Hello
I'm sure that I read something around somewhere but I can't get back to the post.
I'd like to use a key combinatiin on my Tankstick to exit any kind of emulators.
Cause actualy I use my touch screen but enabling touchscreen prevent use lor of great themes such as megamam or Space invanders...
Thanks by advance and sorry to double post.
Seb
Seb - you may want to refer to the posts here and here. In the first post, there is a link you can click to download for install the xarcade.cfg file that goes within your MAME ctrlr folder. You will need to set that up in mame as to the path you have that folder on your hard drive and in the global controller options.
In the second post which is somewhat related to your question/issue, you were asked a few questions by Adultery and fRequeEnCy - did you address them?
Thanks Draco for linked post but I realized that I wasn't clear enought.
What I'd like to do is to configure a combination of keys like alt ctrl W that map the Escape key so I can escape from any emulators going back to gameEx.
Seb
Couldn't you just make an escape combo in GameEx to universally exit any emulator? It's a setting in Input Settings, "Gloal Escape" I think it's called.
I've just try to setup a key combo but to be honest I don't understand how to write it right.
Could you give me samples ?
Seb
Press the [...] button and you will be prompted to enter a key. Repeat for all the keys you want for the combo.
