deadboy Posted January 4, 2012 Share Posted January 4, 2012 I picked up another Golden Tee cabinet for purposes of turning it into a MAME for a friend. It came with the little "Tournament Play" LED display.I've heard these are impossible/a huge pain in the @$$ to repurpose for just general LED display usage. Has anyone around here tried this? Any tips? Would I be better just pulling out the board and display and just replaced it with one that's a little more user friendly?Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Adultery Posted January 5, 2012 Share Posted January 5, 2012 Does it plug in to your PC using a serial cable, and if so, can LedWiz work it? Quote Link to comment Share on other sites More sharing options...
Draco1962 Posted January 5, 2012 Share Posted January 5, 2012 I believe they use a special EPROM and that there is no interface available except through the manufacturer. Might be able to Ebay it though for someone else trying to complete a Golden Tee cab. Quote Link to comment Share on other sites More sharing options...
deadboy Posted January 5, 2012 Author Share Posted January 5, 2012 Yeah, it's got a special plug and an EPROM that's turning out to be a VERY proprietary system to Golden Tee. I was HOPING to use it for my MAME cab since it's made to fit on top of it. Quote Link to comment Share on other sites More sharing options...
headkaze Posted January 5, 2012 Share Posted January 5, 2012 You would probably have to change it to a generic LED scrolly sign. The LCD/LED Plugin supports Pro-Lite PL-M2014R and some BetaBrite signs. It support BetaBrite via USB so that is probably the best option. Quote Link to comment Share on other sites More sharing options...
