I Was Wondering if anyone could tell me how I can rename My Sega Cd Bin/Cue Files as the ones I Have, have silly names and when I change them normally i mess up the files so they dont work for example what i wanna do is
change "Amazing_Spiderman-Man_Vs_The_Kingpin(US-Genesis).bin"
to "The Amazing Spider-man Vs The Kingpin.bin
Its basically just to make my box art and snap videos muatch up and look good in the rom list under sega cd emulator any help would be greatly appreciated
its ok I worked it out basically you re-name them normally and then open your .cue file in notepad and rename it there and save make sure they all have the same name or it won't work
I just rename the cue file and set the rom filter to .cue
