[RESOLVED] Video Snaps...Where to place, not2 working
Hello all, Thanks in advance for the support.
I am trying to ge the preview video snaps to work. I have downloded from EMU in avi format. The only ones that work are the ones that came with the demo, ie 007 N64, donkey kong mame.. I move some to that working demo folder as well and nothing. I can get none video snaps to show in MAME titles. As soon as I try to add video snaps previews screen goes blank. Remove the avi file then the non video snap shows back
Attached is my file log
You are using the default paths for the demo and not the path to the video snaps. You have to locate this via the Setup Wizard and "browse" to the correct path within the MAME setup as well as each emulator you are setting up within GameEx.
Also note that if you haven't got the codecs installed it's not gonna work. (ie do the videos play outside of GameEx?) ;)
Thanks all I changed the path, and the mame videos work now. I am going to to do the same with consoles. All my friends that see this are loving it. Thanks again will check back when I add videos to snes,nes, n64!
