15th January 2006
- GameEx 5.37 - lots of new features
  • The initial production
    release of GameExtender is here.
  • As far as I know it's a world
    first for front ends.
  • When enabled GameEx runs a
    tiny web server when running, this outputs sort of
    like an LCD Display on steroids, on either the
    same pc, or any networked or internet worked PC.
  • You can see exactly what's
    going on with GameEx from a web browser, or via
    the included viewer, which gives a full screen
    output.
  • You have to check it out.
  • In addition, I believe
    another world first for an integrated front end is
    the ability to view the control panel while MAME
    is playing, by pressing a defined key (default is
    L). Thanks to HeadKaze for the idea, help and
    inspiration.
  • If that's not enough, in
    advanced emulator config ini's you can now specify
    up to 10 buttons.
  • NOTE: GameExtender
    only works with registered versions of GameEx.
Wow, the CP Viewer works great! I see what you mean about using the pause key too. I suppose I could just disable the 'p' key in mame and assign that in GameEx? Or do you send the 'p' key to mame to unpause?
Also, did you try minimising Mame while showing the CP viewer? From my experiments it would keep Mame paused. If that's the case then 'p' could be used along with any other key.
Also, there is still a little bug that going to the Mame list will jump randomly to down the list (now it's not just skipping the games that start with a number, now it just seems random in the list).
Bloody great release though! Love the CP viewer, havn't had much of a chance to check out the networked stuff. Any basic instructions on how to get it to work? I suppose by saying "from a web brower" you mean just type in the IP address of the machine while GameEx is running or is it more involved? Do you have to turn on the server? Also I guess for dynamic IP's it might be cool to display the IP address on the GameEx screen.
I use Remote Desktop to administer my Mame machine wirelessly. But GameEx will crash when connecting using it. Perhaps this new feature will open up new things like remote administration, perhaps even things like watching people play remotely using a web cam. The mind boggles what this could bring to GameEx B)
i VNC into my gameex machine and it never crashes (shouldnt say that but heh)
not sure what i'll use this gamextender (clever name btw) and cpviewer for but ill give em a go later.
I use ultraVNC on my arcade machine and GameEx has been crashing. I thought it was just me and was going to format and start over. Maybe I'll try to play with it a bit first.
I can't wait to get home and try out the Extender. Thank you sooo much Tom!
-Matt
Hi Tom,
I'm so excited about the new features. I can't launch a game though, I get this crash report.
MAME32 103u2 / XP Pro
14:45:54.8 1/15/2006: GameEx: Version 5.37: Starting Log
14:45:55.7 1/15/2006: Operating System Platform: Win32NT
14:45:55.7 1/15/2006: Operating System Name: Windows XP
14:45:55.7 1/15/2006: Operating System Version: 5.1.2600
14:45:55.7 1/15/2006: Checking for versions of .net Framework installed
14:45:55.7 1/15/2006: .net Framework 1.1 Installed
14:45:55.7 1/15/2006: .net Framework 2.0 Installed
14:45:55.7 1/15/2006: Checking Registration
14:45:55.7 1/15/2006: Running Randomize()
14:45:55.8 1/15/2006: Initialising Video/MNG DLL's
14:45:56.0 1/15/2006: Running Misc startup tasks
14:45:56.0 1/15/2006: Setting Menu types
14:45:56.0 1/15/2006: Opening Configuration File
14:45:56.0 1/15/2006: Getting Configuration Values
14:45:56.0 1/15/2006: Using Theme: Default - BlueEx - Snap
14:45:56.0 1/15/2006: Checking for alternate Image Directory for Theme: Default - BlueEx - Snap
14:45:56.0 1/15/2006: Using Images from theme: Default - BlueEx - MCE1024x768\MEDIA\
14:45:56.0 1/15/2006: Text/Language: English
14:45:56.0 1/15/2006: Applying Language/Text
14:45:56.1 1/15/2006: Creating Scancodes.txt (List of DirectInput scan codes)
14:45:56.1 1/15/2006: Snap Delay set to: 7
14:45:56.1 1/15/2006: Is Media Center running?
14:45:56.1 1/15/2006: Check Media Center Exit/Start Mode
14:45:56.1 1/15/2006: Media Center Mode 0
14:45:56.1 1/15/2006: Checking for applications to Launch On Startup
14:45:56.1 1/15/2006: Get other settings
14:45:56.1 1/15/2006: Using 2D Animations
14:45:56.2 1/15/2006: Mouse Input is disabled
14:45:56.2 1/15/2006: Desktop set to Hide ICONS and set Background to Black
14:45:56.2 1/15/2006: Backing up Registry Wallpaper Settings
14:45:56.2 1/15/2006: Set: Find emulator artwork on best match basis
14:45:56.2 1/15/2006: Using DirectInput for keyboard input
14:45:56.2 1/15/2006: Launching HideOS.exe
14:45:58.0 1/15/2006: Hiding Taskbar
14:45:58.0 1/15/2006: Start work for Form
14:45:58.0 1/15/2006: Getting Original Screen Size
14:45:58.0 1/15/2006: Loading ICON
14:45:58.0 1/15/2006: Initializing Component
14:45:58.2 1/15/2006: Initialising Bass Audio Library
14:45:58.5 1/15/2006: Loading default loading screen
14:45:58.6 1/15/2006: Using General Font: Arial
14:45:58.6 1/15/2006: Using Title Font: Joystix
14:45:58.6 1/15/2006: Initialising DirectDraw
14:45:58.9 1/15/2006: Creating DirectDraw Device
14:45:58.9 1/15/2006: Using Device: Ultimarc ArcadeVGA
14:45:59.0 1/15/2006: Setting Resolution to 640x480 16 bit color
14:45:59.6 1/15/2006: Creating DirectDraw Surfaces
14:45:59.6 1/15/2006: Creating Primary Surface - Full Screen Mode
14:45:59.6 1/15/2006: Creating Back Buffer
14:45:59.6 1/15/2006: Loading graphic surfaces
14:45:59.7 1/15/2006: Creating Surfaces Misc and Dialogs
14:45:59.8 1/15/2006: Creating Surface Volume
14:45:59.8 1/15/2006: Creating Surfaces Arrows
14:45:59.9 1/15/2006: Creating Surfaces GameEXlogo Text
14:45:59.9 1/15/2006: Creating Surfaces Toolbar
14:46:00.0 1/15/2006: Creating Surfaces Backgrounds
14:46:00.0 1/15/2006: Creating Surfaces Toolbar Controls
14:46:00.1 1/15/2006: Creating Surfaces GameEx Logo
14:46:00.1 1/15/2006: Creating Surfaces Home & Exit
14:46:00.2 1/15/2006: Creating Surfaces Snaps
14:46:00.2 1/15/2006: Creating Surfaces Menu and List Bars
14:46:00.3 1/15/2006: Creating Fonts
14:46:00.3 1/15/2006: Creating Menu Font
14:46:00.9 1/15/2006: Creating Game Font
14:46:01.3 1/15/2006: Creating Game Font Standard Size
14:46:01.7 1/15/2006: Creating Font Black
14:46:01.8 1/15/2006: Creating Font Black Small
14:46:01.8 1/15/2006: Creating Game Font Faded
14:46:02.2 1/15/2006: Creating Title Font
14:46:02.9 1/15/2006: Fonts Created Succesfully
14:46:02.9 1/15/2006: MAME Path is: D:\Mame32_103
14:46:02.9 1/15/2006: daphne Path is: D:\daphne-0.99.7-win32
14:46:02.9 1/15/2006: daphne EXE file is: Daphne.exe
14:46:03.0 1/15/2006: Use daphne on. Daphne.exe will launch games
14:46:03.0 1/15/2006: ZiNc Path is: D:\zinc11-win32
14:46:03.0 1/15/2006: ZiNc EXE file is: ZiNc.exe
14:46:03.0 1/15/2006: Use ZiNc on. ZiNc.exe will launch PSX games
14:46:03.0 1/15/2006: MAME EXE file is: Mame32.exe
14:46:03.0 1/15/2006: ROM Path is: D:\Mame32_103\roms
14:46:03.1 1/15/2006: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
14:46:03.1 1/15/2006: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
14:46:03.1 1/15/2006: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
14:46:03.1 1/15/2006: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
14:46:03.1 1/15/2006: Loading Controls.ini map file
14:46:03.1 1/15/2006: Loading Custom Emulators
14:46:03.1 1/15/2006: Loading Emulator 3: Pinball Games
14:46:03.5 1/15/2006: Snap Path is: D:\Mame32_103\snap
14:46:03.5 1/15/2006: AVI Snap Path: Not Found
14:46:03.5 1/15/2006: Flyer Path is: D:\Mame32_103\flyers
14:46:03.5 1/15/2006: Cabinet Path is: D:\Mame32_103\cabinets
14:46:03.5 1/15/2006: Title Path is: D:\Mame32_103\titles
14:46:03.5 1/15/2006: Panel Path is: D:\Mame32_103\cpanel
14:46:03.5 1/15/2006: Icon Path is: D:\Mame32_103\icons
14:46:03.5 1/15/2006: Marquee Path is: D:\Mame32_103\marquees
14:46:03.5 1/15/2006: MAME CMD options:
14:46:03.5 1/15/2006: Attempting to load game list
14:46:04.4 1/15/2006: Running: Mame32.exe -help
14:46:04.4 1/15/2006: Running: D: D:\Mame32_103\Mame32.exe -help > D:\Mame32_103\help.txt
14:46:07.7 1/15/2006:
14:46:07.7 1/15/2006: Now Outputing Mame32.exe - Help
14:46:07.7 1/15/2006: --BEGIN--
14:46:07.7 1/15/2006: M.A.M.E. v0.103u2 (Jan 11 2006) - Multiple Arcade Machine Emulator
14:46:07.7 1/15/2006: Copyright © 1997-2005 by Nicola Salmoria and the MAME Team
14:46:07.7 1/15/2006: MAME is an emulator: it reproduces, more or less faithfully, the behaviour of
14:46:07.7 1/15/2006: several arcade machines. But hardware is useless without software, so an image
14:46:07.7 1/15/2006: of the ROMs which run on that hardware is required. Such ROMs, like any other
14:46:07.7 1/15/2006: commercial software, are copyrighted material and it is therefore illegal to
14:46:07.7 1/15/2006: use them if you don't own the original arcade machine. Needless to say, ROMs
14:46:07.7 1/15/2006: are not distributed together with MAME. Distribution of MAME together with ROM
14:46:07.7 1/15/2006: images is a violation of copyright law and should be promptly reported to the
14:46:07.7 1/15/2006: authors so that appropriate legal action can be taken.
14:46:07.7 1/15/2006: Usage: MAME gamename [options]
14:46:07.7 1/15/2006: MAME -showusage for a brief list of options
14:46:07.7 1/15/2006: MAME -showconfig for a list of configuration options
14:46:07.7 1/15/2006: MAME -createconfig to create a mame.ini
14:46:07.7 1/15/2006: For usage instructions, please consult the file windows.txt
14:46:07.7 1/15/2006: --END--
14:46:07.7 1/15/2006: Loading last used Game List
14:46:07.7 1/15/2006: Loading Start Page
14:46:08.0 1/15/2006: Setting Music Volume
14:46:08.0 1/15/2006: Cannot Load Play List. Check Path and filename
14:46:08.1 1/15/2006: Sound Disabled
14:46:08.1 1/15/2006: Creating ICONS
14:46:09.3 1/15/2006: Gamepad/Joystick disabled
14:46:09.3 1/15/2006: Initialising DirectInput for Keyboard support
14:46:09.6 1/15/2006: Initializing MCE Remote
14:46:09.6 1/15/2006: Starting GameExtender on: 127.0.0.1:8383
14:46:09.6 1/15/2006: Initialization OK! Starting GameEx!
14:46:09.7 1/15/2006: Testing Main Loop Once: Processing Frame
14:46:10.0 1/15/2006: Testing Main Loop Once: Main Loop ran successfully
14:47:31.5 1/15/2006: 20 Consecutive Exceptions Occured: Exiting
14:47:31.5 1/15/2006: at GameEx.GameEx.mainform.LaunchSelectedMAMEGame()
14:47:31.5 1/15/2006: at GameEx.GameEx.mainform.processgamemenu()
14:47:31.5 1/15/2006: at GameEx.GameEx.mainform.DisplayFrame()
Cheers,
Bob
Question -- in order to get GameExtender to work when I launch GameEx on my system, does a second party have to have GameEx installed on their system? Tried using the default IP and the IP associated with my network - plus the port # -but I'm having a hard time getting this to work.
Any help appreciated.
Tarsis
Tarsis
An easy way to test if its working, is to run GameEx in a window, with Extender on 127.0.0.1 and then access on the same pc HTTP://127.0.0.1:8383 on the same PC.
Also there were some issues with the GameExtender viewer, which have just been fixed in 5.38
  -Matt
UltraVNC works fine for me. At least it was last time I used it.
Can the viewer actually be used with an LCD display? I've got a Betabrite up in my marguee and that would be awesome to have it show what game is being played or whatever information the Viewer displays.
This feature is really for normal displays and not LCD's unless configured in windows as normal displays (how to do that, I dont know, if its even possible)
However:
GameEx does have LCD support via LCDSmartie. Have you checked that out?
In addition, I believe another world first for an integrated front end is
the ability to view the control panel while MAME is playing, by pressing a defined key (default is L). Thanks to HeadKaze for the idea, help and inspiration.quote]
I can't get this to work. I have been pounding the L key on numerous games that I know I have the CPanel file but nothing happens...
I wasn't aware of such a thing. Where do I find that?
  • 4 months later...
