Hi,
I'm having a problem with the scroller since (or just a few updates after?) the first time this feature was implemented in Gameex.
I'm using a text for the startpage and one for each emulator (or system). When I start Gameex the startpage-text scrolls the way it should. Then I select a system (VCS 2600 i.e.) and here too it scrolls without problems.
Now after that one of two things will happen:
#1 I go back to the startpage and the text scrolls normally but when I enter a different system than the VCS 2600 (i.e. C64) the text is that from the previous system (VCS 2600).
or
#2 I go back to the startpage and the text scrolls normally but when I enter a system the text that scrolls is the same from the startpage.
What can be the problem?
Sounds like a bug to me. I would suggest clearing temporary internet files to see if this resolves the issue temporarily. I am going to elevate this to Tom's attention as it should not retain the scroller feeds from the previous screens.
Hi,
the computer which has Gameex installed, isn't connected to internet, so clearing the temporary files doesn't resolve the problem.
As you said before, it could be a bug.
Thanks again for your help
Unfortunately not. Can you kindly supply your GameEx log?
Alright, here's my Log file.
Btw: I have discovered another strange behavior.
I use the "Exit Gameex" Plugin from the Plugin Manager for exiting Gameex and it works flawlessly until I start a "Mame" Game.
After closing "Mame", my configured Exit-Key doesn't work anymore. In the logfile there's a line:"06:34:49.7 25/04/2012: Shutting down RawInput Hook". Could that be the problem?
As far as I could see, it happens only with "Mame", not with the other emulators.
  Reveal hidden contents
06:33:20.3 25/04/2012: Opening Configuration File
06:33:20.3 25/04/2012: GameEx: Version 12.56: Starting Log
06:33:20.3 25/04/2012: Operating System Platform: Win32NT
06:33:20.3 25/04/2012: Operating System Name: Windows XP x64
06:33:20.3 25/04/2012: Operating System Version: 5.2.3790
06:33:20.3 25/04/2012: Intel® Core™2 Duo CPU E8500 @ 3.16GHz, 4095MB
06:33:20.3 25/04/2012: 3,66Ghz - 2 Cores or CPU's
06:33:20.3 25/04/2012: Running Randomize()
06:33:20.3 25/04/2012: Loading PlugIns
06:33:20.3 25/04/2012: Loaded Plugin:"Exit GameEx" Version 1.0 By Ben Baker
06:33:20.5 25/04/2012: PlugIn: "Exit GameEx" Initialized OK
06:33:20.5 25/04/2012: Using Plugin System Version: 1
06:33:20.5 25/04/2012: Loaded Plugin:"LCD/LED Plugin" Version 2.87 By Ben Baker
06:33:39.9 25/04/2012: PlugIn: "LCD/LED Plugin" Initialized OK
06:33:39.9 25/04/2012: Using Plugin System Version: 1,3
06:33:39.9 25/04/2012: Checking for applications to Launch On Startup
06:33:39.9 25/04/2012: Running Misc startup tasks
06:33:39.9 25/04/2012: Setting Menu types
06:33:39.9 25/04/2012: Getting Configuration Values
06:33:39.9 25/04/2012: Using Theme: Default - Default
06:33:39.9 25/04/2012: Checking for alternate Image Directory for Theme: Default - Default
06:33:39.9 25/04/2012: Launching HideOS.exe
06:33:39.9 25/04/2012: Initialising Video/MNG DLL's
06:33:39.9 25/04/2012: GameEx will check for media insertion (may affect performance)
06:33:39.9 25/04/2012: Hiding Taskbar
06:33:39.9 25/04/2012: Is Media Center running?
06:33:39.9 25/04/2012: Checking/Creating LCD Registry values
06:33:39.9 25/04/2012: Check Media Center Exit/Start Mode
06:33:39.9 25/04/2012: Media Center Mode 0
06:33:39.9 25/04/2012: Video previews on. Warning: Only recommended on modern systems
06:33:39.9 25/04/2012: Custom Keyboard Input enabled: Getting custom codes
06:33:40.0 25/04/2012: Advanced Custom Keyboard Input enabled: Getting custom codes
06:33:40.0 25/04/2012: Snap Delay set to: 7
06:33:40.0 25/04/2012: Get other settings
06:33:40.0 25/04/2012: Desktop set to Hide ICONS and set Background to Black
06:33:40.0 25/04/2012: SlikStik support enabled
06:33:40.0 25/04/2012: Using DirectInput for keyboard input
06:33:40.0 25/04/2012: Start work for Form
06:33:40.0 25/04/2012: Getting Original Screen Size
06:33:40.0 25/04/2012: Opening Database Connection
06:33:40.0 25/04/2012: Initializing Component
06:33:40.0 25/04/2012: MAME Path is: F:\mame32fx\Mameui64
06:33:40.0 25/04/2012: daphne Path is: H:\Daphne
06:33:40.0 25/04/2012: daphne EXE file is: Daphne.exe
06:33:40.0 25/04/2012: Use daphne on. Daphne.exe will launch games
06:33:40.0 25/04/2012: MAME EXE file is: MameUI64.exe
06:33:40.0 25/04/2012: ROM Path is: F:\mame32fx\roms
06:33:40.0 25/04/2012: Catver.ini is located at: F:\Frontends\GameEx\DATA\catver.ini
06:33:40.0 25/04/2012: History.dat is located at: F:\mame32fx\Mameui64\history.dat
06:33:40.0 25/04/2012: nplayers.ini Not Found
06:33:40.0 25/04/2012: command.dat is located at: F:\Frontends\GameEx\DATA\command.dat
06:33:40.0 25/04/2012: MAMEinfo.dat is located at: F:\mame32fx\Mameui64\mameinfo.dat
06:33:40.0 25/04/2012: Loading Controls.ini map file
06:33:40.0 25/04/2012: Snap Path is: F:\mame32fx\snap
06:33:40.0 25/04/2012: Background Snap Path: Not Found
06:33:40.0 25/04/2012: AVI Snap Path: Not Found
06:33:40.0 25/04/2012: Flyer Path is: F:\mame32fx\flyers
06:33:40.0 25/04/2012: Cabinet Path is: F:\mame32fx\cabinets
06:33:40.0 25/04/2012: Cabinet 3D Path is: F:\Frontends\GameEx\Mamecab3D
06:33:40.0 25/04/2012: Title Path is: F:\mame32fx itles
06:33:40.0 25/04/2012: PCB Path is: F:\mame32fx\PCB
06:33:40.0 25/04/2012: Artwork Preview Path is: F:\mame32fx\artwork
06:33:40.0 25/04/2012: Panel Path is: F:\mame32fx\cpanel
06:33:40.0 25/04/2012: Manual Path: Not Found
06:33:40.0 25/04/2012: Icon Path is: F:\mame32fx\icons
06:33:40.0 25/04/2012: Marquee Path is: F:\mame32fx\marquees
06:33:40.0 25/04/2012: Applying Language/Text
06:33:40.1 25/04/2012: Text/Language: Spanish
06:33:40.1 25/04/2012: Loading Custom Emulators
06:33:40.1 25/04/2012: Loading Emulator 1: Arcade - Playstation System
06:33:40.1 25/04/2012: Loading Emulator 2: Arcade - Model 2
06:33:40.1 25/04/2012: Loading Emulator 3: Arcade - Namco System 21,22 Super 22
06:33:40.1 25/04/2012: Loading Emulator 4: Arcade - Otros
06:33:40.1 25/04/2012: Loading Emulator 5: Arcade - Pinball
06:33:40.1 25/04/2012: Loading Emulator 6: Acorn BBC
06:33:40.1 25/04/2012: Loading Emulator 7: Amstrad CPC
06:33:40.1 25/04/2012: Loading Emulator 8: Amstrad GX-4000
06:33:40.1 25/04/2012: Loading Emulator 9: Apple II
06:33:40.1 25/04/2012: Loading Emulator 10: Apple IIGS
06:33:40.1 25/04/2012: Loading Emulator 12: Atari VCS 2600
06:33:40.1 25/04/2012: Loading Emulator 13: Atari 5200
06:33:40.1 25/04/2012: Loading Emulator 14: Atari 7800
06:33:40.1 25/04/2012: Loading Emulator 15: Atari Jaguar
06:33:40.1 25/04/2012: Loading Emulator 16: Atari Lynx
06:33:40.1 25/04/2012: Loading Emulator 17: Atari ST
06:33:40.1 25/04/2012: Loading Emulator 18: Bally professional Arcade
06:33:40.1 25/04/2012: Loading Emulator 19: Bandai WonderSwan
06:33:40.1 25/04/2012: Loading Emulator 20: Bandai WonderSwan Color
06:33:40.1 25/04/2012: Loading Emulator 21: Colecovision
06:33:40.1 25/04/2012: Loading Emulator 22: Colour Computer 2/TRS-80/Dragon 32
06:33:40.1 25/04/2012: Loading Emulator 23: Colour Computer 3
06:33:40.1 25/04/2012: Loading Emulator 24: Colour Genie EG2000
06:33:40.1 25/04/2012: Loading Emulator 25: Commodore VIC20
06:33:40.1 25/04/2012: Loading Emulator 26: Commodore C16
06:33:40.1 25/04/2012: Loading Emulator 27: Commodore C64
06:33:40.1 25/04/2012: Loading Emulator 28: Commodore C64GS
06:33:40.1 25/04/2012: Loading Emulator 29: Commodore 128
06:33:40.1 25/04/2012: Loading Emulator 30: Commodore Amiga
06:33:40.1 25/04/2012: Loading Emulator 31: Commodore Amiga CD32
06:33:40.1 25/04/2012: Loading Emulator 32: CPS Changer (Street Fighter ZERO)
06:33:40.1 25/04/2012: Loading Emulator 33: DEC PDP-1
06:33:40.1 25/04/2012: Loading Emulator 34: Emerson Arcadia 2001
06:33:40.1 25/04/2012: Loading Emulator 35: Entex Adventurevision
06:33:40.1 25/04/2012: Loading Emulator 36: Fairchild Channel F
06:33:40.1 25/04/2012: Loading Emulator 37: Fujitsu FM-Towns/Marty
06:33:40.1 25/04/2012: Loading Emulator 38: Fujitsu Micro Seven
06:33:40.1 25/04/2012: Loading Emulator 39: FunVision/CreatiVision
06:33:40.1 25/04/2012: Loading Emulator 40: Hartung Game Master
06:33:40.1 25/04/2012: Loading Emulator 41: GCE Vectrex
06:33:40.1 25/04/2012: Loading Emulator 42: Interton VC 4000
06:33:40.1 25/04/2012: Loading Emulator 43: Magnavox Odyssey 2
06:33:40.1 25/04/2012: Loading Emulator 44: Mattel Aquarius
06:33:40.1 25/04/2012: Loading Emulator 45: Mattel Intellivision
06:33:40.1 25/04/2012: Loading Emulator 46: MegaDuck/CougarBoy
06:33:40.1 25/04/2012: Loading Emulator 48: MGT Sam Coupe
06:33:40.1 25/04/2012: Loading Emulator 49: MSX
06:33:40.1 25/04/2012: Loading Emulator 50: MSX 2+
06:33:40.2 25/04/2012: Loading Emulator 51: NEC PC-Engine/TurboGrafx 16
06:33:40.2 25/04/2012: Loading Emulator 52: NEC PC-Engine CD-Rom2 System/Turbo Duo
06:33:40.2 25/04/2012: Loading Emulator 53: NEC PC-Engine-FX
06:33:40.2 25/04/2012: Loading Emulator 54: Neo-Geo Console
06:33:40.2 25/04/2012: Loading Emulator 55: Neo-Geo CD
06:33:40.2 25/04/2012: Loading Emulator 56: Neo-Geo Pocket
06:33:40.2 25/04/2012: Loading Emulator 57: Nintendo Game Boy
06:33:40.2 25/04/2012: Loading Emulator 58: Nintendo Game Boy Color
06:33:40.2 25/04/2012: Loading Emulator 59: Nintendo Game Boy Advance
06:33:40.2 25/04/2012: Loading Emulator 60: Nintendo DS
06:33:40.2 25/04/2012: Loading Emulator 61: Nintendo Virtualboy
06:33:40.2 25/04/2012: Loading Emulator 62: Nintendo Entertainment System/Famicom
06:33:40.2 25/04/2012: Loading Emulator 63: Nintendo Famicom Disk System
06:33:40.2 25/04/2012: Loading Emulator 64: Nintendo Super NES/Super Famicom
06:33:40.2 25/04/2012: Loading Emulator 65: Nintendo Super Famicom - BS Satellaview
06:33:40.2 25/04/2012: Loading Emulator 66: Nintendo 64
06:33:40.2 25/04/2012: Loading Emulator 67: Nintendo GameCube
06:33:40.2 25/04/2012: Loading Emulator 68: Nintendo Wii
06:33:40.2 25/04/2012: Loading Emulator 69: Odyssey 2
06:33:40.2 25/04/2012: Loading Emulator 70: Panasonic 3DO
06:33:40.2 25/04/2012: Loading Emulator 71: PC - Juegos antiguos - hasta 1999
06:33:40.2 25/04/2012: Loading Emulator 72: PC - Juegos antiguos - hasta 1999
06:33:40.2 25/04/2012: Loading Emulator 73: PC - Juegos antiguos - hasta 1999
06:33:40.2 25/04/2012: Loading Emulator 74: PC - Juegos modernos - desde 2000
06:33:40.2 25/04/2012: Loading Emulator 75: Phillips CD-I
06:33:40.2 25/04/2012: Loading Emulator 76: RCA Studio II
06:33:40.2 25/04/2012: Loading Emulator 77: Sega SG-1000
06:33:40.2 25/04/2012: Loading Emulator 78: Sega Master System/Mark III
06:33:40.2 25/04/2012: Loading Emulator 79: Sega Genesis/Mega Drive
06:33:40.2 25/04/2012: Loading Emulator 80: Sega Genesis/Mega Drive - 32X
06:33:40.2 25/04/2012: Loading Emulator 81: Sega CD/Mega CD
06:33:40.2 25/04/2012: Loading Emulator 82: Sega Saturn
06:33:40.2 25/04/2012: Loading Emulator 83: Sega Dreamcast
06:33:40.2 25/04/2012: Loading Emulator 84: Sega Game Gear
06:33:40.2 25/04/2012: Loading Emulator 85: Sharp X68000
06:33:40.2 25/04/2012: Loading Emulator 86: Sinclair ZX Spectrum
06:33:40.2 25/04/2012: Loading Emulator 87: Sony Playstation
06:33:40.2 25/04/2012: Loading Emulator 88: Sony Playstation 2
06:33:40.2 25/04/2012: Loading Emulator 89: Spectravideo SV-318
06:33:40.2 25/04/2012: Loading Emulator 90: Texas Instruments TI-99/4 Home Computer
06:33:40.2 25/04/2012: Loading Emulator 91: Thomson MO5
06:33:40.2 25/04/2012: Loading Emulator 92: Watara Supervision
06:33:40.2 25/04/2012: Loading Emulator 93: LCD Handheld Games
06:33:40.2 25/04/2012: Loading Emulator 95: Neo-Geo Pocket Color
06:33:40.2 25/04/2012: Loading Emulator 96: Epoch Super Cassette Vision
06:33:40.2 25/04/2012: Loading Emulator 97: Worlds of Wonders - Action Max
06:33:40.2 25/04/2012: Loading Emulator 98: Casio PV-1000
06:33:40.2 25/04/2012: Loading Emulator 99: APF M-1000
06:33:40.2 25/04/2012: Loading Emulator 100: Nintendo Wii
06:33:40.2 25/04/2012: Loading Emulator Group 1: PC - Juegos antiguos - hasta 1999
06:33:40.2 25/04/2012: Loading Emulator Group 2: Arcade - Juegos de Recreativa 2
06:33:40.2 25/04/2012: Loading Emulator Group 3: Sony Playstation 2
06:33:40.2 25/04/2012: Loading Emulator Group 4: Nintendo Wii
06:33:40.2 25/04/2012: Using 3D Alpha Blended Animations.
06:33:40.2 25/04/2012: Retrieving resolution setting
06:33:40.2 25/04/2012: Using General Font: HandelGoth
06:33:40.2 25/04/2012: Using Title Font: D3 Egoistism
06:33:40.3 25/04/2012: Initialising Direct3D
06:33:40.3 25/04/2012: Mouse Input is disabled
06:33:40.3 25/04/2012: Applying GameEx is Loading Image
06:33:40.4 25/04/2012: Setting Resolution to 1024x768 32 bit color
06:33:40.4 25/04/2012: Creating Surfaces
06:33:40.4 25/04/2012: Creating Primary Surface - Full Screen Mode
06:33:40.4 25/04/2012: Creating Back Buffer
06:33:40.5 25/04/2012: Version 2 Theme being used. Loading.
06:33:40.5 25/04/2012: Loading Button Data
06:33:40.5 25/04/2012: Loading Font Data
06:33:40.5 25/04/2012: Loading Layout Data
06:33:40.5 25/04/2012: Loading Taskbar Data
06:33:40.5 25/04/2012: Loading graphic Surfaces
06:33:40.5 25/04/2012: Display is running at: 1024x768 32bit color, 75hz
06:33:40.5 25/04/2012: Adapter: NVIDIA GeForce 8800 GT
06:33:40.5 25/04/2012: Max texture size: 8192x8192
06:33:40.5 25/04/2012: Available texture memory: 976MB
06:33:40.5 25/04/2012: Initialising Bass Audio Library
06:33:40.5 25/04/2012: Creating Surfaces Misc and Dialogs
06:33:40.5 25/04/2012: Creating Surfaces Volume
06:33:40.5 25/04/2012: Creating Surfaces Arrows
06:33:40.5 25/04/2012: Creating Surfaces GameEXlogo Text
06:33:40.5 25/04/2012: Creating Surfaces Toolbar
06:33:40.6 25/04/2012: Creating Surfaces Toolbar Controls
06:33:40.6 25/04/2012: Creating Surfaces Backgrounds
06:33:40.6 25/04/2012: Creating Surfaces GameEx Logo
06:33:40.6 25/04/2012: Creating Surface Unselected
06:33:40.7 25/04/2012: Creating Surfaces Snaps
06:33:40.7 25/04/2012: Creating Surfaces Menu and List Bars
06:33:40.8 25/04/2012: Creating Fonts
06:33:40.8 25/04/2012: Creating Game Font
06:33:41.0 25/04/2012: Creating Game Font Faded
06:33:41.3 25/04/2012: Creating Title Font
06:33:41.3 25/04/2012: Restoring Title Font From Cache
06:33:41.4 25/04/2012: Creating Font Black
06:33:41.4 25/04/2012: Creating Font Black Small
06:33:41.5 25/04/2012: Fonts Created Succesfully
06:33:41.5 25/04/2012: 3MB Video Memory Used
06:33:41.7 25/04/2012: Attempting to load game list
06:33:41.7 25/04/2012: MAME CMD options:
06:33:41.7 25/04/2012: Loading Music Play List
06:33:41.7 25/04/2012: Loading Playlist Directory
06:33:41.8 25/04/2012: Loading music
06:33:41.8 25/04/2012: Initialising Windows Media Player Component
06:33:41.9 25/04/2012: Initialising Windows Media Player Component
06:33:41.9 25/04/2012: Creating DirectSound Device
06:33:41.9 25/04/2012: Trying: Primary Sound Driver
06:33:41.9 25/04/2012: Loading Sound Files
06:33:41.9 25/04/2012: DirectSound Device Created Successfully
06:33:41.9 25/04/2012: Initialising DirectInput for Gamepad support
06:33:42.0 25/04/2012: Using Device Logitech RumblePad 2 USB
06:33:42.1 25/04/2012: Initialising DirectInput for Keyboard support
06:33:42.2 25/04/2012: Loading Start Page
06:33:42.3 25/04/2012: Initializing MCE Remote
06:33:42.3 25/04/2012: Playing intro sound file
06:33:42.3 25/04/2012: Initialization OK! Starting GameEx!
06:33:42.3 25/04/2012: Testing Main Loop Once: Processing Frame
06:33:42.5 25/04/2012: Testing Main Loop Once: Main Loop ran successfully
06:33:50.6 25/04/2012: Validating: Emulator_1: Custom Background: mamebak.png
06:33:50.6 25/04/2012: Validating: Emulator_1: Snap Path: F:\zinc\Snap
06:33:50.6 25/04/2012: Validating: Emulator_1: Custom Art Path 1: C:\Documents and Settings speirs\Desktop\Nintendo 64 - Cart Scans (No-Intro 20080521)(U)(EmuMovies)\Nintendo 64 - Cart Scans (No-Intro 20080521)(U)(EmuMovies)
06:33:50.6 25/04/2012: Warning: Emulator_1: Custom Art Path 1 Does not exist
06:33:50.6 25/04/2012: Validating: Emulator_1: Custom Art Path 2: C:\eBooks
06:33:50.6 25/04/2012: Warning: Emulator_1: Custom Art Path 2 Does not exist
06:33:50.6 25/04/2012: Validating: Emulator_2: Custom Background: mamebak.png
06:33:50.6 25/04/2012: Validating: Emulator_2: Snap Path: F:\nebula\Snap
06:33:50.6 25/04/2012: Validating: Emulator_3: Custom Background: mamebak.png
06:33:50.6 25/04/2012: Validating: Emulator_3: Snap Path: G:\mjolnir\snap
06:33:50.6 25/04/2012: Warning: Emulator_3: MAPFile Does Not Exist
06:33:50.6 25/04/2012: Validating: Emulator_4: Custom Background: mamebak.png
06:33:50.6 25/04/2012: Validating: Emulator_4: Snap Path: G:\Arcademisc\Screenshots
06:33:50.6 25/04/2012: Warning: Emulator_4: Snap Path Does not exist
06:33:50.6 25/04/2012: Validating: Emulator_5: Custom Background: pinball.png
06:33:50.6 25/04/2012: Validating: Emulator_5: Snap Path: F:\Visualpinball\Screenshots
06:33:50.6 25/04/2012: Warning: Emulator_5: Snap Path Does not exist
06:33:50.6 25/04/2012: Validating: Emulator_5: Control Panel Path: E:\stella\snaps
06:33:50.6 25/04/2012: Warning: Emulator_5: Control Panel Path Does not exist
06:33:50.6 25/04/2012: Validating: Emulator_5: Instructions Path: E:\stella\snaps
06:33:50.6 25/04/2012: Warning: Emulator_5: Instructions Path Does not exist
06:33:50.6 25/04/2012: Validating: Emulator_7: Custom Background: cpc.png
06:33:50.6 25/04/2012: Validating: Emulator_7: Snap Path: G:\Amstrad CPC\Caprice32\disk\Snap
06:33:50.6 25/04/2012: Validating: Emulator_8: Snap Path: G:\Amstrad GX 4000\Box Scans
06:33:50.6 25/04/2012: Validating: Emulator_9: Snap Path: G:\Apple ll\Snaps
06:33:50.6 25/04/2012: Validating: Emulator_10: Snap Path: G:\Apple2gs\Snaps
06:33:50.6 25/04/2012: Validating: Emulator_12: Custom Background: atari2600.png
06:33:50.6 25/04/2012: Validating: Emulator_12: Snap Path: G:\Atari\Snap
06:33:50.6 25/04/2012: Validating: Emulator_13: Custom Background: atari 5200.png
06:33:50.6 25/04/2012: Validating: Emulator_13: Snap Path: G:\Atari 5200\Snap
06:33:50.6 25/04/2012: Validating: Emulator_14: Custom Background: 7800.png
06:33:50.6 25/04/2012: Validating: Emulator_14: Snap Path: G:\Atari 7800\EMU7800\Snap
06:33:50.6 25/04/2012: Validating: Emulator_15: Custom Background: jaguar.png
06:33:50.6 25/04/2012: Validating: Emulator_15: Snap Path: F:\JaguarPtempest\Roms\Snap
06:33:50.6 25/04/2012: Validating: Emulator_16: Custom Background: lynx.png
06:33:50.6 25/04/2012: Validating: Emulator_16: Snap Path: G:\Atary Lynx\Roms\Snap
06:33:50.6 25/04/2012: Validating: Emulator_16: Control Panel Path: c:\emulators\Atari 2600\Controls
06:33:50.6 25/04/2012: Warning: Emulator_16: Control Panel Path Does not exist
06:33:50.6 25/04/2012: Validating: Emulator_17: Snap Path: G:\Atari ST\roms\Snap
06:33:50.6 25/04/2012: Validating: Emulator_18: Custom Background: astrocade.png
06:33:50.6 25/04/2012: Validating: Emulator_18: Snap Path: F:\Mess\software\astrocde\Snap
06:33:50.6 25/04/2012: Validating: Emulator_19: Custom Background: wonderswan.png
06:33:50.6 25/04/2012: Validating: Emulator_19: Snap Path: G:\Wonderswan\Roms\Snap
06:33:50.6 25/04/2012: Warning: Emulator_19: Snap Path Does not exist
06:33:50.6 25/04/2012: Validating: Emulator_20: Custom Background: wswanc.png
06:33:50.6 25/04/2012: Validating: Emulator_20: Snap Path: G:\Wonderswan\Roms\Snap
06:33:50.6 25/04/2012: Warning: Emulator_20: Snap Path Does not exist
06:33:50.6 25/04/2012: Validating: Emulator_21: Custom Background: colecovision.png
06:33:50.6 25/04/2012: Validating: Emulator_21: Snap Path: G:\Colecovision\Snap
06:33:50.6 25/04/2012: Validating: Emulator_22: Snap Path: G:\Coco2\Roms\Snap
06:33:50.6 25/04/2012: Warning: Emulator_22: Snap Path Does not exist
06:33:50.6 25/04/2012: Validating: Emulator_23: Snap Path: G:\Coco 3\Snap
06:33:50.6 25/04/2012: Validating: Emulator_24: Snap Path: G:\Colour genie\Snap
06:33:50.6 25/04/2012: Validating: Emulator_25: Snap Path: G:\C64\VIC20\roms\Snap
06:33:50.6 25/04/2012: Validating: Emulator_26: Snap Path: G:\C16\Snaps
06:33:50.6 25/04/2012: Validating: Emulator_27: Custom Background: c64.png
06:33:50.6 25/04/2012: Validating: Emulator_27: Snap Path: G:\C64\Romsc64\Snap
06:33:50.6 25/04/2012: Validating: Emulator_28: Snap Path: G:\C64\Romsc64\Cartridges\Snap
06:33:50.6 25/04/2012: Validating: Emulator_29: Snap Path: G:\C64\Romsc128\Snap
06:33:50.6 25/04/2012: Validating: Emulator_30: Custom Background: amiga.png
06:33:50.6 25/04/2012: Validating: Emulator_30: Snap Path: F:\Amiga\Box
06:33:50.6 25/04/2012: Validating: Emulator_31: Custom Background: cd32.png
06:33:50.6 25/04/2012: Validating: Emulator_31: Snap Path: H:\CD32\Roms\Snaps
06:33:50.6 25/04/2012: Validating: Emulator_32: Snap Path: F:\Frontends\GameEx\Other Systems\CPSChanger\Snap
06:33:50.6 25/04/2012: Validating: Emulator_33: Custom Background: pdp1.png
06:33:50.6 25/04/2012: Validating: Emulator_33: Snap Path: F:\Mess\software\pdp1
06:33:50.6 25/04/2012: Validating: Emulator_34: Snap Path: F:\Mess\software\arcadia\Snap
06:33:50.6 25/04/2012: Validating: Emulator_35: Snap Path: F:\Mess\software\advision\Snap
06:33:50.6 25/04/2012: Validating: Emulator_36: Snap Path: F:\Mess\software\channelf\Snap
06:33:50.6 25/04/2012: Validating: Emulator_37: Custom Background: fmtowns.png
06:33:50.6 25/04/2012: Validating: Emulator_37: Snap Path: F:\Fujitsu FM Towns\roms\Snaps
06:33:50.6 25/04/2012: Validating: Emulator_38: Snap Path: H:\Fujitsu Micro seven\Snap
06:33:50.6 25/04/2012: Validating: Emulator_39: Snap Path: G:\Creativision\Snap
06:33:50.6 25/04/2012: Warning: Emulator_39: Snap Path Does not exist
06:33:50.6 25/04/2012: Validating: Emulator_40: Snap Path: G:\gm2001\Snap
06:33:50.6 25/04/2012: Validating: Emulator_41: Snap Path: F:\Mess\software\Vectrex\Snap
06:33:50.6 25/04/2012: Validating: Emulator_42: Snap Path: G:\Interton vc4000\Box
06:33:50.6 25/04/2012: Validating: Emulator_43: Custom Background: odyssey2.avi
06:33:50.6 25/04/2012: Warning: Emulator_43: Custom Background Does not exist
06:33:50.6 25/04/2012: Validating: Emulator_43: Snap Path: G:\Odissey 2\Box
06:33:50.6 25/04/2012: Validating: Emulator_44: Snap Path: G:\Aquarius\Gameexroms\Snaps
06:33:50.6 25/04/2012: Validating: Emulator_45: Snap Path: G:\Intellivision\Nostalgia\Snap
06:33:50.6 25/04/2012: Validating: Emulator_46: Snap Path: F:\Mess\software\Megaduck\Snap
06:33:50.6 25/04/2012: Validating: Emulator_48: Snap Path: G:\Sam Coupe\SimCoupe\Snap
06:33:50.6 25/04/2012: Validating: Emulator_49: Snap Path: G:\MSX\Carts\Snap
06:33:50.6 25/04/2012: Validating: Emulator_50: Snap Path: G:\MSX2\Snap
06:33:50.6 25/04/2012: Validating: Emulator_51: Custom Background: pcengine.png
06:33:50.6 25/04/2012: Validating: Emulator_51: Snap Path: H:\Pcengine\Me\Box
06:33:50.6 25/04/2012: Validating: Emulator_51: Box Art Path: H:\Pcengine\Me\Snap
06:33:50.6 25/04/2012: Validating: Emulator_52: Custom Background: pccd.png
06:33:50.6 25/04/2012: Validating: Emulator_52: Snap Path: H:\Pcengine\CDs\Snaps
06:33:50.6 25/04/2012: Validating: Emulator_53: Custom Background: pcfx.png
06:33:50.6 25/04/2012: Validating: Emulator_53: Snap Path: H:\Pc Engine FX\Snap
06:33:50.6 25/04/2012: Validating: Emulator_54: Custom Background: neogeo.png
06:33:50.6 25/04/2012: Validating: Emulator_54: Snap Path: F:\Neo Geo\Boxes
06:33:50.6 25/04/2012: Validating: Emulator_55: Snap Path: F:\NeogeoCD\Roms\Box
06:33:50.6 25/04/2012: Validating: Emulator_56: Snap Path: G:\Neo Geo Pocket\MonoRoms\Snap
06:33:50.6 25/04/2012: Validating: Emulator_57: Custom Background: gameboy.png
06:33:50.6 25/04/2012: Validating: Emulator_57: Snap Path: H:\Game Boy\BoxGB
06:33:50.6 25/04/2012: Validating: Emulator_57: Cart Art Path: H:\Game Boy\SnapGB
06:33:50.6 25/04/2012: Validating: Emulator_58: Snap Path: H:\Game Boy\SnapGBC
06:33:50.6 25/04/2012: Validating: Emulator_59: Snap Path: H:\Game Boy\SnapGBA
06:33:50.6 25/04/2012: Validating: Emulator_60: Custom Background: nintendods.png
06:33:50.6 25/04/2012: Validating: Emulator_60: Snap Path: F:\Nintendo DS\Snap
06:33:50.6 25/04/2012: Validating: Emulator_61: Custom Background: virtualboy.png
06:33:50.6 25/04/2012: Validating: Emulator_61: Snap Path: G:\Virtualboy\Snap
06:33:50.6 25/04/2012: Validating: Emulator_62: Custom Background: nes.png
06:33:50.6 25/04/2012: Validating: Emulator_62: Snap Path: F:\Nes\Box
06:33:50.6 25/04/2012: Validating: Emulator_62: Box Art Path: F:\Nes\Snap
06:33:50.6 25/04/2012: Validating: Emulator_62: Cart Art Path: F:\Nes\Cart
06:33:50.6 25/04/2012: Validating: Emulator_63: Snap Path: F:\Nes\Roms\Famicon disk system\Snap
06:33:50.6 25/04/2012: Validating: Emulator_64: Custom Background: snes.png
06:33:50.6 25/04/2012: Validating: Emulator_64: Snap Path: F:\Snes\Roms\Snaps
06:33:50.6 25/04/2012: Validating: Emulator_65: Custom Background: satellaview.avi
06:33:50.6 25/04/2012: Warning: Emulator_65: Custom Background Does not exist
06:33:50.6 25/04/2012: Validating: Emulator_65: Snap Path: F:\Snes\Roms BSX\Snaps
06:33:50.6 25/04/2012: Validating: Emulator_66: Custom Background: n64.png
06:33:50.6 25/04/2012: Validating: Emulator_66: Snap Path: F:\Nintendo64\Box
06:33:50.6 25/04/2012: Validating: Emulator_67: Custom Background: gamecube.png
06:33:50.6 25/04/2012: Validating: Emulator_67: Snap Path: F:\Gamecube\Snap GC
06:33:50.6 25/04/2012: Validating: Emulator_68: Custom Background: wii.png
06:33:50.6 25/04/2012: Validating: Emulator_68: Snap Path: F:\Gamecube\Snap Wii
06:33:50.6 25/04/2012: Validating: Emulator_69: Snap Path: G:\Odissey 2\Snap
06:33:50.6 25/04/2012: Validating: Emulator_70: Snap Path: F:\3DO\Isos\Snaps
06:33:50.6 25/04/2012: Validating: Emulator_71: Custom Background: pcold.png
06:33:50.6 25/04/2012: Validating: Emulator_71: Snap Path: G:\PcGamesold\Box
06:33:50.6 25/04/2012: Validating: Emulator_72: Custom Background: pcold.png
06:33:50.6 25/04/2012: Validating: Emulator_72: Snap Path: G:\PcGamesold\Box
06:33:50.6 25/04/2012: Validating: Emulator_73: Custom Background: pcold.png
06:33:50.6 25/04/2012: Validating: Emulator_73: Snap Path: G:\PcGamesold\Box
06:33:50.6 25/04/2012: Validating: Emulator_74: Custom Background: pcnew.png
06:33:50.6 25/04/2012: Validating: Emulator_74: Snap Path: G:\PC Games\Box
06:33:50.6 25/04/2012: Validating: Emulator_75: Snap Path: F:\CDI\Snap
06:33:50.6 25/04/2012: Validating: Emulator_76: Snap Path: G:\StudioII\Snap
06:33:50.6 25/04/2012: Validating: Emulator_77: Custom Background: sega.png
06:33:50.6 25/04/2012: Validating: Emulator_77: Snap Path: G:\Sega SG-1000\Boxes
06:33:50.6 25/04/2012: Validating: Emulator_78: Custom Background: master.png
06:33:50.6 25/04/2012: Validating: Emulator_78: Snap Path: F:\Master System\Box
06:33:50.6 25/04/2012: Validating: Emulator_79: Custom Background: genesis.png
06:33:50.6 25/04/2012: Validating: Emulator_79: Snap Path: F:\Mega Drive\Roms\Box
06:33:50.6 25/04/2012: Validating: Emulator_80: Custom Background: 32x.png
06:33:50.6 25/04/2012: Validating: Emulator_80: Snap Path: F:\Mega Drive\Roms\32x\Box
06:33:50.6 25/04/2012: Validating: Emulator_81: Custom Background: sega.png
06:33:50.6 25/04/2012: Validating: Emulator_81: Snap Path: F:\Mega Drive\Roms\Sega cd\Box
06:33:50.6 25/04/2012: Validating: Emulator_81: Box Art Path: F:\Mega Drive\Roms\Sega cd\Snap
06:33:50.6 25/04/2012: Validating: Emulator_81: Manual Path: K:\Misc Stuff\Computer Console & Arcade Stuff\Misc Videogame Stuff\Game Manuals\Mega CD Manuals
06:33:50.6 25/04/2012: Warning: Emulator_81: Manual Path Does not exist
06:33:50.6 25/04/2012: Validating: Emulator_82: Custom Background: saturn.png
06:33:50.6 25/04/2012: Validating: Emulator_82: Snap Path: H:\Sega Saturn\Snap
06:33:50.6 25/04/2012: Validating: Emulator_83: Custom Background: dreamcast.png
06:33:50.6 25/04/2012: Validating: Emulator_83: Snap Path: H:\Dreamcast\Snap
06:33:50.6 25/04/2012: Validating: Emulator_84: Custom Background: sega.png
06:33:50.6 25/04/2012: Validating: Emulator_84: Snap Path: F:\Mess\software\Gamegear\Snap
06:33:50.6 25/04/2012: Validating: Emulator_85: Snap Path: G:\Sharp X68000\XM6\Frontend Launcher\Snaps
06:33:50.6 25/04/2012: Validating: Emulator_87: Custom Background: psx.png
06:33:50.6 25/04/2012: Validating: Emulator_87: Snap Path: H:\epsxe\Isos\Snap
06:33:50.6 25/04/2012: Validating: Emulator_88: Custom Background: ps2.png
06:33:50.6 25/04/2012: Validating: Emulator_88: Snap Path: H:\Playstation2\Pcsx2\Box
06:33:50.6 25/04/2012: Validating: Emulator_89: Snap Path: G:\Spectravideo\TAPE\Snap
06:33:50.6 25/04/2012: Validating: Emulator_90: Snap Path: G:\TI-99\Snap
06:33:50.6 25/04/2012: Validating: Emulator_91: Snap Path: G:\Thomson MO5\Roms\Snaps
06:33:50.6 25/04/2012: Validating: Emulator_92: Snap Path: F:\Mess\software\svision\Snap
06:33:50.6 25/04/2012: Validating: Emulator_93: Custom Background: gamewatch.png
06:33:50.6 25/04/2012: Validating: Emulator_93: Snap Path: G:\Game&Watch\Snaps
06:33:50.6 25/04/2012: Validating: Emulator_95: Snap Path: G:\Neo Geo Pocket\ColorRoms\Snap
06:33:50.6 25/04/2012: Validating: Emulator_96: Snap Path: F:\Mess\roms\scv\Box
06:33:50.6 25/04/2012: Validating: Emulator_97: Snap Path: F:\Action Max\Box
06:33:50.6 25/04/2012: Validating: Emulator_98: Snap Path: G:\Casio PV1000\Box
06:33:50.6 25/04/2012: Validating: Emulator_99: Snap Path: G:\Apfm1000\Box
06:33:50.6 25/04/2012: Validating: Emulator_100: Custom Background: wii.png
06:33:50.6 25/04/2012: Validating: Emulator_100: Snap Path: F:\Gamecube\Snap Wii
06:33:50.8 25/04/2012: Restoring Emulator from Cache: 12
06:33:58.9 25/04/2012: Restoring Emulator from Cache: 14
06:34:15.0 25/04/2012: Restoring Emulator from Cache: 62
06:34:27.3 25/04/2012: Restoring Emulator from Cache: 13
06:34:40.5 25/04/2012: Restoring Cached ICONS from File
06:34:44.2 25/04/2012: Setting Up RawInput Hook
06:34:44.2 25/04/2012: Launching RawInputHook.exe
06:34:45.3 25/04/2012: Running: cmd.exe /c F: F:\mame32fx\Mameui64\mameui64.exe 1943kai -rompath F:\mame32fx\roms -bezel -artpath artworkgameex
06:34:45.5 25/04/2012: Shutting down display
06:34:49.4 25/04/2012: Exiting game
06:34:49.7 25/04/2012: Writing MAME stats
06:34:49.7 25/04/2012: Restoring Bezel
06:34:49.7 25/04/2012: Plugin: Game Exit
06:34:49.7 25/04/2012: Plugin: Process Commands
06:34:49.8 25/04/2012: Restoring Window
06:34:49.8 25/04/2012: Reinitializing Graphics System
06:34:49.8 25/04/2012: Mouse Input is disabled
06:34:50.8 25/04/2012: Returning to GameEx
06:35:01.1 25/04/2012: Exiting GameEx!
06:35:01.1 25/04/2012: Disposing all videos
06:35:01.1 25/04/2012: Deleting temporary Karaoke videos
06:35:01.1 25/04/2012: Disposing Image List
06:35:01.1 25/04/2012: Disposing Fonts
06:35:01.1 25/04/2012: Disposing Surfaces
06:35:01.1 25/04/2012: Saving Settings
06:35:01.1 25/04/2012: Shutting down Bass
06:35:01.1 25/04/2012: Closing HideOS.exe
06:35:02.8 25/04/2012: Disposing Plugins
06:35:02.8 25/04/2012: Closing database connection
06:35:02.9 25/04/2012: Checking for applications to Launch On Exit
06:35:02.9 25/04/2012: Launching and waiting: C:\Program Files (x86)\DAEMON Tools Lite\daemon.exe -unmount scsi, 0
06:35:03.4 25/04/2012: Bye
Edited by Draco1962
