hello again im working on demul for my Naomi games. and for some reason when ever i hit ESC from in game it should close the game and send me back to gameex. but its only closing the game & gameex stays out of focus and never comes back. i have to kill it (Gameex.ex*32) from the task manager and reopen. im sure its something easy im missing any ideas?
Naomi.txt
I'm going to assume you didn't change the ExitEmulator mapping in Demul to something other than escape.
On the next to last page of your emu setup (I think it's page #3 like the third or fouth option down), there should be a drop down box that says "Advanced Config" or something to that effect. Select the one that says "Mapping Off [ESC]" and you should be set. ;)
.:EDIT:. Did you import the Raine config for this emu? I couldn't help but notice:
System=Arcade
Category=Arcade
Emulator=Raine
Version=0.51.5
Rating=
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/raine.7z
RequiredFiles=
Website=http://rainemu.swishparty.co.uk/
Info=Raine is an arcade emulator which emulates some games which use M68000 or M68020 CPU's. The main focus is on emulating Taito and Jaleco games.
yes i did import raine config cause i couldnt find the emulator setup for demul in the setup wizard. i did change all the paths and everything so i didnt think it would be a issue. Also i did try setting this "Mapping Off [ESC]" but no luck. here is the latest ini
-UPDATE- seems to be working now i did a quick reboot and it magically works. this is the best forum hands down. now im done for today i promise lol ;)
Naomi.txt
This part is what confuses me! :blink:
Sorry guys i was a bit quick to mark this as resolved. i dont know how i didnt notice this issue before. the issue is while playing a game if i hit the ESC key it will close the game and send me back to gameex like it should but for some reason i lose all control. i cant use the arrow keys to scroll or enter to play nothing is working. I have to restart gameex to get things back to normal.
Update-the one button that will still work is the left mouse button. so i tryed to relaunch the game and the game does launch but once i exit gameex gives me this error log.
Naomi.txt
Error Log.txt
The wired thing is i also use Demul for my Atomiswave games and it works fine. i can exit games and still have control once back in gameex.i have both emulators set up the same way. by importing the Raine config in the setup wizard and just changing all the paths. i dont undestand why its not working with naomi the same way it works for atomiswave. anyone have any ideas?
Naomi.txt
Atomiswave.txt
Edited by Draco1962
