I've noticed something worse... probably a bug. Selecting the various views, at a certain point you arrive at the horizontal scrolling view (the last one indroduced). Obiously GameEx picks up its default background, since no theme has a proper background for that view for now.
The issue is that, from that moment, if you continue changing views, GameEx keeps its background and doesen't revert to the one from the selected theme.
I tried with three different themes, same results.
I've noticed this too. If you exit out of GamEx and start again, everything reverts to normal.
Also, there is no reverse scroll in this view. To get to the change view again, you must cycle through the entire list. Not so bad with only a handful of SEGA Saturn games that I have, but tedious as can be with a full MAME list.
You can "reverse scroll" if you are all the way to the left and arrow key with the keyboard. Still very tedious when you have more than 5 or 6 menu items to pass through in addition to the By Year, Category, etc. would be nice to have greater control over that menu or have a mix of the big ribbon view with menu text but not sure how/if that is something that could be easily implemented. Main Menu commands should have their own structure separate from the submenu lists in this case IMO.
  • 4 months later...
I've just had this happened to me when changing the view for SNES. I can't get back the theme background, even after restarting GameEx.
Resolved it by changing the view until GameEx displayed it's default background, then restarting.
Edited by Draco1962
This thread is now marked as Resolved and has been closed. If the problem re-occurs, please start a new thread.
