Hi,
So I am having an issue where when I am done planing a game and chose to go back to browse games by name GameEx crashes. I have been getting this error ever since I installed GameEx.
Thanks in advance!
Here is the log info:
13:38:21.5 4/15/2012: Opening Configuration File
13:38:21.6 4/15/2012: GameEx: Version 12.56: Starting Log
13:38:21.6 4/15/2012: Operating System Platform: Win32NT
13:38:21.6 4/15/2012: Operating System Name: Windows XP
13:38:21.6 4/15/2012: Operating System Version: 5.1.2600
13:38:21.6 4/15/2012: Intel® Core™2 Duo CPU E6550 @ 2.33GHz, 3567MB
13:38:21.6 4/15/2012: 2.33Ghz - 2 Cores or CPU's
13:38:21.6 4/15/2012: Running Randomize()
13:38:21.6 4/15/2012: Loading PlugIns
13:38:21.7 4/15/2012: Checking for applications to Launch On Startup
13:38:21.7 4/15/2012: Running Misc startup tasks
13:38:21.7 4/15/2012: Setting Menu types
13:38:21.7 4/15/2012: Getting Configuration Values
13:38:21.7 4/15/2012: Using Theme: Default - Hybrid Blue 2011
13:38:21.7 4/15/2012: Checking for alternate Image Directory for Theme: Default - Hybrid Blue 2011
13:38:21.7 4/15/2012: Launching HideOS.exe
13:38:21.7 4/15/2012: Initialising Video/MNG DLL's
13:38:21.7 4/15/2012: GameEx will check for media insertion (may affect performance)
13:38:21.7 4/15/2012: Hiding Taskbar
13:38:21.7 4/15/2012: Is Media Center running?
13:38:21.7 4/15/2012: Checking/Creating LCD Registry values
13:38:21.7 4/15/2012: Check Media Center Exit/Start Mode
13:38:21.7 4/15/2012: Media Center Mode 2
13:38:21.7 4/15/2012: Video previews on. Warning: Only recommended on modern systems
13:38:21.7 4/15/2012: Custom Game Device Input enabled: Getting custom codes
13:38:21.7 4/15/2012: Snap Delay set to: 2
13:38:21.7 4/15/2012: Get other settings
13:38:21.7 4/15/2012: Desktop set to Hide ICONS and set Background to Black
13:38:21.7 4/15/2012: Set: Find emulator artwork on best match basis
13:38:21.7 4/15/2012: Using DirectInput for keyboard input
13:38:21.7 4/15/2012: Start work for Form
13:38:21.7 4/15/2012: Getting Original Screen Size
13:38:21.8 4/15/2012: Opening Database Connection
13:38:22.9 4/15/2012: Initializing Component
13:38:23.1 4/15/2012: MAME Path is: C:\MAME
13:38:23.1 4/15/2012: MAME EXE file is: mame.exe
13:38:23.1 4/15/2012: ROM Path is: C:\MAME\roms
13:38:23.1 4/15/2012: Catver.ini is located at: C:\GameEx\DATA\catver.ini
13:38:23.1 4/15/2012: controls.ini is located at: C:\GameEx\DATA\controls.ini
13:38:23.1 4/15/2012: History.dat is located at: C:\GameEx\DATA\history.dat
13:38:23.1 4/15/2012: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
13:38:23.1 4/15/2012: command.dat is located at: C:\GameEx\DATA\command.dat
13:38:23.1 4/15/2012: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
13:38:23.1 4/15/2012: Loading Controls.ini map file
13:38:23.1 4/15/2012: Snap Path is: C:\MAME\snap
13:38:23.1 4/15/2012: Background Snap Path is: C:\MAME\snap
13:38:23.1 4/15/2012: AVI Snap Path is: C:\MAME\Mame Intro Vids
13:38:23.1 4/15/2012: Flyer Path is: C:\MAME\flyers
13:38:23.1 4/15/2012: Cabinet Path is: C:\MAME\cabinets
13:38:23.1 4/15/2012: Cabinet 3D Path: Not Found
13:38:23.1 4/15/2012: Title Path is: C:\MAME\titles
13:38:23.1 4/15/2012: PCB Path: Not Found
13:38:23.1 4/15/2012: Artwork Preview Path: Not Found
13:38:23.1 4/15/2012: Panel Path is: C:\MAME\cpanel
13:38:23.1 4/15/2012: Manual Path: Not Found
13:38:23.1 4/15/2012: Icon Path is: C:\MAME\icons
13:38:23.1 4/15/2012: Marquee Path is: C:\MAME\marquees
13:38:23.1 4/15/2012: Applying Language/Text
13:38:23.1 4/15/2012: Text/Language: English
13:38:23.2 4/15/2012: Using Version 3 Themes Animations
13:38:23.2 4/15/2012: Retrieving resolution setting
13:38:23.2 4/15/2012: Using General Font: Microsoft Sans Serif
13:38:23.2 4/15/2012: Using Title Font: Microsoft Sans Serif
13:38:23.2 4/15/2012: GameEx will try to reduce CPU usage
13:38:23.2 4/15/2012: Initialising Direct3D
13:38:23.3 4/15/2012: Applying GameEx is Loading Image
13:38:23.4 4/15/2012: Setting Resolution to 1920x1080 32 bit color
13:38:23.5 4/15/2012: Creating Surfaces
13:38:23.7 4/15/2012: Creating Primary Surface - Full Screen Mode
13:38:23.7 4/15/2012: Creating Back Buffer
13:38:23.8 4/15/2012: Loading graphic Surfaces
13:38:23.8 4/15/2012: Display is running at: 1920x1080 32bit color, 60hz
13:38:23.8 4/15/2012: Adapter: Intel® Q35 Express Chipset Family
13:38:23.8 4/15/2012: Max texture size: 2048x2048
13:38:23.8 4/15/2012: Available texture memory: 337MB
13:38:23.8 4/15/2012: Initialising Bass Audio Library
13:38:23.9 4/15/2012: Creating Surfaces Misc and Dialogs
13:38:24.2 4/15/2012: Creating Surfaces Volume
13:38:24.2 4/15/2012: Creating Surfaces Arrows
13:38:24.2 4/15/2012: Creating Surfaces GameEXlogo Text
13:38:24.2 4/15/2012: Creating Surfaces Toolbar
13:38:25.2 4/15/2012: Creating Surfaces Toolbar Controls
13:38:25.4 4/15/2012: Creating Surfaces Backgrounds
13:38:25.4 4/15/2012: Creating Surfaces GameEx Logo
13:38:25.4 4/15/2012: Creating Surface Unselected
13:38:25.5 4/15/2012: Creating Surfaces Snaps
13:38:25.5 4/15/2012: Creating Surfaces Menu and List Bars
13:38:25.8 4/15/2012: Creating Fonts
13:38:25.8 4/15/2012: Creating Game Font
13:38:25.9 4/15/2012: Creating Game Font Faded
13:38:26.0 4/15/2012: Creating Title Font
13:38:26.6 4/15/2012: Creating Font Black
13:38:26.6 4/15/2012: Creating Font Black Small
13:38:26.7 4/15/2012: Fonts Created Succesfully
13:38:26.7 4/15/2012: 9MB Video Memory Used
13:38:27.4 4/15/2012: Attempting to load game list
13:38:28.0 4/15/2012: MAME CMD options: -nowindow -joy -skip_gameinfo
13:38:28.0 4/15/2012: Creating DirectSound Device
13:38:28.0 4/15/2012: Trying: Primary Sound Driver
13:38:28.0 4/15/2012: Loading Sound Files
13:38:28.2 4/15/2012: DirectSound Device Created Successfully
13:38:28.2 4/15/2012: Initialising DirectInput for Gamepad support
13:38:28.4 4/15/2012: Unable to create a joystick device
13:38:28.4 4/15/2012: Initialising DirectInput for Keyboard support
13:38:28.7 4/15/2012: Loading Start Page
13:38:28.7 4/15/2012: Initializing MCE Remote
13:38:28.7 4/15/2012: Playing intro sound file
13:38:28.7 4/15/2012: Initialization OK! Starting GameEx!
13:38:28.7 4/15/2012: Testing Main Loop Once: Processing Frame
13:38:29.7 4/15/2012: Testing Main Loop Once: Main Loop ran successfully
13:42:32.1 4/15/2012: Starting Attract Mode
13:42:32.1 4/15/2012: Reading MAME hall of fame
13:42:32.8 4/15/2012: Shutting down display
13:42:32.9 4/15/2012: Setting Up RawInput Hook
13:42:32.9 4/15/2012: Launching RawInputHook.exe
13:42:34.6 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe magicstk -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
13:44:36.5 4/15/2012: Setting Up RawInput Hook
13:44:36.6 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe pc_sjetm -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
13:46:38.0 4/15/2012: Setting Up RawInput Hook
13:46:38.0 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe strnskil -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
13:48:39.5 4/15/2012: Setting Up RawInput Hook
13:48:39.5 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe tshingen -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
13:50:41.1 4/15/2012: Setting Up RawInput Hook
13:50:41.1 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe tm3k -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
13:52:42.6 4/15/2012: Setting Up RawInput Hook
13:52:42.7 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe sjcd2kx3 -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
13:54:44.2 4/15/2012: Setting Up RawInput Hook
13:54:44.3 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe rastan -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
13:56:45.8 4/15/2012: Setting Up RawInput Hook
13:56:45.9 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe tjumpman -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
13:58:47.3 4/15/2012: Setting Up RawInput Hook
13:58:47.4 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe gtroppo -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
14:00:48.9 4/15/2012: Setting Up RawInput Hook
14:00:48.9 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe mosaic -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
14:02:50.4 4/15/2012: Setting Up RawInput Hook
14:02:50.5 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe splat -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
14:04:51.9 4/15/2012: Setting Up RawInput Hook
14:04:52.1 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe toobin -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
14:06:56.1 4/15/2012: Setting Up RawInput Hook
14:06:56.2 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe strongx -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
14:08:57.7 4/15/2012: Setting Up RawInput Hook
14:08:57.8 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe choko -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
14:10:59.3 4/15/2012: Setting Up RawInput Hook
14:10:59.4 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe wof -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
14:13:00.8 4/15/2012: Setting Up RawInput Hook
14:13:00.9 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe rchase -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
14:15:02.5 4/15/2012: Setting Up RawInput Hook
14:15:02.6 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe kof96 -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
14:17:04.1 4/15/2012: Setting Up RawInput Hook
14:17:04.2 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe dkingjr -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
14:19:05.7 4/15/2012: Setting Up RawInput Hook
14:19:05.7 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe madmotor -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
14:21:07.2 4/15/2012: Setting Up RawInput Hook
14:21:07.2 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe fantsy95 -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -volume -32 -bezel -artpath artworkgameex
14:22:05.1 4/15/2012: Key/Joy press detected: Exiting Attract mode, closing MAME
14:22:05.2 4/15/2012: Shutting down RawInput Hook
14:22:07.4 4/15/2012: Returning From Attract Mode
14:22:09.0 4/15/2012: Failed Opening Video: c:\mame\mame intro vids\005.avi
14:22:11.7 4/15/2012: Failed Opening Video: c:\mame\mame intro vids\nycaptor.avi
14:22:15.5 4/15/2012: Failed Opening Video: c:\mame\mame intro vids\fghtatck.avi
14:22:15.7 4/15/2012: Failed Opening Video: c:\mame\mame intro vids\faceoff.avi
14:22:15.9 4/15/2012: Failed Opening Video: c:\mame\mame intro vids\fncywld.avi
14:22:16.4 4/15/2012: Failed Opening Video: c:\mame\mame intro vids\fantasia.avi
14:22:21.0 4/15/2012: Failed Opening Video: c:\mame\mame intro vids\fantsy95.avi
14:22:26.8 4/15/2012: Setting Up RawInput Hook
14:22:26.8 4/15/2012: Launching RawInputHook.exe
14:22:27.9 4/15/2012: Running: cmd.exe /c C: C:\MAME\mame.exe fantsy95 -rompath C:\MAME\roms -nowindow -joy -skip_gameinfo -bezel -artpath artworkgameex
14:22:28.0 4/15/2012: Shutting down display
14:24:12.7 4/15/2012: Exiting game
14:24:13.1 4/15/2012: Shutting down RawInput Hook
14:24:13.1 4/15/2012: Writing MAME stats
14:24:13.1 4/15/2012: Restoring Bezel
14:24:13.1 4/15/2012: Plugin: Game Exit
14:24:13.1 4/15/2012: Plugin: Process Commands
14:24:13.2 4/15/2012: Restoring Window
14:24:13.2 4/15/2012: Reinitializing Graphics System
14:24:15.0 4/15/2012: Returning to GameEx
14:24:21.9 4/15/2012: 21 Consecutive Exceptions Occured
14:24:21.9 4/15/2012: Object reference not set to an instance of an object.
14:24:22.0 4/15/2012: at y.a(RectangleF A_0, Rectangle A_1, Byte A_2, Byte A_3, Byte A_4, Byte A_5, Single A_6)
14:24:22.0 4/15/2012: at y.a(RectangleF A_0, Rectangle A_1, Byte A_2)
14:24:22.0 4/15/2012: at y.a(RectangleF A_0, RectangleF A_1, Byte A_2)
14:24:22.0 4/15/2012: at ag.a(Int32 A_0, Int32 A_1, String A_2, Boolean A_3, Boolean A_4, Int32 A_5, Int32 A_6)
14:24:22.0 4/15/2012: at ag.a(Boolean A_0)
14:24:22.0 4/15/2012: at ag.w(Boolean A_0)
14:24:22.0 4/15/2012: at ag.ad()
14:24:22.0 4/15/2012: Trying reinitialising the display after sleeping for 4 seconds
14:24:22.0 4/15/2012: Exception count will be dropped to 15
14:24:28.8 4/15/2012: --**--
14:24:28.8 4/15/2012: 21 Consecutive Exceptions Occured: Exiting
14:24:28.8 4/15/2012: Closing database connection
14:24:28.8 4/15/2012: First Exception:
14:24:28.8 4/15/2012: Object reference not set to an instance of an object.
14:24:28.8 4/15/2012: at y.a(RectangleF A_0, Rectangle A_1, Byte A_2, Byte A_3, Byte A_4, Byte A_5, Single A_6)
14:24:28.8 4/15/2012: at y.a(RectangleF A_0, Rectangle A_1, Byte A_2)
14:24:28.8 4/15/2012: at y.a(RectangleF A_0, RectangleF A_1, Byte A_2)
14:24:28.8 4/15/2012: at ag.a(Int32 A_0, Int32 A_1, String A_2, Boolean A_3, Boolean A_4, Int32 A_5, Int32 A_6)
14:24:28.8 4/15/2012: at ag.a(Boolean A_0)
14:24:28.8 4/15/2012: at ag.w(Boolean A_0)
14:24:28.8 4/15/2012: at ag.ad()
14:24:28.8 4/15/2012: Last Exception:
With all of the video file failures I have to ask if you have installed any video codecs? You may want to consider the Shark007 Vista Codec Pack for Vista and XP.
