Hey guys,
having some trouble with PJ64. Everything works outside of GameEx. But when trying to load any 64 roms inside of GameEx I get "Attempt to open file fail" I'm using PJ64 1.7.0.49 if that helps?
Also here's my GameEx emu config
[Emulator_8]
STARTPAGENAME=Nintendo N64
TITLETEXT=Nintendo N64
StartPageLogo=Nintendo N64
ROMFilter=
RomPath=E:\Emulators\Nintendo\N64\Roms
RomsInFolders=True
SnapPath=E:\Emulators\Nintendo\N64\Snap
TitlePath=E:\Emulators\Nintendo\N64\Title
BoxPath=K:\HyperSpin\Media\Nintendo 64\Images\Artwork3
CartPath=K:\HyperSpin\Media\Nintendo 64\Images\Artwork4
ManualPath=E:\Emulators\N64\Manuals
ControlPanelPath=C:\Assets\Nintendo N64\Controls
InstructionsPath=
TVAdPath=
MusicPath=
ImageNotFound=
WorkingPath=E:\Emulators\Nintendo\N64
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=True
Debug=False
MAPFile=
AlsoLaunch=
Command=Project64.exe [ROMPATH]\[ROMFILE]
LaunchBefore=
LaunchAfter=
ExcludedFiles=
PlayMusic=False
DontShowInfo=
PlaySelectionMusic=False
SelectionMusicFolder=
PCGame=False
DATABASE=[Console] Nintendo N64
UseDbName=True
GamesIn7Zips=True
MergeSets=False
PlayInScreenSaver=False
ShowMostPlayed=True
RandomMostPlayed=True
CDCheck=False
CDCheckFile=
CustomArtName1=
CustomArtPath1=
CustomArtName2=
CustomArtPath2=
CustomArtName3=
CustomArtPath3=
System=Nintendo N64
Category=Console
Emulator=Project64
Version=1.6
Rating=
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/Project64.7z
RequiredFiles=
Website=http://www.pj64-emu.com/
Info=Nintendo 64 emulator
OLDatZip=
CustomArtName4=
CustomArtPath4=
CustomArtName5=
Have you tried putting the file in quotes? I know the older version required there be no quotes used but I think the newer versions fixed that. I could be wrong and have no way of testing since don't have that version. Try the following and if not then we'll try something else.
Project64.exe "[ROMPATH]\[ROMFILE]"
Thanks a lot man! That seemed to do the trick. Can't believe it was such an easy fix lol.
No problem. As a rule it's always best to enclose [ROMPATH]\[ROMFILE] in quotes. Actually Project64 (earlier versions) is the only exception I'm aware of. Marking as [RESOLVED]! Enjoy!
Ah ok man I'll definitely keep that in mind. Thanks again! :)
