Hello
Actualy I'm launching iTune using a false emulator config like starting windows games (*.ink).
What I'd like to do is to create a launch shortcut in multimedia category.
Is that possible and how set it up in gameEx ?
Thanks for your help
  • 4 weeks later...
Why not just use it as an external app?
Whether or not you setup it up as an emulator or external app (which I think works out better in general), you will probably need to add it to the Multimedia category by creating Custom Menus using the Custom Menus application that is part of your GameEx install and a registered version feature.
