O.k.
I had to re-install windows on my gamebox.
The emulators and assets was on drive E: but in the instal it changed to D:
so..
I setup gameEX on it again by doing a "find and replace" in GameEX.ini finding E: and replacing with D:
Now this worked as all the games are listed again and all the emus work. I have 1 MAJOR issue and I cant seem to figure it out.
Any EMU that required the config to call for an xpadder profile fails because I get the
"Windows cannot find 'xpadder.exe'. Make sure you typed the name correctly, and then try again"
mesaage
the thing is when I test the varios .bat commands outside gameex it works fine (and so it should, it was working before the re-instal)
I did not re-apply my GameEX reg key as I am gonna give this box to my bro but I am sure being unregistered is not the issue here.
Any help would be much appreciated.
runitbat
D:
CD "D:\Games\emulated\sega saturn\SSF_012_beta"
cmd /c "D:\Games\Ultils\xpadder\xpadderSSF.bat"
SSF.exe
start "" "D:\Games\emulated\sega saturn\SSF_012_beta\deamon tools and xpadder exit.bat"
Log
18:55:33.7 25/06/2011: GameEx: Version 11.72: Starting Log
18:55:33.7 25/06/2011: Operating System Platform: Win32NT
18:55:33.7 25/06/2011: Operating System Name: Windows 7
18:55:33.7 25/06/2011: Operating System Version: 6.1.7600
18:55:33.7 25/06/2011: Aero running
18:55:33.7 25/06/2011: Initializing Vista/Windows 7 volume control
18:55:33.7 25/06/2011: Checking for versions of .net Framework installed
18:55:33.7 25/06/2011: .net Framework 2.0 Installed
18:55:33.7 25/06/2011: .net Framework 3.0 Installed
18:55:33.7 25/06/2011: .net Framework 3.5 Installed
18:55:33.7 25/06/2011: Intel® Core i3 CPU 540 @ 3.07GHz, 3575MB
18:55:33.7 25/06/2011: 3.07Ghz - 4 Cores or CPU's
18:55:33.7 25/06/2011: Running Randomize()
18:55:33.7 25/06/2011: Loading PlugIns
18:55:33.7 25/06/2011: Checking for applications to Launch On Startup
18:55:33.7 25/06/2011: Running Misc startup tasks
18:55:33.7 25/06/2011: Setting Menu types
18:55:33.7 25/06/2011: Opening Configuration File
18:55:33.7 25/06/2011: Getting Configuration Values
18:55:33.7 25/06/2011: Using Theme: Dark Champion
18:55:33.7 25/06/2011: Checking for alternate Image Directory for Theme: Dark Champion
18:55:33.7 25/06/2011: Launching HideOS.exe
18:55:33.7 25/06/2011: Initialising Video/MNG DLL's
18:55:33.7 25/06/2011: GameEx will check for media insertion (may affect performance)
18:55:33.7 25/06/2011: Hiding Taskbar
18:55:33.7 25/06/2011: Is Media Center running?
18:55:33.7 25/06/2011: Checking/Creating LCD Registry values
18:55:33.7 25/06/2011: Check Media Center Exit/Start Mode
18:55:33.7 25/06/2011: Media Center Mode 2
18:55:33.7 25/06/2011: Video previews on. Warning: Only recommended on modern systems
18:55:33.7 25/06/2011: Custom Game Device Input enabled: Getting custom codes
18:55:33.7 25/06/2011: Snap Delay set to: 7
18:55:33.7 25/06/2011: Get other settings
18:55:33.7 25/06/2011: Desktop set to Hide ICONS and set Background to Black
18:55:33.7 25/06/2011: Set: Find emulator artwork on best match basis
18:55:33.7 25/06/2011: Start work for Form
18:55:33.7 25/06/2011: Getting Original Screen Size
18:55:33.7 25/06/2011: Opening Database Connection
18:55:33.8 25/06/2011: Initializing Component
18:55:33.8 25/06/2011: Retrieving resolution setting
18:55:33.8 25/06/2011: MAME Path is: D:\Games\emulated\Mame32
18:55:33.8 25/06/2011: Model 2 Path Path is: D:\Games\emulated\Model 2
18:55:33.8 25/06/2011: Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe
18:55:33.8 25/06/2011: Model 2 EXE file is: emulator_multicpu.exe
18:55:33.8 25/06/2011: Model 2 emulator with command line support detected
18:55:33.8 25/06/2011: Use Model 2 on. emulator_multicpu.exe will launch Sega Model 2 games
18:55:33.8 25/06/2011: ZiNc Path is: D:\Games\emulated\zinc
18:55:33.8 25/06/2011: ZiNc EXE file is: zinc.exe
18:55:33.8 25/06/2011: Use ZiNc on. zinc.exe will launch PSX games
18:55:33.8 25/06/2011: MAME EXE file is: MameUI32.exe
18:55:33.8 25/06/2011: ROM Path is: D:\Games\ROMs\Mame
18:55:33.8 25/06/2011: Catver.ini is located at: D:\GameEx\DATA\catver.ini
18:55:33.8 25/06/2011: controls.ini is located at: D:\GameEx\data\controls.ini
18:55:33.8 25/06/2011: History.dat is located at: D:\GameEx\DATA\history.dat
18:55:33.8 25/06/2011: nplayers.ini is located at: D:\GameEx\DATA\nplayers.ini
18:55:33.8 25/06/2011: command.dat is located at: D:\GameEx\DATA\command.dat
18:55:33.8 25/06/2011: MAMEinfo.dat is located at: D:\GameEx\DATA\mameinfo.dat
18:55:33.8 25/06/2011: Loading Controls.ini map file
18:55:33.8 25/06/2011: Snap Path is: D:\Games\emulated\Mame32\snap
18:55:33.8 25/06/2011: AVI Snap Path is: D:\Video\avisnap
18:55:33.8 25/06/2011: Flyer Path is: D:\Games\emulated\Mame32\flyers
18:55:33.8 25/06/2011: Cabinet Path is: D:\Games\emulated\Mame32\cabinets
18:55:33.8 25/06/2011: Cabinet 3D Path is: D:\Games\emulated\Mame32\cabinets
18:55:33.8 25/06/2011: Title Path is: D:\Games\emulated\Mame32\titles
18:55:33.8 25/06/2011: PCB Path is: D:\Games\emulated\Mame32\pcb
18:55:33.8 25/06/2011: Artwork Preview Path is: D:\Games\emulated\Mame32\artwork
18:55:33.8 25/06/2011: Panel Path: Not Found
18:55:33.8 25/06/2011: Manual Path: Not Found
18:55:33.8 25/06/2011: Icon Path is: D:\Games\emulated\Mame32\icons
18:55:33.8 25/06/2011: Marquee Path is: D:\Games\emulated\Mame32\marquees
18:55:33.8 25/06/2011: Loading Custom Emulators
18:55:33.8 25/06/2011: Loading Emulator 1: [Console] Panasonic 3DO
18:55:33.8 25/06/2011: Loading Emulator 3: [Console] Atari 2600 (Stella)
18:55:33.8 25/06/2011: Loading Emulator 4: [Console] Atari 5200 (MESS)
18:55:33.8 25/06/2011: Loading Emulator 5: [Console] Atari 7800 (ProSystem)
18:55:33.8 25/06/2011: Loading Emulator 6: [Console] Atari Jaguar
18:55:33.8 25/06/2011: Loading Emulator 7: [Handheld] Atari Lynx (Handy)
18:55:33.8 25/06/2011: Loading Emulator 8: [Handheld] Bandai WonderSwan Color (Oswan)
18:55:33.8 25/06/2011: Loading Emulator 9: [Console] Coleco Vision (MESS)
18:55:33.8 25/06/2011: Loading Emulator 10: [Console] Fairchild Channel F (MESS)
18:55:33.8 25/06/2011: Loading Emulator 11: [Arcade] Arcade (FB Alpha)
18:55:33.8 25/06/2011: Loading Emulator 12: [Handheld] Nintendo Game Boy Advance (VisualBoyAdvance)
18:55:33.8 25/06/2011: Loading Emulator 13: [Handheld] Nintendo DS (DeSmuME)
18:55:33.8 25/06/2011: Loading Emulator 14: [Console] Mattel Intellivision (MESS)
18:55:33.8 25/06/2011: Loading Emulator 16: [Handheld] SNK Neo-Geo Pocket (NeoPop)
18:55:33.8 25/06/2011: Loading Emulator 17: [Console] Nintendo N64 (Project64)
18:55:33.8 25/06/2011: Loading Emulator 18: [Console] Nintendo NES (Jnes)
18:55:33.8 25/06/2011: Loading Emulator 19: [Console] Nintendo GameCube (Dolphin)
18:55:33.8 25/06/2011: Loading Emulator 20: [Handheld] Nintendo Virtual Boy (Red Dragon)
18:55:33.8 25/06/2011: Loading Emulator 21: [Console] Nintendo Wii (Dolphin)
18:55:33.8 25/06/2011: Loading Emulator 22: [Console] NEC TurboGrafx-16 (MagicEngine)
18:55:33.8 25/06/2011: Loading Emulator 23: [Console] Sony Playstation (ePSXe)
18:55:33.8 25/06/2011: Loading Emulator 24: [Console] Sony Playstation 2 (PCSX2)
18:55:33.8 25/06/2011: Loading Emulator 25: [PC] Sam Coupe
18:55:33.8 25/06/2011: Loading Emulator 26: [Console] Sega Dreamcast (nullDC)
18:55:33.8 25/06/2011: Loading Emulator 27: [Handheld] Sega Game Gear (Fusion)
18:55:33.8 25/06/2011: Loading Emulator 28: [Console] Sega Master System (Fusion)
18:55:33.8 25/06/2011: Loading Emulator 29: [Console] Sega Genesis (Fusion)
18:55:33.8 25/06/2011: Loading Emulator 30: [PC] Microsoft MSX (MESS)
18:55:33.8 25/06/2011: Loading Emulator 31: [PC] Microsoft MSX2 (MESS)
18:55:33.9 25/06/2011: Loading Emulator 32: [Console] Nintendo SNES (ZSNES)
18:55:33.9 25/06/2011: Loading Emulator 38: [Console] Sega Saturn (SSF)
18:55:33.9 25/06/2011: Loading Emulator 39: [PC] Microsoft Windows
18:55:33.9 25/06/2011: Loading Emulator 40: [Console] Sega 32X (Fusion)
18:55:33.9 25/06/2011: Loading Emulator 42: [PC] Microsoft Windows CD
18:55:33.9 25/06/2011: Loading Emulator 43: [Arcade] Arcade (ZiNc)
18:55:33.9 25/06/2011: Loading Emulator 46: [PC GAME] M.U.G.E.N
18:55:33.9 25/06/2011: Using 3D Alpha Blended Animations.
18:55:33.9 25/06/2011: Using General Font: Architext
18:55:33.9 25/06/2011: Using Title Font: Architext
18:55:33.9 25/06/2011: Initialising Direct3D
18:55:33.9 25/06/2011: Setting Resolution to 1360x768 32 bit color
18:55:34.0 25/06/2011: Creating Surfaces
18:55:34.1 25/06/2011: Creating Primary Surface - Full Screen Mode
18:55:34.1 25/06/2011: Creating Back Buffer
18:55:34.1 25/06/2011: Version 2 Theme being used. Loading.
18:55:34.1 25/06/2011: Loading Button Data
18:55:34.1 25/06/2011: Loading Font Data
18:55:34.1 25/06/2011: Loading Layout Data
18:55:34.1 25/06/2011: Loading Taskbar Data
18:55:34.1 25/06/2011: Loading graphic Surfaces
18:55:34.1 25/06/2011: Display is running at: 1360x768 32bit color, 60hz
18:55:34.2 25/06/2011: Creating Surfaces Misc and Dialogs
18:55:34.2 25/06/2011: Creating Surfaces Volume
18:55:34.2 25/06/2011: Creating Surfaces Arrows
18:55:34.2 25/06/2011: Creating Surfaces GameEXlogo Text
18:55:34.2 25/06/2011: Creating Surfaces Toolbar
18:55:34.2 25/06/2011: Creating Surfaces Backgrounds
18:55:34.2 25/06/2011: Creating Surfaces Toolbar Controls
18:55:34.2 25/06/2011: Creating Surfaces GameEx Logo
18:55:34.2 25/06/2011: Creating Surface Unselected
18:55:34.2 25/06/2011: Creating Surfaces Snaps
18:55:34.2 25/06/2011: Creating Surfaces Menu and List Bars
18:55:34.3 25/06/2011: Creating Fonts
18:55:34.3 25/06/2011: Creating Game Font
18:55:34.4 25/06/2011: Creating Game Font Faded
18:55:34.4 25/06/2011: Creating Title Font
18:55:34.4 25/06/2011: Restoring Title Font From Cache
18:55:34.6 25/06/2011: Creating Font Black
18:55:34.7 25/06/2011: Creating Font Black Small
18:55:34.7 25/06/2011: Fonts Created Succesfully
18:55:34.7 25/06/2011: Initialising Bass Audio Library
18:55:34.7 25/06/2011: Creating instance of global keyboard hook
18:55:58.0 25/06/2011: Playing Startup Video on thread
18:55:58.0 25/06/2011: Attempting to load game list
18:55:58.1 25/06/2011: Applying Language/Text
18:55:58.1 25/06/2011: Text/Language: English
18:55:58.1 25/06/2011: MAME CMD options: -nowindow -joy -skip_gameinfo
18:55:58.1 25/06/2011: Loading last used Game List
18:55:58.2 25/06/2011: Creating DirectSound Device
18:55:58.2 25/06/2011: Trying: Primary Sound Driver
18:55:58.2 25/06/2011: Loading Sound Files
18:55:58.2 25/06/2011: DirectSound Device Created Successfully
18:55:58.2 25/06/2011: Initialising DirectInput for Gamepad support
18:55:58.3 25/06/2011: Using Device Controller (XBOX 360 For Windows)
18:55:58.4 25/06/2011: Initializing MCE Remote
18:55:58.4 25/06/2011: Playing intro sound file
18:55:58.4 25/06/2011: Initialization OK! Starting GameEx!
18:55:58.4 25/06/2011: Testing Main Loop Once: Processing Frame
18:55:58.6 25/06/2011: Testing Main Loop Once: Main Loop ran successfully
18:56:08.6 25/06/2011: Validating: Emulator_1: Custom Background: D:\Games\emulated\3DO\snaps\Video\Panasonic - 3DO.flv
18:56:08.6 25/06/2011: Warning: Emulator_1: Custom Background Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_1: Snap Path: D:\Games\emulated\3DO\snaps\Video\Panasonic - 3DO.flv
18:56:08.6 25/06/2011: Warning: Emulator_1: Snap Path Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_1: Database: [Console] Panasonic 3DO
18:56:08.6 25/06/2011: Validating: Emulator_11: Custom Background: D:\Games\emulated\Mame32\snap
18:56:08.6 25/06/2011: Warning: Emulator_11: Custom Background Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_11: Snap Path: D:\Games\emulated\Mame32\snap
18:56:08.6 25/06/2011: Validating: Emulator_12: Custom Background: D:\Games\emulated\Nintendo game boy advance, DS\Snaps
18:56:08.6 25/06/2011: Warning: Emulator_12: Custom Background Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_12: Snap Path: D:\Games\emulated\Nintendo game boy advance, DS\Snaps
18:56:08.6 25/06/2011: Validating: Emulator_12: Control Panel Path: D:\Games\emulated\Nintendo game boy advance, DS\GBA Controls\GBA.png
18:56:08.6 25/06/2011: Validating: Emulator_12: Database: [Handheld] Nintendo Game Boy Advance
18:56:08.6 25/06/2011: Validating: Emulator_13: Custom Background: D:\Games\emulated\Nintendo game boy advance, DS\Snaps\DS
18:56:08.6 25/06/2011: Warning: Emulator_13: Custom Background Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_13: Snap Path: D:\Games\emulated\Nintendo game boy advance, DS\Snaps\DS
18:56:08.6 25/06/2011: Validating: Emulator_13: Control Panel Path: D:\Games\emulated\Nintendo game boy advance, DS\DS Cntrols\Nintendo DS.png
18:56:08.6 25/06/2011: Validating: Emulator_13: Database: [Handheld] Nintendo DS
18:56:08.6 25/06/2011: Validating: Emulator_17: Custom Background: D:\Games\emulated\Nintendo 64\Snaps
18:56:08.6 25/06/2011: Warning: Emulator_17: Custom Background Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_17: Snap Path: D:\Games\emulated\Nintendo 64\Snaps
18:56:08.6 25/06/2011: Validating: Emulator_17: Control Panel Path: D:\Games\emulated\Nintendo 64\Controls\N64.png
18:56:08.6 25/06/2011: Validating: Emulator_17: Database: [Console] Nintendo N64
18:56:08.6 25/06/2011: Validating: Emulator_19: Custom Background: D:\Games\emulated\Nintendo game cube, Wii\Snaps\Video\Nintendo GameCube.avi
18:56:08.6 25/06/2011: Warning: Emulator_19: Custom Background Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_19: Snap Path: D:\Games\emulated\Nintendo game cube, Wii\Snaps\Video\Nintendo GameCube.avi
18:56:08.6 25/06/2011: Warning: Emulator_19: Snap Path Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_19: Control Panel Path: D:\Games\emulated\Nintendo game cube, Wii\Controls\Gamecube.png
18:56:08.6 25/06/2011: Validating: Emulator_19: Database: [Console] Nintendo GameCube
18:56:08.6 25/06/2011: Validating: Emulator_21: Custom Background: D:\Games\emulated\Nintendo game cube, Wii\Snaps
18:56:08.6 25/06/2011: Warning: Emulator_21: Custom Background Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_21: Snap Path: D:\Games\emulated\Nintendo game cube, Wii\Snaps
18:56:08.6 25/06/2011: Validating: Emulator_21: Control Panel Path: D:\Games\emulated\Nintendo game cube, Wii\Controls
18:56:08.6 25/06/2011: Validating: Emulator_21: Database: [Console] Nintendo GameCube
18:56:08.6 25/06/2011: Validating: Emulator_23: Custom Background: D:\Games\emulated\Sony Playstation\snap\Sony PlayStation].flv
18:56:08.6 25/06/2011: Warning: Emulator_23: Custom Background Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_23: Snap Path: D:\Games\emulated\Sony Playstation\snap\Sony PlayStation].flv
18:56:08.6 25/06/2011: Warning: Emulator_23: Snap Path Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_23: Control Panel Path: D:\Games\emulated\Sony Playstation\Controls\PS1.png
18:56:08.6 25/06/2011: Validating: Emulator_23: Database: [Console] Sony Playstation
18:56:08.6 25/06/2011: Warning: Emulator_23: MAPFile Does Not Exist
18:56:08.6 25/06/2011: Validating: Emulator_24: Custom Background: D:\Games\emulated\Sony Playstation 2\snaps
18:56:08.6 25/06/2011: Warning: Emulator_24: Custom Background Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_24: Snap Path: D:\Games\emulated\Sony Playstation 2\snaps
18:56:08.6 25/06/2011: Validating: Emulator_24: Control Panel Path: D:\Games\emulated\Sony Playstation 2\Controls\PS2.png
18:56:08.6 25/06/2011: Validating: Emulator_24: Database: [Console] Sony Playstation 2
18:56:08.6 25/06/2011: Warning: Emulator_24: MAPFile Does Not Exist
18:56:08.6 25/06/2011: Validating: Emulator_26: Custom Background: D:\Games\emulated\Sega Dreamcast\Snaps\Sega - Dreamcast.flv
18:56:08.6 25/06/2011: Warning: Emulator_26: Custom Background Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_26: Snap Path: D:\Games\emulated\Sega Dreamcast\Snaps\Sega - Dreamcast.flv
18:56:08.6 25/06/2011: Warning: Emulator_26: Snap Path Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_26: Control Panel Path: D:\Games\emulated\Sega Dreamcast\Controls\Dreamcast.png
18:56:08.6 25/06/2011: Validating: Emulator_26: Database: [Console] Sega Dreamcast
18:56:08.6 25/06/2011: Validating: Emulator_29: Custom Background: D:\Games\emulated\sega megadrive, Game Gear, Master system\Snaps\Megadrive
18:56:08.6 25/06/2011: Warning: Emulator_29: Custom Background Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_29: Snap Path: D:\Games\emulated\sega megadrive, Game Gear, Master system\Snaps\Megadrive
18:56:08.6 25/06/2011: Validating: Emulator_29: Control Panel Path: D:\Games\emulated\sega megadrive, Game Gear, Master system\MD Controls\Sega Megadrive.png
18:56:08.6 25/06/2011: Validating: Emulator_29: Database: [Console] Sega Genesis
18:56:08.6 25/06/2011: Validating: Emulator_32: Custom Background: D:\Games\emulated\super nintendo\Snaps
18:56:08.6 25/06/2011: Warning: Emulator_32: Custom Background Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_32: Snap Path: D:\Games\emulated\super nintendo\Snaps
18:56:08.6 25/06/2011: Validating: Emulator_32: Control Panel Path: D:\Games\emulated\super nintendo\Layout\Snes layout.png
18:56:08.6 25/06/2011: Validating: Emulator_32: Database: [Console] Nintendo SNES
18:56:08.6 25/06/2011: Validating: Emulator_38: Custom Background: D:\Games\emulated\sega saturn\Snaps
18:56:08.6 25/06/2011: Warning: Emulator_38: Custom Background Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_38: Snap Path: D:\Games\emulated\sega saturn\Snaps
18:56:08.6 25/06/2011: Validating: Emulator_38: Control Panel Path: D:\Games\emulated\sega saturn\Controls\Sega Saturn.png
18:56:08.6 25/06/2011: Validating: Emulator_38: Database: [Console] Sega Saturn
18:56:08.6 25/06/2011: Validating: Emulator_39: Custom Background: D:\Games\emulated\sega saturn\Snaps
18:56:08.6 25/06/2011: Warning: Emulator_39: Custom Background Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_39: Snap Path: D:\Games\emulated\sega saturn\Snaps
18:56:08.6 25/06/2011: Validating: Emulator_40: Custom Background: D:\Games\emulated\sega megadrive, Game Gear, Master system\Snaps\32X
18:56:08.6 25/06/2011: Warning: Emulator_40: Custom Background Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_40: Snap Path: D:\Games\emulated\sega megadrive, Game Gear, Master system\Snaps\32X
18:56:08.6 25/06/2011: Validating: Emulator_40: Database: [Console] Sega 32X
18:56:08.6 25/06/2011: Validating: Emulator_42: Custom Background: D:\Games\PC Games\Snaps
18:56:08.6 25/06/2011: Warning: Emulator_42: Custom Background Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_42: Snap Path: D:\Games\PC Games\Snaps
18:56:08.6 25/06/2011: Validating: Emulator_43: Custom Background: D:\Games\emulated\zinc\SNAP
18:56:08.6 25/06/2011: Warning: Emulator_43: Custom Background Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_43: Snap Path: D:\Games\emulated\zinc\SNAP
18:56:08.6 25/06/2011: Validating: Emulator_46: Custom Background:
18:56:08.6 25/06/2011: Warning: Emulator_46: Custom Background Does not exist
18:56:08.6 25/06/2011: Validating: Emulator_46: Snap Path:
18:56:09.5 25/06/2011: Restoring Emulator from Cache
18:56:09.6 25/06/2011: Restoring Emulator Database From Cache
18:56:09.6 25/06/2011: Restoring Emulator from Cache
18:56:09.8 25/06/2011: Restoring Emulator from Cache
18:56:09.8 25/06/2011: Restoring Emulator Database From Cache
18:56:09.9 25/06/2011: Restoring Emulator from Cache
18:56:09.9 25/06/2011: Restoring Emulator Database From Cache
18:56:10.0 25/06/2011: No Database Data
18:56:10.0 25/06/2011: Restoring Emulator from Cache
18:56:10.0 25/06/2011: Restoring Emulator Database From Cache
18:56:10.1 25/06/2011: Restoring Emulator from Cache
18:56:10.1 25/06/2011: Restoring Emulator Database From Cache
18:56:10.2 25/06/2011: Restoring Emulator from Cache
18:56:10.2 25/06/2011: Restoring Emulator Database From Cache
18:56:10.3 25/06/2011: Restoring Emulator from Cache
18:56:10.3 25/06/2011: Restoring Emulator Database From Cache
18:56:20.0 25/06/2011: Running: cmd.exe /c D: SSF.exe
18:56:20.2 25/06/2011: Shutting down display
18:56:20.3 25/06/2011: Also Launching: C:\Program Files\DAEMON Tools Lite\dtlite.exe -mount 0,"D:\Games\ROMs\Sega Saturn\GUARDIAN_HEROES.CUE"
18:56:23.8 25/06/2011: Exiting Game
18:56:23.8 25/06/2011: Closing Process
18:56:24.9 25/06/2011: Closing Game Process
18:56:24.9 25/06/2011: Writing Stats
18:56:24.9 25/06/2011: Plugin: Game Exit
18:56:24.9 25/06/2011: Plugin: Process Commands
18:56:24.9 25/06/2011: Refreshing Keyboard
18:56:25.0 25/06/2011: Initialising Audio
18:56:25.2 25/06/2011: Restoring Window
18:56:25.2 25/06/2011: Reinitializing Graphics System
18:56:26.1 25/06/2011: Reloading Game Info Page
18:56:26.2 25/06/2011: Returning to GameEx
18:56:29.3 25/06/2011: Exiting GameEx!
18:56:29.3 25/06/2011: Saving Settings
18:56:30.9 25/06/2011: Disposing Plugins
18:56:30.9 25/06/2011: Closing database connection
18:56:30.9 25/06/2011: Checking for applications to Launch On Exit
18:56:30.9 25/06/2011: Media Center was not open when starting GameEx, so not launching
Where are you pointing to xpadder? In the bat file? In the config? Just make sure you adjust where xpadder is located where ever you're calling it. Maybe post your bat file or emulator config where this is occurring so that we can troubleshoot.
Thanks for the prompt response.
here is the emu config
[Emulator_38]
STARTPAGENAME=[Console] Sega Saturn (SSF)
TITLETEXT=Sega Saturn
StartPageLogo=Sega Saturn
ROMFilter=*.cue;*.img;*.iso;*.nrg;*.mds
RomPath=D:\Games\ROMs\Sega Saturn
RomsInFolders=True
SnapPath=
TitlePath=
BoxPath=
CartPath=
ManualPath=
ControlPanelPath=
InstructionsPath=
TVAdPath=
MusicPath=
ImageNotFound=
WorkingPath=D:\Games\emulated\sega saturn\SSF_012_beta
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=False
Debug=False
MAPFile=
AlsoLaunch=C:\Program Files\DAEMON Tools Lite\dtlite.exe -mount 0,"[rompath]\[romfile]"
Command=SSF.exe
LaunchBefore=cmd /c "D:\Games\Ultils\xpadder\xpadderSSF.bat"
LaunchAfter=start "" "D:\Games\emulated\sega saturn\SSF_012_beta\deamon tools and xpadder exit.bat"
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PlaySelectionMusic=False
SelectionMusicFolder=
PCGame=False
DATABASE=[Console] Sega Saturn
UseDbName=
GamesIn7Zips=False
MergeSets=
PlayInScreenSaver=False
ShowMostPlayed=True
RandomMostPlayed=True
CDCheck=False
CDCheckFile=
CustomArtName1=
CustomArtPath1=
CustomArtName2=
CustomArtPath2=
CustomArtName3=
CustomArtPath3=
CustomArtName4=
CustomArtPath4=
CustomArtName5=
CustomArtPath5=
GameExtenderCustomArtPath=
GameExtenderConstants=
System=Sega Saturn
Category=Console
Emulator=SSF
Version=Ver0.12 alpha
Rating=
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/SSF.7z
RequiredFiles=Bios - SEGA_101.BIN and stv110.bin (512kb each)
Website=http://www7a.biglobe.ne.jp/~phantasy/ssf/index.html
Info=Sega Saturn emulator
OLDatZip=
lastgame=
As you can see in the launch before line I have it pointing to this .bat
@echo off
D:
cd games\Ultils\xpadder\
start "" xpadder.exe "SSF P1" "SSF P2" /M
@echo on
Running this bat outside of game EX works correctly.
I tried deleting the cache files from gameex/data just incase there was some kind of glitch there but to no avail.
It seems like something may be remembering the old path but this is not reflected in the runitgame.bat or log file, or maybe not. I am totally lost on this one, all that has changed since yesterday is the gameEX instalation and paths
Regards
Well the log won't give use much detail in this case since you're running a batch file and it doesn't read the output of that file. Is that a direct cut from the bat file or did you manually type that in the forums? Reason I ask is the misspell of "Ultils". I also notice that you use different methods of starting the batch files ("cmd /c" & "start """). That could also be an issue. If you want real-time support then we can set a time to meet in chat to troubleshoot as it would be faster.
Yeah thanks mate that would be awesome, Ill be in the chat channel from now for about 5 hours so I am sure ill catch you.
And ye those files were a copy/paste job
I found the issue.
in my bat files i called the location of file and executed it like this
D:
Now this worked perfectly until the re-instal, no idea why it no longer works.
Anyway I played around with the .bat commands and now I finally have it working using..
cd /D D:\games\Ultils\xpadder\
So sussed it, it was a weird windows bug who knows,
Even though I fixed it I would like to know why it stopped working.
