My GameEx crashes everytime i start it, i load it up and when i scroll threw the list it comes up with the error gameex has stopped working, pic attached, mame seems to work ok but none of the rest :( please help. Ive done nothing out of the ordinary, its just happened. I have cleared the cache files just in case and that didnt work.
log attached.
EDIT: I have found the epsxe was or is causing the problem, dont know how or why so if any body knows of this problem please let me know as psx is one of the emulators i was looking forward to having in the cab, works fine outside of GameEx but not in.
Does it crash for everything or just future pinball? Also, does it crash in full screen mode or just windowed mode?
All but MAME seems to work though, and both either windowed or full screen i have tried altering my screen res and altering the themes in gameex but to no avail.
Also the gfx are messed up at the top?
PS also i havent updated GameEx foroa while as it seemed stable im going to update now and see if that does anygood.
This might be related to your multiple installs mentioned in the other thread, but I also think it may be related to the res problem Tom corrected a couple builds ago.
I Dont have multiple installs, only 1 on the f:drive.
  On 4/26/2011 at 8:36 PM, TSpeirs said:
I notice your not running the latest version. If this is a bug it may well have been fixed.
Thanks Tom, ive downloaded and installed 11.69 and i still get a crash but ive now found that its caused by the PSX emulator ive installed, any ideas why this would cause GameEx to crash.. ive unticked the psx and its running sweet. I was using epsxe.
