dudunkle Posted June 7, 2011 Share Posted June 7, 2011 Hi, I have configured GameEx with emulator epsxe, but the games donâ??t start.I think the problem is in these pages...Does anyone know where am I wrong?Thanks Link to comment Share on other sites More sharing options...
fRequEnCy Posted June 7, 2011 Share Posted June 7, 2011 Hi, I have configured GameEx with emulator epsxe, but the games donâ??t start.I think the problem is in these pages...Does anyone know where am I wrong?ThanksIt would be best to export your config so that we can see all the settings you have for this emulator. Also what are the details of it not starting? Does GameEx try to run the emulator and then returns back right away? Please give more detail so we know how to direct you to troubleshoot. Link to comment Share on other sites More sharing options...
dudunkle Posted June 8, 2011 Author Share Posted June 8, 2011 Sorry, how do you export the configuration...? Link to comment Share on other sites More sharing options...
fRequEnCy Posted June 8, 2011 Share Posted June 8, 2011 Sorry, how do you export the configuration...? Step 1 in how to ask for help found here. Link to comment Share on other sites More sharing options...
dudunkle Posted June 8, 2011 Author Share Posted June 8, 2011 GameEx try to run the emulator and then returns back right away.This is the configuration with emulator epsxe:[Emulator_7]Enabled=TrueSTARTPAGENAME=Sony Playstation (ePSXe)TITLETEXT=Sony PlaystationStartPageLogo=Sony PlaystationROMFilter=*.bin;*.img;*.mdfRomPath=C:\EMU\PSX\ROMSRomsInFolders=TrueSnapPath=C:\EMU\PSX\VIDEOTitlePath=BoxPath=C:\EMU\PSX\BOX ARTCartPath=ManualPath=ControlPanelPath=InstructionsPath=TVAdPath=MusicPath=ImageNotFound=WorkingPath=C:\EMU\PSX\epsxe170MapKeys=TrueWaitBeforeKeys=SendKeys=ReplaceDash=FalseReplaceUnder=TrueCapitals=FalseRemoveBrackets=TrueShowDesktop=TrueDebug=FalseMAPFile=[Console] Sony Playstation.mapAlsoLaunch=Command=ePSXe.exe -nogui[-VIRTUALDRIVE-]LaunchBefore=LaunchAfter=ConfigFile=[Mapping Off] Exit (Process Close)ExcludedFiles=CustomBackground=PlayMusic=FalseDontShowInfo=PlaySelectionMusic=FalseSelectionMusicFolder=PCGame=FalseDatabase=[Console] Sony PlaystationUseDbName=GamesIn7Zips=FalseMergeSets=PlayInScreenSaver=FalseShowMostPlayed=TrueRandomMostPlayed=TrueCDCheck=FalseCDCheckFile=CustomArtName1=CustomArtPath1=CustomArtName2=CustomArtPath2=CustomArtName3=CustomArtPath3=CustomArtName4=CustomArtPath4=CustomArtName5=CustomArtPath5=GameExtenderCustomArtPath=GameExtenderConstants=System=Sony PlaystationCategory=ConsoleEmulator=ePSXeVersion=1.70Rating=8.3DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/epsxe.7zRequiredFiles=scph1001.bin (512kb)Website=http://www.epsxe.com/Info=Sony Playstation Emulator Link to comment Share on other sites More sharing options...
simbamame Posted June 8, 2011 Share Posted June 8, 2011 Does epsxe run outside of GameEx ? if so then its only a matter of getting the correct command line if not then try setting epsxe up outside of gameex 1st, i take it you have the psx1 bios?. If not don't ask for here you will need to search google.On other note have you tryed PSX ? Grab it HERE i have both installed and found psx easier and better to set up.Ian. Link to comment Share on other sites More sharing options...
fRequEnCy Posted June 8, 2011 Share Posted June 8, 2011 GameEx try to run the emulator and then returns back right away.This is the configuration with emulator epsxe:[Emulator_7]Enabled=TrueSTARTPAGENAME=Sony Playstation (ePSXe)TITLETEXT=Sony PlaystationStartPageLogo=Sony PlaystationROMFilter=*.bin;*.img;*.mdfRomPath=C:\EMU\PSX\ROMSRomsInFolders=TrueSnapPath=C:\EMU\PSX\VIDEOTitlePath=BoxPath=C:\EMU\PSX\BOX ARTCartPath=ManualPath=ControlPanelPath=InstructionsPath=TVAdPath=MusicPath=ImageNotFound=WorkingPath=C:\EMU\PSX\epsxe170MapKeys=TrueWaitBeforeKeys=SendKeys=ReplaceDash=FalseReplaceUnder=TrueCapitals=FalseRemoveBrackets=TrueShowDesktop=TrueDebug=FalseMAPFile=[Console] Sony Playstation.mapAlsoLaunch=Command=ePSXe.exe -nogui[-VIRTUALDRIVE-]LaunchBefore=LaunchAfter=ConfigFile=[Mapping Off] Exit (Process Close)ExcludedFiles=CustomBackground=PlayMusic=FalseDontShowInfo=PlaySelectionMusic=FalseSelectionMusicFolder=PCGame=FalseDatabase=[Console] Sony PlaystationUseDbName=GamesIn7Zips=FalseMergeSets=PlayInScreenSaver=FalseShowMostPlayed=TrueRandomMostPlayed=TrueCDCheck=FalseCDCheckFile=CustomArtName1=CustomArtPath1=CustomArtName2=CustomArtPath2=CustomArtName3=CustomArtPath3=CustomArtName4=CustomArtPath4=CustomArtName5=CustomArtPath5=GameExtenderCustomArtPath=GameExtenderConstants=System=Sony PlaystationCategory=ConsoleEmulator=ePSXeVersion=1.70Rating=8.3DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/epsxe.7zRequiredFiles=scph1001.bin (512kb)Website=http://www.epsxe.com/Info=Sony Playstation EmulatorA quick return usually indicates an issue with the command-line (could be incorrect paths, the exe, or even parameters). Please try troubleshooting by following Step 4B in the link i directed you to before and post the results.Also, did you install ISO Mounting Support? This is required to use the [-VIRTUALDRIVE-] parameter! Link to comment Share on other sites More sharing options...
dudunkle Posted June 9, 2011 Author Share Posted June 9, 2011 I don't use a ISO Mounting Support for load the games, I kept the default configuration of GameEx... Link to comment Share on other sites More sharing options...
dudunkle Posted June 9, 2011 Author Share Posted June 9, 2011 I have changed the command line in following way:ePSXe.exe -nogui "[ROMPATH]\[ROMFILE]" Link to comment Share on other sites More sharing options...
dudunkle Posted June 9, 2011 Author Share Posted June 9, 2011 But when I try to load a game, the following error compare:Do you know where I mistake?error.bmp Link to comment Share on other sites More sharing options...
simbamame Posted June 9, 2011 Share Posted June 9, 2011 But when I try to load a game, the following error compare:Do you know where I mistake?Its because you are trying to open a bin file under the exe path which you cant do as bin is an image, load epsxe up then goto File, run ISO. Link to comment Share on other sites More sharing options...
mesk Posted June 9, 2011 Share Posted June 9, 2011 Dudunkle-what format are your psx games in? are they iso or bin\cue?on a side note,I & another of our members adultery have recommended pSX to many members here,simbamame included and they were all using epsxe and having issue.now they all use pSX without any issues.what I am suggesting is that you may want to make things a bit easier for yourself and make the switch. but regardless of your decision we will help you best we can Link to comment Share on other sites More sharing options...
fRequEnCy Posted June 9, 2011 Share Posted June 9, 2011 I don't use a ISO Mounting Support for load the games, I kept the default configuration of GameEx... Then that command-line would be invalid as ISO Mounting Support would be required for the [-VIRTUALDRIVE-] parameter.I have changed the command line in following way:ePSXe.exe -nogui "[ROMPATH]\[ROMFILE]"This is also invalid. Please take a look at the documentation for this emulator!But when I try to load a game, the following error compare:Do you know where I mistake?It errors because it is an invalid parameter. Really depends on the format of your disc images but for basic support by using the emulator and not a disc mounting application then try the following:ePSXe.exe -nogui -loadbin "[ROMPATH]\[ROMFILE]" 3 Link to comment Share on other sites More sharing options...
simbamame Posted June 10, 2011 Share Posted June 10, 2011 Dudunkle-what format are your psx games in? are they iso or bin\cue?on a side note,I & another of our members adultery have recommended pSX to many members here,simbamame included and they were all using epsxe and having issue.now they all use pSX without any issues.what I am suggesting is that you may want to make things a bit easier for yourself and make the switch. but regardless of your decision we will help you best we canVery True Mesk, having switched to PSX its a lot more user friendly Link to comment Share on other sites More sharing options...
dudunkle Posted June 11, 2011 Author Share Posted June 11, 2011 Dudunkle-what format are your psx games in? are they iso or bin\cue?The roms for psx have different formats:.bin.bin .ape.bin .cue.ccd .img. sub.mdf .mdson a side note,I & another of our members adultery have recommended pSX to many members here,simbamame included and they were all using epsxe and having issue.now they all use pSX without any issues.what I am suggesting is that you may want to make things a bit easier for yourself and make the switch. but regardless of your decision we will help you best we canIâ??m using both emulators PXS and ePSXe because some games that work with PXS not run on ePSXe and vice versa.... Configure pSX with GameEx has not given to me no problems! Its because you are trying to open a bin file under the exe path which you cant do as bin is an image, load epsxe up then goto File, run ISO.It errors because it is an invalid parameter. Really depends on the format of your disc images but for basic support by using the emulator and not a disc mounting application then try the following: ePSXe.exe -nogui -loadbin "[ROMPATH]\[ROMFILE]"I have changed the command line as suggested and now the games of GameEx start! It also start the games that have a different extension of .bin! Thanks!! Link to comment Share on other sites More sharing options...
fRequEnCy Posted June 11, 2011 Share Posted June 11, 2011 So would you consider to be marked as resolved? Link to comment Share on other sites More sharing options...
