Not sure what is happening - please upload a copy of your gameex.ini and log.txt files. Would also like to know if you have made any recent updates to your system, software additions, etc.
I had something similar appear, about 30% of the time I booted up, when I was first starting to use the awesome Future Retro theme. The problem went away eventually though - I think it is likely that updating GameEx is the reason why.
I hope you get it sorted anyway!
Nothing appears out of the ordinary for your setup or in the log file that I can see. Since you just updated to 11.92 would you mind rebooting your system and report back whether or not the issue continues?
