 4/25/2012: Video previews on. Warning: Only recommended on modern systems
05:06:19.2 4/25/2012: Snap Delay set to: 2
05:06:19.2 4/25/2012: Get other settings
05:06:19.2 4/25/2012: Desktop set to Hide ICONS and set Background to Black
05:06:19.2 4/25/2012: Set: Find emulator artwork on best match basis
05:06:19.2 4/25/2012: SlikStik support enabled
05:06:19.2 4/25/2012: Start work for Form
05:06:19.2 4/25/2012: Getting Original Screen Size
05:06:19.2 4/25/2012: Opening Database Connection
05:06:19.2 4/25/2012: Initializing Component
05:06:19.3 4/25/2012: MAME Path is: C:\Emulators\Mame32
05:06:19.3 4/25/2012: daphne Path is: C:\Daphne
05:06:19.3 4/25/2012: daphne EXE file is: DaphneLoader.exe
05:06:19.3 4/25/2012: Use daphne on. DaphneLoader.exe will launch games
05:06:19.3 4/25/2012: Model 2 Path Path is: C:\Emulators\Model2
05:06:19.3 4/25/2012: Model 2 EXE file is: emulator.exe
05:06:19.3 4/25/2012: Model 2 emulator with command line support detected
05:06:19.3 4/25/2012: Use Model 2 on. emulator.exe will launch Sega Model 2 games
05:06:19.3 4/25/2012: MAME EXE file is: Mame32.exe
05:06:19.3 4/25/2012: ROM Path is: C:\Emulators\Mame32\roms
05:06:19.3 4/25/2012: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
05:06:19.3 4/25/2012: controls.ini is located at: C:\Program Files\GameEx\DATA\controls.ini
05:06:19.3 4/25/2012: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
05:06:19.3 4/25/2012: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
05:06:19.3 4/25/2012: command.dat is located at: C:\Program Files\GameEx\DATA\command.dat
05:06:19.3 4/25/2012: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
05:06:19.3 4/25/2012: Loading Controls.ini map file
05:06:19.3 4/25/2012: Snap Path is: C:\Emulators\Mame32\snap
05:06:19.3 4/25/2012: Background Snap Path: Not Found
05:06:19.3 4/25/2012: AVI Snap Path is: C:\Emulators\Mame32\avisnap
05:06:19.3 4/25/2012: Flyer Path is: C:\Emulators\Mame32\flyers
05:06:19.3 4/25/2012: Cabinet Path is: C:\Emulators\Mame32\cabinets
05:06:19.3 4/25/2012: Cabinet 3D Path: Not Found
05:06:19.3 4/25/2012: Title Path is: C:\Emulators\Mame32\titles
05:06:19.3 4/25/2012: PCB Path: Not Found
05:06:19.3 4/25/2012: Artwork Preview Path: Not Found
05:06:19.3 4/25/2012: Panel Path is: C:\Emulators\Mame32\cpanel
05:06:19.3 4/25/2012: Manual Path: Not Found
05:06:19.3 4/25/2012: Icon Path is: C:\Emulators\Mame32\icons
05:06:19.3 4/25/2012: Marquee Path is: C:\Emulators\Mame32\marquees
05:06:19.3 4/25/2012: Applying Language/Text
05:06:19.3 4/25/2012: Text/Language: English
05:06:19.4 4/25/2012: Loading Custom Emulators
05:06:19.4 4/25/2012: Loading Emulator 1: Sega CD
05:06:19.4 4/25/2012: Loading Emulator 2: Sega 32x
05:06:19.4 4/25/2012: Loading Emulator 3: Sega Genesis
05:06:19.4 4/25/2012: Loading Emulator 4: Sony Playstation
05:06:19.4 4/25/2012: Loading Emulator 5: Nintendo N64
05:06:19.4 4/25/2012: Loading Emulator 6: Nintendo SNES
05:06:19.5 4/25/2012: Loading Emulator 8: pc game
05:06:19.5 4/25/2012: Using Version 3 Themes Animations
05:06:19.5 4/25/2012: Retrieving resolution setting
05:06:19.5 4/25/2012: Using General Font: Trebuchet MS
05:06:19.5 4/25/2012: Using Title Font: Trebuchet MS
05:06:19.5 4/25/2012: GameEx will try to reduce CPU usage
05:06:19.5 4/25/2012: Initialising Direct3D
05:06:19.7 4/25/2012: Applying GameEx is Loading Image
05:06:19.7 4/25/2012: Setting Resolution to 1024x768 32 bit color
05:06:19.7 4/25/2012: Creating Surfaces
05:06:19.8 4/25/2012: Creating Primary Surface - Full Screen Mode
05:06:19.8 4/25/2012: Creating Back Buffer
05:06:19.8 4/25/2012: Loading graphic Surfaces
05:06:19.8 4/25/2012: Display is running at: 1024x768 32bit color, 60hz
05:06:19.8 4/25/2012: Adapter: RADEON 7000 SERIES
05:06:19.8 4/25/2012: Max texture size: 2048x2048
05:06:19.8 4/25/2012: Available texture memory: 79MB
05:06:19.8 4/25/2012: Initialising Bass Audio Library
05:06:19.9 4/25/2012: Creating Surfaces Misc and Dialogs
05:06:20.0 4/25/2012: Creating Surfaces Volume
05:06:20.0 4/25/2012: Creating Surfaces Arrows
05:06:20.0 4/25/2012: Creating Surfaces GameEXlogo Text
05:06:20.0 4/25/2012: Creating Surfaces Toolbar
05:06:20.0 4/25/2012: Creating Surfaces Toolbar Controls
05:06:20.0 4/25/2012: Creating Surfaces Backgrounds
05:06:20.0 4/25/2012: Creating Surfaces GameEx Logo
05:06:20.0 4/25/2012: Creating Surface Unselected
05:06:20.1 4/25/2012: Creating Surfaces Snaps
05:06:20.1 4/25/2012: Creating Surfaces Menu and List Bars
05:06:20.2 4/25/2012: Creating Fonts
05:06:20.2 4/25/2012: Creating Game Font
05:06:20.3 4/25/2012: Creating Game Font Faded
05:06:20.4 4/25/2012: Creating Title Font
05:06:20.5 4/25/2012: Restoring Title Font From Cache
05:06:20.6 4/25/2012: Creating Font Black
05:06:20.7 4/25/2012: Creating Font Black Small
05:06:20.8 4/25/2012: Fonts Created Succesfully
05:06:20.8 4/25/2012: 3MB Video Memory Used
05:06:21.2 4/25/2012: Playing Startup Video on thread
05:06:21.2 4/25/2012: Attempting to load game list
05:06:21.4 4/25/2012: MAME CMD options: -nowindow -joy -skip_gameinfo
05:06:21.4 4/25/2012: Creating DirectSound Device
05:06:21.4 4/25/2012: Trying: Primary Sound Driver
05:06:21.4 4/25/2012: Loading Sound Files
05:06:21.5 4/25/2012: DirectSound Device Created Successfully
05:06:21.5 4/25/2012: Initialising DirectInput for Gamepad support
05:06:21.5 4/25/2012: Unable to create a joystick device
05:06:21.5 4/25/2012: Initialising DirectInput for Keyboard support
05:06:21.5 4/25/2012: Loading Start Page
05:06:21.6 4/25/2012: Initializing MCE Remote
05:06:27.7 4/25/2012: Playing intro sound file
05:06:27.7 4/25/2012: Initialization OK! Starting GameEx!
05:06:27.7 4/25/2012: Testing Main Loop Once: Processing Frame
05:06:28.2 4/25/2012: Testing Main Loop Once: Main Loop ran successfully
05:06:48.0 4/25/2012: Not Restoring Emulator Database From Cache: 1000
05:06:55.6 4/25/2012: Running: cmd.exe /c C: C:\Daphne\DaphneLoader.exe dle20 vldp -fullscreen -x 640 -y 480 -nohwaccel daphne.exe lair vldp -framefile C:\Daphne\framefile\lair\lair.txt -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir C:\Daphne -bank 0 11111001 -bank 1 00100111 -noissues -noserversend -sound_buffer 2048 -x 640 -y 480
05:06:55.7 4/25/2012: Shutting down display
05:07:01.0 4/25/2012: Restoring Window
05:07:01.0 4/25/2012: Reinitializing Graphics System
05:07:02.1 4/25/2012: Returning to GameEx
05:07:04.2 4/25/2012: Exiting GameEx!
05:07:04.2 4/25/2012: Disposing all videos
05:07:04.2 4/25/2012: Deleting temporary Karaoke videos
05:07:04.2 4/25/2012: Disposing Image List
05:07:04.2 4/25/2012: Disposing Fonts
05:07:04.2 4/25/2012: Disposing Surfaces
05:07:04.2 4/25/2012: Saving Settings
05:07:04.2 4/25/2012: Shutting down Bass
05:07:04.2 4/25/2012: Closing HideOS.exe
05:07:05.2 4/25/2012: Disposing Plugins
05:07:05.2 4/25/2012: Closing database connection
05:07:05.2 4/25/2012: Checking for applications to Launch On Exit
05:07:05.2 4/25/2012: Bye
now when i go to emulated games and pick lasergames and pick lair, screen goes black and i hear a windows fatal error sound.i hit escape key and it goes back to the pick lair screen.i even let it sit for five mins to make sure it was not loading first..
this has me stumped been at it for two days pulling my hair out...you guys are the smart guys hope you can help...please...
Hello and welcome to the forums! The problem seems to be that the loader is being used instead of daphne. Change DaphneLoader.exe to Daphne.exe and then report back please! This setting is called Daphne EXE which is located in the Daphne section of Setup Wizard.
Frequency that did it...Thanks alot...funny thing is when i changed it through advanced config, to daphne.exe in there, it kept going back to daphneloader.exe after i loaded the game...So i though it was a default that i could not change.. Maybe it is a program Fault in gameex not sure...So does that mean all changes should be made through the wizard program?
Thanks Alot for this info..funny it all worked before gameex updated to the new one..12.56.every thing changed and i had to redo all my games emulators again..but i know to to do it fast as i have done it many times after power spikes in my town..it's a small town that has 128 degree weather during the summer and everybody uses there air..Lol..and yes i have a spike protector connected to my mame cab..
I was going to go bald by pulling my hair out.. So yes this is RESOLVED but i don't know how to make it say it on this forum..
I am glad you got it working and marked it resolved for you. Welcome to the Forums!
How were you making changes before? Also with updates, your config is backed up so in case something goes wrong, you're able to restore your settings so you can avoid starting over. Oh oh. Don't go bald cuz then you'll look like me. LOL.
edit: I just noticed you were using advanced config. Advanced config is no longer used or supported. So to make changes to your settings, Setup Wizard is the way to go.
To address fReqEnCy's advice, definitely get used to using the Setup Wizard. As he noted, Advanced Config is no longer supported and new fixes and features are being added to the wizard often thanks to tireless work by our own Headkaze.
Draco1962,
Thats for sure.using the wizard is way better
..did you read my last post as to which folder or file to save after i get all my daphne games in gameex? to save so i dont have to get all the comand lines from daphne again aarrrggg..
I use the Daphneloader.exe per the pdf instructions to setup all of my laserdisc games, substituting the paths for the appropriate ROM names for each game.You have to make sure you do the setup via the Daphne loader first for each game and initial game launch outside of GameEx to ensure that each game receives the proper updates and to obtain the options in the command line box referenced. You shouldn't have to worry about re-entering the command lines again if you have entered them properly and save the configurations by next-arrow to the path verification page in the Setup Wizard.
I am quoting your MAME question and setting up as a separate thread for answering the question since not really a part of the Daphne questions you had here.
