Hey guys. Got my cab all put back together and the kids have been playing it just fine. They mentioned the controller not working after they exited a game but then yelled "never mind" (they used the mouse) and continued playing. I decided to play a game and yeah, the controller isn't working after exiting MAME or even emulators. I either have to use the mouse to exit or the keyboard Esc key to exit. I checked all my computer stuff after the move and its all fine.
What kind of controller and how is it connected? Are there any drivers involved? DId you check Device Manager to see if there are any devices showing a yellow triangle?
Draco I've checked all settings, video card is already updated, nothing in Device Manager looked array. I'm still using my modified X-arcade stick until I can find the time to install my iPac4. This is now reached frustration level as it does this for every game now thru GameEx.
Well a quick fix was to disable Custom Keyboard Controls. Now everything works again but is back to default controls.
