Hi All
I have spent allllllll day trying to figure this out and I am ultimatley stuck.
I have Null DC working fine in game EX with a wrapper that someone posted in the config section.
The issue I am having is that when I exit the emu, game EX does not close it. Before I post what I have done to try and fix this, here are my config files
Emu ini
[Emulator_26]
System=Sega Dreamcast
Category=Console
Emulator=nullDC
Version=1.04r50
Rating=
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/nullDC.7z
RequiredFiles=dc_boot.bin, dc_flash.bin, d3dx9_37.dll, msvcr80.dll
Website=http://www.emudev.org/nullDC/Releases/Current/nullDC_103.rar
Info=Sega Dreamcast emulator
TITLETEXT=Sega Dreamcast
STARTPAGENAME=[Console] Sega Dreamcast (nullDC)
StartPageLogo=Sega Dreamcast
Command=nullDC_Win32_Release-NoTrace.exe -config ImageReader:DefaultImage="[ROMPATH]\[ROMFILE]"
ROMFilter=*.cdi;*.gdi;*.bin;*.mdf;*.nrg
Database=[Console] Sega Dreamcast
configFile=[Mapping On] Exit nullDC (Process Close)
MAPFile=
RomPath=E:\Games\ROMs\Sega Dreamcast
SnapPath=
TitlePath=
BoxPath=
CartPath=
ManualPath=
ControlPanelPath=
WorkingPath=E:\Games\emulated\Sega Dreamcast\nullDC_104_r50
MapKeys=True
WaitBeforeKeys=1000
SendKeys={ENTER}
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=False
Debug=False
AlsoLaunch=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PlaySelectionMusic=False
SelectionMusicFolder=
PCGame=False
GamesIn7Zips=False
PlayInScreenSaver=False
ShowMostPlayed=True
RandomMostPlayed=True
CDCheck=False
CDCheckFile=
RomsInFolders=
InstructionsPath=
TVAdPath=
MusicPath=
ImageNotFound=
UseDbName=
MergeSets=
CustomArtName1=
CustomArtPath1=
CustomArtName2=
CustomArtPath2=
CustomArtName3=
CustomArtPath3=
CustomArtName4=
CustomArtPath4=
CustomArtName5=
CustomArtPath5=
GameExtenderCustomArtPath=
GameExtenderConstants=
OLDatZip=
lastgame=
start.ahk
NumParams = %0%
Param1 = %1%
Param2 = %2%
Param3 = %3%
Run, nullDC_Win32_Release-NoTrace.exe, E:\Games\emulated\Sega Dreamcast\nullDC_104_r50\
WinWait, nullDC v1.0.4,
IfWinNotActive, nullDC v1.0.4, , WinActivate, nullDC v1.0.4,
WinWaitActive, nullDC v1.0.4,
Sleep, 100
Send, {ALTDOWN}fn{ALTUP}
Sleep, 100
WinWait, Select Image File,
IfWinNotActive, Select Image File, , WinActivate, Select Image File,
WinWaitActive, Select Image File,
send {TAB 2}
send {DEL}
Send %1%{ENTER}
WinWaitClose, E:\Games\emulated\Sega Dreamcast\nullDC_104_r50\nullDC_Win32_Release-NoTrace.exe,
ExitApp
Runitbat
E:
CD "E:\Games\emulated\Sega Dreamcast\nullDC_104_r50"
start.ahk "E:\Games\ROMs\Sega Dreamcast\Looney Tunes - Space Race.nrg"
Tskill.exe nullDC_Win32_Release-NoTrace.exe
Log file
20:51:31.0 29/05/2011: GameEx: Version 11.72: Starting Log
20:51:31.0 29/05/2011: Operating System Platform: Win32NT
20:51:31.0 29/05/2011: Operating System Name: Windows Vista
20:51:31.0 29/05/2011: Operating System Version: 6.1.7601
20:51:31.0 29/05/2011: Aero running
20:51:31.0 29/05/2011: Initializing Vista/Windows 7 volume control
20:51:31.0 29/05/2011: Checking for versions of .net Framework installed
20:51:31.0 29/05/2011: .net Framework 2.0 Installed
20:51:31.0 29/05/2011: .net Framework 3.0 Installed
20:51:31.0 29/05/2011: .net Framework 3.5 Installed
20:51:31.0 29/05/2011: Intel® Core i3 CPU 540 @ 3.07GHz, 3575MB
20:51:31.0 29/05/2011: 3.07Ghz - 4 Cores or CPU's
20:51:31.0 29/05/2011: Running Randomize()
20:51:31.0 29/05/2011: Loading PlugIns
20:51:31.0 29/05/2011: Checking for applications to Launch On Startup
20:51:31.0 29/05/2011: Running Misc startup tasks
20:51:31.0 29/05/2011: Setting Menu types
20:51:31.0 29/05/2011: Opening Configuration File
20:51:31.0 29/05/2011: Getting Configuration Values
20:51:31.0 29/05/2011: Using Theme: Default - Dark Gloss
20:51:31.0 29/05/2011: Checking for alternate Image Directory for Theme: Default - Dark Gloss
20:51:31.0 29/05/2011: Launching HideOS.exe
20:51:31.0 29/05/2011: Initialising Video/MNG DLL's
20:51:31.0 29/05/2011: GameEx will check for media insertion (may affect performance)
20:51:31.0 29/05/2011: Hiding Taskbar
20:51:31.0 29/05/2011: Is Media Center running?
20:51:31.0 29/05/2011: Checking/Creating LCD Registry values
20:51:31.0 29/05/2011: Check Media Center Exit/Start Mode
20:51:31.0 29/05/2011: Media Center Mode 2
20:51:31.0 29/05/2011: Video previews on. Warning: Only recommended on modern systems
20:51:31.0 29/05/2011: Custom Game Device Input enabled: Getting custom codes
20:51:31.0 29/05/2011: Snap Delay set to: 7
20:51:31.0 29/05/2011: Get other settings
20:51:31.0 29/05/2011: Desktop set to Hide ICONS and set Background to Black
20:51:31.0 29/05/2011: Set: Find emulator artwork on best match basis
20:51:31.0 29/05/2011: Start work for Form
20:51:31.0 29/05/2011: Getting Original Screen Size
20:51:31.0 29/05/2011: Opening Database Connection
20:51:31.1 29/05/2011: Initializing Component
20:51:31.1 29/05/2011: Retrieving resolution setting
20:51:31.1 29/05/2011: MAME Path is: E:\Games\emulated\Mame32
20:51:31.1 29/05/2011: Model 2 Path Path is: E:\Games\emulated\Model 2
20:51:31.1 29/05/2011: Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe
20:51:31.1 29/05/2011: Model 2 EXE file is: emulator_multicpu.exe
20:51:31.1 29/05/2011: Model 2 emulator with command line support detected
20:51:31.1 29/05/2011: Use Model 2 on. emulator_multicpu.exe will launch Sega Model 2 games
20:51:31.1 29/05/2011: ZiNc Path is: E:\Games\emulated\zinc
20:51:31.1 29/05/2011: ZiNc EXE file is: zinc.exe
20:51:31.1 29/05/2011: Use ZiNc on. zinc.exe will launch PSX games
20:51:31.1 29/05/2011: MAME EXE file is: MameUI32.exe
20:51:31.1 29/05/2011: ROM Path is: E:\Games\ROMs\Mame
20:51:31.1 29/05/2011: Catver.ini is located at: E:\GameEx\DATA\catver.ini
20:51:31.1 29/05/2011: controls.ini is located at: E:\GameEx\data\controls.ini
20:51:31.1 29/05/2011: History.dat is located at: E:\GameEx\DATA\history.dat
20:51:31.1 29/05/2011: nplayers.ini is located at: E:\GameEx\DATA\nplayers.ini
20:51:31.1 29/05/2011: command.dat is located at: E:\GameEx\DATA\command.dat
20:51:31.1 29/05/2011: MAMEinfo.dat is located at: E:\GameEx\DATA\mameinfo.dat
20:51:31.1 29/05/2011: Loading Controls.ini map file
20:51:31.1 29/05/2011: Snap Path is: E:\Games\emulated\Mame32\snap
20:51:31.1 29/05/2011: AVI Snap Path is: E:\Video\avisnap
20:51:31.1 29/05/2011: Flyer Path is: E:\Games\emulated\Mame32\flyers
20:51:31.1 29/05/2011: Cabinet Path is: E:\Games\emulated\Mame32\cabinets
20:51:31.1 29/05/2011: Cabinet 3D Path is: E:\Games\emulated\Mame32\cabinets
20:51:31.1 29/05/2011: Title Path is: E:\Games\emulated\Mame32\titles
20:51:31.1 29/05/2011: PCB Path is: E:\Games\emulated\Mame32\pcb
20:51:31.1 29/05/2011: Artwork Preview Path is: E:\Games\emulated\Mame32\artwork
20:51:31.1 29/05/2011: Panel Path is: E:\Games\emulated\Mame32\cpanel
20:51:31.1 29/05/2011: Manual Path: Not Found
20:51:31.1 29/05/2011: Icon Path is: E:\Games\emulated\Mame32\icons
20:51:31.1 29/05/2011: Marquee Path is: E:\Games\emulated\Mame32\marquees
20:51:31.1 29/05/2011: Loading Custom Emulators
20:51:31.1 29/05/2011: Loading Emulator 1: [Console] Panasonic 3DO
20:51:31.1 29/05/2011: Loading Emulator 3: [Console] Atari 2600 (Stella)
20:51:31.1 29/05/2011: Loading Emulator 4: [Console] Atari 5200 (MESS)
20:51:31.1 29/05/2011: Loading Emulator 5: [Console] Atari 7800 (ProSystem)
20:51:31.1 29/05/2011: Loading Emulator 6: [Console] Atari Jaguar
20:51:31.1 29/05/2011: Loading Emulator 7: [Handheld] Atari Lynx (Handy)
20:51:31.1 29/05/2011: Loading Emulator 8: [Handheld] Bandai WonderSwan Color (Oswan)
20:51:31.1 29/05/2011: Loading Emulator 9: [Console] Coleco Vision (MESS)
20:51:31.1 29/05/2011: Loading Emulator 10: [Console] Fairchild Channel F (MESS)
20:51:31.1 29/05/2011: Loading Emulator 11: [Arcade] Arcade (FB Alpha)
20:51:31.1 29/05/2011: Loading Emulator 12: [Handheld] Nintendo Game Boy Advance (VisualBoyAdvance)
20:51:31.1 29/05/2011: Loading Emulator 13: [Handheld] Nintendo DS (DeSmuME)
20:51:31.1 29/05/2011: Loading Emulator 14: [Console] Mattel Intellivision (MESS)
20:51:31.1 29/05/2011: Loading Emulator 16: [Handheld] SNK Neo-Geo Pocket (NeoPop)
20:51:31.2 29/05/2011: Loading Emulator 17: [Console] Nintendo N64 (Project64)
20:51:31.2 29/05/2011: Loading Emulator 18: [Console] Nintendo NES (Jnes)
20:51:31.2 29/05/2011: Loading Emulator 19: [Console] Nintendo GameCube (Dolphin)
20:51:31.2 29/05/2011: Loading Emulator 20: [Handheld] Nintendo Virtual Boy (Red Dragon)
20:51:31.2 29/05/2011: Loading Emulator 21: [Console] Nintendo Wii (Dolphin)
20:51:31.2 29/05/2011: Loading Emulator 22: [Console] NEC TurboGrafx-16 (MagicEngine)
20:51:31.2 29/05/2011: Loading Emulator 23: [Console] Sony Playstation (ePSXe)
20:51:31.2 29/05/2011: Loading Emulator 24: [Console] Sony Playstation 2 (PCSX2)
20:51:31.2 29/05/2011: Loading Emulator 25: [PC] Sam Coupe
20:51:31.2 29/05/2011: Loading Emulator 26: [Console] Sega Dreamcast (nullDC)
20:51:31.2 29/05/2011: Loading Emulator 27: [Handheld] Sega Game Gear (Fusion)
20:51:31.2 29/05/2011: Loading Emulator 28: [Console] Sega Master System (Fusion)
20:51:31.2 29/05/2011: Loading Emulator 29: [Console] Sega Genesis (Fusion)
20:51:31.2 29/05/2011: Loading Emulator 30: [PC] Microsoft MSX (MESS)
20:51:31.2 29/05/2011: Loading Emulator 31: [PC] Microsoft MSX2 (MESS)
20:51:31.2 29/05/2011: Loading Emulator 32: [Console] Nintendo SNES (ZSNES)
20:51:31.2 29/05/2011: Loading Emulator 38: [Console] Sega Saturn (SSF)
20:51:31.2 29/05/2011: Loading Emulator 39: [PC] Microsoft Windows
20:51:31.2 29/05/2011: Loading Emulator 40: [Console] Sega 32X (Fusion)
20:51:31.2 29/05/2011: Loading Emulator 42: [PC] Microsoft Windows CD
20:51:31.2 29/05/2011: Loading Emulator 43: [Arcade] Arcade (ZiNc)
20:51:31.2 29/05/2011: Loading Emulator 46: [PC GAME] M.U.G.E.N
20:51:31.2 29/05/2011: Using 3D Alpha Blended Animations.
20:51:31.2 29/05/2011: Using General Font: Trebuchet MS
20:51:31.2 29/05/2011: Using Title Font: Trebuchet MS
20:51:31.3 29/05/2011: Initialising Direct3D
20:51:31.3 29/05/2011: Applying GameEx is Loading Image
20:51:31.3 29/05/2011: Setting Resolution to 1360x768 32 bit color
20:51:31.3 29/05/2011: Creating Surfaces
20:51:31.5 29/05/2011: Creating Primary Surface - Full Screen Mode
20:51:31.5 29/05/2011: Creating Back Buffer
20:51:31.5 29/05/2011: Loading graphic Surfaces
20:51:31.5 29/05/2011: Display is running at: 1360x768 32bit color, 60hz
20:51:31.5 29/05/2011: Creating Surfaces Misc and Dialogs
20:51:31.6 29/05/2011: Creating Surfaces Volume
20:51:31.6 29/05/2011: Creating Surfaces Arrows
20:51:31.6 29/05/2011: Creating Surfaces GameEXlogo Text
20:51:31.6 29/05/2011: Creating Surfaces Toolbar
20:51:31.6 29/05/2011: Creating Surfaces Backgrounds
20:51:31.6 29/05/2011: Creating Surfaces Toolbar Controls
20:51:31.6 29/05/2011: Creating Surfaces GameEx Logo
20:51:31.6 29/05/2011: Creating Surface Unselected
20:51:31.6 29/05/2011: Creating Surfaces Snaps
20:51:31.6 29/05/2011: Creating Surfaces Menu and List Bars
20:51:31.6 29/05/2011: Creating Fonts
20:51:31.6 29/05/2011: Creating Game Font
20:51:31.7 29/05/2011: Creating Game Font Faded
20:51:31.8 29/05/2011: Creating Title Font
20:51:31.8 29/05/2011: Restoring Title Font From Cache
20:51:31.9 29/05/2011: Creating Font Black
20:51:32.0 29/05/2011: Creating Font Black Small
20:51:32.0 29/05/2011: Fonts Created Succesfully
20:51:32.0 29/05/2011: Initialising Bass Audio Library
20:51:32.0 29/05/2011: Creating instance of global keyboard hook
20:51:32.3 29/05/2011: Playing Startup Video on thread
20:51:32.3 29/05/2011: Attempting to load game list
20:51:32.3 29/05/2011: Applying Language/Text
20:51:32.3 29/05/2011: Text/Language: English
20:51:32.3 29/05/2011: MAME CMD options: -nowindow -joy -skip_gameinfo
20:51:32.3 29/05/2011: Loading last used Game List
20:51:32.4 29/05/2011: Creating DirectSound Device
20:51:32.4 29/05/2011: Trying: Primary Sound Driver
20:51:32.4 29/05/2011: Loading Sound Files
20:51:32.4 29/05/2011: DirectSound Device Created Successfully
20:51:32.4 29/05/2011: Initialising DirectInput for Gamepad support
20:51:32.6 29/05/2011: Using Device Controller (XBOX 360 For Windows)
20:51:32.6 29/05/2011: Using Device Nintendo RVL-CNT-01
20:51:32.6 29/05/2011: Initializing MCE Remote
20:51:32.6 29/05/2011: Playing intro sound file
20:51:32.7 29/05/2011: Initialization OK! Starting GameEx!
20:51:32.7 29/05/2011: Testing Main Loop Once: Processing Frame
20:51:32.9 29/05/2011: Testing Main Loop Once: Main Loop ran successfully
20:51:40.6 29/05/2011: Validating: Emulator_1: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_1: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_1: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_1: Database: [Console] Panasonic 3DO
20:51:40.6 29/05/2011: Validating: Emulator_3: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_3: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_3: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_3: Database: [Console] Atari 2600
20:51:40.6 29/05/2011: Validating: Emulator_4: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_4: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_4: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_4: Database: [Console] Atari 5200
20:51:40.6 29/05/2011: Validating: Emulator_5: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_5: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_5: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_5: Database: [Console] Atari 7800
20:51:40.6 29/05/2011: Validating: Emulator_6: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_6: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_6: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_6: Database: [Console] Atari Jaguar
20:51:40.6 29/05/2011: Validating: Emulator_7: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_7: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_7: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_7: Database: [Handheld] Atari Lynx
20:51:40.6 29/05/2011: Validating: Emulator_8: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_8: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_8: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_8: Database: [Handheld] Bandai WonderSwan Color
20:51:40.6 29/05/2011: Validating: Emulator_9: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_9: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_9: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_9: Database: [Console] Coleco Vision
20:51:40.6 29/05/2011: Validating: Emulator_10: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_10: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_10: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_10: Database: [Console] Fairchild Channel F
20:51:40.6 29/05/2011: Validating: Emulator_11: Custom Background: E:\Games\emulated\mame\Snaps
20:51:40.6 29/05/2011: Warning: Emulator_11: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_11: Snap Path: E:\Games\emulated\mame\Snaps
20:51:40.6 29/05/2011: Warning: Emulator_11: Snap Path Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_11: Control Panel Path: E:\Games\emulated\mame\Controls
20:51:40.6 29/05/2011: Warning: Emulator_11: Control Panel Path Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_11: Title Snap Path: E:\Games\emulated\mame\Titles
20:51:40.6 29/05/2011: Warning: Emulator_11: Title Snap Path Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_11: Box Art Path: E:\Games\emulated\mame\Boxes
20:51:40.6 29/05/2011: Warning: Emulator_11: Box Art Path Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_11: Cart Art Path: E:\Games\emulated\mame\Cartridges
20:51:40.6 29/05/2011: Warning: Emulator_11: Cart Art Path Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_11: Manual Path: E:\Games\emulated\mame\Manuals
20:51:40.6 29/05/2011: Warning: Emulator_11: Manual Path Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_12: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_12: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_12: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_12: Database: [Handheld] Nintendo Game Boy Advance
20:51:40.6 29/05/2011: Validating: Emulator_13: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_13: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_13: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_13: Database: [Handheld] Nintendo DS
20:51:40.6 29/05/2011: Validating: Emulator_14: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_14: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_14: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_14: Database: [Console] Mattel Intellivision
20:51:40.6 29/05/2011: Validating: Emulator_16: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_16: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_16: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_16: Database: [Handheld] SNK Neo-Geo Pocket
20:51:40.6 29/05/2011: Validating: Emulator_17: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_17: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_17: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_17: Database: [Console] Nintendo N64
20:51:40.6 29/05/2011: Validating: Emulator_18: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_18: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_18: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_18: Database: [Console] Nintendo NES
20:51:40.6 29/05/2011: Validating: Emulator_19: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_19: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_19: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_19: Database: [Console] Nintendo GameCube
20:51:40.6 29/05/2011: Validating: Emulator_20: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_20: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_20: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_20: Database: [Handheld] Nintendo Virtual Boy
20:51:40.6 29/05/2011: Validating: Emulator_21: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_21: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_21: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_21: Database: [Console] Nintendo GameCube
20:51:40.6 29/05/2011: Validating: Emulator_22: Custom Background: E:\Games\emulated\PC Engine\Snaps
20:51:40.6 29/05/2011: Warning: Emulator_22: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_22: Snap Path: E:\Games\emulated\PC Engine\Snaps
20:51:40.6 29/05/2011: Warning: Emulator_22: Snap Path Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_22: Control Panel Path: E:\Games\emulated\PC Engine\Controls
20:51:40.6 29/05/2011: Warning: Emulator_22: Control Panel Path Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_22: Database: [Console] NEC TurboGrafx-16
20:51:40.6 29/05/2011: Validating: Emulator_22: Title Snap Path: E:\Games\emulated\PC Engine\Titles
20:51:40.6 29/05/2011: Warning: Emulator_22: Title Snap Path Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_22: Box Art Path: E:\Games\emulated\PC Engine\Boxes
20:51:40.6 29/05/2011: Warning: Emulator_22: Box Art Path Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_22: Cart Art Path: E:\Games\emulated\PC Engine\Cartridges
20:51:40.6 29/05/2011: Warning: Emulator_22: Cart Art Path Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_22: Manual Path: E:\Games\emulated\PC Engine\Manuals
20:51:40.6 29/05/2011: Warning: Emulator_22: Manual Path Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_23: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_23: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_23: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_23: Database: [Console] Sony Playstation
20:51:40.6 29/05/2011: Warning: Emulator_23: MAPFile Does Not Exist
20:51:40.6 29/05/2011: Validating: Emulator_24: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_24: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_24: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_24: Database: [Console] Sony Playstation 2
20:51:40.6 29/05/2011: Warning: Emulator_24: MAPFile Does Not Exist
20:51:40.6 29/05/2011: Validating: Emulator_25: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_25: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_25: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_25: Database: Template
20:51:40.6 29/05/2011: Validating: Emulator_26: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_26: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_26: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_26: Database: [Console] Sega Dreamcast
20:51:40.6 29/05/2011: Validating: Emulator_27: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_27: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_27: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_27: Database: [Handheld] Sega Game Gear
20:51:40.6 29/05/2011: Validating: Emulator_28: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_28: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_28: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_28: Database: [Console] Sega Master System
20:51:40.6 29/05/2011: Validating: Emulator_29: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_29: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_29: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_29: Database: [Console] Sega Genesis
20:51:40.6 29/05/2011: Validating: Emulator_29: Box Art Path: E:\Games\emu
20:51:40.6 29/05/2011: Warning: Emulator_29: Box Art Path Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_30: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_30: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_30: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_30: Database: [PC] Microsoft MSX
20:51:40.6 29/05/2011: Validating: Emulator_31: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_31: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_31: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_31: Database: [PC] Microsoft MSX 2
20:51:40.6 29/05/2011: Validating: Emulator_32: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_32: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_32: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_32: Database: [Console] Nintendo SNES
20:51:40.6 29/05/2011: Validating: Emulator_38: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_38: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_38: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_38: Database: [Console] Sega Saturn
20:51:40.6 29/05/2011: Validating: Emulator_39: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_39: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_39: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_40: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_40: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_40: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_40: Database: [Console] Sega 32X
20:51:40.6 29/05/2011: Validating: Emulator_40: Box Art Path: E:\Games\emu
20:51:40.6 29/05/2011: Warning: Emulator_40: Box Art Path Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_42: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_42: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_42: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_43: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_43: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_43: Snap Path:
20:51:40.6 29/05/2011: Validating: Emulator_46: Custom Background:
20:51:40.6 29/05/2011: Warning: Emulator_46: Custom Background Does not exist
20:51:40.6 29/05/2011: Validating: Emulator_46: Snap Path:
20:51:40.6 29/05/2011: Restoring Emulator from Cache
20:51:40.6 29/05/2011: Restoring Emulator Database From Cache
20:51:40.7 29/05/2011: Restoring Emulator from Cache
20:51:40.7 29/05/2011: Restoring Emulator Database From Cache
20:51:40.8 29/05/2011: Restoring Emulator from Cache
20:51:40.8 29/05/2011: Restoring Emulator Database From Cache
20:51:40.9 29/05/2011: Restoring Emulator from Cache
20:51:40.9 29/05/2011: Restoring Emulator Database From Cache
20:51:41.1 29/05/2011: Restoring Emulator from Cache
20:51:41.1 29/05/2011: Restoring Emulator Database From Cache
20:51:41.2 29/05/2011: Restoring Emulator from Cache
20:51:41.2 29/05/2011: Restoring Emulator Database From Cache
20:51:41.3 29/05/2011: Restoring Emulator from Cache
20:51:41.3 29/05/2011: Restoring Emulator Database From Cache
20:51:41.5 29/05/2011: Restoring Emulator from Cache
20:51:41.5 29/05/2011: No Database Data
20:51:41.5 29/05/2011: Restoring Emulator Database From Cache
20:51:41.6 29/05/2011: Restoring Emulator from Cache
20:51:41.6 29/05/2011: No Database Data
20:51:41.6 29/05/2011: Restoring Emulator Database From Cache
20:51:41.6 29/05/2011: DBCache Diff: 13/11/2009 00:23:19 - 13/11/2009 00:23:19
20:51:41.6 29/05/2011: Not Restoring Emulator Database From Cache
20:51:41.9 29/05/2011: Restoring Emulator from Cache
20:51:41.9 29/05/2011: Restoring Emulator Database From Cache
20:51:42.0 29/05/2011: Restoring Emulator from Cache
20:51:42.0 29/05/2011: Restoring Emulator Database From Cache
20:51:42.1 29/05/2011: Restoring Emulator Database From Cache
20:51:42.1 29/05/2011: Restoring Emulator from Cache
20:51:42.2 29/05/2011: Restoring Emulator Database From Cache
20:51:42.2 29/05/2011: Restoring Emulator from Cache
20:51:42.3 29/05/2011: Restoring Emulator from Cache
20:51:42.3 29/05/2011: Restoring Emulator Database From Cache
20:52:46.0 29/05/2011: Running: cmd.exe /c E: start.ahk "E:\Games\ROMs\Sega Dreamcast\Looney Tunes - Space Race.nrg"
20:52:46.1 29/05/2011: Shutting down display
20:57:48.1 29/05/2011: Exiting Game
20:57:48.1 29/05/2011: Sending %{F4} to emulator
20:57:49.8 29/05/2011: Exiting Game
20:57:49.8 29/05/2011: Writing Stats
20:57:49.8 29/05/2011: Plugin: Game Exit
20:57:49.8 29/05/2011: Plugin: Process Commands
20:57:49.8 29/05/2011: Refreshing Keyboard
20:57:49.9 29/05/2011: Initialising Audio
20:57:50.0 29/05/2011: Restoring Window
20:57:50.0 29/05/2011: Reinitializing Graphics System
20:57:50.8 29/05/2011: Reloading Game Info Page
20:57:50.9 29/05/2011: Returning to GameEx
20:57:53.9 29/05/2011: Exiting GameEx!
20:57:53.9 29/05/2011: Saving Settings
20:57:55.5 29/05/2011: Disposing Plugins
20:57:55.5 29/05/2011: Closing database connection
20:57:55.6 29/05/2011: Checking for applications to Launch On Exit
20:57:55.6 29/05/2011: Media Center was not open when starting GameEx, so not launching
[Mapping On] Exit nullDC (Process Close).ini
# This is an advanced emulator configuration file. It does things such as allow keyboard only emulators to be operated by a gamepad, wait for additional processes to exit and map keys. If this file is used it overrides the MAPKeys setting for the emulator.
[GENERAL]
# Enabled. Use this.
#Make MCE Back button and X-ARCADE Escape and SlikStik Escape to close emulator process
MapBack=True
#Make Escape key close emulator process
MapEscape=True
#When exiting an emulator via the above mappings, you can specify keys in the send keys format to send instead of having GameEx close the process to cleanly exit the emulator. Such as the Q Key or ALT F4 which is %{F4}
KeysToSendOnExit=%{F4}
#Wait for keys to be processed by the emulator
EmuWaitForKeys=True
#Additional processes to wait to exit or close on exit. Dont include the .exe. Leave blank not to use.
Process1=
Process2=
Process3=
Process4=
[JOYMAPPING]
# For mapping a GamePad to keys
# Specify a virtual key code to send when the specific joystick control is pressed. Look at vkcodes.htm for codes.
JoymappingEnabled=FALSE
Left=
up=
Right=
Down=
Button1=
Button2=
Button3=
Button4=
Button5=
Button6=
Button7=
Button8=
Button9=
Button10=
Button11=
Button12=
[GAMEPADEXIT]
#MAP Gamepad controls to exit and make controls exit process
MapGamePadExit=True
#Flag the controls that exit a game by placing True next to each control. To not use the control as part of the combination use a 0
Left=True
Down=
Right=
Up=True
Button1=
Button2=
Button3=
Button4=True
Button5=True
Button6=True
Button7=
Button8=
Button9=
Button10=
Button11=
Button12=
[MOUSEMAPPING]
# For registered users, the ability to control the mouse with a gamepad and/or directional keys.
# For example for PC strategy games.
# Apparantly this functionality is similar to the software Pinnacle profiler. Remember you can setup an emulator
# as one PC game. Specify enabled, and mousespeed 0-20. 20 Being fastest. This setting overrides the directional
# mapping for the above and buttons 1 and 2 Button 1/CTRL becomes left mouse. Button 2/ALT Right mouse
MouseMappingEnabled=False
MouseSpeed=0
[bLOCKKEYS]
# Use this section to disable and block key presses and mouse clicks.
# To disable the mouse clicks use code 1 for left mouse button,
# 2 for right button and 4 for middle button
Enabled=False
BlockKey_1=1
BlockKey_2=2
BlockKey_3=4
BlockKey_4=
BlockKey_5=
[KEYBOARDREMAP]
# Remap Keys for the emulator. Specify from the from key, which is the key you wish to replace the to key
# This should be good enough for real time gaming. Registered version feature. Look at VKCodes.htm for codes.
Enabled=False
Remap_1_From_VK=
Remap_1_To_VK=
Remap_2_From_VK=
Remap_2_To_VK=
Remap_3_From_VK=
Remap_3_To_VK=
Remap_4_From_VK=
Remap_4_To_VK=
Remap_5_From_VK=
Remap_5_To_VK=
o.k I am trying to use the "[Mapping On] Exit nullDC (Process Close).ini" options that comes with gameEX, I added "KeysToSendOnExit=%{F4}" in the file and it is trying to do it but it does not work.
Following that failure I tried using the Tskill.exe command in "Launch after" what is odd about this is that I get the "process cannot be found" error when its executed even though in CTRL+ALT+DEL task manager Null DC is clearly running.
I took it outside of game EX and tried to Tskill NullDC manually (command prompt) and I got the same issue. Because the NullDC has so many "_" and "-" in the file/process name I changed the EXE name to "Test" and tried
Tskill.exe test.exe
Again I got the "cannot be found" error but in task manager its clearly listed as "test.exe"
I went back to the ALT+F4 solution and noticed that you cannot "ALT+F4" nullDC unless the menu at the top is visable (to do that you need to move the mouse) which is why I think GameEX cant close it using that advanced config.
I think the solution would be to add a mouse movement in the "[Mapping On] Exit nullDC (Process Close).ini" before ALT+F4 is sent.
Any help would be greatly appreciated.
Kool thanks man.
This works fine outside gameEX now (If I open NullDC, then command prompt "taskkill /f /im nullDC_Win32_Release-NoTrace.exe")
But inside GameEX it does not work, I checked runitgame.bat and it did send "taskkill /f /im nullDC_Win32_Release-NoTrace.exe", I also removed [Mapping On] Exit nullDC (Process Close).ini incase of any conflict, but still didnt work.
Any ideas?
Kool thanks man.
Any ideas?
Please export the emulator config for this system.
Why not compile the script and then run it? This would fix all your problems as GameEx would be looking for the correct exe to close.
err....
I feel a lil embarressed.
How does gameEX know what process to look at if the script is compiled or not?
I had no idea it made a difference,
compliled my .ahk to a .exe made the changes and it works more than perfect now.
duh..
Thanks for the help man, your awesome as always
err....
duh..
GameEx looks for the process that is in the command-line. So if you compile the script and run it then GameEx will wait for the process to finish and then return back to GameEx. Before you were running a script directly. So GameEx wouldn't know when to return unless you used an advanced config and listed other processes to watch out for. In your case it should have been autohotkey.exe maybe? I'm not sure how AHK handles that as I'm an AI user but same concept.
