GameEx doesn't recognize keyboard after exiting Demul 0.56 (Atomiswave and Naomi) after latest update . I can use the mouse but the cursor is hidden . I've checked the hide cursor plugin and it is setup correctly . Even when disabled there isn't a pointer . Also I don't have keyboard / tankstick control . Nothing works . This is the only emulator it does this with . It was working fine before latest update . Also starting Mame or any other emu (if I can get to it without mouse cursor ) fixes the problem when I exit back I get keyboard controls back in GameEx. Also the last time I exited Atomiswave and launched Naomi when I exited it crashed GameEx .
- Windows 7 Ultimate 64 bit
- Latest GameEx version (Auto update )
Thank you .
Noticed 2 erors the first is a glider error so update your grafix drivers and direct x the 2nd error is a visual basic error and could cause the keyboard error,, so ensure these are upto date and 64 bit versions.
