Does anyone know how to use GameEx to run N64 Project64 roms
I can get GameEx to display the roms but it just runs he emulator when I use it.
With version 1.6 you just need to make sure that you do not use qoutes on the command line.
ie your command line should look like this. Project64.exe [ROMPATH]/[ROMFILE]
make sure that you set the options in Project64 for "Run fullscreen after Rom load".
