Can someone help me setup Game Ex to use the 3 different Mame emulators I'm using? I just downloaded GameEx and can't seem to figure out how to get my emu's to work with it. I'm assuming I can set them all up and be able to choose from all the games that I'm playing between all 3 emu's since they all play specific ROM's that the others don't.
Thanks for any help anyone can offer in advance,
Greg
This needs to be done in MAMEmap, but you need to specify which non-mame emu you require for the games you intend to run.
Hey thanks for the reply man, all my emulators are mame....Just different version numbers. So is mame map in the Game EX program?
Yes. There is also a setup app that can help you set things up. You can find it under GameEx/Config in the start menu. Basically, set up your main MAME emulator as you wish. Next, set up all other versions of MAME as emulators. Finally, you specify roms that you want to load with your alternate version. This works with different versions of MAME as well as other emulators (ZiNc, Model2, etc).
