Hi,
Is that possible to hide the "Title" of the emulator in the menu ? Like "Nintendo NES"...
I'm purchasing a solution for that because I would like to display the console logo only, and when I erase the "Title Text" in Setup Wizard, GameEx menu doesn't work...
You may have to modify the theme you are using if it is still showing after you disable via Display Title Text (under the Display Settings) within Setup Wizard. Check Setup Wizard first and make sure that Display Title Text is set to No. Restart GameEx. If that resolves the issue, then no need to modify the theme.
If that does not resolve the Title text display, then open your theme via Theme Editor. Click on Edit, then Options. Next, click on the Settings tab and uncheck Display Title Text. Click OK, then save your theme. Let us know if either/both of these work.
The second solution will work regardless of if you are using Custom Menus. That is because the setting in Theme Editor was overriding the setting in Setup Wizard. Glad you got it working as you needed!
