Everything worked fine, error occurred after reboot. Gameex crashed immediately after loading window. Tried to change theme - without result.
20:54:08.5 09.03.2012: Opening Configuration File
20:54:08.5 09.03.2012: GameEx: Version 12.55: Starting Log
20:54:08.5 09.03.2012: Operating System Platform: Win32NT
20:54:08.5 09.03.2012: Operating System Name: Windows XP
20:54:08.5 09.03.2012: Operating System Version: 5.1.2600
20:54:08.5 09.03.2012: Intel® Pentium® Dual CPU E2160 @ 1.80GHz, 2047MB
20:54:08.6 09.03.2012: 1,8Ghz - 2 Cores or CPU's
20:54:08.6 09.03.2012: Running Randomize()
20:54:08.6 09.03.2012: Loading PlugIns
20:54:08.6 09.03.2012: Checking for applications to Launch On Startup
20:54:08.6 09.03.2012: Running Misc startup tasks
20:54:08.6 09.03.2012: Setting Menu types
20:54:08.6 09.03.2012: Getting Configuration Values
20:54:08.6 09.03.2012: Using Theme: Leon GameEx
20:54:08.6 09.03.2012: Checking for alternate Image Directory for Theme: Leon GameEx
20:54:08.6 09.03.2012: Launching HideOS.exe
20:54:08.6 09.03.2012: Initialising Video/MNG DLL's
20:54:08.6 09.03.2012: GameEx will check for media insertion (may affect performance)
20:54:08.6 09.03.2012: Hiding Taskbar
20:54:08.6 09.03.2012: Is Media Center running?
20:54:08.6 09.03.2012: Checking/Creating LCD Registry values
20:54:08.7 09.03.2012: Check Media Center Exit/Start Mode
20:54:08.7 09.03.2012: Media Center Mode 2
20:54:08.7 09.03.2012: Video previews on. Warning: Only recommended on modern systems
20:54:08.7 09.03.2012: Custom Keyboard Input enabled: Getting custom codes
20:54:08.7 09.03.2012: Custom Game Device Input enabled: Getting custom codes
20:54:08.7 09.03.2012: Snap Delay set to: 2
20:54:08.7 09.03.2012: Get other settings
20:54:08.7 09.03.2012: Desktop set to Hide ICONS and set Background to Black
20:54:08.7 09.03.2012: Set: Find emulator artwork on best match basis
20:54:08.7 09.03.2012: Using DirectInput for keyboard input
20:54:08.7 09.03.2012: Start work for Form
20:54:08.7 09.03.2012: Getting Original Screen Size
20:54:08.7 09.03.2012: Compacting Database
20:54:09.1 09.03.2012: Opening Database Connection
20:54:09.2 09.03.2012: Initializing Component
20:54:09.2 09.03.2012: MAME Path is: C:\Program Files\GameEx\EMU\MAME
20:54:09.2 09.03.2012: AdvanceMAME Path is: C:\Program Files\GameEx\EMU\MAME
20:54:09.2 09.03.2012: AdvanceMAME EXE file is: advmame.exe
20:54:09.2 09.03.2012: Cannot Find AdvanceMAME executable: MAME Disabled
20:54:09.2 09.03.2012: Loading Controls.ini map file
20:54:09.2 09.03.2012: Applying Language/Text
20:54:09.2 09.03.2012: Text/Language: English
20:54:09.3 09.03.2012: Loading Custom Emulators
20:54:09.3 09.03.2012: Loading Emulator 1: [4 bit] Atari 2600
20:54:09.3 09.03.2012: Loading Emulator 2: [4 bit] Atari 5200
20:54:09.3 09.03.2012: Loading Emulator 3: [4 bit] Coleco Vision
20:54:09.3 09.03.2012: Loading Emulator 4: [8 bit] Nintendo NES
20:54:09.3 09.03.2012: Loading Emulator 5: [8 bit] Sega Master System
20:54:09.3 09.03.2012: Loading Emulator 6: [8 bit] Atari 7800
20:54:09.3 09.03.2012: Loading Emulator 7: [16 bit] Sega Genesis
20:54:09.4 09.03.2012: Loading Emulator 8: [16 bit] Nintendo SNES
20:54:09.4 09.03.2012: Loading Emulator 9: [32 bit] Nintendo N64
20:54:09.4 09.03.2012: Loading Emulator 10: [PC] Sinclair ZX Spectrum
20:54:09.4 09.03.2012: Loading Emulator 11: [Arcade] Arcade (MAME)
20:54:09.4 09.03.2012: gamebase support enabled.
20:54:09.4 09.03.2012: ERROR: Could not find gamebase path or gblanucher.exe
20:54:09.4 09.03.2012: gamebase support disabled.
20:54:09.4 09.03.2012: Using 3D Alpha Blended Animations.
20:54:09.4 09.03.2012: Retrieving resolution setting
20:54:09.4 09.03.2012: Using General Font: Georgia
20:54:09.4 09.03.2012: Using Title Font: Trebuchet MS
20:54:09.4 09.03.2012: GameEx will try to reduce CPU usage
20:54:09.4 09.03.2012: Initialising Direct3D
20:54:09.6 09.03.2012: Applying GameEx is Loading Image
20:54:09.7 09.03.2012: Setting Resolution to 1920x1080 32 bit color
20:54:09.7 09.03.2012: Creating Surfaces
20:54:09.8 09.03.2012: Creating Primary Surface - Full Screen Mode
20:54:09.8 09.03.2012: Creating Back Buffer
20:54:09.8 09.03.2012: Version 2 Theme being used. Loading.
20:54:09.8 09.03.2012: Loading Button Data
20:54:09.9 09.03.2012: Loading Font Data
20:54:09.9 09.03.2012: Loading Layout Data
20:54:09.9 09.03.2012: Loading Taskbar Data
20:54:09.9 09.03.2012: Loading graphic Surfaces
20:54:09.9 09.03.2012: Display is running at: 1920x1080 32bit color, 60hz
20:54:09.9 09.03.2012: Adapter: NVIDIA GeForce 8500 GT
20:54:09.9 09.03.2012: Max texture size: 8192x8192
20:54:09.9 09.03.2012: Available texture memory: 727MB
20:54:09.9 09.03.2012: Initialising Bass Audio Library
20:54:10.0 09.03.2012: Creating Surfaces Misc and Dialogs
20:54:10.2 09.03.2012: Creating Surfaces Volume
20:54:10.2 09.03.2012: Creating Surfaces Arrows
20:54:10.2 09.03.2012: Creating Surfaces GameEXlogo Text
20:54:10.2 09.03.2012: Creating Surfaces Toolbar
20:54:10.2 09.03.2012: Creating Surfaces Toolbar Controls
20:54:10.3 09.03.2012: Creating Surfaces Backgrounds
20:54:10.3 09.03.2012: Creating Surfaces GameEx Logo
20:54:10.3 09.03.2012: Creating Surface Unselected
20:54:10.3 09.03.2012: Creating Surfaces Snaps
20:54:10.3 09.03.2012: Creating Surfaces Menu and List Bars
20:54:10.7 09.03.2012: Creating Fonts
20:54:10.8 09.03.2012: Creating Game Font
20:54:10.9 09.03.2012: Creating Game Font Faded
20:54:11.0 09.03.2012: Creating Title Font
20:54:11.0 09.03.2012: Restoring Title Font From Cache
20:54:11.5 09.03.2012: Creating Font Black
20:54:11.5 09.03.2012: Creating Font Black Small
20:54:11.6 09.03.2012: Fonts Created Succesfully
20:54:11.6 09.03.2012: 8MB Video Memory Used
20:54:12.5 09.03.2012: MAME CMD options: -nowindow -joy -skip_gameinfo
20:54:12.5 09.03.2012: Creating DirectSound Device
20:54:12.5 09.03.2012: Trying: Первичный звуковой драйвер
20:54:12.5 09.03.2012: Loading Sound Files
20:54:12.5 09.03.2012: DirectSound Device Created Successfully
20:54:12.5 09.03.2012: Initialising DirectInput for Gamepad support
20:54:12.7 09.03.2012: Using Device PLAYSTATION®3 Controller
20:54:12.9 09.03.2012: Initialising DirectInput for Keyboard support
20:54:13.0 09.03.2012: Resuming Last Status
20:54:13.0 09.03.2012: Initializing MCE Remote
20:54:13.0 09.03.2012: Initialization OK! Starting GameEx!
20:54:13.0 09.03.2012: Testing Main Loop Once: Processing Frame
20:54:13.3 09.03.2012: --**--
20:54:13.3 09.03.2012: ERRORS DETECTED: EXITING
20:54:13.3 09.03.2012: Object reference not set to an instance of an object.
20:54:13.3 09.03.2012: at ag.ad()
Well something's not initiaizing for you or you missed a path during setup. What's happening is GameEx is supposed to run a test loop. Only Tom knows what ag.ad() does for sure, but I'd guess it's got something to do with drawing to the screen. :)
Did you try and run the check at the end of Headkaze's Setup Wizard and see if it finds anything?
could this be some problem with the sound ? recently I changed some settings in jukebox? but im not sure...
What settings did you change? Anything is possible. :)
Can you please post your GameEx.ini file?
Первичный звуковой драйвер - what driver is this?
As he stated the literal translation is Primary sound driver
I should have mentioned that (I looked it up before I responded). :)
@eckimo: Can I see your theme.ini for this: theme=Leon GameEx
Also, if you could please try the default theme for me and see if you have the same issues. Please also disable GameBase support so we can get rid of that error. :)
I disable GameBase support and put default theme - no results. About Primary sound driver I have no information. Very sorry for my english - sometimes misunderstood some sentences. Very much hope for your help.
Please my theme .ini :
Theme.ini
From what I am able to determine that is something not quite right with the Direct X drivers. You may want to download the latest available for XP SP3 and install again.
DirectX update does not give results.But this morning when loading Gameex I received a different report :
10:18:30.2 10.03.2012: Opening Configuration File
10:18:30.2 10.03.2012: GameEx: Version 12.55: Starting Log
10:18:30.2 10.03.2012: Operating System Platform: Win32NT
10:18:30.2 10.03.2012: Operating System Name: Windows XP
10:18:30.2 10.03.2012: Operating System Version: 5.1.2600
10:18:30.2 10.03.2012: Intel® Pentium® Dual CPU E2160 @ 1.80GHz, 2047MB
10:18:30.3 10.03.2012: 1,8Ghz - 2 Cores or CPU's
10:18:30.3 10.03.2012: Running Randomize()
10:18:30.3 10.03.2012: Loading PlugIns
10:18:30.3 10.03.2012: Checking for applications to Launch On Startup
10:18:30.3 10.03.2012: Running Misc startup tasks
10:18:30.3 10.03.2012: Setting Menu types
10:18:30.3 10.03.2012: Getting Configuration Values
10:18:30.3 10.03.2012: Using Theme: Default - Media Center
10:18:30.3 10.03.2012: Checking for alternate Image Directory for Theme: Default - Media Center
10:18:30.3 10.03.2012: Using Images from theme: Default - Media Center V1\MEDIA\
10:18:30.3 10.03.2012: Launching HideOS.exe
10:18:30.3 10.03.2012: Initialising Video/MNG DLL's
10:18:30.3 10.03.2012: GameEx will check for media insertion (may affect performance)
10:18:30.3 10.03.2012: Hiding Taskbar
10:18:30.4 10.03.2012: Is Media Center running?
10:18:30.4 10.03.2012: Checking/Creating LCD Registry values
10:18:30.4 10.03.2012: Check Media Center Exit/Start Mode
10:18:30.4 10.03.2012: Media Center Mode 2
10:18:30.5 10.03.2012: Video previews on. Warning: Only recommended on modern systems
10:18:30.5 10.03.2012: Custom Keyboard Input enabled: Getting custom codes
10:18:30.5 10.03.2012: Custom Game Device Input enabled: Getting custom codes
10:18:30.5 10.03.2012: Snap Delay set to: 2
10:18:30.5 10.03.2012: Get other settings
10:18:30.5 10.03.2012: Desktop set to Hide ICONS and set Background to Black
10:18:30.5 10.03.2012: Set: Find emulator artwork on best match basis
10:18:30.5 10.03.2012: Using DirectInput for keyboard input
10:18:30.5 10.03.2012: Start work for Form
10:18:30.5 10.03.2012: Getting Original Screen Size
10:18:30.5 10.03.2012: Opening Database Connection
10:18:30.8 10.03.2012: Initializing Component
10:18:30.9 10.03.2012: MAME Path is: C:\Program Files\GameEx\EMU\MAME
10:18:30.9 10.03.2012: AdvanceMAME Path is: C:\Program Files\GameEx\EMU\MAME
10:18:30.9 10.03.2012: AdvanceMAME EXE file is: advmame.exe
10:18:30.9 10.03.2012: Cannot Find AdvanceMAME executable: MAME Disabled
10:18:30.9 10.03.2012: Loading Controls.ini map file
10:18:30.9 10.03.2012: Applying Language/Text
10:18:30.9 10.03.2012: Text/Language: English
10:18:31.0 10.03.2012: Loading Custom Emulators
10:18:31.0 10.03.2012: Loading Emulator 1: [4 bit] Atari 2600
10:18:31.2 10.03.2012: Loading Emulator 2: [4 bit] Atari 5200
10:18:31.3 10.03.2012: Loading Emulator 3: [4 bit] Coleco Vision
10:18:31.4 10.03.2012: Loading Emulator 4: [8 bit] Nintendo NES
10:18:31.4 10.03.2012: Loading Emulator 5: [8 bit] Sega Master System
10:18:31.5 10.03.2012: Loading Emulator 6: [8 bit] Atari 7800
10:18:31.5 10.03.2012: Loading Emulator 7: [16 bit] Sega Genesis
10:18:31.7 10.03.2012: Loading Emulator 8: [16 bit] Nintendo SNES
10:18:31.7 10.03.2012: Loading Emulator 9: [32 bit] Nintendo N64
10:18:31.8 10.03.2012: Loading Emulator 10: [PC] Sinclair ZX Spectrum
10:18:31.9 10.03.2012: Loading Emulator 11: [Arcade] Arcade (MAME)
10:18:31.9 10.03.2012: Using 3D Alpha Blended Animations.
10:18:31.9 10.03.2012: Retrieving resolution setting
10:18:31.9 10.03.2012: Using General Font: Georgia
10:18:31.9 10.03.2012: Using Title Font: Georgia
10:18:31.9 10.03.2012: GameEx will try to reduce CPU usage
10:18:35.9 10.03.2012: Initialising Direct3D
10:18:37.2 10.03.2012: Applying GameEx is Loading Image
10:18:38.5 10.03.2012: Setting Resolution to 1920x1080 32 bit color
10:18:38.7 10.03.2012: Creating Surfaces
10:18:40.7 10.03.2012: Applying GameEx is Loading Image
10:18:41.4 10.03.2012: Setting Resolution to 1920x1080 32 bit color
10:18:41.4 10.03.2012: Creating Surfaces
10:18:41.4 10.03.2012: --**--
10:18:41.4 10.03.2012: Error: Error in the application.
10:18:41.7 10.03.2012: at Microsoft.DirectX.Direct3D.Manager.GetDeviceCaps(Int32 adapter, DeviceType deviceType)
10:18:41.7 10.03.2012: at o.a(Form A_0, Int32 A_1, Int32 A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6)
10:18:41.7 10.03.2012: at o..ctor(Form A_0, Int32 A_1, Int32 A_2, Boolean A_3, Boolean A_4, Boolean A_5, Boolean A_6)
10:18:41.7 10.03.2012: at ag.a(Boolean A_0, Boolean A_1, Boolean A_2, Boolean A_3, Int32 A_4)
10:18:41.7 10.03.2012: at ag.b(Boolean A_0, Boolean A_1, Boolean A_2)
10:18:41.7 10.03.2012: at ag.a(Boolean A_0, String A_1, Boolean A_2)
10:18:41.7 10.03.2012: at ag..ctor()
10:18:41.7 10.03.2012: Closing database connection
10:18:41.8 10.03.2012: Disposing Plugins
10:18:41.8 10.03.2012: GameEx is exiting with errors
10:18:41.8 10.03.2012: Deleting search cache
10:18:45.8 10.03.2012: ERRORS DETECTED: EXITING
10:18:46.6 10.03.2012: Bye
I have NVidia GF 8500GT. Just installed the new driver but nothing has changed. How can I correctly reset all settings to default, but keep the a copy of my settings. Maybe reinstall Gameex help me ? Does it make sense to ?
Let's not get too hasty about reinstalling GameEx! We may be able to help you resolve the issue and that should be a last resort. Check your display driver through Device Manager for the version number.
The latest driver (from nVidia - not Microsoft!) is GeForce 295.73. If your latest driver version is 290.xx (beta) or 285.xx (stable releases, but very problematic) then you need to download the newest from the link I provided and install.
For the DirectX drivers, the latest supported version for XP SP3 is DirectX 9.0c. Please make sure that you have this version installed.
What about video driver it is the one that I need, but directx try to install on your link, I hope this time luck will come.
Your driver link is to the latest version, just Russian translation. The link you provided for DirectX is good. One other thing to be certain of is that you have the .net frameworks installed. Was your XP install from a standard install disk or a stripped down version of XP (i.e. nlite or similar)?
I deleted the settings file and everything was working, try to find something that prevents me. If you find something - please write me.
I think it's Tom's texture drawing class but no one knows for sure but him.
I honestly think this is related to artwork somehow.
I edited the topic title to try to elevate it to Tom's attention. Not sure where he has been skulking off to lately... hopefully it doesn't involve cheap scotch and cheaper women...
and why not Mike?...nothing wrong with either of those lol !
