Help!
I'm running the newest build of GameEx with 2 new ultrastick 360's but its not autoswitcing to the correct joystick layout. If i set the joystick to 2 way in ultramap, when i boot up gameex or any of my mame games from within GameEx, it doesnt switch. I made sure my setting had the joystick support on, and all my path seem correct. Any ideas? I'm using Mame64 for my emulator.
Ok Figured it out. I had to go to the plu-in manager and turn on the plug in. It's in the GameEx config folder. Hope that helps others with the problem. Works great now.
