I have just turned on auto update its downloaded and installed and restarted now its saying update?
SM
Also my GamEx is located on F: a removable drive, the update keeps installing a version on d: ?? why doesnt it update the one on f:
Ahh the update loop.
Try installing the full package off of GameEx.com and then turn it on.
Do you have two installs on your machine? One might be in C:/GameEx and the other might be in C:/Program Files/GameEx
Just to make sure.
Edit: yeah it sounds like you have 2 seperate installations there. Take out your removable drive and uninstall GameEx. Then put it back in and reinstall the offline installer. Be sure you point the installer at the F drive where your current install resides.
No i had only 1 version on drive f: when it asked do i want to update i said yes it then downloaded and installed a version in c: ?? its on f: as c: is a fixed drive and i use a removable cos its in my cab that doesnt have internet access.
How can i make it update the one on f: i have deleted the one on d:
Just to make sure.
reinstall the offline installer ??
Update using the offline installer before enabling auto update. There you can select the path to install to. Make sure you uninstall the C: drive installation first.
Reinstall *using* the offline installer. :)
Im sorry but i dont understand what you mean by using the offline installer. Do you mean download Gameex and reinstall on f: ?
Yeah. Download gameexsetup.exe I mean.
update now done. :). Thanks a million dood.
You bet compadre! :)
