Seb02 Posted January 29, 2012 Share Posted January 29, 2012 HelloI don't know my games are always running with the lowest screen résolution. When I launch the model2 emulator directly and select the best resolution it works but each time I start it again it always goes for the lowest one!!Other issue I can't find how to configure keyboard keys and disable digital input ?Thanks by advance for your helpSeb Link to comment Share on other sites More sharing options...
fRequEnCy Posted January 29, 2012 Share Posted January 29, 2012 HelloI don't know my games are always running with the lowest screen résolution. When I launch the model2 emulator directly and select the best resolution it works but each time I start it again it always goes for the lowest one!!Other issue I can't find how to configure keyboard keys and disable digital input ?Thanks by advance for your helpSebAs far as you first question, what resolution would you like to set this emulator at? These settings are saved in the emulator.ini file. Link to comment Share on other sites More sharing options...
Seb02 Posted January 29, 2012 Author Share Posted January 29, 2012 where can I find this emulator.ini file ?? Link to comment Share on other sites More sharing options...
fRequEnCy Posted January 29, 2012 Share Posted January 29, 2012 where can I find this emulator.ini file ??Should be in the same directory as the Model2 emulator. Link to comment Share on other sites More sharing options...
Seb02 Posted January 29, 2012 Author Share Posted January 29, 2012 I find it I set up the resolution for fullscreen at 1280 X 1024 and same issue at each start resolution is still the same and not which one I want. To note if I set it up manualy it works. To read from any of you Link to comment Share on other sites More sharing options...
fRequEnCy Posted January 29, 2012 Share Posted January 29, 2012 I find it I set up the resolution for fullscreen at 1280 X 1024 and same issue at each start resolution is still the same and not which one I want. To note if I set it up manualy it works.To read from any of youPlease post the contents of that file! Link to comment Share on other sites More sharing options...
Seb02 Posted January 29, 2012 Author Share Posted January 29, 2012 Ok I will do that tomorow. By the way if you can advice me for a steering wheel and pedals. Link to comment Share on other sites More sharing options...
Seb02 Posted January 30, 2012 Author Share Posted January 30, 2012 as requested please find enclosed the fileEMULATOR.zip Link to comment Share on other sites More sharing options...
fRequEnCy Posted January 30, 2012 Share Posted January 30, 2012 as requested please find enclosed the filefullmode should be equal to 3 to get the resolution you're after. fullmode=3The following values are used for the custom value. Have a look at this topic. Same applies to this emulator as well. Link to comment Share on other sites More sharing options...
Seb02 Posted January 30, 2012 Author Share Posted January 30, 2012 Thanks a lot it works. Link to comment Share on other sites More sharing options...
Krakerman Posted January 30, 2012 Share Posted January 30, 2012 Funny I was just testing model 2 1.0 and it doesn't seem to read the ini config file at all as when I open the gui it still at the defaults. Also none of the options or cheats menus are working either. Link to comment Share on other sites More sharing options...
fRequEnCy Posted January 30, 2012 Share Posted January 30, 2012 Funny I was just testing model 2 1.0 and it doesn't seem to read the ini config file at all as when I open the gui it still at the defaults. Also none of the options or cheats menus are working either.It reads the values just doesn't save them unless closed correctly. Best way is to run the emulator outside of GameEx and then make the changes and then close by using the x on top of the window. I noticed that closing the emulator by the hotkey or by the exit menu option from the file menu doesn't save the settings. Link to comment Share on other sites More sharing options...
fRequEnCy Posted January 30, 2012 Share Posted January 30, 2012 Thanks a lot it works.No problem! Enjoy! Marking as resolved! Link to comment Share on other sites More sharing options...
