[RESOLVED] MAME Compiler 64 Error. :)
Why is this happening? I tried downloading the source twice in each distro. Any and all help is appreciated.
Never seen that error before. Wierd. I have successfully compiled MAME 0145 with Mame Compiler so I have no idea what that error is. A search on Google doesn't help either.
Aww man! :)
I've compiled every major release since you put this out. I'll try compiling it on a different machine and see if it helps any.
Thanks HK!
Clear any folders you have from the previous release and create everything from scratch. Select Auto Detect in the optimization and 64-bit Processor in addition to Dual Core.
I was having issues on this machine before (HK had to fix the NONE selection for Optimize For so it would work for me).
I use an x86 OS, so would I still want to select 64-bit?
I just completed a compile using the UI64 version- here is the compile output:
Compiling Mame...
Using Parameters OSD=winui TARGETOS=win32 -j5 ARCHOPTS=-march=native PTR64=1
mkdir.exe -p obj/winui64
mkdir.exe -p obj/winui64/build
mkdir.exe -p obj/winui64/emu/audio
mkdir.exe -p obj/winui64/emu/cpu
mkdir.exe -p obj/winui64/emu/cpu/adsp2100
mkdir.exe -p obj/winui64/emu/cpu/alph8201
mkdir.exe -p obj/winui64/emu/cpu/am29000
mkdir.exe -p obj/winui64/emu/cpu/apexc
mkdir.exe -p obj/winui64/emu/cpu/arm
mkdir.exe -p obj/winui64/emu/cpu/arm7
mkdir.exe -p obj/winui64/emu/cpu/asap
mkdir.exe -p obj/winui64/emu/cpu/avr8
mkdir.exe -p obj/winui64/emu/cpu/ccpu
mkdir.exe -p obj/winui64/emu/cpu/cop400
mkdir.exe -p obj/winui64/emu/cpu/cosmac
mkdir.exe -p obj/winui64/emu/cpu/cp1610
mkdir.exe -p obj/winui64/emu/cpu/cubeqcpu
mkdir.exe -p obj/winui64/emu/cpu/dsp16
mkdir.exe -p obj/winui64/emu/cpu/dsp32
mkdir.exe -p obj/winui64/emu/cpu/dsp56k
mkdir.exe -p obj/winui64/emu/cpu/e132xs
mkdir.exe -p obj/winui64/emu/cpu/esrip
mkdir.exe -p obj/winui64/emu/cpu/f8
mkdir.exe -p obj/winui64/emu/cpu/g65816
mkdir.exe -p obj/winui64/emu/cpu/h6280
mkdir.exe -p obj/winui64/emu/cpu/h83002
mkdir.exe -p obj/winui64/emu/cpu/hcd62121
mkdir.exe -p obj/winui64/emu/cpu/hd61700
mkdir.exe -p obj/winui64/emu/cpu/hd6309
mkdir.exe -p obj/winui64/emu/cpu/i386
mkdir.exe -p obj/winui64/emu/cpu/i4004
mkdir.exe -p obj/winui64/emu/cpu/i8008
mkdir.exe -p obj/winui64/emu/cpu/i8085
mkdir.exe -p obj/winui64/emu/cpu/i86
mkdir.exe -p obj/winui64/emu/cpu/i860
mkdir.exe -p obj/winui64/emu/cpu/i960
mkdir.exe -p obj/winui64/emu/cpu/jaguar
mkdir.exe -p obj/winui64/emu/cpu/konami
mkdir.exe -p obj/winui64/emu/cpu/lh5801
mkdir.exe -p obj/winui64/emu/cpu/lr35902
mkdir.exe -p obj/winui64/emu/cpu/m37710
mkdir.exe -p obj/winui64/emu/cpu/m6502
mkdir.exe -p obj/winui64/emu/cpu/m6800
mkdir.exe -p obj/winui64/emu/cpu/m68000
mkdir.exe -p obj/winui64/emu/cpu/m6805
mkdir.exe -p obj/winui64/emu/cpu/m6809
mkdir.exe -p obj/winui64/emu/cpu/mb86233
mkdir.exe -p obj/winui64/emu/cpu/mb88xx
mkdir.exe -p obj/winui64/emu/cpu/mc68hc11
mkdir.exe -p obj/winui64/emu/cpu/mcs48
mkdir.exe -p obj/winui64/emu/cpu/mcs51
mkdir.exe -p obj/winui64/emu/cpu/minx
mkdir.exe -p obj/winui64/emu/cpu/mips
mkdir.exe -p obj/winui64/emu/cpu/mn10200
mkdir.exe -p obj/winui64/emu/cpu/nec
mkdir.exe -p obj/winui64/emu/cpu/pdp1
mkdir.exe -p obj/winui64/emu/cpu/pic16c5x
mkdir.exe -p obj/winui64/emu/cpu/pic16c62x
mkdir.exe -p obj/winui64/emu/cpu/powerpc
mkdir.exe -p obj/winui64/emu/cpu/pps4
mkdir.exe -p obj/winui64/emu/cpu/psx
mkdir.exe -p obj/winui64/emu/cpu/rsp
mkdir.exe -p obj/winui64/emu/cpu/s2650
mkdir.exe -p obj/winui64/emu/cpu/saturn
mkdir.exe -p obj/winui64/emu/cpu/sc61860
mkdir.exe -p obj/winui64/emu/cpu/scmp
mkdir.exe -p obj/winui64/emu/cpu/se3208
mkdir.exe -p obj/winui64/emu/cpu/sh2
mkdir.exe -p obj/winui64/emu/cpu/sh4
mkdir.exe -p obj/winui64/emu/cpu/sharc
mkdir.exe -p obj/winui64/emu/cpu/sm8500
mkdir.exe -p obj/winui64/emu/cpu/spc700
mkdir.exe -p obj/winui64/emu/cpu/ssem
mkdir.exe -p obj/winui64/emu/cpu/ssp1601
mkdir.exe -p obj/winui64/emu/cpu/superfx
mkdir.exe -p obj/winui64/emu/cpu/t11
mkdir.exe -p obj/winui64/emu/cpu/tlcs90
mkdir.exe -p obj/winui64/emu/cpu/tlcs900
mkdir.exe -p obj/winui64/emu/cpu/tms0980
mkdir.exe -p obj/winui64/emu/cpu/tms32010
mkdir.exe -p obj/winui64/emu/cpu/tms32025
mkdir.exe -p obj/winui64/emu/cpu/tms32031
mkdir.exe -p obj/winui64/emu/cpu/tms32051
mkdir.exe -p obj/winui64/emu/cpu/tms34010
mkdir.exe -p obj/winui64/emu/cpu/tms57002
mkdir.exe -p obj/winui64/emu/cpu/tms7000
mkdir.exe -p obj/winui64/emu/cpu/tms9900
mkdir.exe -p obj/winui64/emu/cpu/unsp
mkdir.exe -p obj/winui64/emu/cpu/upd7725
mkdir.exe -p obj/winui64/emu/cpu/upd7810
mkdir.exe -p obj/winui64/emu/cpu/v30mz
mkdir.exe -p obj/winui64/emu/cpu/v60
mkdir.exe -p obj/winui64/emu/cpu/v810
mkdir.exe -p obj/winui64/emu/cpu/z180
mkdir.exe -p obj/winui64/emu/cpu/z8
mkdir.exe -p obj/winui64/emu/cpu/z80
mkdir.exe -p obj/winui64/emu/cpu/z8000
mkdir.exe -p obj/winui64/emu/debug
mkdir.exe -p obj/winui64/emu/debugint
mkdir.exe -p obj/winui64/emu/drivers
mkdir.exe -p obj/winui64/emu/imagedev
mkdir.exe -p obj/winui64/emu/layout
mkdir.exe -p obj/winui64/emu/machine
mkdir.exe -p obj/winui64/emu/sound
mkdir.exe -p obj/winui64/emu/video
mkdir.exe -p obj/winui64/lib/expat
mkdir.exe -p obj/winui64/lib/formats
mkdir.exe -p obj/winui64/lib/libflac
mkdir.exe -p obj/winui64/lib/libflacpp
mkdir.exe -p obj/winui64/lib/libjpeg
mkdir.exe -p obj/winui64/lib/softfloat
mkdir.exe -p obj/winui64/lib/util
mkdir.exe -p obj/winui64/lib/zlib
mkdir.exe -p obj/winui64/mame/audio
mkdir.exe -p obj/winui64/mame/drivers
mkdir.exe -p obj/winui64/mame/layout
mkdir.exe -p obj/winui64/mame/machine
mkdir.exe -p obj/winui64/mame/mame
mkdir.exe -p obj/winui64/mame/video
mkdir.exe -p obj/winui64/osd
mkdir.exe -p obj/winui64/osd/windows
mkdir.exe -p obj/winui64/osd/winui
mkdir.exe -p obj/winui64/tools
Compiling src/emu/cpu/m68000/m68kmake.c...
Compiling src/osd/windows/strconv.c...
Compiling src/osd/windows/windir.c...
Compiling src/osd/windows/winfile.c...
Compiling src/osd/windows/winclip.c...
Compiling src/osd/windows/winmisc.c...
Compiling src/osd/windows/winsync.c...
Compiling src/osd/windows/wintime.c...
Compiling src/osd/windows/winutf8.c...
Compiling src/osd/windows/winutil.c...
Compiling src/osd/windows/winwork.c...
Compiling src/osd/windows/winsocket.c...
Compiling src/emu/cpu/tms57002/tmsmake.c...
Compiling src/build/file2str.c...
Compiling src/build/makedep.c...
Compiling src/lib/util/astring.c...
Compiling src/lib/util/avcomp.c...
Compiling src/lib/util/aviio.c...
Compiling src/lib/util/bitmap.c...
Compiling src/lib/util/cdrom.c...
Compiling src/lib/util/chd.c...
Compiling src/lib/util/chdcd.c...
Compiling src/lib/util/corefile.c...
Compiling src/lib/util/corestr.c...
Compiling src/lib/util/coreutil.c...
Compiling src/lib/util/harddisk.c...
Compiling src/lib/util/huffman.c...
Compiling src/lib/util/jedparse.c...
Compiling src/lib/util/md5.c...
Compiling src/lib/util/opresolv.c...
Compiling src/lib/util/options.c...
Compiling src/lib/util/palette.c...
Compiling src/lib/util/png.c...
Compiling src/lib/util/pool.c...
Compiling src/lib/util/sha1.c...
Compiling src/lib/util/unicode.c...
Compiling src/lib/util/unzip.c...
Compiling src/lib/util/vbiparse.c...
Compiling src/lib/util/xmlfile.c...
Compiling src/lib/util/zippath.c...
Compiling src/lib/zlib/adler32.c...
Compiling src/lib/zlib/compress.c...
Compiling src/lib/zlib/crc32.c...
Compiling src/lib/zlib/deflate.c...
Compiling src/lib/zlib/gzio.c...
Compiling src/lib/zlib/inflate.c...
Compiling src/lib/zlib/inffast.c...
Compiling src/lib/zlib/infback.c...
Compiling src/lib/zlib/inftrees.c...
Compiling src/lib/zlib/trees.c...
Compiling src/lib/zlib/uncompr.c...
Compiling src/lib/zlib/zutil.c...
Compiling src/build/makelist.c...
Compiling src/build/makedev.c...
Compiling src/build/png2bdc.c...
Compiling src/build/verinfo.c...
Compiling src/mame/drivers/ertictac.c...
Compiling src/mame/drivers/ssfindo.c...
Compiling src/mame/drivers/aristmk5.c...
Compiling src/mame/machine/archimds.c...
Compiling src/mame/video/archimds.c...
Compiling src/mame/drivers/albazc.c...
Compiling src/mame/drivers/albazg.c...
Compiling src/mame/drivers/rmhaihai.c...
Compiling src/mame/drivers/ace.c...
Compiling src/mame/drivers/clayshoo.c...
Compiling src/mame/video/alpha68k.c...
Compiling src/mame/drivers/alpha68k.c...
Compiling src/mame/drivers/champbas.c...
Compiling src/mame/video/champbas.c...
Compiling src/mame/drivers/equites.c...
Compiling src/mame/video/equites.c...
Compiling src/mame/drivers/meijinsn.c...
Compiling src/mame/drivers/shougi.c...
Compiling src/mame/drivers/alg.c...
Compiling src/mame/machine/amiga.c...
Compiling src/mame/audio/amiga.c...
Compiling src/mame/video/amiga.c...
Compiling src/mame/video/amigaaga.c...
Compiling src/mame/drivers/arcadia.c...
Compiling src/mame/drivers/cd32.c...
Compiling src/mame/machine/cd32.c...
Compiling src/mame/drivers/mquake.c...
Compiling src/mame/drivers/upscope.c...
Compiling src/mame/drivers/aristmk6.c...
Compiling src/mame/drivers/caswin.c...
Compiling src/mame/drivers/big10.c...
Compiling src/mame/drivers/forte2.c...
Compiling src/mame/drivers/pengadvb.c...
Compiling src/mame/drivers/sangho.c...
Compiling src/mame/drivers/sfkick.c...
Compiling src/mame/drivers/arcadecl.c...
Compiling src/mame/video/arcadecl.c...
Compiling src/mame/drivers/asteroid.c...
Compiling src/mame/machine/asteroid.c...
Compiling src/mame/audio/llander.c...
Compiling src/mame/audio/asteroid.c...
Compiling src/mame/machine/atarifb.c...
Compiling src/mame/audio/atarifb.c...
Compiling src/mame/video/atarifb.c...
Compiling src/mame/drivers/atarig1.c...
Compiling src/mame/video/atarig1.c...
Compiling src/mame/drivers/atarig42.c...
Compiling src/mame/video/atarig42.c...
Compiling src/mame/drivers/atarigt.c...
Compiling src/mame/video/atarigt.c...
Compiling src/mame/drivers/atarigx2.c...
Compiling src/mame/video/atarigx2.c...
Compiling src/mame/drivers/atarisy1.c...
Compiling src/mame/video/atarisy1.c...
Compiling src/mame/drivers/atarisy2.c...
Compiling src/mame/video/atarisy2.c...
Compiling src/mame/drivers/atarisy4.c...
Compiling src/mame/drivers/atetris.c...
Compiling src/mame/video/atetris.c...
Compiling src/mame/audio/avalnche.c...
Compiling src/mame/drivers/badlands.c...
Compiling src/mame/video/badlands.c...
Compiling src/mame/drivers/bartop52.c...
Compiling src/mame/drivers/batman.c...
Compiling src/mame/video/batman.c...
Compiling src/mame/drivers/beathead.c...
Compiling src/mame/video/beathead.c...
Compiling src/mame/drivers/blstroid.c...
Compiling src/mame/video/blstroid.c...
Compiling src/mame/drivers/boxer.c...
Compiling src/mame/drivers/bsktball.c...
Compiling src/mame/machine/bsktball.c...
Compiling src/mame/audio/bsktball.c...
Compiling src/mame/video/bsktball.c...
Compiling src/mame/drivers/bwidow.c...
Compiling src/mame/audio/bzone.c...
Compiling src/mame/drivers/canyon.c...
Compiling src/mame/audio/canyon.c...
Compiling src/mame/video/canyon.c...
Compiling src/mame/drivers/cball.c...
Compiling src/mame/drivers/ccastles.c...
Compiling src/mame/video/ccastles.c...
Compiling src/mame/drivers/centiped.c...
Compiling src/mame/video/centiped.c...
Compiling src/mame/drivers/cloak.c...
Compiling src/mame/video/cloak.c...
Compiling src/mame/drivers/cloud9.c...
Compiling src/mame/video/cloud9.c...
Compiling src/mame/drivers/cmmb.c...
Compiling src/mame/audio/copsnrob.c...
Compiling src/mame/video/copsnrob.c...
Compiling src/mame/drivers/cyberbal.c...
Compiling src/mame/audio/cyberbal.c...
Compiling src/mame/video/cyberbal.c...
Compiling src/mame/drivers/dragrace.c...
Compiling src/mame/audio/dragrace.c...
Compiling src/mame/video/dragrace.c...
Compiling src/mame/drivers/eprom.c...
Compiling src/mame/video/eprom.c...
Compiling src/mame/drivers/firefox.c...
Compiling src/mame/audio/firetrk.c...
Compiling src/mame/drivers/firetrk.c...
Compiling src/mame/video/firetrk.c...
Compiling src/mame/drivers/flyball.c...
Compiling src/mame/drivers/foodf.c...
Compiling src/mame/video/foodf.c...
Compiling src/mame/drivers/gauntlet.c...
Compiling src/mame/video/gauntlet.c...
Compiling src/mame/drivers/harddriv.c...
Compiling src/mame/machine/harddriv.c...
Compiling src/mame/audio/harddriv.c...
Compiling src/mame/video/harddriv.c...
Compiling src/mame/drivers/irobot.c...
Compiling src/mame/machine/irobot.c...
Compiling src/mame/video/irobot.c...
Compiling src/mame/drivers/jaguar.c...
Compiling src/mame/audio/jaguar.c...
Compiling src/mame/video/jaguar.c...
Compiling src/mame/drivers/jedi.c...
Compiling src/mame/audio/jedi.c...
Compiling src/mame/video/jedi.c...
Compiling src/mame/drivers/klax.c...
Compiling src/mame/video/klax.c...
Compiling src/mame/drivers/liberatr.c...
Compiling src/mame/video/liberatr.c...
Compiling src/mame/drivers/mediagx.c...
Compiling src/mame/drivers/metalmx.c...
Compiling src/mame/drivers/mgolf.c...
Compiling src/mame/machine/mhavoc.c...
Compiling src/mame/drivers/mhavoc.c...
Compiling src/mame/drivers/missile.c...
Compiling src/mame/drivers/nitedrvr.c...
Compiling src/mame/machine/nitedrvr.c...
Compiling src/mame/audio/nitedrvr.c...
Compiling src/mame/video/nitedrvr.c...
Compiling src/mame/drivers/offtwall.c...
Compiling src/mame/video/offtwall.c...
Compiling src/mame/drivers/orbit.c...
Compiling src/mame/video/orbit.c...
Compiling src/mame/audio/orbit.c...
Compiling src/mame/drivers/poolshrk.c...
Compiling src/mame/audio/poolshrk.c...
Compiling src/mame/video/poolshrk.c...
Compiling src/mame/drivers/quantum.c...
Compiling src/mame/drivers/rampart.c...
Compiling src/mame/video/rampart.c...
Compiling src/mame/drivers/relief.c...
Compiling src/mame/video/relief.c...
Compiling src/mame/drivers/runaway.c...
Compiling src/mame/video/runaway.c...
Compiling src/mame/drivers/shuuz.c...
Compiling src/mame/video/shuuz.c...
Compiling src/mame/drivers/skullxbo.c...
Compiling src/mame/video/skullxbo.c...
Compiling src/mame/drivers/skydiver.c...
Compiling src/mame/audio/skydiver.c...
Compiling src/mame/video/skydiver.c...
Compiling src/mame/drivers/skyraid.c...
Compiling src/mame/audio/skyraid.c...
Compiling src/mame/video/skyraid.c...
Compiling src/mame/drivers/sprint2.c...
Compiling src/mame/audio/sprint2.c...
Compiling src/mame/video/sprint2.c...
Compiling src/mame/drivers/sprint4.c...
Compiling src/mame/video/sprint4.c...
Compiling src/mame/audio/sprint4.c...
Compiling src/mame/drivers/sprint8.c...
Compiling src/mame/audio/sprint8.c...
Compiling src/mame/video/sprint8.c...
Compiling src/mame/drivers/starshp1.c...
Compiling src/mame/audio/starshp1.c...
Compiling src/mame/video/starshp1.c...
Compiling src/mame/drivers/starwars.c...
Compiling src/mame/machine/starwars.c...
Compiling src/mame/audio/starwars.c...
Compiling src/mame/drivers/subs.c...
Compiling src/mame/machine/subs.c...
Compiling src/mame/audio/subs.c...
Compiling src/mame/video/subs.c...
Compiling src/mame/drivers/tank8.c...
Compiling src/mame/audio/tank8.c...
Compiling src/mame/video/tank8.c...
Compiling src/mame/drivers/tempest.c...
Compiling src/mame/drivers/thunderj.c...
Compiling src/mame/video/thunderj.c...
Compiling src/mame/drivers/tomcat.c...
Compiling src/mame/drivers/toobin.c...
Compiling src/mame/video/toobin.c...
Compiling src/mame/drivers/tourtabl.c...
Compiling src/mame/video/tia.c...
Compiling src/mame/drivers/triplhnt.c...
Compiling src/mame/audio/triplhnt.c...
Compiling src/mame/video/triplhnt.c...
Compiling src/mame/drivers/tunhunt.c...
Compiling src/mame/video/tunhunt.c...
Compiling src/mame/drivers/ultratnk.c...
Compiling src/mame/video/ultratnk.c...
Compiling src/mame/audio/videopin.c...
Compiling src/mame/video/videopin.c...
Compiling src/mame/video/vindictr.c...
Compiling src/mame/drivers/vindictr.c...
Compiling src/mame/drivers/wolfpack.c...
Compiling src/mame/video/wolfpack.c...
Compiling src/mame/drivers/xybots.c...
Compiling src/mame/video/xybots.c...
Compiling src/mame/machine/asic65.c...
Compiling src/mame/machine/atari_vg.c...
Compiling src/mame/machine/atarigen.c...
Compiling src/mame/machine/mathbox.c...
Compiling src/mame/machine/slapstic.c...
Compiling src/mame/audio/atarijsa.c...
Compiling src/mame/audio/cage.c...
Compiling src/mame/audio/redbaron.c...
Compiling src/mame/video/atarimo.c...
Compiling src/mame/video/atarirle.c...
Compiling src/mame/drivers/blmbycar.c...
Compiling src/mame/video/blmbycar.c...
Compiling src/mame/drivers/ohmygod.c...
Compiling src/mame/drivers/powerins.c...
Compiling src/mame/video/ohmygod.c...
Compiling src/mame/video/powerins.c...
Compiling src/mame/drivers/mpu2.c...
Compiling src/mame/drivers/mpu3.c...
Compiling src/mame/drivers/mpu5.c...
Compiling src/mame/video/awpvid.c...
Compiling src/mame/machine/meters.c...
Compiling src/mame/machine/steppers.c...
Compiling src/mame/machine/bfm_comn.c...
Compiling src/mame/drivers/bfcobra.c...
Compiling src/mame/video/bfm_adr2.c...
Compiling src/mame/drivers/bfm_sc4.c...
Compiling src/mame/drivers/bfm_sc5.c...
Compiling src/mame/drivers/bfmsys83.c...
Compiling src/mame/drivers/bfm_swp.c...
Compiling src/mame/drivers/bfmsys85.c...
Compiling src/mame/machine/bfm_bd1.c...
Compiling src/mame/video/bfm_dm01.c...
Compiling src/mame/drivers/bmcbowl.c...
Compiling src/mame/drivers/koftball.c...
Compiling src/mame/drivers/popobear.c...
Compiling src/mame/drivers/bmcpokr.c...
Compiling src/mame/drivers/1942.c...
Compiling src/mame/video/1942.c...
Compiling src/mame/drivers/1943.c...
Compiling src/mame/video/1943.c...
Compiling src/mame/drivers/alien.c...
Compiling src/mame/drivers/bionicc.c...
Compiling src/mame/video/bionicc.c...
Compiling src/mame/drivers/blktiger.c...
Compiling src/mame/video/blktiger.c...
Compiling src/mame/drivers/cbasebal.c...
Compiling src/mame/video/cbasebal.c...
Compiling src/mame/drivers/commando.c...
Compiling src/mame/video/commando.c...
Compiling src/mame/drivers/cps1.c...
Compiling src/mame/video/cps1.c...
Compiling src/mame/drivers/cps2.c...
Compiling src/mame/drivers/cps3.c...
Compiling src/mame/audio/cps3.c...
Compiling src/mame/drivers/egghunt.c...
Compiling src/mame/drivers/exedexes.c...
Compiling src/mame/video/exedexes.c...
Compiling src/mame/drivers/fcrash.c...
Compiling src/mame/drivers/gng.c...
Compiling src/mame/video/gng.c...
Compiling src/mame/drivers/gunsmoke.c...
Compiling src/mame/drivers/higemaru.c...
Compiling src/mame/video/gunsmoke.c...
Compiling src/mame/video/higemaru.c...
Compiling src/mame/drivers/lastduel.c...
Compiling src/mame/video/lastduel.c...
Compiling src/mame/drivers/lwings.c...
Compiling src/mame/video/lwings.c...
Compiling src/mame/drivers/mitchell.c...
Compiling src/mame/video/mitchell.c...
Compiling src/mame/drivers/sf.c...
Compiling src/mame/video/sf.c...
Compiling src/mame/drivers/sidearms.c...
Compiling src/mame/video/sidearms.c...
Compiling src/mame/drivers/sonson.c...
Compiling src/mame/video/sonson.c...
Compiling src/mame/drivers/srumbler.c...
Compiling src/mame/video/srumbler.c...
Compiling src/mame/drivers/tigeroad.c...
Compiling src/mame/video/tigeroad.c...
Compiling src/mame/drivers/vulgus.c...
Compiling src/mame/video/vulgus.c...
Compiling src/mame/machine/cps2crpt.c...
Compiling src/mame/drivers/ataxx.c...
Compiling src/mame/machine/kabuki.c...
Compiling src/mame/audio/cinemat.c...
Compiling src/mame/video/cinemat.c...
Compiling src/mame/drivers/cchasm.c...
Compiling src/mame/machine/cchasm.c...
Compiling src/mame/audio/cchasm.c...
Compiling src/mame/video/cchasm.c...
Compiling src/mame/drivers/embargo.c...
Compiling src/mame/drivers/jack.c...
Compiling src/mame/video/jack.c...
Compiling src/mame/drivers/leland.c...
Compiling src/mame/machine/leland.c...
Compiling src/mame/audio/leland.c...
Compiling src/mame/video/leland.c...
Compiling src/mame/drivers/funybubl.c...
Compiling src/mame/video/funybubl.c...
Compiling src/mame/drivers/galspnbl.c...
Compiling src/mame/video/galspnbl.c...
Compiling src/mame/drivers/pushman.c...
Compiling src/mame/video/pushman.c...
Compiling src/mame/drivers/zerozone.c...
Compiling src/mame/video/zerozone.c...
Compiling src/mame/drivers/cvs.c...
Compiling src/mame/video/cvs.c...
Compiling src/mame/drivers/quasar.c...
Compiling src/mame/video/quasar.c...
Compiling src/mame/drivers/actfancr.c...
Compiling src/mame/video/actfancr.c...
Compiling src/mame/drivers/astrof.c...
Compiling src/mame/audio/astrof.c...
Compiling src/mame/drivers/backfire.c...
Compiling src/mame/drivers/battlera.c...
Compiling src/mame/video/battlera.c...
Compiling src/mame/drivers/boogwing.c...
Compiling src/mame/video/boogwing.c...
Compiling src/mame/drivers/brkthru.c...
Compiling src/mame/video/brkthru.c...
Compiling src/mame/drivers/btime.c...
Compiling src/mame/machine/btime.c...
Compiling src/mame/video/btime.c...
Compiling src/mame/drivers/bwing.c...
Compiling src/mame/video/bwing.c...
Compiling src/mame/drivers/cbuster.c...
Compiling src/mame/video/cbuster.c...
Compiling src/mame/drivers/chanbara.c...
Compiling src/mame/drivers/cninja.c...
Compiling src/mame/video/cninja.c...
Compiling src/mame/drivers/cntsteer.c...
Compiling src/mame/drivers/compgolf.c...
Compiling src/mame/video/compgolf.c...
Compiling src/mame/drivers/darkseal.c...
Compiling src/mame/video/darkseal.c...
Compiling src/mame/drivers/dassault.c...
Compiling src/mame/video/dassault.c...
Compiling src/mame/drivers/dblewing.c...
Compiling src/mame/drivers/dec0.c...
Compiling src/mame/machine/dec0.c...
Compiling src/mame/video/dec0.c...
Compiling src/mame/drivers/dec8.c...
Compiling src/mame/video/dec8.c...
Compiling src/mame/drivers/deco_ld.c...
Compiling src/mame/drivers/deco_mlc.c...
Compiling src/mame/video/deco_mlc.c...
Compiling src/mame/drivers/deco156.c...
Compiling src/mame/machine/deco156.c...
Compiling src/mame/drivers/deco32.c...
Compiling src/mame/video/deco32.c...
Compiling src/mame/audio/decobsmt.c...
Compiling src/mame/drivers/decocass.c...
Compiling src/mame/machine/decocass.c...
Compiling src/mame/video/decocass.c...
Compiling src/mame/drivers/deshoros.c...
Compiling src/mame/drivers/dietgo.c...
Compiling src/mame/drivers/exprraid.c...
Compiling src/mame/video/dietgo.c...
Compiling src/mame/video/exprraid.c...
Compiling src/mame/drivers/firetrap.c...
Compiling src/mame/video/firetrap.c...
Compiling src/mame/drivers/funkyjet.c...
Compiling src/mame/video/funkyjet.c...
Compiling src/mame/drivers/karnov.c...
Compiling src/mame/video/karnov.c...
Compiling src/mame/drivers/kchamp.c...
Compiling src/mame/video/kchamp.c...
Compiling src/mame/drivers/kingobox.c...
Compiling src/mame/video/kingobox.c...
Compiling src/mame/drivers/lemmings.c...
Compiling src/mame/video/lemmings.c...
Compiling src/mame/drivers/liberate.c...
Compiling src/mame/video/liberate.c...
Compiling src/mame/drivers/madalien.c...
Compiling src/mame/audio/madalien.c...
Compiling src/mame/video/madalien.c...
Compiling src/mame/drivers/madmotor.c...
Compiling src/mame/video/madmotor.c...
Compiling src/mame/drivers/metlclsh.c...
Compiling src/mame/video/metlclsh.c...
Compiling src/mame/drivers/mirage.c...
Compiling src/mame/drivers/pcktgal.c...
Compiling src/mame/video/pcktgal.c...
Compiling src/mame/drivers/pktgaldx.c...
Compiling src/mame/video/pktgaldx.c...
Compiling src/mame/drivers/progolf.c...
Compiling src/mame/drivers/rohga.c...
Compiling src/mame/video/rohga.c...
Compiling src/mame/drivers/shootout.c...
Compiling src/mame/video/shootout.c...
Compiling src/mame/drivers/sidepckt.c...
Compiling src/mame/video/sidepckt.c...
Compiling src/mame/drivers/simpl156.c...
Compiling src/mame/video/simpl156.c...
Compiling src/mame/drivers/sshangha.c...
Compiling src/mame/video/sshangha.c...
Compiling src/mame/drivers/stadhero.c...
Compiling src/mame/video/stadhero.c...
Compiling src/mame/drivers/supbtime.c...
Compiling src/mame/video/supbtime.c...
Compiling src/mame/drivers/tryout.c...
Compiling src/mame/video/tryout.c...
Compiling src/mame/drivers/tumbleb.c...
Compiling src/mame/drivers/tumblep.c...
Compiling src/mame/video/tumbleb.c...
Compiling src/mame/video/tumblep.c...
Compiling src/mame/drivers/vaportra.c...
Compiling src/mame/video/vaportra.c...
Compiling src/mame/machine/deco102.c...
Compiling src/mame/machine/decocrpt.c...
Compiling src/mame/machine/decoprot.c...
Compiling src/mame/video/decbac06.c...
Compiling src/mame/video/deco16ic.c...
Compiling src/mame/video/decocomn.c...
Compiling src/mame/video/decospr.c...
Compiling src/mame/video/decmxc06.c...
Compiling src/mame/video/deckarn.c...
Compiling src/mame/drivers/blackt96.c...
Compiling src/mame/drivers/pokechmp.c...
Compiling src/mame/video/pokechmp.c...
Compiling src/mame/drivers/dooyong.c...
Compiling src/mame/video/dooyong.c...
Compiling src/mame/drivers/gundealr.c...
Compiling src/mame/video/gundealr.c...
Compiling src/mame/drivers/ddenlovr.c...
Compiling src/mame/drivers/dynax.c...
Compiling src/mame/video/dynax.c...
Compiling src/mame/drivers/hnayayoi.c...
Compiling src/mame/video/hnayayoi.c...
Compiling src/mame/drivers/realbrk.c...
Compiling src/mame/video/realbrk.c...
Compiling src/mame/drivers/royalmah.c...
Compiling src/mame/drivers/diverboy.c...
Compiling src/mame/drivers/fantland.c...
Compiling src/mame/video/fantland.c...
Compiling src/mame/drivers/mwarr.c...
Compiling src/mame/drivers/mugsmash.c...
Compiling src/mame/video/mugsmash.c...
Compiling src/mame/drivers/ppmast93.c...
Compiling src/mame/drivers/stlforce.c...
Compiling src/mame/drivers/pzletime.c...
Compiling src/mame/video/stlforce.c...
Compiling src/mame/drivers/twins.c...
Compiling src/mame/video/eolith.c...
Compiling src/mame/drivers/eolith.c...
Compiling src/mame/drivers/eolith16.c...
Compiling src/mame/drivers/eolithsp.c...
Compiling src/mame/drivers/ghosteo.c...
Compiling src/mame/drivers/vegaeo.c...
Compiling src/mame/drivers/aquarium.c...
Compiling src/mame/video/aquarium.c...
Compiling src/mame/drivers/d9final.c...
Compiling src/mame/video/gcpinbal.c...
Compiling src/mame/drivers/gcpinbal.c...
Compiling src/mame/drivers/lastbank.c...
Compiling src/mame/drivers/vmetal.c...
Compiling src/mame/drivers/carpolo.c...
Compiling src/mame/machine/carpolo.c...
Compiling src/mame/video/carpolo.c...
Compiling src/mame/audio/circus.c...
Compiling src/mame/video/circus.c...
Compiling src/mame/drivers/exidy.c...
Compiling src/mame/audio/exidy.c...
Compiling src/mame/video/exidy.c...
Compiling src/mame/drivers/exidy440.c...
Compiling src/mame/audio/exidy440.c...
Compiling src/mame/video/exidy440.c...
Compiling src/mame/machine/atari.c...
Compiling src/mame/video/atari.c...
Compiling src/mame/video/antic.c...
Compiling src/mame/video/gtia.c...
Compiling src/mame/drivers/starfire.c...
Compiling src/mame/video/starfire.c...
Compiling src/mame/drivers/vertigo.c...
Compiling src/mame/machine/vertigo.c...
Compiling src/mame/video/vertigo.c...
Compiling src/mame/drivers/victory.c...
Compiling src/mame/video/victory.c...
Compiling src/mame/audio/targ.c...
Compiling src/mame/drivers/crospang.c...
Compiling src/mame/video/crospang.c...
Compiling src/mame/drivers/f-32.c...
Compiling src/mame/drivers/4roses.c...
Compiling src/mame/video/funworld.c...
Compiling src/mame/video/snookr10.c...
Compiling src/mame/drivers/fuukifg2.c...
Compiling src/mame/video/fuukifg2.c...
Compiling src/mame/drivers/fuukifg3.c...
Compiling src/mame/video/fuukifg3.c...
Compiling src/mame/drivers/atvtrack.c...
Compiling src/mame/drivers/gaelco.c...
Compiling src/mame/video/gaelco.c...
Compiling src/mame/machine/gaelcrpt.c...
Compiling src/mame/drivers/gaelco2.c...
Compiling src/mame/machine/gaelco2.c...
Compiling src/mame/video/gaelco2.c...
Compiling src/mame/drivers/gaelco3d.c...
Compiling src/mame/video/gaelco3d.c...
Compiling src/mame/machine/gaelco3d.c...
Compiling src/mame/drivers/glass.c...
Compiling src/mame/video/glass.c...
Compiling src/mame/drivers/mastboy.c...
Compiling src/mame/drivers/splash.c...
Compiling src/mame/video/splash.c...
Compiling src/mame/drivers/targeth.c...
Compiling src/mame/video/targeth.c...
Compiling src/mame/drivers/thoop2.c...
Compiling src/mame/video/thoop2.c...
Compiling src/mame/drivers/tokyocop.c...
Compiling src/mame/drivers/wrally.c...
Compiling src/mame/machine/wrally.c...
Compiling src/mame/video/wrally.c...
Compiling src/mame/drivers/xorworld.c...
Compiling src/mame/video/xorworld.c...
Compiling src/mame/drivers/enigma2.c...
Compiling src/mame/drivers/gameplan.c...
Compiling src/mame/video/gameplan.c...
Compiling src/mame/drivers/toratora.c...
Compiling src/mame/video/gatron.c...
Compiling src/mame/drivers/gotya.c...
Compiling src/mame/audio/gotya.c...
Compiling src/mame/video/gotya.c...
Compiling src/mame/drivers/sbugger.c...
Compiling src/mame/video/sbugger.c...
Compiling src/mame/drivers/exterm.c...
Compiling src/mame/video/exterm.c...
Compiling src/mame/drivers/gottlieb.c...
Compiling src/mame/audio/gottlieb.c...
Compiling src/mame/video/gottlieb.c...
Compiling src/mame/drivers/calchase.c...
Compiling src/mame/drivers/pangofun.c...
Compiling src/mame/drivers/pcat_dyn.c...
Compiling src/mame/drivers/pcat_nit.c...
Compiling src/mame/drivers/pcxt.c...
Compiling src/mame/drivers/quakeat.c...
Compiling src/mame/drivers/queen.c...
Compiling src/mame/drivers/igspc.c...
Compiling src/mame/drivers/cabaret.c...
Compiling src/mame/drivers/ddz.c...
Compiling src/mame/drivers/dunhuang.c...
Compiling src/mame/video/goldstar.c...
Compiling src/mame/drivers/jackie.c...
Compiling src/mame/drivers/igs009.c...
Compiling src/mame/drivers/igs011.c...
Compiling src/mame/drivers/igs017.c...
Compiling src/mame/drivers/igs_m027.c...
Compiling src/mame/drivers/iqblock.c...
Compiling src/mame/video/iqblock.c...
Compiling src/mame/drivers/lordgun.c...
Compiling src/mame/drivers/pgm.c...
Compiling src/mame/video/lordgun.c...
Compiling src/mame/video/pgm.c...
Compiling src/mame/drivers/pgm2.c...
Compiling src/mame/drivers/spoker.c...
Compiling src/mame/machine/pgmcrypt.c...
Compiling src/mame/machine/pgmprot.c...
Compiling src/mame/drivers/m10.c...
Compiling src/mame/video/m10.c...
Compiling src/mame/drivers/m14.c...
Compiling src/mame/drivers/m52.c...
Compiling src/mame/video/m52.c...
Compiling src/mame/drivers/m57.c...
Compiling src/mame/video/m57.c...
Compiling src/mame/drivers/m58.c...
Compiling src/mame/drivers/m62.c...
Compiling src/mame/video/m58.c...
Compiling src/mame/video/m62.c...
Compiling src/mame/drivers/m63.c...
Compiling src/mame/drivers/m72.c...
Compiling src/mame/audio/m72.c...
Compiling src/mame/video/m72.c...
Compiling src/mame/drivers/m90.c...
Compiling src/mame/video/m90.c...
Compiling src/mame/drivers/m92.c...
Compiling src/mame/video/m92.c...
Compiling src/mame/drivers/m107.c...
Compiling src/mame/video/m107.c...
Compiling src/mame/drivers/olibochu.c...
Compiling src/mame/drivers/redalert.c...
Compiling src/mame/audio/redalert.c...
Compiling src/mame/video/redalert.c...
Compiling src/mame/drivers/shisen.c...
Compiling src/mame/video/shisen.c...
Compiling src/mame/drivers/travrusa.c...
Compiling src/mame/video/travrusa.c...
Compiling src/mame/drivers/vigilant.c...
Compiling src/mame/video/vigilant.c...
Compiling src/mame/machine/irem_cpu.c...
Compiling src/mame/drivers/capbowl.c...
Compiling src/mame/audio/irem.c...
Compiling src/mame/video/capbowl.c...
Compiling src/mame/drivers/itech8.c...
Compiling src/mame/machine/slikshot.c...
Compiling src/mame/video/itech8.c...
Compiling src/mame/drivers/itech32.c...
Compiling src/mame/drivers/aeroboto.c...
Compiling src/mame/video/itech32.c...
Compiling src/mame/video/aeroboto.c...
Compiling src/mame/drivers/argus.c...
Compiling src/mame/video/argus.c...
Compiling src/mame/drivers/bestleag.c...
Compiling src/mame/drivers/bigstrkb.c...
Compiling src/mame/video/bigstrkb.c...
Compiling src/mame/drivers/blueprnt.c...
Compiling src/mame/video/blueprnt.c...
Compiling src/mame/drivers/bnstars.c...
Compiling src/mame/video/cischeat.c...
Compiling src/mame/drivers/citycon.c...
Compiling src/mame/video/citycon.c...
Compiling src/mame/drivers/ddayjlc.c...
Compiling src/mame/drivers/exerion.c...
Compiling src/mame/video/exerion.c...
Compiling src/mame/drivers/fcombat.c...
Compiling src/mame/video/fcombat.c...
Compiling src/mame/drivers/ginganin.c...
Compiling src/mame/video/ginganin.c...
Compiling src/mame/drivers/homerun.c...
Compiling src/mame/video/homerun.c...
Compiling src/mame/drivers/megasys1.c...
Compiling src/mame/video/megasys1.c...
Compiling src/mame/drivers/momoko.c...
Compiling src/mame/video/momoko.c...
Compiling src/mame/drivers/ms32.c...
Compiling src/mame/video/ms32.c...
Compiling src/mame/video/psychic5.c...
Compiling src/mame/drivers/psychic5.c...
Compiling src/mame/drivers/pturn.c...
Compiling src/mame/drivers/skyfox.c...
Compiling src/mame/video/skyfox.c...
Compiling src/mame/video/tetrisp2.c...
Compiling src/mame/machine/jalcrpt.c...
Compiling src/mame/video/jalblend.c...
Compiling src/mame/drivers/guab.c...
Compiling src/mame/drivers/jpmsys5.c...
Compiling src/mame/drivers/jpmmps.c...
Compiling src/mame/drivers/jpms80.c...
Compiling src/mame/video/jpmimpct.c...
Compiling src/mame/drivers/jpmimpct.c...
Compiling src/mame/drivers/pluto5.c...
Compiling src/mame/drivers/jpmsys7.c...
Compiling src/mame/video/airbustr.c...
Compiling src/mame/drivers/airbustr.c...
Compiling src/mame/drivers/djboy.c...
Compiling src/mame/video/djboy.c...
Compiling src/mame/drivers/expro02.c...
Compiling src/mame/drivers/galpanic.c...
Compiling src/mame/video/galpanic.c...
Compiling src/mame/drivers/galpani2.c...
Compiling src/mame/video/galpani2.c...
Compiling src/mame/drivers/galpani3.c...
Compiling src/mame/drivers/hvyunit.c...
Compiling src/mame/drivers/jchan.c...
Compiling src/mame/drivers/kaneko16.c...
Compiling src/mame/machine/kaneko16.c...
Compiling src/mame/video/kaneko16.c...
Compiling src/mame/drivers/sandscrp.c...
Compiling src/mame/drivers/suprnova.c...
Compiling src/mame/video/suprnova.c...
Compiling src/mame/video/sknsspr.c...
Compiling src/mame/drivers/88games.c...
Compiling src/mame/video/88games.c...
Compiling src/mame/drivers/ajax.c...
Compiling src/mame/machine/ajax.c...
Compiling src/mame/video/ajax.c...
Compiling src/mame/drivers/aliens.c...
Compiling src/mame/video/aliens.c...
Compiling src/mame/drivers/asterix.c...
Compiling src/mame/video/asterix.c...
Compiling src/mame/drivers/battlnts.c...
Compiling src/mame/video/battlnts.c...
Compiling src/mame/drivers/bishi.c...
Compiling src/mame/video/bishi.c...
Compiling src/mame/drivers/bladestl.c...
Compiling src/mame/video/bladestl.c...
Compiling src/mame/drivers/blockhl.c...
Compiling src/mame/video/blockhl.c...
Compiling src/mame/drivers/bottom9.c...
Compiling src/mame/video/bottom9.c...
Compiling src/mame/video/chqflag.c...
Compiling src/mame/drivers/circusc.c...
Compiling src/mame/video/circusc.c...
Compiling src/mame/drivers/cobra.c...
Compiling src/mame/drivers/combatsc.c...
Compiling src/mame/video/combatsc.c...
Compiling src/mame/drivers/contra.c...
Compiling src/mame/video/contra.c...
Compiling src/mame/drivers/crimfght.c...
Compiling src/mame/video/crimfght.c...
Compiling src/mame/drivers/dbz.c...
Compiling src/mame/video/dbz.c...
Compiling src/mame/drivers/ddribble.c...
Compiling src/mame/video/ddribble.c...
Compiling src/mame/drivers/djmain.c...
Compiling src/mame/video/djmain.c...
Compiling src/mame/drivers/fastfred.c...
Compiling src/mame/video/fastfred.c...
Compiling src/mame/drivers/fastlane.c...
Compiling src/mame/video/fastlane.c...
Compiling src/mame/drivers/finalizr.c...
Compiling src/mame/video/finalizr.c...
Compiling src/mame/drivers/flkatck.c...
Compiling src/mame/video/flkatck.c...
Compiling src/mame/drivers/gberet.c...
Compiling src/mame/video/gberet.c...
Compiling src/mame/drivers/gbusters.c...
Compiling src/mame/video/gbusters.c...
Compiling src/mame/drivers/gijoe.c...
Compiling src/mame/video/gijoe.c...
Compiling src/mame/drivers/gradius3.c...
Compiling src/mame/video/gradius3.c...
Compiling src/mame/drivers/gticlub.c...
Compiling src/mame/video/gticlub.c...
Compiling src/mame/drivers/gyruss.c...
Compiling src/mame/video/gyruss.c...
Compiling src/mame/drivers/hcastle.c...
Compiling src/mame/video/hcastle.c...
Compiling src/mame/drivers/hexion.c...
Compiling src/mame/video/hexion.c...
Compiling src/mame/drivers/hornet.c...
Compiling src/mame/machine/konppc.c...
Compiling src/mame/drivers/hyperspt.c...
Compiling src/mame/audio/hyprolyb.c...
Compiling src/mame/video/hyperspt.c...
Compiling src/mame/drivers/ironhors.c...
Compiling src/mame/video/ironhors.c...
Compiling src/mame/video/jackal.c...
Compiling src/mame/drivers/jackal.c...
Compiling src/mame/drivers/jailbrek.c...
Compiling src/mame/video/jailbrek.c...
Compiling src/mame/drivers/junofrst.c...
Compiling src/mame/drivers/konamigq.c...
Compiling src/mame/drivers/konamigv.c...
Compiling src/mame/drivers/konamigx.c...
Compiling src/mame/machine/konamigx.c...
Compiling src/mame/video/konamigx.c...
Compiling src/mame/drivers/konamim2.c...
Compiling src/mame/drivers/kongambl.c...
Compiling src/mame/drivers/konendev.c...
Compiling src/mame/drivers/ksys573.c...
Compiling src/mame/machine/zs01.c...
Compiling src/mame/drivers/labyrunr.c...
Compiling src/mame/video/labyrunr.c...
Compiling src/mame/drivers/lethal.c...
Compiling src/mame/video/lethal.c...
Compiling src/mame/drivers/mainevt.c...
Compiling src/mame/video/mainevt.c...
Compiling src/mame/drivers/megazone.c...
Compiling src/mame/video/megazone.c...
Compiling src/mame/drivers/mikie.c...
Compiling src/mame/video/mikie.c...
Compiling src/mame/drivers/mogura.c...
Compiling src/mame/drivers/moo.c...
Compiling src/mame/video/moo.c...
Compiling src/mame/drivers/mystwarr.c...
Compiling src/mame/video/mystwarr.c...
Compiling src/mame/drivers/nemesis.c...
Compiling src/mame/video/nemesis.c...
Compiling src/mame/drivers/nwk-tr.c...
Compiling src/mame/video/overdriv.c...
Compiling src/mame/drivers/pandoras.c...
Compiling src/mame/video/pandoras.c...
Compiling src/mame/drivers/parodius.c...
Compiling src/mame/video/parodius.c...
Compiling src/mame/drivers/pingpong.c...
Compiling src/mame/video/pingpong.c...
Compiling src/mame/drivers/plygonet.c...
Compiling src/mame/video/plygonet.c...
Compiling src/mame/drivers/pooyan.c...
Compiling src/mame/video/pooyan.c...
Compiling src/mame/drivers/qdrmfgp.c...
Compiling src/mame/video/qdrmfgp.c...
Compiling src/mame/drivers/rockrage.c...
Compiling src/mame/video/rockrage.c...
Compiling src/mame/drivers/rocnrope.c...
Compiling src/mame/video/rocnrope.c...
Compiling src/mame/drivers/rollerg.c...
Compiling src/mame/video/rollerg.c...
Compiling src/mame/drivers/rungun.c...
Compiling src/mame/video/rungun.c...
Compiling src/mame/drivers/sbasketb.c...
Compiling src/mame/drivers/scobra.c...
Compiling src/mame/video/sbasketb.c...
Compiling src/mame/drivers/scotrsht.c...
Compiling src/mame/drivers/scramble.c...
Compiling src/mame/video/scotrsht.c...
Compiling src/mame/machine/scramble.c...
Compiling src/mame/audio/scramble.c...
Compiling src/mame/drivers/shaolins.c...
Compiling src/mame/video/shaolins.c...
Compiling src/mame/drivers/simpsons.c...
Compiling src/mame/machine/simpsons.c...
Compiling src/mame/video/simpsons.c...
Compiling src/mame/drivers/spy.c...
Compiling src/mame/video/spy.c...
Compiling src/mame/drivers/surpratk.c...
Compiling src/mame/video/surpratk.c...
Compiling src/mame/drivers/tgtpanic.c...
Compiling src/mame/drivers/thunderx.c...
Compiling src/mame/video/thunderx.c...
Compiling src/mame/drivers/timeplt.c...
Compiling src/mame/audio/timeplt.c...
Compiling src/mame/video/timeplt.c...
Compiling src/mame/drivers/tmnt.c...
Compiling src/mame/video/tmnt.c...
Compiling src/mame/drivers/tp84.c...
Compiling src/mame/video/tp84.c...
Compiling src/mame/drivers/trackfld.c...
Compiling src/mame/machine/konami1.c...
Compiling src/mame/audio/trackfld.c...
Compiling src/mame/video/trackfld.c...
Compiling src/mame/drivers/tutankhm.c...
Compiling src/mame/video/tutankhm.c...
Compiling src/mame/drivers/twin16.c...
Compiling src/mame/video/twin16.c...
Compiling src/mame/drivers/ultrsprt.c...
Compiling src/mame/drivers/twinkle.c...
Compiling src/mame/drivers/ultraman.c...
Compiling src/mame/video/ultraman.c...
Compiling src/mame/drivers/vendetta.c...
Compiling src/mame/video/vendetta.c...
Compiling src/mame/drivers/viper.c...
Compiling src/mame/video/wecleman.c...
Compiling src/mame/drivers/xexex.c...
Compiling src/mame/video/xexex.c...
Compiling src/mame/drivers/xmen.c...
Compiling src/mame/video/xmen.c...
Compiling src/mame/drivers/yiear.c...
Compiling src/mame/video/yiear.c...
Compiling src/mame/drivers/zr107.c...
Compiling src/mame/video/konamiic.c...
Compiling src/mame/video/konicdev.c...
Compiling src/mame/drivers/maygay1b.c...
Compiling src/mame/drivers/maygayv1.c...
Compiling src/mame/drivers/maygayep.c...
Compiling src/mame/drivers/mmm.c...
Compiling src/mame/drivers/maygaysw.c...
Compiling src/mame/video/lazercmd.c...
Compiling src/mame/audio/meadows.c...
Compiling src/mame/video/meadows.c...
Compiling src/mame/drivers/warpsped.c...
Compiling src/mame/drivers/merit.c...
Compiling src/mame/drivers/hyprduel.c...
Compiling src/mame/drivers/meritm.c...
Compiling src/mame/video/hyprduel.c...
Compiling src/mame/drivers/metro.c...
Compiling src/mame/video/metro.c...
Compiling src/mame/drivers/rabbit.c...
Compiling src/mame/drivers/tmmjprd.c...
Compiling src/mame/drivers/wallc.c...
Compiling src/mame/drivers/wink.c...
Compiling src/mame/audio/8080bw.c...
Compiling src/mame/video/8080bw.c...
Compiling src/mame/drivers/m79amb.c...
Compiling src/mame/audio/m79amb.c...
Compiling src/mame/machine/mw8080bw.c...
Compiling src/mame/audio/mw8080bw.c...
Compiling src/mame/video/mw8080bw.c...
Compiling src/mame/drivers/rotaryf.c...
Compiling src/mame/video/sspeedr.c...
Compiling src/mame/video/astrocde.c...
Compiling src/mame/machine/balsente.c...
Compiling src/mame/video/balsente.c...
Compiling src/mame/drivers/gridlee.c...
Compiling src/mame/audio/gridlee.c...
Compiling src/mame/drivers/mcr.c...
Compiling src/mame/video/gridlee.c...
Compiling src/mame/machine/mcr.c...
Compiling src/mame/audio/mcr.c...
Compiling src/mame/video/mcr.c...
Compiling src/mame/video/mcr3.c...
Compiling src/mame/drivers/mcr68.c...
Compiling src/mame/machine/mcr68.c...
Compiling src/mame/video/mcr68.c...
Compiling src/mame/drivers/midqslvr.c...
Compiling src/mame/drivers/midtunit.c...
Compiling src/mame/machine/midtunit.c...
Compiling src/mame/video/midtunit.c...
Compiling src/mame/drivers/midvunit.c...
Compiling src/mame/video/midvunit.c...
Compiling src/mame/drivers/midwunit.c...
Compiling src/mame/machine/midwunit.c...
Compiling src/mame/drivers/midxunit.c...
Compiling src/mame/machine/midxunit.c...
Compiling src/mame/drivers/midyunit.c...
Compiling src/mame/machine/midyunit.c...
Compiling src/mame/video/midyunit.c...
Compiling src/mame/video/midzeus.c...
Compiling src/mame/video/midzeus2.c...
Compiling src/mame/drivers/omegrace.c...
Compiling src/mame/drivers/seattle.c...
Compiling src/mame/drivers/tmaster.c...
Compiling src/mame/drivers/vegas.c...
Compiling src/mame/drivers/williams.c...
Compiling src/mame/machine/williams.c...
Compiling src/mame/audio/williams.c...
Compiling src/mame/video/williams.c...
Compiling src/mame/machine/midwayic.c...
Compiling src/mame/audio/dcs.c...
Compiling src/mame/audio/gorf.c...
Compiling src/mame/drivers/20pacgal.c...
Compiling src/mame/audio/wow.c...
Compiling src/mame/video/20pacgal.c...
Compiling src/mame/drivers/baraduke.c...
Compiling src/mame/video/baraduke.c...
Compiling src/mame/drivers/dambustr.c...
Compiling src/mame/drivers/gal3.c...
Compiling src/mame/drivers/galaga.c...
Compiling src/mame/audio/galaga.c...
Compiling src/mame/video/galaga.c...
Compiling src/mame/drivers/galaxian.c...
Compiling src/mame/audio/galaxian.c...
Compiling src/mame/video/galaxian.c...
Compiling src/mame/drivers/galaxold.c...
Compiling src/mame/machine/galaxold.c...
Compiling src/mame/video/galaxold.c...
Compiling src/mame/drivers/gaplus.c...
Compiling src/mame/machine/gaplus.c...
Compiling src/mame/video/gaplus.c...
Compiling src/mame/drivers/kungfur.c...
Compiling src/mame/drivers/mappy.c...
Compiling src/mame/video/mappy.c...
Compiling src/mame/video/namcofl.c...
Compiling src/mame/drivers/namcoic.c...
Compiling src/mame/drivers/namcona1.c...
Compiling src/mame/video/namcona1.c...
Compiling src/mame/drivers/namconb1.c...
Compiling src/mame/video/namconb1.c...
Compiling src/mame/drivers/namcond1.c...
Compiling src/mame/machine/namcond1.c...
Compiling src/mame/video/ygv608.c...
Compiling src/mame/drivers/namcops2.c...
Compiling src/mame/drivers/namcos1.c...
Compiling src/mame/machine/namcos1.c...
Compiling src/mame/video/namcos1.c...
Compiling src/mame/drivers/namcos10.c...
Compiling src/mame/drivers/namcos11.c...
Compiling src/mame/drivers/namcos12.c...
Compiling src/mame/machine/namcos2.c...
Compiling src/mame/video/namcos2.c...
Compiling src/mame/drivers/namcos21.c...
Compiling src/mame/video/namcos21.c...
Compiling src/mame/drivers/namcos22.c...
Compiling src/mame/video/namcos22.c...
Compiling src/mame/drivers/namcos23.c...
Compiling src/mame/drivers/namcos86.c...
Compiling src/mame/video/namcos86.c...
Compiling src/mame/drivers/pacland.c...
Compiling src/mame/video/pacland.c...
Compiling src/mame/audio/polepos.c...
Compiling src/mame/video/polepos.c...
Compiling src/mame/drivers/rallyx.c...
Compiling src/mame/video/rallyx.c...
Compiling src/mame/drivers/skykid.c...
Compiling src/mame/video/skykid.c...
Compiling src/mame/video/tankbatt.c...
Compiling src/mame/drivers/tankbatt.c...
Compiling src/mame/video/tceptor.c...
Compiling src/mame/drivers/toypop.c...
Compiling src/mame/video/toypop.c...
Compiling src/mame/drivers/turrett.c...
Compiling src/mame/audio/geebee.c...
Compiling src/mame/audio/warpwarp.c...
Compiling src/mame/video/warpwarp.c...
Compiling src/mame/machine/namcoio.c...
Compiling src/mame/machine/namco06.c...
Compiling src/mame/machine/namco50.c...
Compiling src/mame/machine/namco51.c...
Compiling src/mame/machine/namco53.c...
Compiling src/mame/machine/namco62.c...
Compiling src/mame/audio/namco52.c...
Compiling src/mame/audio/namco54.c...
Compiling src/mame/video/bosco.c...
Compiling src/mame/video/digdug.c...
Compiling src/mame/machine/xevious.c...
Compiling src/mame/video/xevious.c...
Compiling src/mame/drivers/crgolf.c...
Compiling src/mame/drivers/suprgolf.c...
Compiling src/mame/video/crgolf.c...
Compiling src/mame/video/neogeo.c...
Compiling src/mame/machine/neoboot.c...
Compiling src/mame/machine/neocrypt.c...
Compiling src/mame/machine/neoprot.c...
Compiling src/mame/drivers/armedf.c...
Compiling src/mame/video/armedf.c...
Compiling src/mame/drivers/cclimber.c...
Compiling src/mame/machine/cclimber.c...
Compiling src/mame/audio/cclimber.c...
Compiling src/mame/video/cclimber.c...
Compiling src/mame/drivers/clshroad.c...
Compiling src/mame/video/clshroad.c...
Compiling src/mame/drivers/csplayh5.c...
Compiling src/mame/drivers/cop01.c...
Compiling src/mame/video/cop01.c...
Compiling src/mame/drivers/dacholer.c...
Compiling src/mame/drivers/galivan.c...
Compiling src/mame/video/galivan.c...
Compiling src/mame/drivers/gomoku.c...
Compiling src/mame/audio/gomoku.c...
Compiling src/mame/video/gomoku.c...
Compiling src/mame/video/hyhoo.c...
Compiling src/mame/drivers/hyhoo.c...
Compiling src/mame/drivers/jangou.c...
Compiling src/mame/drivers/magmax.c...
Compiling src/mame/video/magmax.c...
Compiling src/mame/video/nbmj8688.c...
Compiling src/mame/drivers/nbmj8891.c...
Compiling src/mame/video/nbmj8891.c...
Compiling src/mame/drivers/nbmj8900.c...
Compiling src/mame/video/nbmj8900.c...
Compiling src/mame/drivers/nbmj8991.c...
Compiling src/mame/video/nbmj8991.c...
Compiling src/mame/drivers/nbmj9195.c...
Compiling src/mame/video/nbmj9195.c...
Compiling src/mame/drivers/niyanpai.c...
Compiling src/mame/drivers/nightgal.c...
Compiling src/mame/machine/m68kfmly.c...
Compiling src/mame/video/niyanpai.c...
Compiling src/mame/drivers/pastelg.c...
Compiling src/mame/video/pastelg.c...
Compiling src/mame/drivers/seicross.c...
Compiling src/mame/video/seicross.c...
Compiling src/mame/video/terracre.c...
Compiling src/mame/drivers/terracre.c...
Compiling src/mame/drivers/tubep.c...
Compiling src/mame/video/tubep.c...
Compiling src/mame/drivers/wiping.c...
Compiling src/mame/audio/wiping.c...
Compiling src/mame/video/wiping.c...
Compiling src/mame/machine/nb1413m3.c...
Compiling src/mame/machine/nb1414m4.c...
Compiling src/mame/drivers/cham24.c...
Compiling src/mame/drivers/dkong.c...
Compiling src/mame/audio/dkong.c...
Compiling src/mame/video/dkong.c...
Compiling src/mame/drivers/mario.c...
Compiling src/mame/audio/mario.c...
Compiling src/mame/video/mario.c...
Compiling src/mame/drivers/multigam.c...
Compiling src/mame/drivers/n8080.c...
Compiling src/mame/audio/n8080.c...
Compiling src/mame/video/n8080.c...
Compiling src/mame/drivers/nss.c...
Compiling src/mame/machine/snes.c...
Compiling src/mame/audio/snes_snd.c...
Compiling src/mame/video/snes.c...
Compiling src/mame/drivers/playch10.c...
Compiling src/mame/machine/playch10.c...
Compiling src/mame/video/playch10.c...
Compiling src/mame/drivers/popeye.c...
Compiling src/mame/video/popeye.c...
Compiling src/mame/drivers/punchout.c...
Compiling src/mame/video/punchout.c...
Compiling src/mame/drivers/famibox.c...
Compiling src/mame/drivers/sfcbox.c...
Compiling src/mame/drivers/snesb.c...
Compiling src/mame/drivers/spacefb.c...
Compiling src/mame/audio/spacefb.c...
Compiling src/mame/video/spacefb.c...
Compiling src/mame/drivers/vsnes.c...
Compiling src/mame/machine/vsnes.c...
Compiling src/mame/video/vsnes.c...
Compiling src/mame/video/ppu2c0x.c...
Compiling src/mame/drivers/fitfight.c...
Compiling src/mame/video/fitfight.c...
Compiling src/mame/drivers/pirates.c...
Compiling src/mame/video/pirates.c...
Compiling src/mame/drivers/acommand.c...
Compiling src/mame/drivers/cultures.c...
Compiling src/mame/drivers/ddealer.c...
Compiling src/mame/drivers/jalmah.c...
Compiling src/mame/drivers/macrossp.c...
Compiling src/mame/video/macrossp.c...
Compiling src/mame/drivers/nmk16.c...
Compiling src/mame/machine/nmk004.c...
Compiling src/mame/video/nmk16.c...
Compiling src/mame/drivers/quizdna.c...
Compiling src/mame/drivers/quizpani.c...
Compiling src/mame/video/quizdna.c...
Compiling src/mame/video/quizpani.c...
Compiling src/mame/drivers/battlex.c...
Compiling src/mame/video/battlex.c...
Compiling src/mame/drivers/carjmbre.c...
Compiling src/mame/video/carjmbre.c...
Compiling src/mame/drivers/popper.c...
Compiling src/mame/video/popper.c...
Compiling src/mame/drivers/spaceg.c...
Compiling src/mame/drivers/dday.c...
Compiling src/mame/video/dday.c...
Compiling src/mame/drivers/monzagp.c...
Compiling src/mame/drivers/portrait.c...
Compiling src/mame/video/portrait.c...
Compiling src/mame/drivers/vega.c...
Compiling src/mame/drivers/espial.c...
Compiling src/mame/video/espial.c...
Compiling src/mame/drivers/funkybee.c...
Compiling src/mame/video/funkybee.c...
Compiling src/mame/drivers/marineb.c...
Compiling src/mame/video/marineb.c...
Compiling src/mame/drivers/vastar.c...
Compiling src/mame/video/vastar.c...
Compiling src/mame/drivers/zodiack.c...
Compiling src/mame/video/zodiack.c...
Compiling src/mame/video/mrflea.c...
Compiling src/mame/drivers/mrflea.c...
Compiling src/mame/drivers/thief.c...
Compiling src/mame/drivers/jrpacman.c...
Compiling src/mame/video/thief.c...
Compiling src/mame/drivers/pacman.c...
Compiling src/mame/video/pacman.c...
Compiling src/mame/drivers/pengo.c...
Compiling src/mame/machine/acitya.c...
Compiling src/mame/machine/jumpshot.c...
Compiling src/mame/machine/pacplus.c...
Compiling src/mame/machine/theglobp.c...
Compiling src/mame/drivers/ggconnie.c...
Compiling src/mame/drivers/paranoia.c...
Compiling src/mame/drivers/tourvis.c...
Compiling src/mame/drivers/uapce.c...
Compiling src/mame/machine/pcecommn.c...
Compiling src/mame/video/vdc.c...
Compiling src/mame/drivers/naughtyb.c...
Compiling src/mame/video/naughtyb.c...
Compiling src/mame/drivers/phoenix.c...
Compiling src/mame/audio/phoenix.c...
Compiling src/mame/video/phoenix.c...
Compiling src/mame/drivers/safarir.c...
Compiling src/mame/audio/pleiads.c...
Compiling src/mame/drivers/drtomy.c...
Compiling src/mame/drivers/playmark.c...
Compiling src/mame/video/playmark.c...
Compiling src/mame/drivers/powerbal.c...
Compiling src/mame/video/sderby.c...
Compiling src/mame/drivers/sslam.c...
Compiling src/mame/video/sslam.c...
Compiling src/mame/video/psikyo.c...
Compiling src/mame/drivers/psikyo.c...
Compiling src/mame/drivers/psikyo4.c...
Compiling src/mame/video/psikyo4.c...
Compiling src/mame/drivers/psikyosh.c...
Compiling src/mame/video/psikyosh.c...
Compiling src/mame/drivers/hitme.c...
Compiling src/mame/audio/hitme.c...
Compiling src/mame/drivers/starcrus.c...
Compiling src/mame/video/starcrus.c...
Compiling src/mame/drivers/btoads.c...
Compiling src/mame/drivers/kinst.c...
Compiling src/mame/drivers/xtheball.c...
Compiling src/mame/video/btoads.c...
Compiling src/mame/video/appoooh.c...
Compiling src/mame/drivers/appoooh.c...
Compiling src/mame/drivers/bankp.c...
Compiling src/mame/video/bankp.c...
Compiling src/mame/drivers/chinsan.c...
Compiling src/mame/drivers/drmicro.c...
Compiling src/mame/video/drmicro.c...
Compiling src/mame/drivers/jantotsu.c...
Compiling src/mame/drivers/mayumi.c...
Compiling src/mame/drivers/mermaid.c...
Compiling src/mame/video/mermaid.c...
Compiling src/mame/drivers/mjkjidai.c...
Compiling src/mame/video/mjkjidai.c...
Compiling src/mame/drivers/angelkds.c...
Compiling src/mame/video/angelkds.c...
Compiling src/mame/drivers/bingoc.c...
Compiling src/mame/audio/blockade.c...
Compiling src/mame/video/blockade.c...
Compiling src/mame/drivers/calorie.c...
Compiling src/mame/drivers/chihiro.c...
Compiling src/mame/drivers/coolridr.c...
Compiling src/mame/drivers/deniam.c...
Compiling src/mame/video/deniam.c...
Compiling src/mame/drivers/dotrikun.c...
Compiling src/mame/video/genesis.c...
Compiling src/mame/drivers/gpworld.c...
Compiling src/mame/drivers/hikaru.c...
Compiling src/mame/drivers/hshavoc.c...
Compiling src/mame/drivers/kopunch.c...
Compiling src/mame/machine/megadriv.c...
Compiling src/mame/video/kopunch.c...
Compiling src/mame/machine/md_cart.c...
Compiling src/mame/drivers/megadrvb.c...
Compiling src/mame/drivers/megaplay.c...
Compiling src/mame/drivers/megatech.c...
Compiling src/mame/drivers/model1.c...
Compiling src/mame/machine/model1.c...
Compiling src/mame/video/model1.c...
Compiling src/mame/audio/dsbz80.c...
Compiling src/mame/drivers/model2.c...
Compiling src/mame/video/model2.c...
Compiling src/mame/drivers/model3.c...
Compiling src/mame/video/model3.c...
Compiling src/mame/machine/model3.c...
Compiling src/mame/drivers/naomi.c...
Compiling src/mame/machine/dc.c...
Compiling src/mame/video/dc.c...
Compiling src/mame/machine/naomi.c...
Compiling src/mame/machine/naomig1.c...
Compiling src/mame/machine/naomibd.c...
Compiling src/mame/machine/naomirom.c...
Compiling src/mame/machine/naomigd.c...
Compiling src/mame/machine/naomim1.c...
Compiling src/mame/machine/naomim2.c...
Compiling src/mame/machine/naomim4.c...
Compiling src/mame/machine/awboard.c...
Compiling src/mame/machine/mie.c...
Compiling src/mame/machine/maple-dc.c...
Compiling src/mame/machine/mapledev.c...
Compiling src/mame/machine/dc-ctrl.c...
Compiling src/mame/machine/jvs13551.c...
Compiling src/mame/drivers/puckpkmn.c...
Compiling src/mame/drivers/triforce.c...
Compiling src/mame/drivers/segac2.c...
Compiling src/mame/drivers/segae.c...
Compiling src/mame/machine/segamsys.c...
Compiling src/mame/drivers/shtzone.c...
Compiling src/mame/drivers/segag80r.c...
Compiling src/mame/machine/segag80.c...
Compiling src/mame/audio/segag80r.c...
Compiling src/mame/video/segag80r.c...
Compiling src/mame/drivers/segag80v.c...
Compiling src/mame/audio/segag80v.c...
Compiling src/mame/video/segag80v.c...
Compiling src/mame/drivers/segahang.c...
Compiling src/mame/video/segahang.c...
Compiling src/mame/drivers/segajw.c...
Compiling src/mame/drivers/segald.c...
Compiling src/mame/video/segaorun.c...
Compiling src/mame/drivers/segas16a.c...
Compiling src/mame/video/segas16a.c...
Compiling src/mame/drivers/segas16b.c...
Compiling src/mame/video/segas16b.c...
Compiling src/mame/drivers/segas18.c...
Compiling src/mame/video/segas18.c...
Compiling src/mame/drivers/segas24.c...
Compiling src/mame/video/segas24.c...
Compiling src/mame/machine/segas32.c...
Compiling src/mame/video/segas32.c...
Compiling src/mame/drivers/segaxbd.c...
Compiling src/mame/video/segaxbd.c...
Compiling src/mame/video/segaybd.c...
Compiling src/mame/drivers/sg1000a.c...
Compiling src/mame/video/stactics.c...
Compiling src/mame/drivers/saturn.c...
Compiling src/mame/machine/stvprot.c...
Compiling src/mame/machine/stvcd.c...
Compiling src/mame/machine/smpc.c...
Compiling src/mame/video/stvvdp1.c...
Compiling src/mame/video/stvvdp2.c...
Compiling src/mame/drivers/suprloco.c...
Compiling src/mame/video/suprloco.c...
Compiling src/mame/drivers/system1.c...
Compiling src/mame/video/system1.c...
Compiling src/mame/drivers/system16.c...
Compiling src/mame/video/system16.c...
Compiling src/mame/drivers/timetrv.c...
Compiling src/mame/audio/turbo.c...
Compiling src/mame/video/turbo.c...
Compiling src/mame/audio/vicdual.c...
Compiling src/mame/video/vicdual.c...
Compiling src/mame/drivers/zaxxon.c...
Compiling src/mame/audio/zaxxon.c...
Compiling src/mame/video/zaxxon.c...
Compiling src/mame/machine/fd1089.c...
Compiling src/mame/machine/fd1094.c...
Compiling src/mame/machine/fddebug.c...
Compiling src/mame/machine/mc8123.c...
Compiling src/mame/machine/s16fd.c...
Compiling src/mame/machine/s24fd.c...
Compiling src/mame/machine/scudsp.c...
Compiling src/mame/machine/segaic16.c...
Compiling src/mame/audio/carnival.c...
Compiling src/mame/audio/depthch.c...
Compiling src/mame/audio/invinco.c...
Compiling src/mame/audio/pulsar.c...
Compiling src/mame/video/segaic16.c...
Compiling src/mame/audio/segasnd.c...
Compiling src/mame/video/sega16sp.c...
Compiling src/mame/video/segaic24.c...
Compiling src/mame/machine/gdrom.c...
Compiling src/mame/drivers/bloodbro.c...
Compiling src/mame/video/bloodbro.c...
Compiling src/mame/drivers/cabal.c...
Compiling src/mame/video/cabal.c...
Compiling src/mame/drivers/cshooter.c...
Compiling src/mame/drivers/dcon.c...
Compiling src/mame/video/dcon.c...
Compiling src/mame/drivers/deadang.c...
Compiling src/mame/video/deadang.c...
Compiling src/mame/drivers/dynduke.c...
Compiling src/mame/video/dynduke.c...
Compiling src/mame/drivers/feversoc.c...
Compiling src/mame/drivers/goal92.c...
Compiling src/mame/video/goal92.c...
Compiling src/mame/drivers/goodejan.c...
Compiling src/mame/drivers/kncljoe.c...
Compiling src/mame/video/kncljoe.c...
Compiling src/mame/drivers/legionna.c...
Compiling src/mame/video/legionna.c...
Compiling src/mame/video/mustache.c...
Compiling src/mame/drivers/mustache.c...
Compiling src/mame/drivers/panicr.c...
Compiling src/mame/drivers/raiden.c...
Compiling src/mame/video/raiden.c...
Compiling src/mame/drivers/raiden2.c...
Compiling src/mame/machine/r2crypt.c...
Compiling src/mame/drivers/r2dx_v33.c...
Compiling src/mame/drivers/seibuspi.c...
Compiling src/mame/machine/seibuspi.c...
Compiling src/mame/video/seibuspi.c...
Compiling src/mame/drivers/sengokmj.c...
Compiling src/mame/drivers/stfight.c...
Compiling src/mame/machine/stfight.c...
Compiling src/mame/video/stfight.c...
Compiling src/mame/drivers/toki.c...
Compiling src/mame/video/toki.c...
Compiling src/mame/drivers/wiz.c...
Compiling src/mame/video/wiz.c...
Compiling src/mame/machine/seicop.c...
Compiling src/mame/machine/spisprit.c...
Compiling src/mame/audio/seibu.c...
Compiling src/mame/video/sei_crtc.c...
Compiling src/mame/drivers/aleck64.c...
Compiling src/mame/machine/n64.c...
Compiling src/mame/video/n64.c...
Compiling src/mame/video/rdpblend.c...
Compiling src/mame/video/rdpfb.c...
Compiling src/mame/video/rdpspn16.c...
Compiling src/mame/video/rdptpipe.c...
Compiling src/mame/drivers/darkhors.c...
Compiling src/mame/drivers/hanaawas.c...
Compiling src/mame/video/hanaawas.c...
Compiling src/mame/drivers/macs.c...
Compiling src/mame/drivers/seta.c...
Compiling src/mame/video/seta.c...
Compiling src/mame/drivers/seta2.c...
Compiling src/mame/video/seta2.c...
Compiling src/mame/drivers/speedatk.c...
Compiling src/mame/video/speedatk.c...
Compiling src/mame/drivers/speglsht.c...
Compiling src/mame/drivers/srmp2.c...
Compiling src/mame/video/srmp2.c...
Compiling src/mame/drivers/srmp5.c...
Compiling src/mame/drivers/srmp6.c...
Compiling src/mame/drivers/ssv.c...
Compiling src/mame/video/ssv.c...
Compiling src/mame/drivers/st0016.c...
Compiling src/mame/video/st0016.c...
Compiling src/mame/video/seta001.c...
Compiling src/mame/drivers/nyny.c...
Compiling src/mame/drivers/r2dtank.c...
Compiling src/mame/drivers/sigmab52.c...
Compiling src/mame/drivers/sigmab98.c...
Compiling src/mame/drivers/spiders.c...
Compiling src/mame/audio/spiders.c...
Compiling src/mame/drivers/bbusters.c...
Compiling src/mame/drivers/sub.c...
Compiling src/mame/video/bbusters.c...
Compiling src/mame/drivers/dmndrby.c...
Compiling src/mame/drivers/hng64.c...
Compiling src/mame/video/hng64.c...
Compiling src/mame/drivers/lasso.c...
Compiling src/mame/video/lasso.c...
Compiling src/mame/drivers/mainsnk.c...
Compiling src/mame/video/mainsnk.c...
Compiling src/mame/drivers/munchmo.c...
Compiling src/mame/video/munchmo.c...
Compiling src/mame/drivers/prehisle.c...
Compiling src/mame/video/prehisle.c...
Compiling src/mame/drivers/snk6502.c...
Compiling src/mame/audio/snk6502.c...
Compiling src/mame/video/snk6502.c...
Compiling src/mame/drivers/snk.c...
Compiling src/mame/video/snk.c...
Compiling src/mame/drivers/snk68.c...
Compiling src/mame/video/snk68.c...
Compiling src/mame/drivers/zn.c...
Compiling src/mame/machine/znsec.c...
Compiling src/mame/machine/psx.c...
Compiling src/mame/drivers/astinvad.c...
Compiling src/mame/drivers/berzerk.c...
Compiling src/mame/drivers/cliffhgr.c...
Compiling src/mame/audio/cliffhgr.c...
Compiling src/mame/drivers/mazerbla.c...
Compiling src/mame/drivers/supdrapo.c...
Compiling src/mame/drivers/lastfght.c...
Compiling src/mame/drivers/subsino2.c...
Compiling src/mame/machine/subsino.c...
Compiling src/mame/drivers/arabian.c...
Compiling src/mame/video/arabian.c...
Compiling src/mame/drivers/dai3wksi.c...
Compiling src/mame/drivers/ikki.c...
Compiling src/mame/video/ikki.c...
Compiling src/mame/drivers/kangaroo.c...
Compiling src/mame/video/kangaroo.c...
Compiling src/mame/drivers/markham.c...
Compiling src/mame/video/markham.c...
Compiling src/mame/drivers/route16.c...
Compiling src/mame/video/route16.c...
Compiling src/mame/drivers/shanghai.c...
Compiling src/mame/drivers/shangha3.c...
Compiling src/mame/video/shangha3.c...
Compiling src/mame/drivers/strnskil.c...
Compiling src/mame/video/strnskil.c...
Compiling src/mame/drivers/tonton.c...
Compiling src/mame/drivers/go2000.c...
Compiling src/mame/drivers/goindol.c...
Compiling src/mame/video/goindol.c...
Compiling src/mame/drivers/suna8.c...
Compiling src/mame/audio/suna8.c...
Compiling src/mame/video/suna8.c...
Compiling src/mame/drivers/suna16.c...
Compiling src/mame/video/suna16.c...
Compiling src/mame/drivers/2mindril.c...
Compiling src/mame/drivers/40love.c...
Compiling src/mame/video/40love.c...
Compiling src/mame/drivers/arkanoid.c...
Compiling src/mame/machine/arkanoid.c...
Compiling src/mame/video/arkanoid.c...
Compiling src/mame/drivers/ashnojoe.c...
Compiling src/mame/video/ashnojoe.c...
Compiling src/mame/drivers/asuka.c...
Compiling src/mame/machine/bonzeadv.c...
Compiling src/mame/video/asuka.c...
Compiling src/mame/drivers/bigevglf.c...
Compiling src/mame/machine/bigevglf.c...
Compiling src/mame/video/bigevglf.c...
Compiling src/mame/drivers/bking.c...
Compiling src/mame/video/bking.c...
Compiling src/mame/drivers/bublbobl.c...
Compiling src/mame/machine/bublbobl.c...
Compiling src/mame/video/bublbobl.c...
Compiling src/mame/machine/buggychl.c...
Compiling src/mame/video/buggychl.c...
Compiling src/mame/drivers/cchance.c...
Compiling src/mame/drivers/chaknpop.c...
Compiling src/mame/machine/chaknpop.c...
Compiling src/mame/video/chaknpop.c...
Compiling src/mame/drivers/champbwl.c...
Compiling src/mame/video/changela.c...
Compiling src/mame/video/crbaloon.c...
Compiling src/mame/drivers/crbaloon.c...
Compiling src/mame/audio/crbaloon.c...
Compiling src/mame/drivers/cyclemb.c...
Compiling src/mame/video/darius.c...
Compiling src/mame/drivers/darkmist.c...
Compiling src/mame/video/darkmist.c...
Compiling src/mame/drivers/exzisus.c...
Compiling src/mame/video/exzisus.c...
Compiling src/mame/drivers/fgoal.c...
Compiling src/mame/video/fgoal.c...
Compiling src/mame/drivers/flstory.c...
Compiling src/mame/machine/flstory.c...
Compiling src/mame/video/flstory.c...
Compiling src/mame/drivers/galastrm.c...
Compiling src/mame/video/galastrm.c...
Compiling src/mame/drivers/gladiatr.c...
Compiling src/mame/video/gladiatr.c...
Compiling src/mame/audio/grchamp.c...
Compiling src/mame/video/grchamp.c...
Compiling src/mame/drivers/groundfx.c...
Compiling src/mame/video/groundfx.c...
Compiling src/mame/drivers/gsword.c...
Compiling src/mame/machine/tait8741.c...
Compiling src/mame/video/gsword.c...
Compiling src/mame/drivers/gunbustr.c...
Compiling src/mame/video/gunbustr.c...
Compiling src/mame/drivers/halleys.c...
Compiling src/mame/drivers/jollyjgr.c...
Compiling src/mame/drivers/ksayakyu.c...
Compiling src/mame/video/ksayakyu.c...
Compiling src/mame/drivers/lgp.c...
Compiling src/mame/drivers/lkage.c...
Compiling src/mame/machine/lkage.c...
Compiling src/mame/video/lkage.c...
Compiling src/mame/drivers/lsasquad.c...
Compiling src/mame/video/lsasquad.c...
Compiling src/mame/machine/lsasquad.c...
Compiling src/mame/drivers/marinedt.c...
Compiling src/mame/drivers/mexico86.c...
Compiling src/mame/machine/mexico86.c...
Compiling src/mame/video/mexico86.c...
Compiling src/mame/drivers/minivadr.c...
Compiling src/mame/drivers/missb2.c...
Compiling src/mame/drivers/mlanding.c...
Compiling src/mame/drivers/msisaac.c...
Compiling src/mame/video/msisaac.c...
Compiling src/mame/drivers/ninjaw.c...
Compiling src/mame/video/ninjaw.c...
Compiling src/mame/drivers/nycaptor.c...
Compiling src/mame/machine/nycaptor.c...
Compiling src/mame/video/nycaptor.c...
Compiling src/mame/drivers/opwolf.c...
Compiling src/mame/machine/opwolf.c...
Compiling src/mame/video/opwolf.c...
Compiling src/mame/drivers/othunder.c...
Compiling src/mame/video/othunder.c...
Compiling src/mame/drivers/pitnrun.c...
Compiling src/mame/machine/pitnrun.c...
Compiling src/mame/video/pitnrun.c...
Compiling src/mame/machine/qix.c...
Compiling src/mame/audio/qix.c...
Compiling src/mame/video/qix.c...
Compiling src/mame/drivers/rainbow.c...
Compiling src/mame/machine/rainbow.c...
Compiling src/mame/drivers/rastan.c...
Compiling src/mame/video/rainbow.c...
Compiling src/mame/video/rastan.c...
Compiling src/mame/drivers/retofinv.c...
Compiling src/mame/machine/retofinv.c...
Compiling src/mame/video/retofinv.c...
Compiling src/mame/drivers/rollrace.c...
Compiling src/mame/video/rollrace.c...
Compiling src/mame/drivers/sbowling.c...
Compiling src/mame/drivers/slapshot.c...
Compiling src/mame/video/slapshot.c...
Compiling src/mame/drivers/ssrj.c...
Compiling src/mame/video/ssrj.c...
Compiling src/mame/video/superchs.c...
Compiling src/mame/drivers/superqix.c...
Compiling src/mame/video/superqix.c...
Compiling src/mame/drivers/taito_b.c...
Compiling src/mame/video/taito_b.c...
Compiling src/mame/drivers/taito_f2.c...
Compiling src/mame/video/taito_f2.c...
Compiling src/mame/drivers/taito_f3.c...
Compiling src/mame/video/taito_f3.c...
Compiling src/mame/audio/taito_en.c...
Compiling src/mame/drivers/taito_h.c...
Compiling src/mame/video/taito_h.c...
Compiling src/mame/drivers/taito_l.c...
Compiling src/mame/video/taito_l.c...
Compiling src/mame/drivers/taito_x.c...
Compiling src/mame/machine/cchip.c...
Compiling src/mame/video/taito_z.c...
Compiling src/mame/drivers/taito_o.c...
Compiling src/mame/video/taito_o.c...
Compiling src/mame/drivers/taitoair.c...
Compiling src/mame/video/taitoair.c...
Compiling src/mame/drivers/taitogn.c...
Compiling src/mame/drivers/taitojc.c...
Compiling src/mame/video/taitojc.c...
Compiling src/mame/drivers/taitopjc.c...
Compiling src/mame/drivers/taitosj.c...
Compiling src/mame/machine/taitosj.c...
Compiling src/mame/video/taitosj.c...
Compiling src/mame/drivers/taitotz.c...
Compiling src/mame/drivers/taitowlf.c...
Compiling src/mame/machine/tnzs.c...
Compiling src/mame/drivers/tnzs.c...
Compiling src/mame/video/tnzs.c...
Compiling src/mame/drivers/tsamurai.c...
Compiling src/mame/video/topspeed.c...
Compiling src/mame/video/tsamurai.c...
Compiling src/mame/video/undrfire.c...
Compiling src/mame/drivers/volfied.c...
Compiling src/mame/machine/volfied.c...
Compiling src/mame/video/volfied.c...
Compiling src/mame/drivers/warriorb.c...
Compiling src/mame/video/warriorb.c...
Compiling src/mame/drivers/wgp.c...
Compiling src/mame/video/wgp.c...
Compiling src/mame/audio/taitosnd.c...
Compiling src/mame/audio/t5182.c...
Compiling src/mame/machine/taitoio.c...
Compiling src/mame/video/taitoic.c...
Compiling src/mame/audio/taito_zm.c...
Compiling src/mame/drivers/lockon.c...
Compiling src/mame/video/lockon.c...
Compiling src/mame/machine/tatsumi.c...
Compiling src/mame/video/tatsumi.c...
Compiling src/mame/machine/tx1.c...
Compiling src/mame/audio/tx1.c...
Compiling src/mame/drivers/kickgoal.c...
Compiling src/mame/video/tx1.c...
Compiling src/mame/video/kickgoal.c...
Compiling src/mame/drivers/littlerb.c...
Compiling src/mame/drivers/rltennis.c...
Compiling src/mame/video/rltennis.c...
Compiling src/mame/drivers/speedspn.c...
Compiling src/mame/video/speedspn.c...
Compiling src/mame/drivers/wheelfir.c...
Compiling src/mame/drivers/ambush.c...
Compiling src/mame/video/ambush.c...
Compiling src/mame/drivers/holeland.c...
Compiling src/mame/video/holeland.c...
Compiling src/mame/drivers/sauro.c...
Compiling src/mame/video/sauro.c...
Compiling src/mame/drivers/speedbal.c...
Compiling src/mame/video/speedbal.c...
Compiling src/mame/drivers/battlane.c...
Compiling src/mame/video/battlane.c...
Compiling src/mame/drivers/blockout.c...
Compiling src/mame/video/blockout.c...
Compiling src/mame/drivers/bogeyman.c...
Compiling src/mame/video/bogeyman.c...
Compiling src/mame/drivers/chinagat.c...
Compiling src/mame/drivers/ddragon.c...
Compiling src/mame/video/ddragon.c...
Compiling src/mame/drivers/ddragon3.c...
Compiling src/mame/video/ddragon3.c...
Compiling src/mame/drivers/dogfgt.c...
Compiling src/mame/video/dogfgt.c...
Compiling src/mame/drivers/matmania.c...
Compiling src/mame/machine/maniach.c...
Compiling src/mame/video/matmania.c...
Compiling src/mame/drivers/mystston.c...
Compiling src/mame/video/mystston.c...
Compiling src/mame/drivers/renegade.c...
Compiling src/mame/video/renegade.c...
Compiling src/mame/drivers/scregg.c...
Compiling src/mame/drivers/shadfrce.c...
Compiling src/mame/video/shadfrce.c...
Compiling src/mame/drivers/spdodgeb.c...
Compiling src/mame/video/spdodgeb.c...
Compiling src/mame/drivers/ssozumo.c...
Compiling src/mame/video/ssozumo.c...
Compiling src/mame/drivers/tagteam.c...
Compiling src/mame/video/tagteam.c...
Compiling src/mame/drivers/vball.c...
Compiling src/mame/video/vball.c...
Compiling src/mame/drivers/wwfsstar.c...
Compiling src/mame/video/wwfsstar.c...
Compiling src/mame/drivers/wwfwfest.c...
Compiling src/mame/video/wwfwfest.c...
Compiling src/mame/drivers/xain.c...
Compiling src/mame/drivers/bombjack.c...
Compiling src/mame/video/xain.c...
Compiling src/mame/video/bombjack.c...
Compiling src/mame/drivers/gaiden.c...
Compiling src/mame/video/gaiden.c...
Compiling src/mame/drivers/lvcards.c...
Compiling src/mame/video/lvcards.c...
Compiling src/mame/drivers/pbaction.c...
Compiling src/mame/video/pbaction.c...
Compiling src/mame/drivers/senjyo.c...
Compiling src/mame/audio/senjyo.c...
Compiling src/mame/video/senjyo.c...
Compiling src/mame/drivers/solomon.c...
Compiling src/mame/video/solomon.c...
Compiling src/mame/drivers/spbactn.c...
Compiling src/mame/video/spbactn.c...
Compiling src/mame/drivers/tbowl.c...
Compiling src/mame/video/tbowl.c...
Compiling src/mame/drivers/tecmo.c...
Compiling src/mame/drivers/tecmo16.c...
Compiling src/mame/video/tecmo.c...
Compiling src/mame/video/tecmo16.c...
Compiling src/mame/drivers/tecmosys.c...
Compiling src/mame/machine/tecmosys.c...
Compiling src/mame/video/tecmosys.c...
Compiling src/mame/video/tehkanwc.c...
Compiling src/mame/video/wc90.c...
Compiling src/mame/drivers/wc90.c...
Compiling src/mame/drivers/wc90b.c...
Compiling src/mame/video/wc90b.c...
Compiling src/mame/drivers/thepit.c...
Compiling src/mame/video/thepit.c...
Compiling src/mame/drivers/timelimt.c...
Compiling src/mame/video/timelimt.c...
Compiling src/mame/drivers/mjsister.c...
Compiling src/mame/drivers/slapfght.c...
Compiling src/mame/machine/slapfght.c...
Compiling src/mame/video/slapfght.c...
Compiling src/mame/drivers/snowbros.c...
Compiling src/mame/video/kan_pand.c...
Compiling src/mame/video/kan_panb.c...
Compiling src/mame/drivers/toaplan1.c...
Compiling src/mame/machine/toaplan1.c...
Compiling src/mame/video/toaplan1.c...
Compiling src/mame/drivers/toaplan2.c...
Compiling src/mame/video/gp9001.c...
Compiling src/mame/video/toaplan2.c...
Compiling src/mame/drivers/twincobr.c...
Compiling src/mame/machine/twincobr.c...
Compiling src/mame/drivers/wardner.c...
Compiling src/mame/video/twincobr.c...
Compiling src/mame/drivers/beezer.c...
Compiling src/mame/machine/beezer.c...
Compiling src/mame/video/beezer.c...
Compiling src/mame/audio/beezer.c...
Compiling src/mame/drivers/drgnmst.c...
Compiling src/mame/video/drgnmst.c...
Compiling src/mame/drivers/silkroad.c...
Compiling src/mame/video/silkroad.c...
Compiling src/mame/drivers/unico.c...
Compiling src/mame/video/unico.c...
Compiling src/mame/drivers/cheekyms.c...
Compiling src/mame/video/cheekyms.c...
Compiling src/mame/drivers/cosmic.c...
Compiling src/mame/video/cosmic.c...
Compiling src/mame/drivers/docastle.c...
Compiling src/mame/machine/docastle.c...
Compiling src/mame/video/docastle.c...
Compiling src/mame/drivers/ladybug.c...
Compiling src/mame/video/ladybug.c...
Compiling src/mame/drivers/mrdo.c...
Compiling src/mame/video/mrdo.c...
Compiling src/mame/drivers/redclash.c...
Compiling src/mame/video/redclash.c...
Compiling src/mame/drivers/superdq.c...
Compiling src/mame/drivers/mouser.c...
Compiling src/mame/video/mouser.c...
Compiling src/mame/drivers/ninjakd2.c...
Compiling src/mame/video/ninjakd2.c...
Compiling src/mame/drivers/nova2001.c...
Compiling src/mame/video/nova2001.c...
Compiling src/mame/drivers/xxmissio.c...
Compiling src/mame/video/xxmissio.c...
Compiling src/mame/drivers/bagman.c...
Compiling src/mame/machine/bagman.c...
Compiling src/mame/video/bagman.c...
Compiling src/mame/drivers/tankbust.c...
Compiling src/mame/video/tankbust.c...
Compiling src/mame/drivers/witch.c...
Compiling src/mame/drivers/looping.c...
Compiling src/mame/drivers/spcforce.c...
Compiling src/mame/video/spcforce.c...
Compiling src/mame/drivers/suprridr.c...
Compiling src/mame/video/suprridr.c...
Compiling src/mame/drivers/aerofgt.c...
Compiling src/mame/video/aerofgt.c...
Compiling src/mame/drivers/crshrace.c...
Compiling src/mame/video/crshrace.c...
Compiling src/mame/drivers/f1gp.c...
Compiling src/mame/video/f1gp.c...
Compiling src/mame/video/fromance.c...
Compiling src/mame/drivers/fromance.c...
Compiling src/mame/drivers/fromanc2.c...
Compiling src/mame/video/fromanc2.c...
Compiling src/mame/drivers/gstriker.c...
Compiling src/mame/video/gstriker.c...
Compiling src/mame/drivers/inufuku.c...
Compiling src/mame/video/inufuku.c...
Compiling src/mame/video/ojankohs.c...
Compiling src/mame/drivers/ojankohs.c...
Compiling src/mame/drivers/pipedrm.c...
Compiling src/mame/drivers/rpunch.c...
Compiling src/mame/video/rpunch.c...
Compiling src/mame/drivers/suprslam.c...
Compiling src/mame/video/suprslam.c...
Compiling src/mame/drivers/tail2nos.c...
Compiling src/mame/video/tail2nos.c...
Compiling src/mame/drivers/taotaido.c...
Compiling src/mame/video/taotaido.c...
Compiling src/mame/drivers/welltris.c...
Compiling src/mame/video/welltris.c...
Compiling src/mame/drivers/nmg5.c...
Compiling src/mame/drivers/paradise.c...
Compiling src/mame/video/paradise.c...
Compiling src/mame/drivers/yunsung8.c...
Compiling src/mame/video/yunsung8.c...
Compiling src/mame/drivers/yunsun16.c...
Compiling src/mame/video/yunsun16.c...
Compiling src/mame/drivers/galaxia.c...
Compiling src/mame/drivers/laserbat.c...
Compiling src/mame/audio/laserbat.c...
Compiling src/mame/video/zac2650.c...
Compiling src/mame/drivers/zaccaria.c...
Compiling src/mame/video/zaccaria.c...
Compiling src/mame/drivers/1945kiii.c...
Compiling src/mame/drivers/39in1.c...
Compiling src/mame/drivers/3do.c...
Compiling src/mame/machine/3do.c...
Compiling src/mame/drivers/4enraya.c...
Compiling src/mame/video/4enraya.c...
Compiling src/mame/drivers/5clown.c...
Compiling src/mame/drivers/aces1.c...
Compiling src/mame/drivers/acesp.c...
Compiling src/mame/drivers/adp.c...
Compiling src/mame/drivers/amaticmg.c...
Compiling src/mame/video/ampoker2.c...
Compiling src/mame/drivers/amspdwy.c...
Compiling src/mame/video/amspdwy.c...
Compiling src/mame/drivers/artmagic.c...
Compiling src/mame/video/artmagic.c...
Compiling src/mame/drivers/astrafr.c...
Compiling src/mame/drivers/astrocorp.c...
Compiling src/mame/drivers/attckufo.c...
Compiling src/mame/drivers/avt.c...
Compiling src/mame/drivers/aztarac.c...
Compiling src/mame/audio/aztarac.c...
Compiling src/mame/video/aztarac.c...
Compiling src/mame/drivers/bgt.c...
Compiling src/mame/drivers/bingor.c...
Compiling src/mame/drivers/blitz.c...
Compiling src/mame/drivers/blitz68k.c...
Compiling src/mame/drivers/buster.c...
Compiling src/mame/drivers/calomega.c...
Compiling src/mame/video/calomega.c...
Compiling src/mame/drivers/carrera.c...
Compiling src/mame/drivers/castle.c...
Compiling src/mame/drivers/cave.c...
Compiling src/mame/video/cave.c...
Compiling src/mame/drivers/cb2001.c...
Compiling src/mame/video/mcd212.c...
Compiling src/mame/machine/cdi070.c...
Compiling src/mame/machine/cdislave.c...
Compiling src/mame/machine/cdicdic.c...
Compiling src/mame/drivers/cesclass.c...
Compiling src/mame/drivers/chsuper.c...
Compiling src/mame/drivers/cidelsa.c...
Compiling src/mame/video/cidelsa.c...
Compiling src/mame/drivers/coinmstr.c...
Compiling src/mame/drivers/coinmvga.c...
Compiling src/mame/drivers/comebaby.c...
Compiling src/mame/drivers/bntyhunt.c...
Compiling src/mame/drivers/coolpool.c...
Compiling src/mame/drivers/crystal.c...
Compiling src/mame/drivers/cubeqst.c...
Compiling src/mame/video/vrender0.c...
Compiling src/mame/drivers/cybertnk.c...
Compiling src/mame/drivers/dcheese.c...
Compiling src/mame/video/dcheese.c...
Compiling src/mame/drivers/dfruit.c...
Compiling src/mame/drivers/dgpix.c...
Compiling src/mame/drivers/discoboy.c...
Compiling src/mame/drivers/dominob.c...
Compiling src/mame/drivers/dorachan.c...
Compiling src/mame/drivers/dreamwld.c...
Compiling src/mame/drivers/dribling.c...
Compiling src/mame/video/dribling.c...
Compiling src/mame/drivers/drw80pkr.c...
Compiling src/mame/drivers/dwarfd.c...
Compiling src/mame/drivers/dynadice.c...
Compiling src/mame/drivers/ecoinfr.c...
Compiling src/mame/drivers/ecoinf1.c...
Compiling src/mame/drivers/ecoinf2.c...
Compiling src/mame/drivers/ecoinf3.c...
Compiling src/mame/drivers/epos.c...
Compiling src/mame/video/epos.c...
Compiling src/mame/drivers/esd16.c...
Compiling src/mame/video/esd16.c...
Compiling src/mame/drivers/esh.c...
Compiling src/mame/drivers/esripsys.c...
Compiling src/mame/video/esripsys.c...
Compiling src/mame/drivers/ettrivia.c...
Compiling src/mame/drivers/flower.c...
Compiling src/mame/audio/flower.c...
Compiling src/mame/video/flower.c...
Compiling src/mame/drivers/freekick.c...
Compiling src/mame/video/freekick.c...
Compiling src/mame/drivers/funkball.c...
Compiling src/mame/drivers/galgame.c...
Compiling src/mame/drivers/gamecstl.c...
Compiling src/mame/drivers/gei.c...
Compiling src/mame/drivers/globalfr.c...
Compiling src/mame/drivers/goldngam.c...
Compiling src/mame/drivers/gotcha.c...
Compiling src/mame/drivers/good.c...
Compiling src/mame/video/gotcha.c...
Compiling src/mame/drivers/gstream.c...
Compiling src/mame/drivers/gumbo.c...
Compiling src/mame/video/gumbo.c...
Compiling src/mame/drivers/gunpey.c...
Compiling src/mame/drivers/hazelgr.c...
Compiling src/mame/drivers/himesiki.c...
Compiling src/mame/video/himesiki.c...
Compiling src/mame/drivers/hitpoker.c...
Compiling src/mame/drivers/homedata.c...
Compiling src/mame/video/homedata.c...
Compiling src/mame/drivers/hotblock.c...
Compiling src/mame/drivers/hotstuff.c...
Compiling src/mame/drivers/ichiban.c...
Compiling src/mame/drivers/imolagp.c...
Compiling src/mame/drivers/intrscti.c...
Compiling src/mame/drivers/istellar.c...
Compiling src/mame/drivers/itgambl2.c...
Compiling src/mame/drivers/itgambl3.c...
Compiling src/mame/drivers/itgamble.c...
Compiling src/mame/drivers/jackpool.c...
Compiling src/mame/drivers/jokrwild.c...
Compiling src/mame/drivers/jongkyo.c...
Compiling src/mame/drivers/jubilee.c...
Compiling src/mame/drivers/kingpin.c...
Compiling src/mame/drivers/koikoi.c...
Compiling src/mame/drivers/kyugo.c...
Compiling src/mame/video/kyugo.c...
Compiling src/mame/drivers/ladyfrog.c...
Compiling src/mame/video/ladyfrog.c...
Compiling src/mame/drivers/laserbas.c...
Compiling src/mame/drivers/lethalj.c...
Compiling src/mame/video/lethalj.c...
Compiling src/mame/drivers/limenko.c...
Compiling src/mame/drivers/ltcasino.c...
Compiling src/mame/video/lucky74.c...
Compiling src/mame/drivers/magicard.c...
Compiling src/mame/drivers/magicfly.c...
Compiling src/mame/drivers/magictg.c...
Compiling src/mame/drivers/magtouch.c...
Compiling src/mame/drivers/malzak.c...
Compiling src/mame/drivers/mcatadv.c...
Compiling src/mame/video/malzak.c...
Compiling src/mame/video/mcatadv.c...
Compiling src/mame/drivers/micro3d.c...
Compiling src/mame/machine/micro3d.c...
Compiling src/mame/video/micro3d.c...
Compiling src/mame/audio/micro3d.c...
Compiling src/mame/drivers/midas.c...
Compiling src/mame/drivers/miniboy7.c...
Compiling src/mame/drivers/mirax.c...
Compiling src/mame/drivers/mole.c...
Compiling src/mame/drivers/mosaic.c...
Compiling src/mame/video/mosaic.c...
Compiling src/mame/drivers/mrjong.c...
Compiling src/mame/video/mrjong.c...
Compiling src/mame/drivers/multfish.c...
Compiling src/mame/drivers/murogem.c...
Compiling src/mame/drivers/neoprint.c...
Compiling src/mame/drivers/murogmbl.c...
Compiling src/mame/drivers/neptunp2.c...
Compiling src/mame/drivers/news.c...
Compiling src/mame/video/news.c...
Compiling src/mame/drivers/nexus3d.c...
Compiling src/mame/audio/norautp.c...
Compiling src/mame/drivers/nsmpoker.c...
Compiling src/mame/drivers/oneshot.c...
Compiling src/mame/video/oneshot.c...
Compiling src/mame/drivers/onetwo.c...
Compiling src/mame/drivers/othello.c...
Compiling src/mame/drivers/othldrby.c...
Compiling src/mame/video/othldrby.c...
Compiling src/mame/drivers/pachifev.c...
Compiling src/mame/drivers/pasha2.c...
Compiling src/mame/drivers/pass.c...
Compiling src/mame/video/pass.c...
Compiling src/mame/drivers/photon.c...
Compiling src/mame/video/pk8000.c...
Compiling src/mame/drivers/photon2.c...
Compiling src/mame/drivers/photoply.c...
Compiling src/mame/drivers/pinkiri8.c...
Compiling src/mame/drivers/pipeline.c...
Compiling src/mame/drivers/pkscram.c...
Compiling src/mame/drivers/pntnpuzl.c...
Compiling src/mame/drivers/policetr.c...
Compiling src/mame/video/policetr.c...
Compiling src/mame/drivers/polyplay.c...
Compiling src/mame/audio/polyplay.c...
Compiling src/mame/video/polyplay.c...
Compiling src/mame/drivers/poker72.c...
Compiling src/mame/drivers/poo.c...
Compiling src/mame/drivers/proconn.c...
Compiling src/mame/drivers/psattack.c...
Compiling src/mame/drivers/quizo.c...
Compiling src/mame/drivers/rbmk.c...
Compiling src/mame/drivers/quizpun2.c...
Compiling src/mame/drivers/rcorsair.c...
Compiling src/mame/drivers/rgum.c...
Compiling src/mame/drivers/savquest.c...
Compiling src/mame/drivers/shangkid.c...
Compiling src/mame/video/shangkid.c...
Compiling src/mame/drivers/skeetsht.c...
Compiling src/mame/drivers/skimaxx.c...
Compiling src/mame/drivers/skyarmy.c...
Compiling src/mame/drivers/skylncr.c...
Compiling src/mame/drivers/sliver.c...
Compiling src/mame/drivers/slotcarn.c...
Compiling src/mame/drivers/sms.c...
Compiling src/mame/drivers/sothello.c...
Compiling src/mame/drivers/spool99.c...
Compiling src/mame/drivers/sprcros2.c...
Compiling src/mame/video/sprcros2.c...
Compiling src/mame/drivers/sshot.c...
Compiling src/mame/drivers/ssingles.c...
Compiling src/mame/drivers/statriv2.c...
Compiling src/mame/drivers/stellafr.c...
Compiling src/mame/drivers/su2000.c...
Compiling src/mame/drivers/summit.c...
Compiling src/mame/drivers/sumt8035.c...
Compiling src/mame/drivers/supertnk.c...
Compiling src/mame/drivers/superwng.c...
Compiling src/mame/drivers/tapatune.c...
Compiling src/mame/drivers/tattack.c...
Compiling src/mame/drivers/taxidriv.c...
Compiling src/mame/video/taxidriv.c...
Compiling src/mame/drivers/tcl.c...
Compiling src/mame/drivers/thedeep.c...
Compiling src/mame/video/thedeep.c...
Compiling src/mame/drivers/tiamc1.c...
Compiling src/mame/video/tiamc1.c...
Compiling src/mame/audio/tiamc1.c...
Compiling src/mame/drivers/tickee.c...
Compiling src/mame/video/truco.c...
Compiling src/mame/drivers/truco.c...
Compiling src/mame/drivers/trucocl.c...
Compiling src/mame/video/trucocl.c...
Compiling src/mame/drivers/trvmadns.c...
Compiling src/mame/drivers/trvquest.c...
Compiling src/mame/drivers/ttchamp.c...
Compiling src/mame/drivers/tugboat.c...
Compiling src/mame/drivers/unkfr.c...
Compiling src/mame/drivers/unkpcp.c...
Compiling src/mame/drivers/usgames.c...
Compiling src/mame/video/usgames.c...
Compiling src/mame/drivers/vamphalf.c...
Compiling src/mame/drivers/vcombat.c...
Compiling src/mame/video/vectrex.c...
Compiling src/mame/drivers/vectrex.c...
Compiling src/mame/machine/vectrex.c...
Compiling src/mame/drivers/vp101.c...
Compiling src/mame/drivers/vpoker.c...
Compiling src/mame/drivers/vroulet.c...
Compiling src/mame/drivers/wldarrow.c...
Compiling src/mame/drivers/xtom3d.c...
Compiling src/mame/drivers/xyonix.c...
Compiling src/mame/video/xyonix.c...
Compiling src/mame/drivers/gamtor.c...
Compiling src/mame/drivers/belatra.c...
Compiling src/mame/drivers/atronic.c...
Compiling src/mame/drivers/astropc.c...
Compiling src/mame/drivers/wms.c...
Compiling src/mame/drivers/cupidon.c...
Compiling src/mame/drivers/extrema.c...
Compiling src/mame/drivers/tmspoker.c...
Compiling src/mame/drivers/allied.c...
Compiling src/mame/drivers/alvg.c...
Compiling src/mame/drivers/atari_s1.c...
Compiling src/mame/drivers/atari_s2.c...
Compiling src/mame/drivers/atari_s3.c...
Compiling src/mame/drivers/bingo.c...
Compiling src/mame/drivers/by17.c...
Compiling src/mame/drivers/by35.c...
Compiling src/mame/drivers/by6803.c...
Compiling src/mame/drivers/by68701.c...
Compiling src/mame/drivers/byvid.c...
Compiling src/mame/drivers/capcom.c...
Compiling src/mame/drivers/de_1.c...
Compiling src/mame/drivers/de_2.c...
Compiling src/mame/drivers/de_3.c...
Compiling src/mame/drivers/de_3b.c...
Compiling src/mame/drivers/flicker.c...
Compiling src/mame/drivers/g627.c...
Compiling src/mame/drivers/gp_1.c...
Compiling src/mame/drivers/gp_2.c...
Compiling src/mame/drivers/gts1.c...
Compiling src/mame/drivers/gts3.c...
Compiling src/mame/drivers/gts80.c...
Compiling src/mame/drivers/gts80a.c...
Compiling src/mame/drivers/hankin.c...
Compiling src/mame/drivers/gts80b.c...
Compiling src/mame/drivers/icecold.c...
Compiling src/mame/drivers/inder.c...
Compiling src/mame/drivers/jp.c...
Compiling src/mame/drivers/jeutel.c...
Compiling src/mame/drivers/jvh.c...
Compiling src/mame/drivers/kissproto.c...
Compiling src/mame/drivers/ltd.c...
Compiling src/mame/drivers/micropin.c...
Compiling src/mame/drivers/mephisto.c...
Compiling src/mame/drivers/mrgame.c...
Compiling src/mame/drivers/nsm.c...
Compiling src/mame/drivers/play_2.c...
Compiling src/mame/drivers/play_3.c...
Compiling src/mame/drivers/play_1.c...
Compiling src/mame/drivers/play_5.c...
Compiling src/mame/drivers/s11.c...
Compiling src/mame/drivers/s11a.c...
Compiling src/mame/drivers/rowamet.c...
Compiling src/mame/drivers/s11b.c...
Compiling src/mame/drivers/s11c.c...
Compiling src/mame/drivers/s3.c...
Compiling src/mame/drivers/s4.c...
Compiling src/mame/drivers/s6.c...
Compiling src/mame/drivers/s6a.c...
Compiling src/mame/drivers/s7.c...
Compiling src/mame/drivers/s8.c...
Compiling src/mame/drivers/s9.c...
Compiling src/mame/drivers/sleic.c...
Compiling src/mame/drivers/spectra.c...
Compiling src/mame/drivers/spinb.c...
Compiling src/mame/drivers/st_mp100.c...
Compiling src/mame/drivers/st_mp200.c...
Compiling src/mame/drivers/taito.c...
Compiling src/mame/drivers/techno.c...
Compiling src/mame/drivers/vd.c...
Compiling src/mame/drivers/whitestar.c...
Compiling src/mame/drivers/white_mod.c...
Compiling src/mame/drivers/wico.c...
Compiling src/mame/drivers/wpc_95.c...
Compiling src/mame/drivers/wpc_an.c...
Compiling src/mame/drivers/wpc_dcs.c...
Compiling src/mame/drivers/wpc_dot.c...
Compiling src/mame/drivers/wpc_flip1.c...
Compiling src/mame/drivers/wpc_s.c...
Compiling src/mame/drivers/wpc_flip2.c...
Compiling src/mame/drivers/zac_1.c...
Compiling src/mame/drivers/zac_2.c...
Compiling src/mame/drivers/zac_proto.c...
Compiling src/mame/machine/nmk112.c...
Compiling src/mame/machine/pckeybrd.c...
Compiling src/mame/machine/pcshare.c...
Compiling src/mame/machine/segacrpt.c...
Compiling src/mame/machine/segacrp2.c...
Compiling src/mame/machine/ticket.c...
Compiling src/mame/video/avgdvg.c...
Compiling src/osd/winui/mui_main.c...
Compiling src/osd/windows/d3d9intf.c...
Compiling src/osd/windows/drawd3d.c...
Compiling src/osd/windows/d3dhlsl.c...
Compiling src/osd/windows/drawdd.c...
Compiling src/osd/windows/drawgdi.c...
Compiling src/osd/windows/drawnone.c...
Compiling src/osd/windows/input.c...
Compiling src/osd/windows/output.c...
Compiling src/osd/windows/sound.c...
Compiling src/osd/windows/video.c...
Compiling src/osd/windows/window.c...
src/osd/windows/video.c:257: error: redefinition of 'void windows_osd_interface::update_hi(bool)'
Compiling src/osd/windows/winmenu.c...
src/osd/windows/video.c:235: error: 'virtual void windows_osd_interface::update_hi(bool)' previously defined here
make: *** [obj/winui64/osd/windows/video.o] Error 1
make: *** Waiting for unfinished jobs....
Finished!
0 Hours 9 Minutes and 16 Seconds Elapsed.
There is no mameui64.exe file created. :(
I just successfully compiled Mame 0145 again with the hiscore patch applied. I did get an error different to yours Draco but pressing Go again it continued on and finished.
EDIT: Just successfully compiled MameUI 0145 too.
Well that suxorz for me! :*(
S'pose I need to roll back my set.
No worries. :)
0.145 with hi-score patch yeah. But I was gonna try it on another machine (my dev machine is W7 64-bit with 8 GB of RAM). Just haven't had time to try it yet and too lazy to learn how to compile it myself. :)
I will try again this weekend. I actually did hit Go again the first time around and no joy.
Well color me befuddled. It works fine on my dev machine way faster at that), so I can mark this as resolved now... Although I still wonder why my cab wouldn't compile it.
Good to be back at being current though! :)
Thanks for the assist Drac & HK.
Sometimes just being there is enough... *insert sappy hollywood type music here* :)
Well, cleaned everything out of the directories and downloaded fresh and this time the compile completed in about 16 mins instead of 9 and with no errors. Go figure!
Edited by Draco1962
