Hello, i have thist problem, in setup wizard custom input key , the mediaplaypause key is detect without problem, but is not save in customimput, just save a 0 value. Using a virtual scancode lookup utility i can get the scancode for this key = 179, i write by hand the custominput,ini file writing 179 value in key definition, but dont work in gamex the key is not detected.
Another weird thing is after exit config wizar all custominput config is lost, all media keys is 0. if star the config wizard again in custom input all config is gone.
I´m using driverless ir remote and media keys in traditional keyboard , both get the same problem.
please help
Where do you have Gameex installed? Is SetupWizard running as admin?
PS: The scancodes should be DirectInput codes (DIK) not virtual keys. Look at scancodes.txt in the config folder.
thnks for respond,
i dont know , i running XP and logged as admin.
looking in scancode.txt for my key, now using 162 code and not luck
bye
