How/where can I change the descriptions/bios that appear with the games.
Secondly I have an x arcade 2 player tankstick with a track ball.
The button display that appears before playing a mame game
does not have enough buttons nor a trackball.
So I can't appropriately label the buttons to my liking.
I'm sure a bunch of other people who have a tankstick must also
have this problem... anyway around it?
First off, the game info for roms can be changed or configured within the .mdb file for that emulator, located in the DATA folder in the GameEx folder install location.
As for the Tank Stick, go grab CPWizard and give that a shot. It's a great tool that can be configured to your individual CP setup.
+1 for CP Wizard. It's awesome, not a beast to get going, and works natively with GameEx. :)
PS: Good choice on that xarcade setup. They got great stuff over there. :)
Any database editor should do. I use Access but theres probably a free alternative like Open Office that can do it.
+1 for OpenOffice! A Great, FREE alternative to the MS products.
Tried open office.. it opens it but it's just a bunch of symbols..
and like a million ###### marks... anyway to open it and see it
legibly?
I see their are descriptions mixed in. But if add a word and go
back in gameex there nolonger is descriptions for any game of that
system.. luckily I backed up that file before fooling around.
You using a database editor? My friend Drac here does db in OO I think...
Really what I'm trying to do is show a list of cheats for that game
after the description. But how would I do this as an alternative..
You know how you can look at your box art.. then under that your manual
or whatever.. is there anyway I could make a new folder and put a png image
of a little cheat sheet or something in that.. and have that be in the categorys..
or are they just restricted to box art,manual,cartridge etc.
Thanks for the help guys.
You could create an image file and each emulator has options to enable for custom artwork paths. So long as the image is named the same as the ROM and is in that custom artwork path, you will be able to see it.
Love the custom artwork paths! :)
Spot on idea there dukeofarcadia and Drac!. I like that see cheats idea. You're on to something there, sirs.
Can you also view the custom artwork pressing the 0 key in-game? That would also be sweet!
Damn that may be work! But I can already see the advantages. Especially with GameExtender...
I've already tried it adultery and you can!
I made one for splatterhouse 3 on genesis.
I even put some stencil art from the game on
top and blood splatters towards the edges.. so you can kinda
make artistic little cheat sheets it's pretty cool.
and you can press zero and check them anytime.
which kind of caused a problem for me in Kega when
entering a game genie code any way to fix that?
cause typing 0 exits you out
Hey maybe we could see a whole line of user created cheat sheets
for use in gameex!
You can change the hotkey for that function from 0 to something else... If I were gonna do this I could see how this would be useful. I'd probably just use the same template for the whole system with specific codes for each game. Man that would take a while! It'd be cool if we had easy access to the intel though!
Definitely be cool to see though!
A while back I did a topic on just this idea. I found a database that is updated monthly and that is free and has thousands of cheats for all types of systems. It also a database for dvd bloopers.
The link is www.cheatbook.de
Agree it would be a great feature within GameEx
