I was just thinking something,ppl who use the sega m2 emulator know that it comes with 2 exe's.1 for single core processors,and 1 for multi core.when using the integrated gameex support which version does it launch?and if it is only using the single core version how do I get it to launch the multi cpu version? :huh:
Tom's right. GameEx will select the appropriate version based on your rig's config, as long as both exe's are in your Model 2 folder. :)
ah hay now i know why my sega model 2 emulator plays better on my HTPC, thats dual core, my cab is single core :) Cheers.
SM
