Krakerman Posted January 16, 2012 Share Posted January 16, 2012 Ok guys I just had to re-format my system once again due to some issues that needed to be fixed. Now when I re-installed Future Pinball it seems that the backbox won't display on the second monitor even thou I have it enabled, but nothing appears on that monitor.Any clue why? The game table shows up on monitor 1. Link to comment Share on other sites More sharing options...
Draco1962 Posted January 16, 2012 Share Posted January 16, 2012 I assume you are using Game Extender - if so, have you verified the settings are correct? Link to comment Share on other sites More sharing options...
Krakerman Posted January 16, 2012 Author Share Posted January 16, 2012 No this is without GameEx involved. I was just re-installing Future Pinball and running this outside GameEx. Link to comment Share on other sites More sharing options...
rockyrocket Posted January 17, 2012 Share Posted January 17, 2012 Hi, future pinball is really pickie about drivers, the 260.99 nvidia ones work for a second screen but any newer ones wont display.The beta 290.43 (think 43) one works on my system but any inbetween dont.If you are on ati then i dont have a clue sorry.The other thing is that you have ticked the box to enable the backbox?.Hope this is of some help. Link to comment Share on other sites More sharing options...
Krakerman Posted January 18, 2012 Author Share Posted January 18, 2012 I just installed beta 290.53 and still not displaying and Yes I have that box checked as well. Link to comment Share on other sites More sharing options...
Adultery Posted January 18, 2012 Share Posted January 18, 2012 Good thing I've got an ATI card then because it works fine for me. Is it only FP? Link to comment Share on other sites More sharing options...
Krakerman Posted January 18, 2012 Author Share Posted January 18, 2012 Another thing I noticed with this new card is before with the ATI 5850 when booting up the system the BIOS display would show up on both monitors now it will display only on monitor 2 when booting up then when it gets to the desktop monitor 2 goes black and monitor 1 displays the welcome desktop then monitor 2 comes back on when the desktop loads. Any way to get it to show on both monitors when booting? It works on monitor 1 if I unplug monitor 2 of course. monitor 1 is HDMI and monitor 2 is DVI if that makes a difference, but before the ATI shows both when booting??? Link to comment Share on other sites More sharing options...
Draco1962 Posted January 18, 2012 Share Posted January 18, 2012 I believe you are stuck with how it is going to load. I have a similar issue with my nVidia if I have monitor 1 selected as the HDMI connection with monitor 2 as DVI or VGA. Otherwise, when loading with Monitor 1 as DVI and 2 as VGA, monitor 2 is blank while the system loads and displays the bootup/logon via Monitor 1. The only way to have the boot show on both would be to clone your display to where what shows on Monitor 1 shows on Monitor 2 - which is what you do not want to do in this case. I would have to say that the load you were seeing on the ATI 5850 was an exception and not the rule for most GPUs in a multiple monitor arrangement.I have had no problems with my nVidia GPUs and FP otherwise. Link to comment Share on other sites More sharing options...
Adultery Posted January 18, 2012 Share Posted January 18, 2012 I would have to say that the load you were seeing on the ATI 5850 was an exception and not the rule for most GPUs in a multiple monitor arrangement.That may be an ATI thing too since I know mine behaves this way. If I use 2 monitors and HDMI as well the bootscreen shows on all three. Link to comment Share on other sites More sharing options...
rockyrocket Posted January 18, 2012 Share Posted January 18, 2012 Thats odd!, maybe the 260.99 will solve it?.What happens if you swap the playfield and backbox screens around in the fp screen config or mess with the resolutions, is it still black when on the other screen?. Link to comment Share on other sites More sharing options...
Krakerman Posted January 19, 2012 Author Share Posted January 19, 2012 Well someone over on vpforums mentioned to try 270.61 drivers so I will give it a go and report back with you all.UPDATE! Well no go as those drivers say couldn't find compatible hardware. After further testing it seems like Future Pinball runs the Backbox then loses focus so I have to click my mouse on monitor 1 for it detect keyboard presses but for some reason it just won't display the backbox. Oh well no big deal just would of been cool to have it work. Link to comment Share on other sites More sharing options...
rockyrocket Posted January 19, 2012 Share Posted January 19, 2012 What do you see as fp is loading, is the splash displayed on both screens or is the backbox just black?.Also what happens if you ALT-TAB?. will it appear? and also if you do a print screen are both screens showing up?.I had the focus issues you mentioned on a win 7 box once, had to mouse onto the screen before any key press would register.To fix it i played about with the properties of the shortcut and whatever i changed at the time fixed it.Future pinball does work fine on all the drivers apart from the backglass not showing up, if your only on one screen then its not a problem.Dont know what card you have krakerman and i dont want to harp on about 260.99 ( and boy can i harp) but here is a thread about working drivers...http://www.hyperspin-fe.com/forum/showthread.php?t=13272&highlight=driver&page=3Of course if the image is just hidden out of focus then this is just mute.As you say it would be cool to get it to work. Link to comment Share on other sites More sharing options...
rockyrocket Posted January 19, 2012 Share Posted January 19, 2012 Just read your other thread and yeah your right the 260 driver is prolly too old for your 560 (nice card).one thing i did notice is that you tried the 290.53 and myself the 290.36, wonder if you can find that? or even if i still have it?. Link to comment Share on other sites More sharing options...
