Okay. Now what version is your rom set for? How long you had them?
I got the rom set with the mameui32 from a friend that doesnt use it anymore it just sat around, I right clicked one of the ROMS it says Dec 2007
Heres the error I get when I try to get into asteroids
Okay. Your rom set is waaaaaaay out of date, which is what your problem is. You're gonna have to audit these. Use the DAT for MAME version 0.122
Do I want the MAME Titles? And how do I apply them?
You need a DAT file for your MAME build that audits your ROMs (not your artwork) and makes sure stuff isn't missing. Point clrMAMEpro at your ROM files and this dat for your version. I suggest you do some googling first to learn how to use this program. ;)
