When I play consoles, I can exit back to GameEx and navigate to chose another game to play. When I play a MAME game though, I lose the ability to navigate inside of GameEx once I return. The only way I can navigate is after right clicking the mouse button, then moving the mouse. I can't control GameEx with the gamepad, remote control, or keyboard. Using latest 11.99 version.
Log:
19:28:00.5 8/10/2011: Opening Configuration File
19:28:00.6 8/10/2011: GameEx: Version 11.99: Starting Log
19:28:00.6 8/10/2011: Operating System Platform: Win32NT
19:28:00.6 8/10/2011: Operating System Name: Windows Vista
19:28:00.6 8/10/2011: Operating System Version: 6.1.7601
19:28:00.6 8/10/2011: Aero running
19:28:00.6 8/10/2011: Initializing Vista/Windows 7 volume control
19:28:00.6 8/10/2011: Checking for versions of .net Framework installed
19:28:00.6 8/10/2011: .net Framework 2.0 Installed
19:28:00.6 8/10/2011: .net Framework 3.0 Installed
19:28:00.6 8/10/2011: .net Framework 3.5 Installed
19:28:00.6 8/10/2011: Intel® Core2 CPU 6600 @ 2.40GHz, 6143MB
19:28:00.6 8/10/2011: 2.4Ghz - 2 Cores or CPU's
19:28:00.6 8/10/2011: Running Randomize()
19:28:00.6 8/10/2011: Loading PlugIns
19:28:00.6 8/10/2011: Checking for applications to Launch On Startup
19:28:00.6 8/10/2011: Running Misc startup tasks
19:28:00.6 8/10/2011: Setting Menu types
19:28:00.6 8/10/2011: Getting Configuration Values
19:28:00.6 8/10/2011: Using Theme: Enter the Dragon
19:28:00.6 8/10/2011: Checking for alternate Image Directory for Theme: Enter the Dragon
19:28:00.6 8/10/2011: Launching HideOS.exe
19:28:00.6 8/10/2011: Initialising Video/MNG DLL's
19:28:00.6 8/10/2011: GameEx will check for media insertion (may affect performance)
19:28:00.6 8/10/2011: Hiding Taskbar
19:28:00.6 8/10/2011: Is Media Center running?
19:28:00.6 8/10/2011: Checking/Creating LCD Registry values
19:28:00.6 8/10/2011: Check Media Center Exit/Start Mode
19:28:00.6 8/10/2011: Media Center Mode 2
19:28:00.7 8/10/2011: Video previews on. Warning: Only recommended on modern systems
19:28:00.7 8/10/2011: Snap Delay set to: 2
19:28:00.7 8/10/2011: Get other settings
19:28:00.7 8/10/2011: Desktop set to Hide ICONS and set Background to Black
19:28:00.7 8/10/2011: Set: Find emulator artwork on best match basis
19:28:00.7 8/10/2011: Start work for Form
19:28:00.7 8/10/2011: Getting Original Screen Size
19:28:00.7 8/10/2011: Opening Database Connection
19:28:00.7 8/10/2011: Initializing Component
19:28:00.8 8/10/2011: Retrieving resolution setting
19:28:00.8 8/10/2011: MAME Path is: M:\MAME
19:28:00.8 8/10/2011: MAME EXE file is: mameui64.exe
19:28:00.8 8/10/2011: ROM Path is: M:\MAME\roms
19:28:00.8 8/10/2011: Catver.ini is located at: M:\GameEx\DATA\catver.ini
19:28:00.8 8/10/2011: controls.ini is located at: M:\GameEx\DATA\controls.ini
19:28:00.8 8/10/2011: History.dat is located at: M:\GameEx\DATA\history.dat
19:28:00.8 8/10/2011: nplayers.ini is located at: M:\GameEx\DATA\nplayers.ini
19:28:00.8 8/10/2011: command.dat is located at: M:\GameEx\DATA\command.dat
19:28:00.8 8/10/2011: MAMEinfo.dat is located at: M:\GameEx\DATA\mameinfo.dat
19:28:00.8 8/10/2011: Loading Controls.ini map file
19:28:00.8 8/10/2011: Snap Path is: M:\MAME\snap
19:28:00.8 8/10/2011: AVI Snap Path is: M:\MAME\avisnap
19:28:00.8 8/10/2011: Flyer Path is: M:\MAME\flyers
19:28:00.8 8/10/2011: Cabinet Path is: M:\MAME\cabinets
19:28:00.8 8/10/2011: Cabinet 3D Path: Not Found
19:28:00.8 8/10/2011: Title Path is: M:\MAME\titles
19:28:00.8 8/10/2011: PCB Path is: M:\MAME\pcb
19:28:00.8 8/10/2011: Artwork Preview Path: Not Found
19:28:00.8 8/10/2011: Panel Path is: M:\MAME\cpanel
19:28:00.8 8/10/2011: Manual Path is: M:\MAME\manuals
19:28:00.8 8/10/2011: Icon Path is: M:\MAME\icons
19:28:00.8 8/10/2011: Marquee Path is: M:\MAME\marquees
19:28:00.8 8/10/2011: Applying Language/Text
19:28:00.8 8/10/2011: Text/Language: English
19:28:00.9 8/10/2011: Loading Custom Emulators
19:28:00.9 8/10/2011: Loading Emulator 1: Fairchild Channel F
19:28:00.9 8/10/2011: Loading Emulator 2: Atari 2600
19:28:00.9 8/10/2011: Loading Emulator 3: Bally Astrocade
19:28:00.9 8/10/2011: Loading Emulator 4: RCA Studio II
19:28:00.9 8/10/2011: Loading Emulator 5: Mattel Intellivision
19:28:00.9 8/10/2011: Loading Emulator 6: Epoch Super Cassette Vision
19:28:00.9 8/10/2011: Loading Emulator 7: Atari 5200
19:28:00.9 8/10/2011: Loading Emulator 8: ColecoVision
19:28:00.9 8/10/2011: Loading Emulator 9: Emerson Arcadia 2001
19:28:00.9 8/10/2011: Loading Emulator 10: Entex Adventure Vision
19:28:00.9 8/10/2011: Loading Emulator 11: GCE Vectrex
19:28:00.9 8/10/2011: Loading Emulator 12: Casio PV-1000
19:28:00.9 8/10/2011: Loading Emulator 13: Magnavox Odyssey 3 (Videopac+ or G7400)
19:28:00.9 8/10/2011: Loading Emulator 14: Sega SG-1000
19:28:00.9 8/10/2011: Loading Emulator 15: Atari 7800
19:28:00.9 8/10/2011: Loading Emulator 16: Nintendo NES
19:28:00.9 8/10/2011: Loading Emulator 17: Nintendo FDS
19:28:00.9 8/10/2011: Loading Emulator 18: Sega Master System
19:28:00.9 8/10/2011: Loading Emulator 19: NEC TurboGrafx-16
19:28:00.9 8/10/2011: Loading Emulator 20: NEC SuperGrafx
19:28:00.9 8/10/2011: Loading Emulator 21: Sega Genesis
19:28:00.9 8/10/2011: Loading Emulator 22: Amstrad GX4000
19:28:00.9 8/10/2011: Loading Emulator 23: Nintendo SNES
19:28:00.9 8/10/2011: Loading Emulator 24: Atari Jaguar
19:28:00.9 8/10/2011: Loading Emulator 25: Sega PICO
19:28:00.9 8/10/2011: Loading Emulator 26: Sega 32X
19:28:00.9 8/10/2011: Loading Emulator 27: Casio Loopy
19:28:00.9 8/10/2011: Loading Emulator 28: Funtech Super A'Can
19:28:00.9 8/10/2011: Loading Emulator 29: Nintendo Virtual Boy
19:28:00.9 8/10/2011: Loading Emulator 30: Nintendo N64
19:28:00.9 8/10/2011: Using Version 3 Themes Animations
19:28:00.9 8/10/2011: Using General Font: Microsoft Sans Serif
19:28:00.9 8/10/2011: Using Title Font: Microsoft Sans Serif
19:28:01.0 8/10/2011: Initialising Direct3D
19:28:01.0 8/10/2011: Applying GameEx is Loading Image
19:28:01.1 8/10/2011: Setting Resolution to 1920x1080 32 bit color
19:28:01.1 8/10/2011: Creating Surfaces
19:28:01.3 8/10/2011: Creating Primary Surface - Full Screen Mode
19:28:01.3 8/10/2011: Creating Back Buffer
19:28:01.3 8/10/2011: Version 2 Theme being used. Loading.
19:28:01.3 8/10/2011: Loading Button Data
19:28:01.3 8/10/2011: Loading Font Data
19:28:01.3 8/10/2011: Loading Layout Data
19:28:01.3 8/10/2011: Loading Taskbar Data
19:28:01.3 8/10/2011: Loading graphic Surfaces
19:28:01.3 8/10/2011: Display is running at: 1920x1080 32bit color, 60hz
19:28:01.4 8/10/2011: Creating Surfaces Misc and Dialogs
19:28:01.5 8/10/2011: Creating Surfaces Volume
19:28:01.5 8/10/2011: Creating Surfaces Arrows
19:28:01.5 8/10/2011: Creating Surfaces GameEXlogo Text
19:28:01.5 8/10/2011: Creating Surfaces Toolbar
19:28:01.5 8/10/2011: Creating Surfaces Backgrounds
19:28:01.5 8/10/2011: Creating Surfaces Toolbar Controls
19:28:01.5 8/10/2011: Creating Surfaces GameEx Logo
19:28:01.5 8/10/2011: Creating Surface Unselected
19:28:01.5 8/10/2011: Creating Surfaces Snaps
19:28:01.5 8/10/2011: Creating Surfaces Menu and List Bars
19:28:01.6 8/10/2011: Creating Fonts
19:28:01.6 8/10/2011: Creating Game Font
19:28:01.9 8/10/2011: Creating Game Font Faded
19:28:02.4 8/10/2011: Creating Title Font
19:28:02.4 8/10/2011: Restoring Title Font From Cache
19:28:02.5 8/10/2011: Creating Font Black
19:28:02.5 8/10/2011: Creating Font Black Small
19:28:02.6 8/10/2011: Fonts Created Succesfully
19:28:02.6 8/10/2011: Initialising Bass Audio Library
19:28:02.6 8/10/2011: Creating instance of global keyboard hook
19:28:11.7 8/10/2011: Attempting to load game list
19:28:12.0 8/10/2011: MAME CMD options: -nowindow -joy -skip_gameinfo
19:28:12.0 8/10/2011: Loading last used Game List
19:28:12.0 8/10/2011: Loading Start Page
19:28:12.2 8/10/2011: Creating DirectSound Device
19:28:12.2 8/10/2011: Trying: Primary Sound Driver
19:28:12.2 8/10/2011: Loading Sound Files
19:28:12.2 8/10/2011: DirectSound Device Created Successfully
19:28:12.2 8/10/2011: Initialising DirectInput for Gamepad support
19:28:12.3 8/10/2011: Using Device Saitek P2500 Rumble Pad
19:28:12.4 8/10/2011: Initializing MCE Remote
19:28:12.4 8/10/2011: Playing intro sound file
19:28:12.5 8/10/2011: Initialization OK! Starting GameEx!
19:28:12.5 8/10/2011: Testing Main Loop Once: Processing Frame
19:28:13.2 8/10/2011: Testing Main Loop Once: Main Loop ran successfully
19:31:41.4 8/10/2011: Validating: Emulator_1: Custom Background:
19:31:41.4 8/10/2011: Warning: Emulator_1: Custom Background Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_1: Snap Path: M:\_CONSOLES\Fairchild Channel F\Snaps
19:31:41.4 8/10/2011: Warning: Emulator_1: Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_1: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.4 8/10/2011: Validating: Emulator_1: Control Panel Path: M:\_CONSOLES\Fairchild Channel F\Controls\control.png
19:31:41.4 8/10/2011: Validating: Emulator_1: Database: [Console] Fairchild Channel F
19:31:41.4 8/10/2011: Validating: Emulator_1: Title Snap Path: M:\_CONSOLES\Fairchild Channel F\Titles
19:31:41.4 8/10/2011: Warning: Emulator_1: Title Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_1: Box Art Path: M:\_CONSOLES\Fairchild Channel F\Boxes
19:31:41.4 8/10/2011: Warning: Emulator_1: Box Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_1: Cart Art Path: M:\_CONSOLES\Fairchild Channel F\Cartridges
19:31:41.4 8/10/2011: Warning: Emulator_1: Cart Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_1: Manual Path: M:\_CONSOLES\Fairchild Channel F\Manuals
19:31:41.4 8/10/2011: Warning: Emulator_1: Manual Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_2: Custom Background:
19:31:41.4 8/10/2011: Warning: Emulator_2: Custom Background Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_2: Snap Path: M:\_CONSOLES\Atari 2600\Snaps
19:31:41.4 8/10/2011: Validating: Emulator_2: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.4 8/10/2011: Validating: Emulator_2: Control Panel Path: M:\_CONSOLES\Atari 2600\Controls\control.png
19:31:41.4 8/10/2011: Validating: Emulator_2: Database: [Console] Atari 2600
19:31:41.4 8/10/2011: Validating: Emulator_2: Title Snap Path: M:\_CONSOLES\Atari 2600\Titles
19:31:41.4 8/10/2011: Warning: Emulator_2: Title Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_2: Box Art Path: M:\_CONSOLES\Atari 2600\Boxes
19:31:41.4 8/10/2011: Validating: Emulator_2: Cart Art Path: M:\_CONSOLES\Atari 2600\Cartridges
19:31:41.4 8/10/2011: Validating: Emulator_2: Manual Path: M:\_CONSOLES\Atari 2600\Manuals
19:31:41.4 8/10/2011: Validating: Emulator_3: Custom Background:
19:31:41.4 8/10/2011: Warning: Emulator_3: Custom Background Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_3: Snap Path: M:\_CONSOLES\Bally Astrocade\Snaps
19:31:41.4 8/10/2011: Warning: Emulator_3: Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_3: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.4 8/10/2011: Validating: Emulator_3: Control Panel Path: M:\_CONSOLES\Bally Astrocade\Controls\control.png
19:31:41.4 8/10/2011: Validating: Emulator_3: Title Snap Path: M:\_CONSOLES\Bally Astrocade\Titles
19:31:41.4 8/10/2011: Warning: Emulator_3: Title Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_3: Box Art Path: M:\_CONSOLES\Bally Astrocade\Boxes
19:31:41.4 8/10/2011: Warning: Emulator_3: Box Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_3: Cart Art Path: M:\_CONSOLES\Bally Astrocade\Cartridges
19:31:41.4 8/10/2011: Warning: Emulator_3: Cart Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_3: Manual Path: M:\_CONSOLES\Bally Astrocade\Manuals
19:31:41.4 8/10/2011: Warning: Emulator_3: Manual Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_4: Custom Background:
19:31:41.4 8/10/2011: Warning: Emulator_4: Custom Background Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_4: Snap Path: M:\_CONSOLES\RCA Studio II\Snaps
19:31:41.4 8/10/2011: Warning: Emulator_4: Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_4: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.4 8/10/2011: Validating: Emulator_4: Control Panel Path: M:\_CONSOLES\RCA Studio II\Controls\control.png
19:31:41.4 8/10/2011: Validating: Emulator_4: Title Snap Path: M:\_CONSOLES\RCA Studio II\Titles
19:31:41.4 8/10/2011: Warning: Emulator_4: Title Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_4: Box Art Path: M:\_CONSOLES\RCA Studio II\Boxes
19:31:41.4 8/10/2011: Warning: Emulator_4: Box Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_4: Cart Art Path: M:\_CONSOLES\RCA Studio II\Cartridges
19:31:41.4 8/10/2011: Warning: Emulator_4: Cart Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_4: Manual Path: M:\_CONSOLES\RCA Studio II\Manuals
19:31:41.4 8/10/2011: Warning: Emulator_4: Manual Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_5: Custom Background:
19:31:41.4 8/10/2011: Warning: Emulator_5: Custom Background Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_5: Snap Path: M:\_CONSOLES\Mattel Intellivision\Snaps
19:31:41.4 8/10/2011: Warning: Emulator_5: Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_5: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.4 8/10/2011: Validating: Emulator_5: Control Panel Path: M:\_CONSOLES\Mattel Intellivision\Controls\control.png
19:31:41.4 8/10/2011: Validating: Emulator_5: Database: [Console] Mattel Intellivision
19:31:41.4 8/10/2011: Validating: Emulator_5: Title Snap Path: M:\_CONSOLES\Mattel Intellivision\Titles
19:31:41.4 8/10/2011: Warning: Emulator_5: Title Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_5: Box Art Path: M:\_CONSOLES\Mattel Intellivision\Boxes
19:31:41.4 8/10/2011: Warning: Emulator_5: Box Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_5: Cart Art Path: M:\_CONSOLES\Mattel Intellivision\Cartridges
19:31:41.4 8/10/2011: Warning: Emulator_5: Cart Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_5: Manual Path: M:\_CONSOLES\Mattel Intellivision\Manuals
19:31:41.4 8/10/2011: Warning: Emulator_5: Manual Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_6: Custom Background:
19:31:41.4 8/10/2011: Warning: Emulator_6: Custom Background Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_6: Snap Path: M:\_CONSOLES\Epoch Super Cassette Vision\Snaps
19:31:41.4 8/10/2011: Warning: Emulator_6: Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_6: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.4 8/10/2011: Validating: Emulator_6: Control Panel Path: M:\_CONSOLES\Epoch Super Cassette Vision\Controls\control.png
19:31:41.4 8/10/2011: Validating: Emulator_6: Title Snap Path: M:\_CONSOLES\Epoch Super Cassette Vision\Titles
19:31:41.4 8/10/2011: Warning: Emulator_6: Title Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_6: Box Art Path: M:\_CONSOLES\Epoch Super Cassette Vision\Boxes
19:31:41.4 8/10/2011: Warning: Emulator_6: Box Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_6: Cart Art Path: M:\_CONSOLES\Epoch Super Cassette Vision\Cartridges
19:31:41.4 8/10/2011: Warning: Emulator_6: Cart Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_6: Manual Path: M:\_CONSOLES\Epoch Super Cassette Vision\Manuals
19:31:41.4 8/10/2011: Warning: Emulator_6: Manual Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_7: Custom Background:
19:31:41.4 8/10/2011: Warning: Emulator_7: Custom Background Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_7: Snap Path: M:\_CONSOLES\Atari 5200\Snaps
19:31:41.4 8/10/2011: Validating: Emulator_7: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.4 8/10/2011: Validating: Emulator_7: Control Panel Path: M:\_CONSOLES\Atari 5200\Controls\control.png
19:31:41.4 8/10/2011: Validating: Emulator_7: Database: [Console] Atari 5200
19:31:41.4 8/10/2011: Validating: Emulator_7: Title Snap Path: M:\_CONSOLES\Atari 5200\Titles
19:31:41.4 8/10/2011: Warning: Emulator_7: Title Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_7: Box Art Path: M:\_CONSOLES\Atari 5200\Boxes
19:31:41.4 8/10/2011: Warning: Emulator_7: Box Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_7: Cart Art Path: M:\_CONSOLES\Atari 5200\Cartridges
19:31:41.4 8/10/2011: Warning: Emulator_7: Cart Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_7: Manual Path: M:\_CONSOLES\Atari 5200\Manuals
19:31:41.4 8/10/2011: Warning: Emulator_7: Manual Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_8: Custom Background:
19:31:41.4 8/10/2011: Warning: Emulator_8: Custom Background Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_8: Snap Path: M:\_CONSOLES\Coleco - Colecovision\Snaps
19:31:41.4 8/10/2011: Validating: Emulator_8: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.4 8/10/2011: Validating: Emulator_8: Control Panel Path: M:\_CONSOLES\Coleco - Colecovision\Controls\control.png
19:31:41.4 8/10/2011: Validating: Emulator_8: Database: [Console] Coleco Vision
19:31:41.4 8/10/2011: Validating: Emulator_8: Title Snap Path: M:\_CONSOLES\Coleco - Colecovision\Titles
19:31:41.4 8/10/2011: Warning: Emulator_8: Title Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_8: Box Art Path: M:\_CONSOLES\Coleco - Colecovision\Boxes
19:31:41.4 8/10/2011: Warning: Emulator_8: Box Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_8: Cart Art Path: M:\_CONSOLES\Coleco - Colecovision\Cartridges
19:31:41.4 8/10/2011: Warning: Emulator_8: Cart Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_8: Manual Path: M:\_CONSOLES\Coleco - Colecovision\Manuals
19:31:41.4 8/10/2011: Warning: Emulator_8: Manual Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_9: Custom Background:
19:31:41.4 8/10/2011: Warning: Emulator_9: Custom Background Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_9: Snap Path: M:\_CONSOLES\Emerson Arcadia 2001\Snaps
19:31:41.4 8/10/2011: Warning: Emulator_9: Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_9: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.4 8/10/2011: Validating: Emulator_9: Control Panel Path: M:\_CONSOLES\Emerson Arcadia 2001\Controls\control.png
19:31:41.4 8/10/2011: Validating: Emulator_9: Title Snap Path: M:\_CONSOLES\Emerson Arcadia 2001\Titles
19:31:41.4 8/10/2011: Warning: Emulator_9: Title Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_9: Box Art Path: M:\_CONSOLES\Emerson Arcadia 2001\Boxes
19:31:41.4 8/10/2011: Warning: Emulator_9: Box Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_9: Cart Art Path: M:\_CONSOLES\Emerson Arcadia 2001\Cartridges
19:31:41.4 8/10/2011: Warning: Emulator_9: Cart Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_9: Manual Path: M:\_CONSOLES\Emerson Arcadia 2001\Manuals
19:31:41.4 8/10/2011: Warning: Emulator_9: Manual Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_10: Custom Background:
19:31:41.4 8/10/2011: Warning: Emulator_10: Custom Background Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_10: Snap Path: M:\_CONSOLES\Entex Adventure Vision\Snaps
19:31:41.4 8/10/2011: Validating: Emulator_10: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.4 8/10/2011: Validating: Emulator_10: Control Panel Path: M:\_CONSOLES\Entex Adventure Vision\Controls\control.png
19:31:41.4 8/10/2011: Validating: Emulator_10: Database: [Console] Entex Adventure Vision
19:31:41.4 8/10/2011: Validating: Emulator_10: Title Snap Path: M:\_CONSOLES\Entex Adventure Vision\Titles
19:31:41.4 8/10/2011: Warning: Emulator_10: Title Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_10: Box Art Path: M:\_CONSOLES\Entex Adventure Vision\Boxes
19:31:41.4 8/10/2011: Warning: Emulator_10: Box Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_10: Cart Art Path: M:\_CONSOLES\Entex Adventure Vision\Cartridges
19:31:41.4 8/10/2011: Warning: Emulator_10: Cart Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_10: Manual Path: M:\_CONSOLES\Entex Adventure Vision\Manuals
19:31:41.4 8/10/2011: Warning: Emulator_10: Manual Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_11: Custom Background:
19:31:41.4 8/10/2011: Warning: Emulator_11: Custom Background Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_11: Snap Path: M:\_CONSOLES\GCE Vectrex\SCREENSHOTs
19:31:41.4 8/10/2011: Validating: Emulator_11: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.4 8/10/2011: Validating: Emulator_11: Control Panel Path: M:\_CONSOLES\GCE Vectrex\Controls\control.png
19:31:41.4 8/10/2011: Validating: Emulator_11: Database: [Console] GCE Vectrex
19:31:41.4 8/10/2011: Validating: Emulator_11: Title Snap Path: M:\_CONSOLES\GCE Vectrex\Titles
19:31:41.4 8/10/2011: Warning: Emulator_11: Title Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_11: Box Art Path: M:\_CONSOLES\GCE Vectrex\Box
19:31:41.4 8/10/2011: Validating: Emulator_11: Cart Art Path: M:\_CONSOLES\GCE Vectrex\Cartridges
19:31:41.4 8/10/2011: Warning: Emulator_11: Cart Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_11: Manual Path: M:\_CONSOLES\GCE Vectrex\Manuals
19:31:41.4 8/10/2011: Warning: Emulator_11: Manual Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_12: Custom Background:
19:31:41.4 8/10/2011: Warning: Emulator_12: Custom Background Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_12: Snap Path: M:\_CONSOLES\Casio PV-1000\Snaps
19:31:41.4 8/10/2011: Warning: Emulator_12: Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_12: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.4 8/10/2011: Validating: Emulator_12: Control Panel Path: M:\_CONSOLES\Casio PV-1000\Controls\control.png
19:31:41.4 8/10/2011: Validating: Emulator_12: Title Snap Path: M:\_CONSOLES\Casio PV-1000\Titles
19:31:41.4 8/10/2011: Warning: Emulator_12: Title Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_12: Box Art Path: M:\_CONSOLES\Casio PV-1000\Boxes
19:31:41.4 8/10/2011: Warning: Emulator_12: Box Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_12: Cart Art Path: M:\_CONSOLES\Casio PV-1000\Cartridges
19:31:41.4 8/10/2011: Warning: Emulator_12: Cart Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_12: Manual Path: M:\_CONSOLES\Casio PV-1000\Manuals
19:31:41.4 8/10/2011: Warning: Emulator_12: Manual Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_13: Custom Background:
19:31:41.4 8/10/2011: Warning: Emulator_13: Custom Background Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_13: Snap Path: M:\_CONSOLES\Magnavox Odyssey 3\Snaps
19:31:41.4 8/10/2011: Warning: Emulator_13: Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_13: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.4 8/10/2011: Validating: Emulator_13: Control Panel Path: C:\Assets\Magnavox Odyssey 2\Controls
19:31:41.4 8/10/2011: Warning: Emulator_13: Control Panel Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_13: Title Snap Path: M:\_CONSOLES\Magnavox Odyssey 3\Titles
19:31:41.4 8/10/2011: Warning: Emulator_13: Title Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_13: Box Art Path: M:\_CONSOLES\Magnavox Odyssey 3\Boxes
19:31:41.4 8/10/2011: Warning: Emulator_13: Box Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_13: Cart Art Path: M:\_CONSOLES\Magnavox Odyssey 3\Cartridges
19:31:41.4 8/10/2011: Warning: Emulator_13: Cart Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_13: Manual Path: M:\_CONSOLES\Magnavox Odyssey 3\Manuals
19:31:41.4 8/10/2011: Warning: Emulator_13: Manual Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_14: Custom Background:
19:31:41.4 8/10/2011: Warning: Emulator_14: Custom Background Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_14: Snap Path: M:\_CONSOLES\Sega SG-1000\Snaps
19:31:41.4 8/10/2011: Warning: Emulator_14: Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_14: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.4 8/10/2011: Validating: Emulator_14: Control Panel Path: M:\_CONSOLES\Sega SG-1000\Controls\control.png
19:31:41.4 8/10/2011: Validating: Emulator_14: Title Snap Path: M:\_CONSOLES\Sega SG-1000\Titles
19:31:41.4 8/10/2011: Warning: Emulator_14: Title Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_14: Box Art Path: M:\_CONSOLES\Sega SG-1000\Boxes
19:31:41.4 8/10/2011: Warning: Emulator_14: Box Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_14: Cart Art Path: M:\_CONSOLES\Sega SG-1000\Cartridges
19:31:41.4 8/10/2011: Warning: Emulator_14: Cart Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_14: Manual Path: M:\_CONSOLES\Sega SG-1000\Manuals
19:31:41.4 8/10/2011: Warning: Emulator_14: Manual Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_15: Custom Background:
19:31:41.4 8/10/2011: Warning: Emulator_15: Custom Background Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_15: Snap Path: M:\_CONSOLES\Atari 7800\Snaps
19:31:41.4 8/10/2011: Validating: Emulator_15: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.4 8/10/2011: Validating: Emulator_15: Control Panel Path: M:\_CONSOLES\Atari 7800\Controls\control.png
19:31:41.4 8/10/2011: Validating: Emulator_15: Database: [Console] Atari 7800
19:31:41.4 8/10/2011: Validating: Emulator_15: Title Snap Path: M:\_CONSOLES\Atari 7800\Titles
19:31:41.4 8/10/2011: Warning: Emulator_15: Title Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_15: Box Art Path: M:\_CONSOLES\Atari 7800\Boxes
19:31:41.4 8/10/2011: Warning: Emulator_15: Box Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_15: Cart Art Path: M:\_CONSOLES\Atari 7800\Cartridges
19:31:41.4 8/10/2011: Warning: Emulator_15: Cart Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_15: Manual Path: M:\_CONSOLES\Atari 7800\Manuals
19:31:41.4 8/10/2011: Warning: Emulator_15: Manual Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_16: Custom Background:
19:31:41.4 8/10/2011: Warning: Emulator_16: Custom Background Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_16: Snap Path: M:\_CONSOLES\Nintendo NES\Snaps
19:31:41.4 8/10/2011: Warning: Emulator_16: Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_16: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.4 8/10/2011: Validating: Emulator_16: Control Panel Path: M:\_CONSOLES\Nintendo NES\Controls\control.png
19:31:41.4 8/10/2011: Validating: Emulator_16: Database: [Console] Nintendo NES
19:31:41.4 8/10/2011: Validating: Emulator_16: Title Snap Path: M:\_CONSOLES\Nintendo NES\Titles
19:31:41.4 8/10/2011: Warning: Emulator_16: Title Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_16: Box Art Path: M:\_CONSOLES\Nintendo NES\Boxes
19:31:41.4 8/10/2011: Warning: Emulator_16: Box Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_16: Cart Art Path: M:\_CONSOLES\Nintendo NES\Cartridges
19:31:41.4 8/10/2011: Warning: Emulator_16: Cart Art Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_16: Manual Path: M:\_CONSOLES\Nintendo NES\Manuals
19:31:41.4 8/10/2011: Warning: Emulator_16: Manual Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_17: Custom Background:
19:31:41.4 8/10/2011: Warning: Emulator_17: Custom Background Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_17: Snap Path: M:\_CONSOLES\Nintendo Famicom Disk System\Snaps
19:31:41.4 8/10/2011: Warning: Emulator_17: Snap Path Does not exist
19:31:41.4 8/10/2011: Validating: Emulator_17: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.4 8/10/2011: Validating: Emulator_17: Control Panel Path: M:\_CONSOLES\Nintendo Famicom Disk System\Controls\control.png
19:31:41.4 8/10/2011: Validating: Emulator_17: Title Snap Path: M:\_CONSOLES\Nintendo Famicom Disk System\Titles
19:31:41.4 8/10/2011: Warning: Emulator_17: Title Snap Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_17: Box Art Path: M:\_CONSOLES\Nintendo Famicom Disk System\Boxes
19:31:41.5 8/10/2011: Warning: Emulator_17: Box Art Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_17: Cart Art Path: M:\_CONSOLES\Nintendo Famicom Disk System\Cartridges
19:31:41.5 8/10/2011: Warning: Emulator_17: Cart Art Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_17: Manual Path: M:\_CONSOLES\Nintendo Famicom Disk System\Manuals
19:31:41.5 8/10/2011: Warning: Emulator_17: Manual Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_18: Custom Background:
19:31:41.5 8/10/2011: Warning: Emulator_18: Custom Background Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_18: Snap Path: M:\_CONSOLES\Sega Master System\Snaps
19:31:41.5 8/10/2011: Validating: Emulator_18: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.5 8/10/2011: Validating: Emulator_18: Control Panel Path: M:\_CONSOLES\Sega Master System\Controls\control.png
19:31:41.5 8/10/2011: Validating: Emulator_18: Database: [Console] Sega Master System
19:31:41.5 8/10/2011: Validating: Emulator_18: Title Snap Path: M:\_CONSOLES\Sega Master System\Snaps
19:31:41.5 8/10/2011: Validating: Emulator_18: Box Art Path: M:\_CONSOLES\Sega Master System\box
19:31:41.5 8/10/2011: Validating: Emulator_18: Cart Art Path: M:\_CONSOLES\Sega Master System\Cartridges
19:31:41.5 8/10/2011: Warning: Emulator_18: Cart Art Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_18: Manual Path: M:\_CONSOLES\Sega Master System\Manuals
19:31:41.5 8/10/2011: Warning: Emulator_18: Manual Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_19: Custom Background:
19:31:41.5 8/10/2011: Warning: Emulator_19: Custom Background Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_19: Snap Path: M:\_CONSOLES\NEC TurboGrafx-16\Snaps
19:31:41.5 8/10/2011: Validating: Emulator_19: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.5 8/10/2011: Validating: Emulator_19: Control Panel Path: M:\_CONSOLES\NEC TurboGrafx-16\Controls\control.png
19:31:41.5 8/10/2011: Validating: Emulator_19: Database: [Console] NEC TurboGrafx-16
19:31:41.5 8/10/2011: Validating: Emulator_19: Title Snap Path: M:\_CONSOLES\NEC TurboGrafx-16\Titles
19:31:41.5 8/10/2011: Warning: Emulator_19: Title Snap Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_19: Box Art Path: M:\_CONSOLES\NEC TurboGrafx-16\Boxes
19:31:41.5 8/10/2011: Warning: Emulator_19: Box Art Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_19: Cart Art Path: M:\_CONSOLES\NEC TurboGrafx-16\Cartridges
19:31:41.5 8/10/2011: Warning: Emulator_19: Cart Art Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_19: Manual Path: M:\_CONSOLES\NEC TurboGrafx-16\Manuals
19:31:41.5 8/10/2011: Warning: Emulator_19: Manual Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_20: Custom Background:
19:31:41.5 8/10/2011: Warning: Emulator_20: Custom Background Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_20: Snap Path: M:\_CONSOLES\NEC SuperGrafx\Snaps
19:31:41.5 8/10/2011: Validating: Emulator_20: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.5 8/10/2011: Validating: Emulator_20: Control Panel Path: M:\_CONSOLES\NEC SuperGrafx\Controls\control.png
19:31:41.5 8/10/2011: Validating: Emulator_20: Database: [Console] NEC SuperGrafx
19:31:41.5 8/10/2011: Validating: Emulator_20: Title Snap Path: M:\_CONSOLES\NEC SuperGrafx\Titles
19:31:41.5 8/10/2011: Warning: Emulator_20: Title Snap Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_20: Box Art Path: M:\_CONSOLES\NEC SuperGrafx\Boxes
19:31:41.5 8/10/2011: Warning: Emulator_20: Box Art Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_20: Cart Art Path: M:\_CONSOLES\NEC SuperGrafx\Cartridges
19:31:41.5 8/10/2011: Warning: Emulator_20: Cart Art Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_20: Manual Path: M:\_CONSOLES\NEC SuperGrafx\Manuals
19:31:41.5 8/10/2011: Warning: Emulator_20: Manual Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_21: Custom Background:
19:31:41.5 8/10/2011: Warning: Emulator_21: Custom Background Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_21: Snap Path: M:\_CONSOLES\Sega Genesis\Snaps
19:31:41.5 8/10/2011: Validating: Emulator_21: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.5 8/10/2011: Validating: Emulator_21: Control Panel Path: M:\_CONSOLES\Sega Genesis\Controls\control.png
19:31:41.5 8/10/2011: Validating: Emulator_21: Database: [Console] Sega Genesis
19:31:41.5 8/10/2011: Validating: Emulator_21: Title Snap Path: M:\_CONSOLES\Sega Genesis\Titles
19:31:41.5 8/10/2011: Validating: Emulator_21: Box Art Path: M:\_CONSOLES\Sega Genesis\Box
19:31:41.5 8/10/2011: Validating: Emulator_21: Cart Art Path: M:\_CONSOLES\Sega Genesis\Carts
19:31:41.5 8/10/2011: Validating: Emulator_21: Manual Path: M:\_CONSOLES\Sega Genesis\Manuals
19:31:41.5 8/10/2011: Warning: Emulator_21: Manual Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_22: Custom Background:
19:31:41.5 8/10/2011: Warning: Emulator_22: Custom Background Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_22: Snap Path: M:\_CONSOLES\Amstrad GX4000\Snaps
19:31:41.5 8/10/2011: Warning: Emulator_22: Snap Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_22: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.5 8/10/2011: Validating: Emulator_22: Control Panel Path: M:\_CONSOLES\Amstrad GX4000\Controls\control.png
19:31:41.5 8/10/2011: Validating: Emulator_22: Database: [Console] Amstrad GX4000
19:31:41.5 8/10/2011: Validating: Emulator_22: Title Snap Path: M:\_CONSOLES\Amstrad GX4000\Titles
19:31:41.5 8/10/2011: Warning: Emulator_22: Title Snap Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_22: Box Art Path: M:\_CONSOLES\Amstrad GX4000\Boxes
19:31:41.5 8/10/2011: Warning: Emulator_22: Box Art Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_22: Cart Art Path: M:\_CONSOLES\Amstrad GX4000\Cartridges
19:31:41.5 8/10/2011: Warning: Emulator_22: Cart Art Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_22: Manual Path: M:\_CONSOLES\Amstrad GX4000\Manuals
19:31:41.5 8/10/2011: Warning: Emulator_22: Manual Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_23: Custom Background:
19:31:41.5 8/10/2011: Warning: Emulator_23: Custom Background Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_23: Snap Path: M:\_CONSOLES\Nintendo SNES\Snaps
19:31:41.5 8/10/2011: Validating: Emulator_23: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.5 8/10/2011: Validating: Emulator_23: Control Panel Path: C:\Assets\Nintendo SNES\Controls\control.png
19:31:41.5 8/10/2011: Warning: Emulator_23: Control Panel Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_23: Database: [Console] Nintendo SNES
19:31:41.5 8/10/2011: Validating: Emulator_23: Title Snap Path: M:\_CONSOLES\Nintendo SNES\Titles
19:31:41.5 8/10/2011: Validating: Emulator_23: Box Art Path: M:\_CONSOLES\Nintendo SNES\Super Nintendo Box
19:31:41.5 8/10/2011: Validating: Emulator_23: Cart Art Path: M:\_CONSOLES\Nintendo SNES\Super Nintendo Cart
19:31:41.5 8/10/2011: Validating: Emulator_23: Manual Path: M:\_CONSOLES\Nintendo SNES\Manuals
19:31:41.5 8/10/2011: Warning: Emulator_23: Manual Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_24: Custom Background:
19:31:41.5 8/10/2011: Warning: Emulator_24: Custom Background Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_24: Snap Path: M:\_CONSOLES\Atari Jaguar\Snaps
19:31:41.5 8/10/2011: Validating: Emulator_24: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.5 8/10/2011: Validating: Emulator_24: Control Panel Path: M:\_CONSOLES\Atari Jaguar\Controls
19:31:41.5 8/10/2011: Warning: Emulator_24: Control Panel Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_24: Database: [Console] Atari Jaguar
19:31:41.5 8/10/2011: Validating: Emulator_24: Title Snap Path: M:\_CONSOLES\Atari Jaguar\Titles
19:31:41.5 8/10/2011: Warning: Emulator_24: Title Snap Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_24: Box Art Path: M:\_CONSOLES\Atari Jaguar\Boxes
19:31:41.5 8/10/2011: Warning: Emulator_24: Box Art Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_24: Cart Art Path: M:\_CONSOLES\Atari Jaguarr\Cartridges
19:31:41.5 8/10/2011: Warning: Emulator_24: Cart Art Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_24: Manual Path: M:\_CONSOLES\Atari Jaguar\Manuals
19:31:41.5 8/10/2011: Warning: Emulator_24: Manual Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_25: Custom Background:
19:31:41.5 8/10/2011: Warning: Emulator_25: Custom Background Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_25: Snap Path: M:\_CONSOLES\Sega PICO\Snaps
19:31:41.5 8/10/2011: Warning: Emulator_25: Snap Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_25: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.5 8/10/2011: Validating: Emulator_25: Control Panel Path: M:\_CONSOLES\Sega PICO\Controls\control.png
19:31:41.5 8/10/2011: Validating: Emulator_25: Title Snap Path: M:\_CONSOLES\Sega PICO\Titles
19:31:41.5 8/10/2011: Warning: Emulator_25: Title Snap Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_25: Box Art Path: M:\_CONSOLES\Sega PICO\Boxes
19:31:41.5 8/10/2011: Warning: Emulator_25: Box Art Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_25: Cart Art Path: M:\_CONSOLES\Sega PICO\Cartridges
19:31:41.5 8/10/2011: Warning: Emulator_25: Cart Art Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_25: Manual Path: M:\_CONSOLES\Sega PICO\Manuals
19:31:41.5 8/10/2011: Warning: Emulator_25: Manual Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_26: Custom Background:
19:31:41.5 8/10/2011: Warning: Emulator_26: Custom Background Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_26: Snap Path: M:\_CONSOLES\Sega 32X\snaps
19:31:41.5 8/10/2011: Validating: Emulator_26: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.5 8/10/2011: Validating: Emulator_26: Control Panel Path: M:\_CONSOLES\Sega 32X\Controls\control.png
19:31:41.5 8/10/2011: Validating: Emulator_26: Database: [Console] Sega 32X
19:31:41.5 8/10/2011: Validating: Emulator_26: Title Snap Path: M:\_CONSOLES\Sega 32X\titles
19:31:41.5 8/10/2011: Validating: Emulator_26: Box Art Path: M:\_CONSOLES\Sega 32X\boxs
19:31:41.5 8/10/2011: Warning: Emulator_26: Box Art Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_26: Cart Art Path: M:\_CONSOLES\Sega 32X\cart
19:31:41.5 8/10/2011: Validating: Emulator_26: Manual Path: M:\_CONSOLES\Sega 32X\Manuals
19:31:41.5 8/10/2011: Warning: Emulator_26: Manual Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_27: Custom Background:
19:31:41.5 8/10/2011: Warning: Emulator_27: Custom Background Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_27: Snap Path: M:\_CONSOLES\Casio Loopy\Snaps
19:31:41.5 8/10/2011: Warning: Emulator_27: Snap Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_27: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.5 8/10/2011: Validating: Emulator_27: Control Panel Path: M:\_CONSOLES\Casio Loopy\Controls
19:31:41.5 8/10/2011: Warning: Emulator_27: Control Panel Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_27: Title Snap Path: M:\_CONSOLES\Casio Loopy\Titles
19:31:41.5 8/10/2011: Warning: Emulator_27: Title Snap Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_27: Box Art Path: M:\_CONSOLES\Casio Loopy\Boxes
19:31:41.5 8/10/2011: Warning: Emulator_27: Box Art Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_27: Cart Art Path: M:\_CONSOLES\Casio Loopy\Cartridges
19:31:41.5 8/10/2011: Warning: Emulator_27: Cart Art Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_27: Manual Path: M:\_CONSOLES\Casio Loopy\Manuals
19:31:41.5 8/10/2011: Warning: Emulator_27: Manual Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_28: Custom Background:
19:31:41.5 8/10/2011: Warning: Emulator_28: Custom Background Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_28: Snap Path: M:\_CONSOLES\Funtech Super A'Can\Snaps
19:31:41.5 8/10/2011: Warning: Emulator_28: Snap Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_28: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.5 8/10/2011: Validating: Emulator_28: Control Panel Path: M:\_CONSOLES\Funtech Super A'Can\Controls
19:31:41.5 8/10/2011: Warning: Emulator_28: Control Panel Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_28: Title Snap Path: M:\_CONSOLES\Funtech Super A'Can\Titles
19:31:41.5 8/10/2011: Warning: Emulator_28: Title Snap Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_28: Box Art Path: M:\_CONSOLES\Funtech Super A'Can\Boxes
19:31:41.5 8/10/2011: Warning: Emulator_28: Box Art Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_28: Cart Art Path: M:\_CONSOLES\Funtech Super A'Can\Cartridges
19:31:41.5 8/10/2011: Warning: Emulator_28: Cart Art Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_28: Manual Path: M:\_CONSOLES\Funtech Super A'Can\Manuals
19:31:41.5 8/10/2011: Warning: Emulator_28: Manual Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_29: Custom Background:
19:31:41.5 8/10/2011: Warning: Emulator_29: Custom Background Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_29: Snap Path: M:\_CONSOLES\Nintendo Virtual Boy\Snaps
19:31:41.5 8/10/2011: Warning: Emulator_29: Snap Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_29: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.5 8/10/2011: Validating: Emulator_29: Control Panel Path: M:\_CONSOLES\Nintendo Virtual Boy\Controls
19:31:41.5 8/10/2011: Warning: Emulator_29: Control Panel Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_29: Database: [Handheld] Nintendo Virtual Boy
19:31:41.5 8/10/2011: Validating: Emulator_29: Title Snap Path: M:\_CONSOLES\Nintendo Virtual Boy\Titles
19:31:41.5 8/10/2011: Warning: Emulator_29: Title Snap Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_29: Box Art Path: M:\_CONSOLES\Nintendo Virtual Boy\Boxes
19:31:41.5 8/10/2011: Warning: Emulator_29: Box Art Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_29: Cart Art Path: M:\_CONSOLES\Nintendo Virtual Boy\Cartridges
19:31:41.5 8/10/2011: Warning: Emulator_29: Cart Art Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_29: Manual Path: M:\_CONSOLES\Nintendo Virtual Boy\Manuals
19:31:41.5 8/10/2011: Warning: Emulator_29: Manual Path Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_30: Custom Background:
19:31:41.5 8/10/2011: Warning: Emulator_30: Custom Background Does not exist
19:31:41.5 8/10/2011: Validating: Emulator_30: Snap Path: M:\_CONSOLES\Nintendo 64\Snaps
19:31:41.5 8/10/2011: Validating: Emulator_30: Not Found Image: M:\GameEx\THEMES\Enter the Dragon\MEDIA\LOGOS\No_Image.png
19:31:41.5 8/10/2011: Validating: Emulator_30: Control Panel Path: M:\_CONSOLES\Nintendo 64\Controls\control.png
19:31:41.5 8/10/2011: Validating: Emulator_30: Database: [Console] Nintendo N64
19:31:41.5 8/10/2011: Validating: Emulator_30: Title Snap Path: M:\_CONSOLES\Nintendo 64\Titles
19:31:41.5 8/10/2011: Validating: Emulator_30: Box Art Path: M:\_CONSOLES\Nintendo 64\Nintendo 64 Box
19:31:41.5 8/10/2011: Validating: Emulator_30: Cart Art Path: M:\_CONSOLES\Nintendo 64\Nintendo 64 Cart
19:31:41.5 8/10/2011: Validating: Emulator_30: Manual Path: M:\_CONSOLES\Nintendo 64\Manuals
19:31:41.5 8/10/2011: Warning: Emulator_30: Manual Path Does not exist
19:32:12.9 8/10/2011: Restoring Cached ICONS from File
19:32:38.1 8/10/2011: Restoring Emulator from Cache
19:32:38.1 8/10/2011: Restoring Emulator Database From Cache
19:32:38.2 8/10/2011: Restoring Emulator from Cache
19:32:38.2 8/10/2011: Restoring Emulator Database From Cache
19:32:38.4 8/10/2011: Restoring Emulator from Cache
19:32:38.4 8/10/2011: Restoring Emulator Database From Cache
19:32:38.5 8/10/2011: Restoring Emulator from Cache
19:32:38.5 8/10/2011: Restoring Emulator Database From Cache
19:32:38.6 8/10/2011: Restoring Emulator Database From Cache
19:32:38.7 8/10/2011: Restoring Emulator from Cache
19:32:38.7 8/10/2011: Restoring Emulator Database From Cache
19:32:38.8 8/10/2011: Restoring Emulator from Cache
19:32:38.8 8/10/2011: Restoring Emulator Database From Cache
19:32:39.2 8/10/2011: Restoring Emulator from Cache
19:32:39.2 8/10/2011: Restoring Emulator Database From Cache
19:32:39.3 8/10/2011: Restoring Emulator from Cache
19:32:39.3 8/10/2011: Restoring Emulator Database From Cache
19:32:39.4 8/10/2011: Restoring Emulator from Cache
19:32:39.4 8/10/2011: Restoring Emulator Database From Cache
19:32:39.5 8/10/2011: Restoring Emulator from Cache
19:32:39.5 8/10/2011: Restoring Emulator Database From Cache
19:32:39.7 8/10/2011: Restoring Emulator from Cache
19:32:39.7 8/10/2011: Restoring Emulator Database From Cache
19:32:39.8 8/10/2011: Restoring Emulator from Cache
19:32:39.8 8/10/2011: Restoring Emulator Database From Cache
19:32:40.2 8/10/2011: Restoring Emulator from Cache
19:32:40.3 8/10/2011: Restoring Emulator Database From Cache
19:32:40.3 8/10/2011: Restoring Emulator from Cache
19:32:40.4 8/10/2011: Restoring Emulator from Cache
19:32:40.4 8/10/2011: Restoring Emulator Database From Cache
19:34:06.9 8/10/2011: Running: cmd.exe /c M: M:\MAME\mameui64.exe blazstar -rompath M:\MAME\roms -nowindow -joy -skip_gameinfo
19:34:06.9 8/10/2011: Shutting down display
20:18:33.1 8/10/2011: Exiting game
20:18:33.1 8/10/2011: Closing MAME window
20:18:33.1 8/10/2011: Waiting for MAME to exit
20:18:33.6 8/10/2011: MAME has exited
20:18:34.0 8/10/2011: Writing MAME stats
20:18:34.0 8/10/2011: Plugin: Game Exit
20:18:34.0 8/10/2011: Plugin: Process Commands
20:18:34.0 8/10/2011: Restoring Window
20:18:34.0 8/10/2011: Reinitializing Graphics System
20:18:35.0 8/10/2011: 21 Consecutive Exceptions Occured
20:18:35.0 8/10/2011: Object reference not set to an instance of an object.
20:18:35.1 8/10/2011: at ag.s(Boolean A_0)
20:18:35.1 8/10/2011: at ag.ac()
20:18:35.1 8/10/2011: Trying reinitialising the display after sleeping for 4 seconds
20:18:35.1 8/10/2011: Exception count will be dropped to 15
20:19:19.6 8/10/2011: Exiting GameEx!
20:19:19.6 8/10/2011: Saving Settings
20:19:20.9 8/10/2011: Disposing Plugins
20:19:20.9 8/10/2011: Closing database connection
20:19:20.9 8/10/2011: Checking for applications to Launch On Exit
20:19:20.9 8/10/2011: Media Center was not open when starting GameEx, so not launching
Wonder if it's the 'mouse behind GameEx' issue... If you shake the mouse around and click it does it return to the desktop?
.:EDIT:. Seen this before...
Have you tried updating your Direct-X and video card drivers? Also try turning off 16-Bit Color if you haven't already.
Well, when I click the mouse, it brings the pointer into the foreground. If I don't click, there's no mouse pointer.
So the mouse works after it comes to the foreground, or nah?
Does it move the list selector if you mouse over it?
Yeah, nothing at all works until I click. After that, the mouse pointer appears, and I can hover things, select things, click them, etc. The other inputs don't work after clicking though, only the mouse.
How do you have your joystick set up to work the menu? Are you using GameEx's custominput.ini? I use a keyboard controller to work all of GameEx's features to get around this, as in it happens on my machine too but when I click the mouse it drops to the daskbar and my desktop pops up. Do you have a way of converting joystick inputs to keystrokes?
PS: That's another hint at Xpadder if you didn't catch it! *LOL*
All I've done is enabled the Gamepad for use under GameEx Setup Wizard's "Input Settings" tab. Nothing else is manually configured (except for the global exit combination via the Input Settings tab as well). I'm not using a custominput.ini.
I finished installing the latest DirectX and rebooted. It still does this. Clicking the mouse doesn't cause GameEx to minimize to the task bar, it just enables the pointer to be shown, then the mouse works like normal inside GameEx. Keyboard, GamePad, and MCE Remote don't work in either case. I get the same group of error's in the log:
20:46:34.0  8/10/2011:  Object reference not set to an instance of an object.
20:46:34.1 8/10/2011: at ag.s(Boolean A_0)
20:46:34.1 8/10/2011: at ag.ac()
20:46:34.1 8/10/2011: Trying reinitialising the display after sleeping for 4 seconds
20:46:34.1 8/10/2011: Exception count will be dropped to 15
I feel I should also mention that this never happened in the previous versions of GameEx. Only since the last 1 or 2 updates. I know I've been gone a while, but even so, GameEx worked fine with the version that was out when I came back. So it's definately something new within the last few updates.
Hmm... Lemmie see here... Could you try configuring your joypad buttons under Input Settings?
I can, only I don't really know what that would solve. I've never had to configure them before. They always worked fine. I don't want to screw something up either, in case it really IS something with the program. If I go in and mess around with my input stuff, I could really screw it up!
I was thinking this would work as a walk-around, my joystick never loses control even when my mouse does.
I suppose I can give it a try. It'll have to wait until tomorrow though. I'm exhausted on games for today. Been up since 9:30 doing emulator stuff all day! Off tomorrow too, so it'll be another full day. Gee, hope I don't get to the point where I hate doing this, like I do my job. :)
Don't worry Han, I hate my job so much in fact that I actually look forward to 'breaking' GameEx! LOL
