Hello, im new on the community im working on a arcade machine for myself. im from argentina so sorry for my bad english.
this is the LOG.
im on XP with latest dx9 and latest nvidia drivers, so if anyone knows how to make it work i'll be thankful
thanks
02:22:18.7 18/05/2011: GameEx: Version 11.72: Starting Log
02:22:18.9 18/05/2011: Operating System Platform: Win32NT
02:22:18.9 18/05/2011: Operating System Name: Windows XP
02:22:18.9 18/05/2011: Operating System Version: 5.1.2600
02:22:18.9 18/05/2011: Checking for versions of .net Framework installed
02:22:18.9 18/05/2011: .net Framework 2.0 Installed
02:22:18.9 18/05/2011: Intel® Core2 Duo CPU T5450 @ 1.66GHz, 2046MB
02:22:19.0 18/05/2011: 1,66Ghz - 2 Cores or CPU's
02:22:19.0 18/05/2011: Running Randomize()
02:22:19.5 18/05/2011: Loading PlugIns
02:22:19.6 18/05/2011: Checking for applications to Launch On Startup
02:22:19.6 18/05/2011: Running Misc startup tasks
02:22:19.6 18/05/2011: Setting Menu types
02:22:19.6 18/05/2011: Opening Configuration File
02:22:19.6 18/05/2011: Getting Configuration Values
02:22:19.7 18/05/2011: Using Theme: Default - Media Center
02:22:19.7 18/05/2011: Checking for alternate Image Directory for Theme: Default - Media Center
02:22:19.7 18/05/2011: Using Images from theme: Default - Media Center V1\MEDIA\
02:22:19.7 18/05/2011: Launching HideOS.exe
02:22:19.7 18/05/2011: Initialising Video/MNG DLL's
02:22:19.7 18/05/2011: GameEx will check for media insertion (may affect performance)
02:22:19.7 18/05/2011: Hiding Taskbar
02:22:19.8 18/05/2011: Is Media Center running?
02:22:19.9 18/05/2011: Checking/Creating LCD Registry values
02:22:20.0 18/05/2011: Check Media Center Exit/Start Mode
02:22:20.0 18/05/2011: Media Center Mode 2
02:22:20.0 18/05/2011: Video previews on. Warning: Only recommended on modern systems
02:22:20.1 18/05/2011: Snap Delay set to: 2
02:22:20.1 18/05/2011: Get other settings
02:22:20.1 18/05/2011: Desktop set to Hide ICONS and set Background to Black
02:22:20.1 18/05/2011: Set: Find emulator artwork on best match basis
02:22:20.1 18/05/2011: Start work for Form
02:22:20.1 18/05/2011: Getting Original Screen Size
02:22:20.2 18/05/2011: Opening Database Connection
02:22:22.7 18/05/2011: --**--
02:22:22.7 18/05/2011: Error: No error message available, result code: REGDB_E_CLASSNOTREG(0x80040154).
02:22:22.9 18/05/2011: at System.Data.OleDb.OleDbConnectionInternal..ctor(OleDbConnectionString constr, OleDbConnection connection)
02:22:22.9 18/05/2011: at System.Data.OleDb.OleDbConnectionFactory.CreateConnection(DbConnectionOptions options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningObject)
02:22:22.9 18/05/2011: at System.Data.ProviderBase.DbConnectionFactory.CreateNonPooledConnection(DbConnection owningConnection, DbConnectionPoolGroup poolGroup)
02:22:22.9 18/05/2011: at System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection owningConnection)
02:22:22.9 18/05/2011: at System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory)
02:22:22.9 18/05/2011: at System.Data.OleDb.OleDbConnection.Open()
02:22:22.9 18/05/2011: at ag.a(Boolean A_0, String A_1, Boolean A_2)
02:22:22.9 18/05/2011: at ag..ctor()
02:22:22.9 18/05/2011: Disposing Plugins
02:22:22.9 18/05/2011: GameEx is exiting with errors
02:22:24.7 18/05/2011: ERRORS DETECTED: EXITING
Welcome to the forums and sorry for the inconvenience. Search turned up a few results. This one was one of the first ones. Is it related? If not then we can troubleshoot from there as I'm not too familiar with this error.
  On 5/18/2011 at 6:05 AM, kosukito said:
Well im usin a cut down version of xp, so i guess i'll try solving that. thank you very much
No problem! ;)
That would explain it. Good luck with your install and please let us know the results.
