Hi all, I have just bought myself an arcade machine. It was initially working and was told just unplug to turn off. My brother shut it down as you would a pc and now it doesnt work. please could somebody assist me, also i am not computer literate, so please if anybody knows if you could explain to me like you would an idiot :D
Below is the error message that comes up when i turn it on:-
error: C:\gameEx\themes\default - gamelauncher original V1\media\mamebak.bmp
at system.drawing.image.fromfile (string filename, boolean useEmbededcolourmanagement)
at system.drawing.image.fromfile (string filename)
at i.a(graphics& A_0, string A_1, Image A_2, Bitmap& A_3, surface& A_4)
at i.c(boolean A_0, Boolean A_1, boolean A_2)
at i.c(boolean A_0, Boolean A_1, boolean A_2, boolean A_3, Boolean A_4, Int32 A_5)
ati.a(boolean A_0, string A_1, boolean A_2)
at i..ctor()
closing database connection
disposing plugins
GameEx is exiting with errors
ERRORS DETECTED: EXITING
Many thanks
Dave
Sorry for the delay.
Changing the theme in the SetupWizard may help. Where did you buy the machine from?
If you need more help please post the "entire" error log.
No worries as i know you're very busy.
I bought the machine off ebay, he initially told me to just pull the plug to turn off the machine. If okay i will stick the entire blog on.
Many Thanks
post-9624-0-69578800-1334138412_thumb.jppost-9624-0-04907200-1334138427_thumb.jp
