Updated to the latest version of Gameex this morning. Wanted to see and use the new preview on karaoke. A great feature. After the update non of my karaoke works. Makes no difference if the are zipped or unzipped.
  • Replies 94
  • Created
  • Last Reply
Top Posters In This Topic
  On 11/29/2011 at 8:04 PM, TSpeirs said:
Do the previews work? What exactly happens?
Hi Tom,
No previews at all. still have previews for movies, games, etc. When you click a song, it says playing in the bottom left corner for a few seconds and then goes away. song never plays. I have a friend who just signed up for Gameex several days ago just for the karaoke after seeing mine. His reacts the same way I'm using the megamane theme. He's using the default list.
  On 11/29/2011 at 9:37 PM, starbuck said:
Hi Tom,
Could I see a log please.
What codecs do you have installed on your system?
Gameex ini attached, using shark codec
Excellent choice of theme by the way... ;)
Sorry to hijack. Lol!
Best frontend to date. Waiting for a few more pages of emulators :o
  On 11/29/2011 at 10:28 PM, TSpeirs said:
I need the log, when attempting to load Karaoke, but please wait for 12.38 before doing so.
Will do , have the log 2 replys up for 12.37. Whne I see 12.38 I will dl then run karaoke and then post log. Do you want me to just run update or dl the update and then install manually
PS: Baks for 100+ emus you might be waiting a minute! Lol!
Have 210 emu running, be waiting longer than a minute <_<
would like a nbak that when you select a system and it foes to the system, it says select game
log for 12.38 won't run karaoke either zipped or non zipped
16:49:24.9 11/29/2011: Opening Configuration File
16:49:25.0 11/29/2011: GameEx: Version 12.38: Starting Log
16:49:25.0 11/29/2011: Operating System Platform: Win32NT
16:49:25.0 11/29/2011: Operating System Name: Windows XP
16:49:25.0 11/29/2011: Operating System Version: 5.1.2600
16:49:25.0 11/29/2011: Intel® Core2 Duo CPU T6570 @ 2.10GHz, 2940MB
16:49:25.0 11/29/2011: 2.09Ghz - 2 Cores or CPU's
16:49:25.0 11/29/2011: Running Randomize()
16:49:25.0 11/29/2011: Loading PlugIns
16:49:25.0 11/29/2011: Checking for applications to Launch On Startup
16:49:25.0 11/29/2011: Running Misc startup tasks
16:49:25.0 11/29/2011: Setting Menu types
16:49:25.0 11/29/2011: Getting Configuration Values
16:49:25.0 11/29/2011: Using Theme: Default - MegaMame - 1680x1050
16:49:25.0 11/29/2011: Checking for alternate Image Directory for Theme: Default - MegaMame - 1680x1050
16:49:25.0 11/29/2011: Launching HideOS.exe
16:49:25.1 11/29/2011: Initialising Video/MNG DLL's
16:49:25.1 11/29/2011: GameEx will check for media insertion (may affect performance)
16:49:25.1 11/29/2011: Hiding Taskbar
16:49:25.1 11/29/2011: Is Media Center running?
16:49:25.1 11/29/2011: Checking/Creating LCD Registry values
16:49:25.1 11/29/2011: Check Media Center Exit/Start Mode
16:49:25.1 11/29/2011: Media Center Mode 2
16:49:25.1 11/29/2011: Video previews on. Warning: Only recommended on modern systems
16:49:25.1 11/29/2011: Snap Delay set to: 5
16:49:25.1 11/29/2011: Get other settings
16:49:25.1 11/29/2011: Desktop set to Hide ICONS and set Background to Black
16:49:25.1 11/29/2011: Set: Find emulator artwork on best match basis
16:49:25.1 11/29/2011: Start work for Form
16:49:25.1 11/29/2011: Getting Original Screen Size
16:49:25.2 11/29/2011: Compacting Database
16:49:25.5 11/29/2011: Opening Database Connection
16:49:25.5 11/29/2011: Initializing Component
16:49:25.6 11/29/2011: MAME Path is: C:\Emulators\MAME
16:49:25.6 11/29/2011: MAME EXE file is: mame.exe
16:49:25.6 11/29/2011: ROM Path is: C:\Roms\Mame
16:49:25.6 11/29/2011: Catver.ini is located at: C:\GameEx\DATA\catver.ini
16:49:25.6 11/29/2011: controls.ini is located at: C:\GameEx\data\controls.ini
16:49:25.6 11/29/2011: History.dat is located at: C:\GameEx\DATA\history.dat
16:49:25.6 11/29/2011: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
16:49:25.6 11/29/2011: command.dat is located at: C:\GameEx\DATA\command.dat
16:49:25.6 11/29/2011: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
16:49:25.7 11/29/2011: Loading Controls.ini map file
16:49:25.7 11/29/2011: Snap Path is: C:\Assets\MAME\Snap
16:49:25.7 11/29/2011: AVI Snap Path is: C:\Assets\MAME\Video_AVI_HI_QUAL
16:49:25.7 11/29/2011: Flyer Path is: C:\Assets\MAME\Advert
16:49:25.7 11/29/2011: Cabinet Path is: C:\Assets\MAME\Cabinet
16:49:25.7 11/29/2011: Cabinet 3D Path is: C:\Emulators\MAME\3D Cabinets
16:49:25.7 11/29/2011: Title Path is: C:\Assets\MAME\Title
16:49:25.7 11/29/2011: PCB Path is: C:\Assets\MAME\PCB
16:49:25.7 11/29/2011: Artwork Preview Path is: C:\Assets\MAME\Artwork
16:49:25.7 11/29/2011: Panel Path is: C:\Assets\MAME\CP
16:49:25.7 11/29/2011: Manual Path is: C:\Assets\MAME\Manuals
16:49:25.7 11/29/2011: Icon Path is: C:\Assets\MAME\Icon
16:49:25.7 11/29/2011: Marquee Path is: C:\Assets\MAME\Marquee
16:49:25.7 11/29/2011: Applying Language/Text
16:49:25.7 11/29/2011: Text/Language: English
16:49:25.7 11/29/2011: Loading Custom Emulators
16:49:25.7 11/29/2011: Loading Emulator 2: [Arcade] AAE
16:49:25.7 11/29/2011: Loading Emulator 3: [Arcade] Arcade (Raine)
16:49:25.7 11/29/2011: Loading Emulator 4: [Arcade] Arcade EmuDX (Raine)
16:49:25.7 11/29/2011: Loading Emulator 5: [Arcade] CPS-1
16:49:25.7 11/29/2011: Loading Emulator 6: [Arcade] CPS-2
16:49:25.7 11/29/2011: Loading Emulator 7: [Arcade] CPS-3
16:49:25.7 11/29/2011: Loading Emulator 8: [Arcade] FB Alpha
16:49:25.8 11/29/2011: Loading Emulator 10: [Arcade] MisFitMAME
16:49:25.8 11/29/2011: Loading Emulator 11: [Arcade] Mjolnir
16:49:25.8 11/29/2011: Loading Emulator 12: [Arcade] Nebula
16:49:25.8 11/29/2011: Loading Emulator 13: [Arcade] Sammy Atomiswave (DEmul)
16:49:25.8 11/29/2011: Loading Emulator 14: [Arcade] Sega Model 2
16:49:25.8 11/29/2011: Loading Emulator 15: [Arcade] Sega Naomi (DEmul)
16:49:25.8 11/29/2011: Loading Emulator 16: [Arcade] WinKawaks
16:49:25.8 11/29/2011: Loading Emulator 17: [Arcade] ZiNc
16:49:25.8 11/29/2011: Loading Emulator 18: [Console] Atari 2600 (MESS)
16:49:25.8 11/29/2011: Loading Emulator 19: [Console] Atari 5200 (MESS)
16:49:25.8 11/29/2011: Loading Emulator 20: [Console] Atari 7800 (MESS)
16:49:25.8 11/29/2011: Loading Emulator 21: [Console] Atari Jaguar (Virtual Jaguar)
16:49:25.8 11/29/2011: Loading Emulator 22: [Console] Atari Jaguar CD (Virtual Jaguar)
16:49:25.8 11/29/2011: Loading Emulator 23: [Console] Bally Astrocade (MESS)
16:49:25.8 11/29/2011: Loading Emulator 24: [Console] Casio Loopy (MESS)
16:49:25.8 11/29/2011: Loading Emulator 25: [Console] Coleco Vision (MESS)
16:49:25.8 11/29/2011: Loading Emulator 26: [Console] Emerson Arcadia 2001 (Mess)
16:49:25.8 11/29/2011: Loading Emulator 27: [Console] Fairchild Channel F (MESS)
16:49:25.8 11/29/2011: Loading Emulator 28: [Console] Fujitsu FM-Towns Marty (UNZ)
16:49:25.8 11/29/2011: Loading Emulator 29: [Console] GamePark GP32 (GeePee32)
16:49:25.9 11/29/2011: Loading Emulator 30: [Console] GCE Vectrex (ParaJVE)
16:49:25.9 11/29/2011: Loading Emulator 31: [Console] Hartung Game Master (MESS)
16:49:25.9 11/29/2011: Loading Emulator 32: [Console] Magnavox Odyssey (ODYEmu)
16:49:25.9 11/29/2011: Loading Emulator 33: [Console] Magnavox Odyssey 2 (O2EM)
16:49:25.9 11/29/2011: Loading Emulator 34: [Console] Mattel Intellivision (Nostalgia)
16:49:25.9 11/29/2011: Loading Emulator 35: [Console] Microsoft Xbox (Cxbx)
16:49:25.9 11/29/2011: Loading Emulator 36: [Console] NEC PC-Engine (mednafen)
16:49:25.9 11/29/2011: Loading Emulator 37: [Console] NEC Pc-Engine CD (mednafen)
16:49:25.9 11/29/2011: Loading Emulator 38: [Console] NEC PC-FX (mednafen)
16:49:25.9 11/29/2011: Loading Emulator 39: [Console] NEC SuperGrafx (mednafen)
16:49:25.9 11/29/2011: Loading Emulator 40: [Console] NEC TurboGrafx CD (mednafen)
16:49:25.9 11/29/2011: Loading Emulator 41: [Console] NEC TurboGrafx-16 (mednafen)
16:49:25.9 11/29/2011: Loading Emulator 42: [Console] Nintendo Famicom Disk (MESS)
16:49:25.9 11/29/2011: Loading Emulator 43: [Console] Nintendo GameCube (Dolphin)
16:49:25.9 11/29/2011: Loading Emulator 44: [Console] Nintendo N64 (USA) (Project64)
16:49:25.9 11/29/2011: Loading Emulator 45: [Console] Nintendo NES (USA) (MESS)
16:49:25.9 11/29/2011: Loading Emulator 46: [Console] Nintendo Pokemon Mini (Minmon)
16:49:25.9 11/29/2011: Loading Emulator 47: [Console] Nintendo SNES (USA) (MESS)
16:49:25.9 11/29/2011: Loading Emulator 48: [Console] Nintendo Wii (Dolphin)
16:49:25.9 11/29/2011: Loading Emulator 49: [Console] Panasonic 3DO
16:49:26.0 11/29/2011: Loading Emulator 50: [Console] Philips - Videopac+ (O2EM)
16:49:26.0 11/29/2011: Loading Emulator 51: [Console] Phillips CD-I (MESS)
16:49:26.0 11/29/2011: Loading Emulator 52: [Console] RCA Studio II (MESS)
16:49:26.0 11/29/2011: Loading Emulator 53: [Console] Sega 32x (USA) (Fusion)
16:49:26.0 11/29/2011: Loading Emulator 54: [Console] Sega CD (Fusion)
16:49:26.0 11/29/2011: Loading Emulator 55: [Console] Sega Dreamcast (nullDC)
16:49:26.0 11/29/2011: Loading Emulator 56: [Console] Sega Genesis (Fusion)
16:49:26.0 11/29/2011: Loading Emulator 57: [Console] Sega Master System (USA) (Fusion)
16:49:26.0 11/29/2011: Loading Emulator 58: [Console] Sega Mega CD (Fusion)
16:49:26.0 11/29/2011: Loading Emulator 59: [Console] Sega Mega Drive (Japan) (Fusion)
16:49:26.0 11/29/2011: Loading Emulator 60: [Console] Sega Pico (Fusion)
16:49:26.0 11/29/2011: Loading Emulator 61: [Console] Sega Saturn (SSF)
16:49:26.0 11/29/2011: Loading Emulator 62: [Console] Sega SG-1000 (Mess)
16:49:26.0 11/29/2011: Loading Emulator 63: [Console] SNK Neo-Geo (Mame)
16:49:26.0 11/29/2011: Loading Emulator 64: [Console] SNK Neo-Geo CD (NeoRaine)
16:49:26.1 11/29/2011: Loading Emulator 65: [Console] Sony Playstation (ePSXe)
16:49:26.1 11/29/2011: Loading Emulator 66: [Console] Sony Playstation 2 (PCSX2)
16:49:26.1 11/29/2011: Loading Emulator 67: [Console] Sony Pocketstation (PKEmu)
16:49:26.1 11/29/2011: Loading Emulator 68: [Console] Tangerine Oric (MESS)
16:49:26.1 11/29/2011: Loading Emulator 69: [Console] Tsukuda Othello Multivision
16:49:26.1 11/29/2011: Loading Emulator 70: [Console] Vtech CreatiVision (MESS)
16:49:26.1 11/29/2011: Loading Emulator 71: [Fruit] Fruit (BFM)
16:49:26.1 11/29/2011: Loading Emulator 72: [Fruit] Fruit (MFME)
16:49:26.1 11/29/2011: Loading Emulator 73: [Handheld] Atari Lynx (mednafen)
16:49:26.1 11/29/2011: Loading Emulator 74: [Handheld] Bandai WonderSwan (mednafen)
16:49:26.1 11/29/2011: Loading Emulator 75: [Handheld] Bandai WonderSwan Color (mednafen)
16:49:26.1 11/29/2011: Loading Emulator 76: [Handheld] CVT Mega Duck/Cougar Boy (MESS)
16:49:26.1 11/29/2011: Loading Emulator 77: [Handheld] Entex Adventure Vision (MESS)
16:49:26.1 11/29/2011: Loading Emulator 78: [Handheld] Hartung Game Master (MESS)
16:49:26.1 11/29/2011: Loading Emulator 79: [Handheld] Nintendo DS (DeSmuME)
16:49:26.1 11/29/2011: Loading Emulator 80: [Handheld] Nintendo Game Boy (USA) (VisualBoyAdvance)
16:49:26.1 11/29/2011: Loading Emulator 81: [Handheld] Nintendo Game Boy Advance (USA) (VisualBoyAdvance)
16:49:26.2 11/29/2011: Loading Emulator 82: [Handheld] Nintendo Game Boy Color (VisualBoyAdvance)
16:49:26.2 11/29/2011: Loading Emulator 83: [Handheld] Nintendo Super Game Boy (BGB)
16:49:26.2 11/29/2011: Loading Emulator 84: [Handheld] Nintendo Virtual Boy (Reality Boy)
16:49:26.2 11/29/2011: Loading Emulator 85: [Handheld] Sega Game Gear (USA) (Fusion)
16:49:26.2 11/29/2011: Loading Emulator 86: [Handheld] SNK Neo-Geo Pocket (mednafen)
16:49:26.2 11/29/2011: Loading Emulator 87: [Handheld] SNK Neo-Geo Pocket Color (mednafen)
16:49:26.2 11/29/2011: Loading Emulator 88: [HandHeld] Sony PSP (PCSP)
16:49:26.2 11/29/2011: Loading Emulator 89: [Handheld] Watara Supervision (MESS)
16:49:26.2 11/29/2011: Loading Emulator 90: [PC] Apple IIc (MESS)
16:49:26.2 11/29/2011: Loading Emulator 91: [PC] Atari 8-Bit (Altirra)
16:49:26.2 11/29/2011: Loading Emulator 92: [PC] Coleco Vision Adam (MESS)
16:49:26.2 11/29/2011: Loading Emulator 93: [PC] Commodore 128 (WinVice)
16:49:26.2 11/29/2011: Loading Emulator 94: [PC] Commodore 64 (WinVice)
16:49:26.3 11/29/2011: Loading Emulator 95: [PC] Commodore Amiga (GameBase)
16:49:26.3 11/29/2011: Loading Emulator 96: [PC] Commodore CBM-II (WinVice)
16:49:26.3 11/29/2011: Loading Emulator 97: [PC] Commodore PET (WinVice)
16:49:26.3 11/29/2011: Loading Emulator 98: [PC] Commodore PLUS4 (WinVice)
16:49:26.3 11/29/2011: Loading Emulator 99: [PC] Commodore VIC20 (WinVice)
16:49:26.3 11/29/2011: Loading Emulator 100: [PC] Mattel Aquarius (MESS)
16:49:26.3 11/29/2011: Loading Emulator 101: [PC] MGT Sam Coupe (SimCoupe)
16:49:26.3 11/29/2011: Loading Emulator 102: [PC] Microsoft DOS (DOSBox)
16:49:26.4 11/29/2011: Loading Emulator 103: [PC] Microsoft MSX (MESS)
16:49:26.4 11/29/2011: Loading Emulator 104: [PC] Microsoft MSX 2 (blueMSX)
16:49:26.4 11/29/2011: Loading Emulator 105: [PC] Microsoft Windows
16:49:26.4 11/29/2011: Loading Emulator 106: [PC] PopCap Game Collection
16:49:26.4 11/29/2011: Loading Emulator 107: [PC] Scumm (ScummVM)
16:49:26.4 11/29/2011: Loading Emulator 108: [PC] Sega SC-3000 (MESS)
16:49:26.4 11/29/2011: Loading Emulator 109: [PC] Sega SF-7000 (MESS)
16:49:26.4 11/29/2011: Loading Emulator 110: [PC] Sinclair ZX Spectrum (Spectaculator)
16:49:26.4 11/29/2011: Loading Emulator 111: [PC] Spectravideo SVI 318-328
16:49:26.4 11/29/2011: Loading Emulator 112: [PC] Z-Code Interactive Fiction (Frontz)
16:49:26.4 11/29/2011: Loading Emulator 113: [Pinball] Future Pinball
16:49:26.5 11/29/2011: Loading Emulator 114: [Pinball] Visual Pinball
16:49:26.5 11/29/2011: Loading Emulator 116: Adobe Flash Games
16:49:26.5 11/29/2011: Loading Emulator 117: Comic Book Reader
16:49:26.5 11/29/2011: Loading Emulator 118: FretsOnFire
16:49:26.5 11/29/2011: Loading Emulator 119: UltraStar Deluxe
16:49:26.5 11/29/2011: Using Version 3 Themes Animations
16:49:26.5 11/29/2011: Retrieving resolution setting
16:49:26.5 11/29/2011: Using General Font: Tahoma
16:49:26.5 11/29/2011: Using Title Font: Tahoma
16:49:26.6 11/29/2011: Initialising Direct3D
16:49:26.6 11/29/2011: Applying GameEx is Loading Image
16:49:26.7 11/29/2011: Setting Resolution to 1366x768 32 bit color
16:49:26.7 11/29/2011: Creating Surfaces
16:49:27.4 11/29/2011: Creating Primary Surface - Full Screen Mode
16:49:27.4 11/29/2011: Creating Back Buffer
16:49:27.4 11/29/2011: Version 2 Theme being used. Loading.
16:49:27.4 11/29/2011: Loading Button Data
16:49:27.5 11/29/2011: Loading Font Data
16:49:27.5 11/29/2011: Loading Layout Data
16:49:27.5 11/29/2011: Loading Taskbar Data
16:49:27.5 11/29/2011: Loading graphic Surfaces
16:49:27.5 11/29/2011: Display is running at: 1366x768 32bit color, 60hz
16:49:27.5 11/29/2011: Adapter: Mobile Intel® 4 Series Express Chipset Family
16:49:27.5 11/29/2011: Max texture size: 4096x4096
16:49:27.5 11/29/2011: Available texture memory: 985MB
16:49:27.5 11/29/2011: Initialising Bass Audio Library
16:49:27.6 11/29/2011: Creating Surfaces Misc and Dialogs
16:49:27.7 11/29/2011: Creating Surfaces Volume
16:49:27.7 11/29/2011: Creating Surfaces Arrows
16:49:27.7 11/29/2011: Creating Surfaces GameEXlogo Text
16:49:27.7 11/29/2011: Creating Surfaces Toolbar
16:49:27.8 11/29/2011: Creating Surfaces Toolbar Controls
16:49:27.8 11/29/2011: Creating Surfaces Backgrounds
16:49:27.8 11/29/2011: Creating Surfaces GameEx Logo
16:49:27.8 11/29/2011: Creating Surface Unselected
16:49:27.8 11/29/2011: Creating Surfaces Snaps
16:49:27.8 11/29/2011: Creating Surfaces Menu and List Bars
16:49:27.9 11/29/2011: Creating Fonts
16:49:27.9 11/29/2011: Creating Game Font
16:49:28.0 11/29/2011: Creating Game Font Faded
16:49:28.1 11/29/2011: Creating Title Font
16:49:28.1 11/29/2011: Restoring Title Font From Cache
16:49:28.3 11/29/2011: Creating Font Black
16:49:28.3 11/29/2011: Creating Font Black Small
16:49:28.4 11/29/2011: Fonts Created Succesfully
16:49:28.4 11/29/2011: 6MB Video Memory Used
16:49:28.5 11/29/2011: Loading News Feed: http://www.gameex.net/gameexnews.xml
16:49:29.5 11/29/2011: Attempting to load game list
16:49:29.5 11/29/2011: MAME CMD options: -nowindow -joy -skip_gameinfo
16:49:29.5 11/29/2011: Creating DirectSound Device
16:49:29.5 11/29/2011: Trying: Primary Sound Driver
16:49:29.5 11/29/2011: Loading Sound Files
16:49:29.5 11/29/2011: DirectSound Device Created Successfully
16:49:29.6 11/29/2011: Initialising DirectInput for Gamepad support
16:49:29.6 11/29/2011: Unable to create a joystick device
16:49:29.6 11/29/2011: Loading Start Page
16:49:29.7 11/29/2011: Initializing MCE Remote
16:49:29.7 11/29/2011: Playing intro sound file
16:49:29.7 11/29/2011: Initialization OK! Starting GameEx!
16:49:29.7 11/29/2011: Testing Main Loop Once: Processing Frame
16:49:30.0 11/29/2011: Testing Main Loop Once: Main Loop ran successfully
16:49:43.5 11/29/2011: No Karaoke Cache, scanning files
16:49:46.8 11/29/2011: Failed Opening Video: c:\karaoke\spc001 - 12 - spears, britney - baby one more time.zip
16:49:52.1 11/29/2011: Failed Opening Video: c:\karaoke\spc006 - 01 - gaynor, gloria - i will survive.cdg
16:50:03.6 11/29/2011: Exiting GameEx!
16:50:03.6 11/29/2011: Saving Settings
16:50:05.8 11/29/2011: Disposing Plugins
16:50:05.8 11/29/2011: Closing database connection
16:50:05.9 11/29/2011: Checking for applications to Launch On Exit
Tell me what you mean by nbak or explain it and I'll gladly make you one! ;)
Doesn't the default emubak.PNG say 'select a game' in the header?
I am on 12.38 right now and no problems with seeing Karaoke vid display as I page through my list or playing upon selection. My songs, however, are not in .7z or .zip format.
When you have a background for a emulator and you pick the system it goes and shows a top ribbion that shows the system name. If you don't have a background it says select a game. Would like the statement select a game somewhere on the ribbon when you have a background. So my stupid friends won't ask me what do i do next. I've also attached a set of ribbions I got awhile back that has a lot of systems that you don't have backgrounds for. Maybe you can use them, maybe not.
OK so to make sure I understand:
You select SNES and Snes.bak comes up. You pick Super Mario World and Snes.bak is still up, but you want a system based emubaks.PNG that says "select a game" instead of "Super Nintendo"... so like a snesgameselect.bak? That's a feature request but I'd be happy to add them (its really just a minor change on the psd).
  On 11/29/2011 at 11:02 PM, TSpeirs said:
Do you have a media\copiedvideos folder? What is in there?
Sorry to derail the thread Tom. :(
I'll try not to bury the important stuff.
What OS are you running?
running windows xp . Friend i just had sign up has windows 7. Both working same way
Could you anwser my other question about the media\copiedvideos folder.
