Hi Folks!
Long time ago, I released a launcher to choose between GameEx or XBMC.
I needed this, because in my HTPC I use the two solutions together.
So, when my HTPC starts , the launcher gives the option to choose what to start.
My first program was very simple, you can't choose the paths of the applications.
So in this new version I fixed it ! :D
On the zip file you will find :
Mustarda_Launcher.exe
config.xml
The config.xml has to be on the same directory of the Mustarda_Launcher.exe
Open the xml in Notepad++ and set your application paths.
This time the software runs with the Full HD resolution (1920x1080) the old one runs on (1024x768)
Some screenshots :
post-4791-0-13114500-1334273845_thumb.pn
post-4791-0-83653500-1334273857_thumb.pn
And the files : Mustarda_Launcher.zip
Please let me know if you guys need a custom resolution or the source code.
And bug reports are welcome too !
Bye !
Thanks, vsilvalopes! Something I may look into using at some point. Would it be possible to make a modification to the program to allow for changing the background?
If he programs in .net I'm happy to contribute to this functionality. ;)
Either way it shouldn't be too tough. I can contribute code if you use a language I know.
Oh no !
I'm not a developer ! :D
I did this seeing video-tutorials in YouTube.
Then I just figured out how to change the pictures.
It's done in Visual Studio 2008, using Visual Basic as language.
I don't have any clue on how to change the background without re-compiling...
I will post the source as soon I arrive home!
Thanks vsilvalopes! I see there's a configuration form in here too (although it's in a different language). Lemmie see what I can do with it. :)
