i just did the latest software update to gameex and my arcade ambiance stopped working. I was gonna try selecting the folder instead of actual mp3 file in the advanced config but it wont let me select a folder it is asking for the file.
Update- i got it working i had to select the folder but for some reason you cant do this from the advance config. So i used the setup wizard and all is good now.
thanks
gameex ini.txt
This is do to a change in the release of version 11.82. Details about it here and quoted below.
The arcade ambiance setting is now for a folder and GameEx now supports multiple MP3s. NOTE: This will break existing setups. You will need to go in to the setup wizard and change the setting to a folder instead of a file.
Advanced Config is no longer supported so this setting will not be changed. Must use Setup Wizard.
