Total noob here looking for theme and video snap help
I downloaded a few themes for this site and a few of them have "intro" files. (ie. ArcadeDark 84...etc)
Where do I put these intro files so they will play when GameEx loads up?
I've downloaded the AVI video snap clips from EmuMovies. I am unable to get them to play however when I'm under the MAME games emulator. I'm not sure if I have them in the correct place. Do I put them under C:\Emulators\Mame32\Avisnaps or C:\Assets\Mame\Avisnaps?
I'm a total noob so please bear with me.
You have Shark007 codecs installed?
Let's get the game snaps going first then we'll focus on the other videos.
Please post your GameEx log after you run your theme. :)
Here is my log.
17:30:35.2 1/14/2012: Opening Configuration File
17:30:35.7 1/14/2012: GameEx: Version 12.53: Starting Log
17:30:35.8 1/14/2012: Operating System Platform: Win32NT
17:30:35.8 1/14/2012: Operating System Name: Windows XP
17:30:35.8 1/14/2012: Operating System Version: 5.1.2600
17:30:35.8 1/14/2012: Intel® Pentium® 4 CPU 3.60GHz, 3070MB
17:30:35.8 1/14/2012: 3.59Ghz - 2 Cores or CPU's
17:30:35.8 1/14/2012: Running Randomize()
17:30:36.0 1/14/2012: Loading PlugIns
17:30:36.0 1/14/2012: Checking for applications to Launch On Startup
17:30:36.0 1/14/2012: Running Misc startup tasks
17:30:36.0 1/14/2012: Setting Menu types
17:30:36.0 1/14/2012: Getting Configuration Values
17:30:36.1 1/14/2012: Using Theme: Default - RedEx - MCE1024x768
17:30:36.1 1/14/2012: Checking for alternate Image Directory for Theme: Default - RedEx - MCE1024x768
17:30:36.1 1/14/2012: Launching HideOS.exe
17:30:36.1 1/14/2012: Initialising Video/MNG DLL's
17:30:36.1 1/14/2012: GameEx will check for media insertion (may affect performance)
17:30:36.1 1/14/2012: Hiding Taskbar
17:30:36.2 1/14/2012: Is Media Center running?
17:30:36.2 1/14/2012: Checking/Creating LCD Registry values
17:30:36.2 1/14/2012: Check Media Center Exit/Start Mode
17:30:36.2 1/14/2012: Media Center Mode 2
17:30:36.4 1/14/2012: Video previews on. Warning: Only recommended on modern systems
17:30:36.4 1/14/2012: Snap Delay set to: 4
17:30:36.4 1/14/2012: Get other settings
17:30:36.4 1/14/2012: Desktop set to Hide ICONS and set Background to Black
17:30:36.4 1/14/2012: Set: Find emulator artwork on best match basis
17:30:36.4 1/14/2012: Start work for Form
17:30:36.4 1/14/2012: Getting Original Screen Size
17:30:36.8 1/14/2012: Opening Database Connection
17:30:38.4 1/14/2012: Initializing Component
17:30:39.2 1/14/2012: MAME Path is: C:\Emulators\Mame32
17:30:39.2 1/14/2012: MAME EXE file is: MameUI32.exe
17:30:39.3 1/14/2012: ROM Path is: C:\Emulators\Mame32\Roms
17:30:39.3 1/14/2012: Catver.ini is located at: C:\GameEx\DATA\catver.ini
17:30:39.3 1/14/2012: controls.ini is located at: C:\GameEx\DATA\controls.ini
17:30:39.3 1/14/2012: History.dat is located at: C:\GameEx\DATA\history.dat
17:30:39.3 1/14/2012: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
17:30:39.3 1/14/2012: command.dat is located at: C:\GameEx\DATA\command.dat
17:30:39.3 1/14/2012: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
17:30:39.3 1/14/2012: Loading Controls.ini map file
17:30:39.4 1/14/2012: Snap Path is: C:\Emulators\Mame32\snap
17:30:39.4 1/14/2012: Background Snap Path is: C:\Emulators\Mame32\snap
17:30:39.4 1/14/2012: AVI Snap Path is: C:\Emulators\Mame32\avisnap
17:30:39.4 1/14/2012: Flyer Path is: C:\Emulators\Mame32\flyers
17:30:39.4 1/14/2012: Cabinet Path is: C:\Emulators\Mame32\cabinets
17:30:39.4 1/14/2012: Cabinet 3D Path: Not Found
17:30:39.4 1/14/2012: Title Path is: C:\Emulators\Mame32\titles
17:30:39.4 1/14/2012: PCB Path: Not Found
17:30:39.4 1/14/2012: Artwork Preview Path: Not Found
17:30:39.4 1/14/2012: Panel Path is: C:\Emulators\Mame32\cpanel
17:30:39.4 1/14/2012: Manual Path: Not Found
17:30:39.4 1/14/2012: Icon Path is: C:\Emulators\Mame32\icons
17:30:39.4 1/14/2012: Marquee Path is: C:\Emulators\Mame32\marquees
17:30:39.4 1/14/2012: Applying Language/Text
17:30:39.4 1/14/2012: Text/Language: English
17:30:39.5 1/14/2012: Loading Custom Emulators
17:30:39.5 1/14/2012: Loading Emulator 1: [Arcade] Arcade (MAME)
17:30:39.5 1/14/2012: Using 2D Animations
17:30:39.5 1/14/2012: Retrieving resolution setting
17:30:39.5 1/14/2012: Using General Font: Trebuchet MS
17:30:39.5 1/14/2012: Using Title Font: Trebuchet MS
17:30:39.5 1/14/2012: GameEx will try to reduce CPU usage
17:30:39.6 1/14/2012: Initialising Direct3D
17:30:40.0 1/14/2012: Applying GameEx is Loading Image
17:30:40.1 1/14/2012: Setting Resolution to 1824x1028 32 bit color
17:30:40.2 1/14/2012: Creating Surfaces
17:30:40.7 1/14/2012: Creating Primary Surface - Full Screen Mode
17:30:40.7 1/14/2012: Creating Back Buffer
17:30:41.1 1/14/2012: Loading graphic Surfaces
17:30:41.1 1/14/2012: Display is running at: 1824x1028 32bit color, 60hz
17:30:41.2 1/14/2012: Adapter: NVIDIA GeForce GT 430
17:30:41.2 1/14/2012: Max texture size: 8192x8192
17:30:41.2 1/14/2012: Available texture memory: 1446MB
17:30:41.2 1/14/2012: Initialising Bass Audio Library
17:30:41.6 1/14/2012: Creating Surfaces Misc and Dialogs
17:30:42.6 1/14/2012: Creating Surfaces Volume
17:30:42.6 1/14/2012: Creating Surfaces Arrows
17:30:42.6 1/14/2012: Creating Surfaces GameEXlogo Text
17:30:42.6 1/14/2012: Creating Surfaces Toolbar
17:30:42.7 1/14/2012: Creating Surfaces Toolbar Controls
17:30:42.8 1/14/2012: Creating Surfaces Backgrounds
17:30:42.8 1/14/2012: Creating Surfaces GameEx Logo
17:30:42.8 1/14/2012: Creating Surface Unselected
17:30:42.8 1/14/2012: Creating Surfaces Home & Exit
17:30:42.9 1/14/2012: Creating Surfaces Snaps
17:30:42.9 1/14/2012: Creating Surfaces Menu and List Bars
17:30:43.2 1/14/2012: Creating Fonts
17:30:43.2 1/14/2012: Creating Game Font
17:30:43.6 1/14/2012: Creating Game Font Faded
17:30:43.7 1/14/2012: Creating Title Font
17:30:43.7 1/14/2012: Restoring Title Font From Cache
17:30:44.2 1/14/2012: Creating Menu Font
17:30:44.3 1/14/2012: Creating Font Black
17:30:44.4 1/14/2012: Creating Font Black Small
17:30:44.6 1/14/2012: Fonts Created Succesfully
17:30:44.6 1/14/2012: 8MB Video Memory Used
17:30:45.2 1/14/2012: Attempting to load game list
17:30:45.6 1/14/2012: MAME CMD options: -nowindow -joy -skip_gameinfo
17:30:45.7 1/14/2012: Creating DirectSound Device
17:30:45.7 1/14/2012: Trying: Primary Sound Driver
17:30:45.7 1/14/2012: Loading Sound Files
17:30:45.9 1/14/2012: DirectSound Device Created Successfully
17:30:45.9 1/14/2012: Initialising DirectInput for Gamepad support
17:30:46.0 1/14/2012: Unable to create a joystick device
17:30:46.0 1/14/2012: Loading Start Page
17:30:46.2 1/14/2012: Initializing MCE Remote
17:30:46.2 1/14/2012: Playing intro sound file
17:30:46.2 1/14/2012: Initialization OK! Starting GameEx!
17:30:46.2 1/14/2012: Testing Main Loop Once: Processing Frame
17:30:47.2 1/14/2012: Testing Main Loop Once: Main Loop ran successfully
17:31:14.0 1/14/2012: GameEx configuration updated, reinitialising
17:31:14.0 1/14/2012: Reloading Configuration file
17:31:14.1 1/14/2012: Getting Configuration Values
17:31:14.1 1/14/2012: Using Theme: Arcade84 Dark
17:31:14.1 1/14/2012: Checking for alternate Image Directory for Theme: Arcade84 Dark
17:31:14.1 1/14/2012: Initialising Video/MNG DLL's
17:31:14.1 1/14/2012: GameEx will check for media insertion (may affect performance)
17:31:14.1 1/14/2012: Hiding Taskbar
17:31:14.1 1/14/2012: Is Media Center running?
17:31:14.1 1/14/2012: Checking/Creating LCD Registry values
17:31:14.1 1/14/2012: Check Media Center Exit/Start Mode
17:31:14.1 1/14/2012: Media Center Mode 2
17:31:14.1 1/14/2012: Video previews on. Warning: Only recommended on modern systems
17:31:14.1 1/14/2012: Snap Delay set to: 4
17:31:14.1 1/14/2012: Get other settings
17:31:14.1 1/14/2012: Set: Find emulator artwork on best match basis
17:31:14.1 1/14/2012: Compacting Database
17:31:14.5 1/14/2012: Error: Could not compact database data.mdb
17:31:14.6 1/14/2012: Opening Database Connection
17:31:14.6 1/14/2012: MAME Path is: C:\Emulators\Mame32
17:31:14.6 1/14/2012: MAME EXE file is: MameUI32.exe
17:31:14.6 1/14/2012: ROM Path is: C:\Emulators\Mame32\Roms
17:31:14.6 1/14/2012: Catver.ini is located at: C:\GameEx\DATA\catver.ini
17:31:14.6 1/14/2012: controls.ini is located at: C:\GameEx\DATA\controls.ini
17:31:14.6 1/14/2012: History.dat is located at: C:\GameEx\DATA\history.dat
17:31:14.6 1/14/2012: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
17:31:14.6 1/14/2012: command.dat is located at: C:\GameEx\DATA\command.dat
17:31:14.6 1/14/2012: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
17:31:14.6 1/14/2012: Snap Path is: C:\Emulators\Mame32\snap
17:31:14.6 1/14/2012: Background Snap Path is: C:\Emulators\Mame32\snap
17:31:14.6 1/14/2012: AVI Snap Path is: C:\Emulators\Mame32\avisnap
17:31:14.6 1/14/2012: Flyer Path is: C:\Emulators\Mame32\flyers
17:31:14.6 1/14/2012: Cabinet Path is: C:\Emulators\Mame32\cabinets
17:31:14.6 1/14/2012: Cabinet 3D Path: Not Found
17:31:14.6 1/14/2012: Title Path is: C:\Emulators\Mame32\titles
17:31:14.6 1/14/2012: PCB Path: Not Found
17:31:14.6 1/14/2012: Artwork Preview Path: Not Found
17:31:14.6 1/14/2012: Panel Path is: C:\Emulators\Mame32\cpanel
17:31:14.6 1/14/2012: Manual Path: Not Found
17:31:14.6 1/14/2012: Icon Path is: C:\Emulators\Mame32\icons
17:31:14.6 1/14/2012: Marquee Path is: C:\Emulators\Mame32\marquees
17:31:14.6 1/14/2012: Applying Language/Text
17:31:14.6 1/14/2012: Text/Language: English
17:31:14.6 1/14/2012: Loading Custom Emulators
17:31:14.6 1/14/2012: Loading Emulator 1: [Arcade] Arcade (MAME)
17:31:14.6 1/14/2012: Using 2D Animations
17:31:14.6 1/14/2012: Retrieving resolution setting
17:31:14.6 1/14/2012: Using General Font: Verdana
17:31:14.6 1/14/2012: Using Title Font: Verdana
17:31:14.6 1/14/2012: GameEx will try to reduce CPU usage
17:31:14.6 1/14/2012: Initialising Direct3D
17:31:14.6 1/14/2012: Applying GameEx is Loading Image
17:31:14.7 1/14/2012: Setting Resolution to 1824x1028 32 bit color
17:31:14.7 1/14/2012: Creating Surfaces
17:31:14.8 1/14/2012: Creating Primary Surface - Full Screen Mode
17:31:14.8 1/14/2012: Creating Back Buffer
17:31:14.8 1/14/2012: Version 2 Theme being used. Loading.
17:31:14.8 1/14/2012: Loading Button Data
17:31:14.8 1/14/2012: Loading Font Data
17:31:14.8 1/14/2012: Loading Layout Data
17:31:14.8 1/14/2012: Loading Taskbar Data
17:31:14.9 1/14/2012: Loading graphic Surfaces
17:31:14.9 1/14/2012: Display is running at: 1824x1028 32bit color, 60hz
17:31:14.9 1/14/2012: Adapter: NVIDIA GeForce GT 430
17:31:14.9 1/14/2012: Max texture size: 8192x8192
17:31:14.9 1/14/2012: Available texture memory: 1446MB
17:31:14.9 1/14/2012: Initialising Bass Audio Library
17:31:15.0 1/14/2012: Creating Surfaces Misc and Dialogs
17:31:15.2 1/14/2012: Creating Surfaces Volume
17:31:15.2 1/14/2012: Creating Surfaces Arrows
17:31:15.2 1/14/2012: Creating Surfaces GameEXlogo Text
17:31:15.2 1/14/2012: Creating Surfaces Toolbar
17:31:15.4 1/14/2012: Creating Surfaces Toolbar Controls
17:31:15.5 1/14/2012: Creating Surfaces Backgrounds
17:31:15.5 1/14/2012: Creating Surfaces GameEx Logo
17:31:15.5 1/14/2012: Creating Surface Unselected
17:31:15.5 1/14/2012: Creating Surfaces Home & Exit
17:31:15.6 1/14/2012: Creating Surfaces Snaps
17:31:15.6 1/14/2012: Creating Surfaces Menu and List Bars
17:31:15.7 1/14/2012: Creating Fonts
17:31:15.7 1/14/2012: Creating Game Font
17:31:15.9 1/14/2012: Creating Game Font Faded
17:31:16.0 1/14/2012: Creating Title Font
17:31:16.6 1/14/2012: Creating Menu Font
17:31:16.6 1/14/2012: Creating Font Black
17:31:16.7 1/14/2012: Creating Font Black Small
17:31:16.8 1/14/2012: Fonts Created Succesfully
17:31:16.8 1/14/2012: 8MB Video Memory Used
17:31:17.5 1/14/2012: Attempting to load game list
17:31:17.7 1/14/2012: MAME CMD options: -nowindow -joy -skip_gameinfo
17:31:17.7 1/14/2012: Loading Start Page
17:31:17.7 1/14/2012: Initializing MCE Remote
17:31:17.8 1/14/2012: Testing Main Loop Once: Main Loop ran successfully
17:31:40.9 1/14/2012: Exiting GameEx!
17:31:40.9 1/14/2012: Disposing all videos
17:31:41.0 1/14/2012: Deleting temporary Karaoke videos
17:31:41.0 1/14/2012: Disposing Image List
17:31:41.0 1/14/2012: Disposing Fonts
17:31:41.0 1/14/2012: Disposing Surfaces
17:31:41.0 1/14/2012: Saving Settings
17:31:41.0 1/14/2012: Shutting down Bass
17:31:41.1 1/14/2012: Closing HideOS.exe
17:31:42.3 1/14/2012: Disposing Plugins
17:31:42.3 1/14/2012: Closing database connection
17:31:42.3 1/14/2012: Checking for applications to Launch On Exit
17:31:42.3 1/14/2012: Bye
I had a similar issue - hit Change View multiple times until the view shows correctly.
