Open your theme in Theme Editor, click on Edit, then Options, then click the Fonts tab. There you can change your Main Font and Title Font name, size, and style. You can also select your Text Color and Outline Color. As it stands now, whatever color you select will be for both Main and Title. They are not independently selectible, although numerous requests have been made to have this changed as part of a new Feature or Enhancement.
Hi,
I'm working on a theme for GameEx and I would like to know how to change the font color ?
Thanks for help
Myg
Myg - if you are wanting to change the title, then why did you ask how to change the font color? I don't think that anything was lost in translation! ;)
You will have to modify it in the Text/Languages section of the Setup Wizard or manually modify the language .ini file for the language you are using and locate Start=Start.. and change it to read Start=Choose System. It is in the GameEx\languages folder.
you're right, I should add that I also wanted to change the title.
Thank you =)
