I have a bit of an anomolie.
I'm using CPWizard for MAME control panels and I've created a static control panel for SNES & GBA.
Within GameEx when I select a MAME game and then select View Control panel I can exit the viewing and go back to menu by pressing a button mapped to Esc key.
However, if I select a SNES or GBA game and then select View Control panel I cannot exit viewing by pressing the button mapped to Esc key. I have to push joy button 4.
How do I configure to be able to use Esc?
I'm assuming that its something to do with the Emulator Advance Config - but not sure where.
Still not resolved this. I'm now not thinking this is a Emulator Advance Config issue as I'm sure if your just viewing the control panel GameEx would not load have loaded the Emulator config.
Anyone any ideas where I should check?
OK - mapped 'Back' to 'Esc' in GameEx Advanced Key Config.....which is what CPWizard was mapped to.
Just got to hope no other undesired impacts
