I have a very annoying problem that I hope somebody can help me with.
Some SNES games that work without problem in ZSNES don't show up in GameEx. The game starts to load then returns to GameEx.
I have managed to get all SNES games that I have to work except for these 5 remaining ROMS.
The games in particular is TMNT - Tournament Fighters, Super Star Wars - Empire Strikes Back & Return of the Jedi, Tiny Toons - Wacky Sports and Marvel Super Heroes.
Does anyone know any solution on this?
are the file extensions included in the "RomFilter=" section for that emulator.
I am now running NES, SNES and N64 and all OK.
Also, you ay want to consider using snes9x for the SNES side of things as found this runs 95% of all games and is a lot easier to configure when things go wrong.
Hope this helps.
Here is my ZSnes config. It took me ages to get this working properly but now it is perfect. Try this if you like it may solve your problem.
[Emulator_40]
STARTPAGENAME=Super Nintendo Entertainment System
TITLETEXT=SNES Games
StartPageLogo=snes
ROMFilter=*.smc;*.zip;*.rar
RomsInFolders=False
RomPath=H:\Emulators\Super Nintendo Entertainment System\Roms\USA
SnapPath=H:\Emulators\Super Nintendo Entertainment System\EmuMovies Super Nintendo AVI Game Previews
WorkingPath=H:\Emulators\Super Nintendo Entertainment System
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=False
Debug=False
MAPFile=
AlsoLaunch=
Command=Zsnesw.exe -m "[ROMPath]\[RomFile]"
OLDatZip=
TitlePath=H:\Emulators\Super Nintendo Entertainment System\Title Scans (SNES)
BoxPath=H:\Emulators\Super Nintendo Entertainment System\Box Scans (SNES)
LaunchBefore=
LaunchAfter=
CartPath=H:\Emulators\Super Nintendo Entertainment System\Cart Scans (SNES)
CustomBackground=snes
J.
actually that does make my life easier as well LOL
how would you setup the joypads 1 and 2 for the emulator though
and also setup a joystick button for exit? hopefully
With Zsnes there is a cfg file that you can edit. Firstly set up your joysticks and exit buttons using the Zsnes GUI. Then go into the cfg file and look for this line.
GUIDisable = 0
Change it to 1 and this should make it run even better. No Gui will show when loading a rom within GameEx and your joysticks should stay configured as long as you dont change which USB ports they are plugged into.
J.
P.S. Dont forget to change this line back to normal if you need to get back into Zsnes on it's own . It will not open with this line changed.
