[RESOLVED] 11.98 Fontname Pop-ups when starting
I just updated to 11.98 and whenever I start GameEx, it pops-up a ton of windows pop-up warnings displaying some font names. I need to press and hold the enter key so they all go away quickly, if not, it's clickety, clickety hell.
I'm guessing it's a known bug and it's being figured out? Since I haven't seen mention of 11.98 here in the forums yet.
Excellent job to all involved in such a wonderful piece of software.
Wow, that sounds like a bummer! What OS you using? Windows 7?
Yeah, same for me... autoinstall triggers them all to display their font names after "finalizing install". Need to press [OK] or press enter on each one before GameEx loads.
[EDIT] Windows 7 64bit
Hmm. That's a new one on me. Can you guys post your logs, or you can't make it to loading?
It all loads fine after pressing Enter on all of them, and everything works just as it should. Just a minor annoyance whenever you start GameEx.
Exiting MAME no longer causes GameEx to crash... Displaying of each font name occurs on each time GameEx loads.
Odd ive updated ... Im running win 7 32 bit no problems.
I just wanted to have a look at your gameex log and see why it needs the permissions.
Seems to be specific to W-64 bit versions eh?
.:edit:. Guess not, just read djonek's post again.
Since it is occurring prior to load, the log only shows information post load as far as I can see. Here is my log:
17:34:39.2 8/9/2011: Opening Configuration File
17:34:39.3 8/9/2011: GameEx: Version 11.98: Starting Log
17:34:39.3 8/9/2011: Operating System Platform: Win32NT
17:34:39.3 8/9/2011: Operating System Name: Windows Vista
17:34:39.3 8/9/2011: Operating System Version: 6.1.7601
17:34:39.3 8/9/2011: Aero running
17:34:39.3 8/9/2011: Initializing Vista/Windows 7 volume control
17:34:39.3 8/9/2011: Checking for versions of .net Framework installed
17:34:39.3 8/9/2011: .net Framework 2.0 Installed
17:34:39.3 8/9/2011: .net Framework 3.0 Installed
17:34:39.3 8/9/2011: .net Framework 3.5 Installed
17:34:39.3 8/9/2011: Intel® Core™2 Quad CPU Q6600 @ 2.40GHz, 8126MB
17:34:39.3 8/9/2011: 2.39Ghz - 4 Cores or CPU's
17:34:39.3 8/9/2011: Running Randomize()
17:34:39.3 8/9/2011: Loading PlugIns
17:34:39.3 8/9/2011: Checking for applications to Launch On Startup
17:34:39.3 8/9/2011: Running Misc startup tasks
17:34:39.3 8/9/2011: Setting Menu types
17:34:39.3 8/9/2011: Getting Configuration Values
17:34:39.3 8/9/2011: Using Theme: Hexed
17:34:39.3 8/9/2011: Checking for alternate Image Directory for Theme: Hexed
17:34:39.3 8/9/2011: Launching HideOS.exe
17:34:39.3 8/9/2011: Initialising Video/MNG DLL's
17:34:39.3 8/9/2011: GameEx will check for media insertion (may affect performance)
17:34:39.3 8/9/2011: Hiding Taskbar
17:34:39.3 8/9/2011: Is Media Center running?
17:34:39.4 8/9/2011: Checking/Creating LCD Registry values
17:34:39.4 8/9/2011: Check Media Center Exit/Start Mode
17:34:39.4 8/9/2011: Media Center Mode 2
17:34:39.4 8/9/2011: Video previews on. Warning: Only recommended on modern systems
17:34:39.4 8/9/2011: Snap Delay set to: 7
17:34:39.4 8/9/2011: Get other settings
17:34:39.4 8/9/2011: Desktop set to Hide ICONS and set Background to Black
17:34:39.4 8/9/2011: Start work for Form
17:34:39.4 8/9/2011: Getting Original Screen Size
17:34:39.4 8/9/2011: Opening Database Connection
17:34:39.4 8/9/2011: Initializing Component
17:34:39.5 8/9/2011: Retrieving resolution setting
17:34:39.5 8/9/2011: MAME Path is: C:\Emulators\MameUI64
17:34:39.5 8/9/2011: Client/Server MAME Path is: C:\Emulators\ClientServerMAME
17:34:39.5 8/9/2011: Cannot Find Client/Server Mame Path: Disabled
17:34:39.5 8/9/2011: Client/Server MAME EXE file is: vmame.exe
17:34:39.5 8/9/2011: Cannot find Client/Server MAME executable: Disabled
17:34:39.5 8/9/2011: daphne Path is: C:\Emulators\Daphne
17:34:39.5 8/9/2011: daphne EXE file is: Daphne.exe
17:34:39.5 8/9/2011: Use daphne on. Daphne.exe will launch games
17:34:39.5 8/9/2011: Model 2 Path Path is: C:\Emulators\Model 2
17:34:39.5 8/9/2011: Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe
17:34:39.5 8/9/2011: Model 2 EXE file is: emulator_multicpu.exe
17:34:39.5 8/9/2011: Model 2 emulator with command line support detected
17:34:39.5 8/9/2011: Use Model 2 on. emulator_multicpu.exe will launch Sega Model 2 games
17:34:39.5 8/9/2011: ZiNc Path is: C:\Emulators\ZiNc
17:34:39.5 8/9/2011: ZiNc EXE file is: zinc.exe
17:34:39.5 8/9/2011: Use ZiNc on. zinc.exe will launch PSX games
17:34:39.5 8/9/2011: MAME EXE file is: MameUI64.exe
17:34:39.5 8/9/2011: ROM Path is: E:\Roms\MAME\ROMS
17:34:39.5 8/9/2011: Catver.ini is located at: C:\GameEx\DATA\catver.ini
17:34:39.5 8/9/2011: controls.ini is located at: C:\GameEx\data\controls.ini
17:34:39.5 8/9/2011: History.dat is located at: C:\GameEx\DATA\history.dat
17:34:39.5 8/9/2011: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
17:34:39.5 8/9/2011: command.dat is located at: C:\GameEx\DATA\command.dat
17:34:39.5 8/9/2011: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
17:34:39.5 8/9/2011: Loading Controls.ini map file
17:34:39.5 8/9/2011: Snap Path is: E:\Assets\MAME\snap
17:34:39.5 8/9/2011: AVI Snap Path is: E:\Assets\MAME\snap
17:34:39.5 8/9/2011: Flyer Path is: E:\Assets\MAME\flyers
17:34:39.5 8/9/2011: Cabinet Path is: E:\Assets\MAME\cabinets
17:34:39.5 8/9/2011: Cabinet 3D Path is: E:\Assets\MAME\3D Cabs
17:34:39.5 8/9/2011: Title Path is: E:\Assets\MAME\titles
17:34:39.5 8/9/2011: PCB Path is: E:\Assets\MAME\pcb
17:34:39.5 8/9/2011: Artwork Preview Path is: E:\Assets\MAME\artwork
17:34:39.5 8/9/2011: Panel Path is: E:\Assets\MAME\cpanel
17:34:39.5 8/9/2011: Manual Path is: E:\Assets\MAME\Manual
17:34:39.5 8/9/2011: Icon Path is: E:\Assets\MAME\icons
17:34:39.5 8/9/2011: Marquee Path is: E:\Assets\MAME\marquees
17:34:39.6 8/9/2011: Applying Language/Text
17:34:39.6 8/9/2011: Text/Language: English
17:34:39.6 8/9/2011: Loading Custom Emulators
17:34:39.6 8/9/2011: Loading Emulator 1: [Console] Atari 2600 (MESS)
17:34:39.6 8/9/2011: Loading Emulator 2: [Console] Atari 5200 (MESS)
17:34:39.6 8/9/2011: Loading Emulator 3: [Console] Atari 7800 (MESS)
17:34:39.6 8/9/2011: Loading Emulator 4: [Console] Bally Astrocade (MESS)
17:34:39.6 8/9/2011: Loading Emulator 5: [Console] Coleco Vision (Virtual Colecovision)
17:34:39.6 8/9/2011: Loading Emulator 6: [Console] Fairchild Channel F (MESS)
17:34:39.6 8/9/2011: Loading Emulator 7: [Console] Mattel Intellivision (Bliss)
17:34:39.6 8/9/2011: Loading Emulator 8: [Console] Nintendo NES (MESS)
17:34:39.6 8/9/2011: Loading Emulator 9: [Console] Nintendo SNES (MESS)
17:34:39.6 8/9/2011: Loading Emulator 10: [Console] Nintendo N64 (Project64)
17:34:39.6 8/9/2011: Loading Emulator 11: [Console] Nintendo GameCube (Dolphin)
17:34:39.6 8/9/2011: Loading Emulator 12: [Fruit] Fruit (MFME)
17:34:39.6 8/9/2011: Loading Emulator 13: [Fruit] Fruit (BFM)
17:34:39.6 8/9/2011: Loading Emulator 14: [Handheld] Sega Game Gear (Fusion)
17:34:39.7 8/9/2011: Loading Emulator 15: [Handheld] Nintendo Game Boy (VisualBoyAdvance)
17:34:39.7 8/9/2011: Loading Emulator 16: [Handheld] Nintendo Game Boy Advance (VisualBoyAdvance)
17:34:39.7 8/9/2011: Loading Emulator 17: [Handheld] Nintendo Game Boy Color (VisualBoyAdvance)
17:34:39.7 8/9/2011: Loading Emulator 18: [Handheld] Nintendo Virtual Boy (Reality Boy)
17:34:39.7 8/9/2011: Loading Emulator 19: [PC] Scumm (ScummVM)
17:34:39.7 8/9/2011: Loading Emulator 20: [PC] Commodore Amiga (GameBase)
17:34:39.7 8/9/2011: Loading Emulator 21: [PC] Microsoft DOS (DOSBox)
17:34:39.7 8/9/2011: Loading Emulator 22: [PC] Z-Code Interactive Fiction
17:34:39.7 8/9/2011: Loading Emulator 23: [Pinball] Future Pinball
17:34:39.7 8/9/2011: Loading Emulator 24: [Pinball] Visual Pinball
17:34:39.7 8/9/2011: Loading Emulator 25: [Pinball] Visual PinMAME
17:34:39.7 8/9/2011: Using Version 3 Themes Animations
17:34:39.7 8/9/2011: Using General Font: Arial Rounded MT Bold
17:34:39.7 8/9/2011: Using Title Font: Arial Rounded MT Bold
17:34:42.1 8/9/2011: Initialising Direct3D
17:34:42.1 8/9/2011: Applying GameEx is Loading Image
17:34:42.2 8/9/2011: Setting Resolution to 1680x1050 32 bit color
17:34:42.2 8/9/2011: Creating Surfaces
17:34:42.4 8/9/2011: Creating Primary Surface - Full Screen Mode
17:34:42.4 8/9/2011: Creating Back Buffer
17:34:42.4 8/9/2011: Version 2 Theme being used. Loading.
17:34:42.4 8/9/2011: Loading Button Data
17:34:42.4 8/9/2011: Loading Font Data
17:34:42.4 8/9/2011: Loading Layout Data
17:34:42.5 8/9/2011: Loading Taskbar Data
17:34:42.5 8/9/2011: Loading graphic Surfaces
17:34:42.5 8/9/2011: Display is running at: 1680x1050 32bit color, 60hz
17:34:42.5 8/9/2011: Creating Surfaces Misc and Dialogs
17:34:42.6 8/9/2011: Creating Surfaces Volume
17:34:42.6 8/9/2011: Creating Surfaces Arrows
17:34:42.6 8/9/2011: Creating Surfaces GameEXlogo Text
17:34:42.6 8/9/2011: Creating Surfaces Toolbar
17:34:42.6 8/9/2011: Creating Surfaces Backgrounds
17:34:42.6 8/9/2011: Creating Surfaces Toolbar Controls
17:34:42.6 8/9/2011: Creating Surfaces GameEx Logo
17:34:42.7 8/9/2011: Creating Surface Unselected
17:34:42.7 8/9/2011: Creating Surfaces Snaps
17:34:42.7 8/9/2011: Creating Surfaces Menu and List Bars
17:34:42.7 8/9/2011: Creating Fonts
17:34:42.7 8/9/2011: Creating Game Font
17:34:43.0 8/9/2011: Creating Game Font Faded
17:34:43.5 8/9/2011: Creating Title Font
17:34:44.1 8/9/2011: Creating Font Black
17:34:44.2 8/9/2011: Creating Font Black Small
17:34:44.2 8/9/2011: Fonts Created Succesfully
17:34:44.2 8/9/2011: Initialising Bass Audio Library
17:34:44.2 8/9/2011: Creating instance of global keyboard hook
17:34:45.3 8/9/2011: Attempting to load game list
17:34:45.8 8/9/2011: MAME CMD options: -nowindow -joy -skip_gameinfo
17:34:45.8 8/9/2011: Loading last used Game List
17:34:45.9 8/9/2011: Loading Start Page
17:34:45.9 8/9/2011: Creating DirectSound Device
17:34:45.9 8/9/2011: Trying: Primary Sound Driver
17:34:45.9 8/9/2011: Loading Sound Files
17:34:45.9 8/9/2011: DirectSound Device Created Successfully
17:34:45.9 8/9/2011: Initialising DirectInput for Gamepad support
17:34:46.1 8/9/2011: Using Device TigerGame Xbox to USB Controller
17:34:46.3 8/9/2011: Initializing MCE Remote
17:34:46.3 8/9/2011: Playing intro sound file
17:34:46.4 8/9/2011: Initialization OK! Starting GameEx!
17:34:46.4 8/9/2011: Testing Main Loop Once: Processing Frame
17:34:46.7 8/9/2011: Testing Main Loop Once: Main Loop ran successfully
17:35:01.3 8/9/2011: Exiting GameEx!
17:35:01.3 8/9/2011: Saving Settings
17:35:02.5 8/9/2011: Disposing Plugins
17:35:02.5 8/9/2011: Closing database connection
17:35:02.5 8/9/2011: Checking for applications to Launch On Exit
17:35:02.5 8/9/2011: Media Center was not open when starting GameEx, so not launching
[ spoiler ] ... [ /spoiler ]
Well.. can't be a 64bit problem cuz as I said above, I'm running Vista 32bit. And yea.. it happens before even loading GameEx, since I have a tool that runs before GameEx to swap primary/secondary displays, and the warnings pop up before that.
DJoneK has Vista 32-bit. All others except for Ian (he has Win 7 x86) are Win 7 x64. I do not believe it is a rights access issue or a Win 7 x64 issue specifically. Will need to see if any XP users are experiencing the issue or other 32-bit Vista/7 users impacted.
@Drac: does it make an entry in your Windows Error Report console at all?
I don't think it's an error, because you can bypass it by clicking the OK button in the window for each font. It's not saying "Error Loading Font..Arial" or anything like that. It's just a small, 1 cubic inch window with the font name and an [OK] button.
It seems like it's a message box in a loop going through all the fonts in code. Maybe was used for testing and was forgotten to be removed for release. Thanks for the report guys. Am sure Tom will fix soon.
Thanks freq! On the ball as usual! ;)
Installed update last night as well and have the same issue. I am running Windows 7 (ultimate) 32 bit.
I was going to uninstall and re install this morning... Glad I checked here first to see if others had the same problem.
