Not a gameEX question but I know most of you use xpadder here.
Some emulators require I use xpadder for 1 - 6 players, I use a .bat file to launch xpadder with the specified profile.
My question is, how do I run the command in the .bat to launch the xpadder profile for controllers 2+
This is what I use normally
@ECHO off
E:
cd Games\Ultils\xpadder\
start "" xpadder.exe "E:\Games\Ultils\xpadder\xbox360 P1" /M
@ECHO on
I tried something like this but it just changed the profile for the first controller
@ECHO off
E:
start "" xpadder.exe "E:\Games\Ultils\xpadder\xbox360 P2"
start "" xpadder.exe "E:\Games\Ultils\xpadder\xbox360 P3"
start "" xpadder.exe "E:\Games\Ultils\xpadder\xbox360 P4"
@ECHO on
Thanks in advance.
Haven't used XPadder in a long time but I think you just load the profiles off the same exe instead of each one individually. Meaning:
xpadder.exe <profile1> <profile2> <profile3> <profile4> /M
You fill in the <profile#> with you profile names of course.
Perfect thanks.
@echo off
E:
start "" xpadder.exe "xbox360 P1" "xbox360 P2" "xbox360 P3" "xbox360 P4" /M
@echo on
Thats how I configured it and it works a charm
  On 5/14/2011 at 1:16 PM, massop said:
Perfect thanks.
@echo off
E:
@echo on
Good deal! Since only running a single command in this one, why not just use the exe in the launch before instead of using a batch? Also the @ECHO ON serves no purpose at the end of the batch script since you're hiding the rest anyways. I'd get out of the habit of adding it.
