i've post before about sending vertical games to one monitor and horizontal games to the other, i found a simple solution, if we use a mame with user interface (mameui32).
on the left column we have games filters (all games, availble games,etc...) and we have vertical and horizontal games. right clck on vertical, chose properties, on screen tab chose wich display we want vertical games, a txt file is generate for vertical games. should be enough.
I imagine that text file will be a config file called "vertical.cfg" that has the one setting with the screen to use in it. Correct?
the good thing is, after the file is create by mameui, we can still use cmdlinemame. by having both mame in the same folder.
hey bkenobi, i was reading the other post I've made , and you actualy sugest an INI file the first time, I just thought it was something out of my league.
