hi. i have an arcade cabinet with a vertically mounted arcade monitor. i only play vertical games on this cab so i use only mame. everything works perfect but i can't make the screensaver to work and i can't figure out why. i need some help please! here's the log file:
11:58:36.7 05/07/2011: Starting Attract Mode
11:58:36.7 05/07/2011: Exception occured running Attract Mode
11:58:36.7 05/07/2011: Retrieving the COM class factory for component with CLSID {02BC8527-BAFA-4A81-9617-4460CEF0F6C7} failed due to the following error: 8007007e.
11:58:36.7 05/07/2011: at y.a(Boolean A_0)
11:58:36.7 05/07/2011: at f.b(Boolean A_0)
11:58:40.9 05/07/2011: Returning From Attract Mode
thanks in advance
thanks in advance
Please post a full log when this happens!
We're gonna need the whole log, not just the snippet of it.
Internet research shows this is an error common to MSN Messenger, no idea why it's working against you here. Fact is you either deleted a COM object or DLL and didn't unregister it first somehow, or something got junked up in an uninstall somewhere. Give this a try:
Link Here
Of course, I'm assuming you're using Windows 7 since you didn't provide the full log and/or specs of the system it's running on.
@Freq: Dang man! On it again! Man I'm getting a bit slower everyday!
I'm sorry. this is the full log
16:12:17.8 05/07/2011: GameEx Lite: Version 10.25: Starting Log
16:12:17.8 05/07/2011: Operating System Platform: Win32NT
16:12:17.8 05/07/2011: Operating System Name: Windows XP
16:12:17.8 05/07/2011: Operating System Version: 5.1.2600
16:12:17.8 05/07/2011: Checking for versions of .net Framework installed
16:12:17.8 05/07/2011: .net Framework 2.0 Installed
16:12:17.8 05/07/2011: Intel® Pentium® 4 CPU 1.80GHz, 767MB
16:12:17.8 05/07/2011: 1,8Ghz
16:12:17.8 05/07/2011: Running Randomize()
16:12:17.8 05/07/2011: Checking for applications to Launch On Startup
16:12:17.8 05/07/2011: Running Misc startup tasks
16:12:17.8 05/07/2011: Setting Menu types
16:12:17.8 05/07/2011: Opening Configuration File
16:12:17.8 05/07/2011: Getting Configuration Values
16:12:17.8 05/07/2011: Using Theme: Default - GameLauncher
16:12:17.8 05/07/2011: Checking for alternate Image Directory for Theme: Default - GameLauncher
16:12:17.8 05/07/2011: Using Images from theme: Default - Media Center V1\MEDIA\
16:12:17.8 05/07/2011: Launching HideOS.exe
16:12:17.8 05/07/2011: Initialising Video/MNG DLL's
16:12:17.8 05/07/2011: Arcade Mode is on
16:12:17.8 05/07/2011: Hiding Taskbar
16:12:17.9 05/07/2011: Is Media Center running?
16:12:17.9 05/07/2011: Checking/Creating LCD Registry values
16:12:17.9 05/07/2011: Check Media Center Exit/Start Mode
16:12:17.9 05/07/2011: Media Center Mode 2
16:12:17.9 05/07/2011: Custom Game Device Input enabled: Getting custom codes
16:12:18.0 05/07/2011: Snap Delay set to: 2
16:12:18.0 05/07/2011: Get other settings
16:12:18.0 05/07/2011: Mouse Input is disabled
16:12:18.0 05/07/2011: Desktop set to Hide ICONS and set Background to Black
16:12:18.0 05/07/2011: Start work for Form
16:12:18.0 05/07/2011: Getting Original Screen Size
16:12:18.0 05/07/2011: Opening Database Connection
16:12:18.2 05/07/2011: Initializing Component
16:12:18.3 05/07/2011: Retrieving resolution setting
16:12:18.3 05/07/2011: MAME Path is: C:\Documents and Settings\Administrador\Escritorio\Mame32
16:12:18.3 05/07/2011: MAME EXE file is: Mame32.exe
16:12:18.3 05/07/2011: ROM Path is: C:\Documents and Settings\Administrador\Escritorio\Mame32\roms
16:12:18.3 05/07/2011: Catver.ini is located at: C:\GameEx\DATA\catver.ini
16:12:18.3 05/07/2011: History.dat is located at: C:\GameEx\DATA\history.dat
16:12:18.3 05/07/2011: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
16:12:18.3 05/07/2011: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
16:12:18.3 05/07/2011: Loading Controls.ini map file
16:12:18.3 05/07/2011: Snap Path is: C:\Documents and Settings\Administrador\Escritorio\Mame32\snap
16:12:18.3 05/07/2011: AVI Snap Path: Not Found
16:12:18.3 05/07/2011: Flyer Path is: C:\Documents and Settings\Administrador\Escritorio\Mame32\flyers
16:12:18.3 05/07/2011: Cabinet Path is: C:\Documents and Settings\Administrador\Escritorio\Mame32\cabinets
16:12:18.3 05/07/2011: Title Path is: C:\Documents and Settings\Administrador\Escritorio\Mame32\titles
16:12:18.3 05/07/2011: PCB Path: Not Found
16:12:18.3 05/07/2011: Artwork Preview Path is: C:\Documents and Settings\Administrador\Escritorio\Mame32\artwork
16:12:18.3 05/07/2011: Panel Path is: C:\Documents and Settings\Administrador\Escritorio\Mame32\cpanel
16:12:18.3 05/07/2011: Manual Path: Not Found
16:12:18.3 05/07/2011: Icon Path: Not Found
16:12:18.3 05/07/2011: Marquee Path is: C:\Documents and Settings\Administrador\Escritorio\Mame32\marquees
16:12:18.4 05/07/2011: Loading Custom Emulators
16:12:18.7 05/07/2011: Using 2D Animations
16:12:18.7 05/07/2011: Using General Font: Arial
16:12:18.7 05/07/2011: Using Title Font: Arial
16:12:18.7 05/07/2011: Game Launcher Mode Enabled
16:12:18.7 05/07/2011: Initialising DirectDraw
16:12:18.8 05/07/2011: Applying GameEx is Loading Image
16:12:18.9 05/07/2011: Creating DirectDraw Device
16:12:18.9 05/07/2011: Using Device: NVIDIA GeForce2 MX/MX 400
16:12:19.2 05/07/2011: 62mb video memory available
16:12:19.6 05/07/2011: Setting Resolution to 320x224 16 bit color
16:12:20.1 05/07/2011: Creating DirectDraw Surfaces
16:12:20.1 05/07/2011: Creating Primary Surface - Full Screen Mode
16:12:20.2 05/07/2011: Creating Back Buffer
16:12:20.3 05/07/2011: Loading graphic Surfaces
16:12:20.3 05/07/2011: Display is running at: 320x224 16bit color, 60hz
16:12:20.4 05/07/2011: Creating Surfaces Flags
16:12:20.4 05/07/2011: Creating Surfaces Misc and Dialogs
16:12:20.6 05/07/2011: Creating Surfaces Volume
16:12:20.7 05/07/2011: Creating Surfaces Arrows
16:12:20.7 05/07/2011: Creating Surfaces GameEXlogo Text
16:12:20.7 05/07/2011: Creating Surfaces Toolbar
16:12:20.7 05/07/2011: Creating Surfaces Backgrounds
16:12:20.7 05/07/2011: Creating Surfaces Toolbar Controls
16:12:20.8 05/07/2011: Creating Surfaces GameEx Logo
16:12:20.8 05/07/2011: Creating Surface Unselected
16:12:20.8 05/07/2011: Creating Surfaces Home & Exit
16:12:20.8 05/07/2011: Creating Surfaces Snaps
16:12:20.9 05/07/2011: Creating Surfaces Menu and List Bars
16:12:21.0 05/07/2011: Creating Fonts
16:12:21.0 05/07/2011: Creating Game Font
16:12:22.1 05/07/2011: Creating Game Font Faded
16:12:24.0 05/07/2011: Creating Title Font
16:12:24.1 05/07/2011: Restoring Title Font From Cache
16:12:24.2 05/07/2011: Creating Menu Font
16:12:24.3 05/07/2011: Creating Font Black
16:12:24.5 05/07/2011: Creating Font Black Small
16:12:24.6 05/07/2011: Fonts Created Succesfully
16:12:24.6 05/07/2011: 50mb video memory left available
16:12:24.6 05/07/2011: Creating instance of global keyboard hook
16:12:24.6 05/07/2011: Playing Startup Video On Thread
16:12:24.6 05/07/2011: Attempting to load game list
16:12:24.8 05/07/2011: Failed Opening Video: c:\gameex\mamearcade.mpeg
16:12:24.9 05/07/2011: Applying Language/Text
16:12:24.9 05/07/2011: Text/Language: Spanish
16:12:24.9 05/07/2011: Initialising Bass Audio Library
16:12:25.2 05/07/2011: MAME CMD options: -nowindow -joy -skip_gameinfo
16:12:25.2 05/07/2011: Loading last used Game List
16:12:25.4 05/07/2011: Setting Music Volume
16:12:25.4 05/07/2011: Creating DirectSound Device
16:12:25.5 05/07/2011: Trying: Controlador primario de sonido
16:12:25.5 05/07/2011: Loading Sound Files
16:12:25.5 05/07/2011: DirectSound Device Created Successfully
16:12:25.5 05/07/2011: Initialising DirectInput for Gamepad support
16:12:25.5 05/07/2011: Looking for Device: Psx Gamepad 1
16:12:25.6 05/07/2011: Device Created
16:12:26.1 05/07/2011: Initializing MCE Remote
16:12:26.1 05/07/2011: Playing intro sound file
16:12:26.1 05/07/2011: Initialization OK! Starting GameEx!
16:12:26.1 05/07/2011: Testing Main Loop Once: Processing Frame
16:12:26.7 05/07/2011: Testing Main Loop Once: Main Loop ran successfully
16:14:31.6 05/07/2011: Starting Attract Mode
16:14:31.7 05/07/2011: Exception occured running Attract Mode
16:14:31.7 05/07/2011: Retrieving the COM class factory for component with CLSID {02BC8527-BAFA-4A81-9617-4460CEF0F6C7} failed due to the following error: 8007007e.
16:14:31.7 05/07/2011: at y.a(Boolean A_0)
16:14:31.7 05/07/2011: at f.b(Boolean A_0)
16:14:35.5 05/07/2011: Returning From Attract Mode
16:16:44.8 05/07/2011: Exiting GameEx!
16:16:44.8 05/07/2011: Saving Settings
16:16:45.9 05/07/2011: Closing database connection
16:16:46.0 05/07/2011: Checking for applications to Launch On Exit
Update your GameEx build to the recent version first, then try and run it again. You also may want to install .net framework 1 and 3 as a troubleshooter.
i don't mhave internet on that machine. how can i do it? and also, i'm a little afraid that it could change my configuration. like i said, everything runs perfect except the screensaver. if you say it's safe i'll do it
Just to ease your mind you can make a copy of the GameEx directory as a backup but it should be fine to update it.
You can download the GameEx offline installer from www.gameex.com and run it on your offline machine to update it, but I would look at adding and updating your .net framework packs first. GameEx uses .net framework function calls to do what it does. :)
It looks like GameEx is not installed properly and has been copied across. As said try a reinstall.
Thank you. you were right. i made a safe copy of my gameex folder and then i updated. it didn't work at all. but when i delete the folder and put back the safe copy, the screensaver started to work perfect. bye
