I am new to GameEx and am having trouble getting it to start up. Here is the error log:
20:32:07.8 12/28/2005: GameEx: Version 5.33: Starting Log
20:32:07.8 12/28/2005: Operating System Platform: Win32NT
20:32:07.8 12/28/2005: Operating System Name: Windows XP
20:32:07.8 12/28/2005: Operating System Version: 5.1.2600
20:32:07.8 12/28/2005: Checking for versions of .net Framework installed
20:32:07.8 12/28/2005: .net Framework 1.1 Installed
20:32:07.8 12/28/2005: Checking Registration
20:32:07.8 12/28/2005: Running Randomize()
20:32:07.8 12/28/2005: Initialising Video/MNG DLL's
20:32:07.8 12/28/2005: Running Misc startup tasks
20:32:07.9 12/28/2005: Setting Menu types
20:32:07.9 12/28/2005: Opening Configuration File
20:32:07.9 12/28/2005: Getting Configuration Values
20:32:07.9 12/28/2005: Using Theme: Default - Default
20:32:07.9 12/28/2005: Checking for alternate Image Directory for Theme: Default - Default
20:32:07.9 12/28/2005: Text/Language: English
20:32:07.9 12/28/2005: Applying Language/Text
20:32:07.9 12/28/2005: Creating Scancodes.txt (List of DirectInput scan codes)
20:32:08.0 12/28/2005: Snap Delay set to: 1
20:32:08.0 12/28/2005: Is Media Center running?
20:32:08.0 12/28/2005: Check Media Center Exit/Start Mode
20:32:08.0 12/28/2005: Media Center Mode 2
20:32:08.0 12/28/2005: Checking for applications to Launch On Startup
20:32:08.0 12/28/2005: Get other settings
20:32:08.0 12/28/2005: Using 2D Animations
20:32:08.0 12/28/2005: Set: Find emulator artwork on best match basis
20:32:08.0 12/28/2005: Launching HideOS.exe
20:32:09.0 12/28/2005: Hiding Taskbar
20:32:09.0 12/28/2005: Start work for Form
20:32:09.0 12/28/2005: Getting Original Screen Size
20:32:09.0 12/28/2005: Loading ICON
20:32:09.0 12/28/2005: Initializing Component
20:32:09.0 12/28/2005: Initialising Bass Audio Library
20:32:09.2 12/28/2005: Loading default loading screen
20:32:09.2 12/28/2005: Using General Font: Trebuchet MS
20:32:09.2 12/28/2005: Using Title Font: Trebuchet MS
20:32:09.2 12/28/2005: Initialising DirectDraw
20:32:09.3 12/28/2005: Creating DirectDraw Device
20:32:09.3 12/28/2005: Using Device: ATI MOBILITY RADEON 7500
20:32:09.3 12/28/2005: Setting Resolution to 800x600 32 bit color
20:32:10.9 12/28/2005: Creating DirectDraw Surfaces
20:32:10.9 12/28/2005: Creating Primary Surface - Full Screen Mode
20:32:10.9 12/28/2005: Creating Back Buffer
20:32:10.9 12/28/2005: Loading graphic surfaces
20:32:10.9 12/28/2005: Creating Surfaces Misc and Dialogs
20:32:11.1 12/28/2005: Creating Surface Volume
20:32:11.1 12/28/2005: Creating Surfaces Arrows
20:32:11.1 12/28/2005: Creating Surfaces GameEXlogo Text
20:32:11.1 12/28/2005: Creating Surfaces Toolbar
20:32:11.1 12/28/2005: Creating Surfaces Backgrounds
20:32:12.5 12/28/2005: Creating Surfaces Toolbar Controls
20:32:12.5 12/28/2005: Creating Surfaces GameEx Logo
20:32:12.5 12/28/2005: Creating Surfaces Home & Exit
20:32:12.6 12/28/2005: Creating Surfaces Snaps
20:32:12.6 12/28/2005: Creating Surfaces Menu and List Bars
20:32:12.7 12/28/2005: Creating Fonts
20:32:12.7 12/28/2005: Creating Menu Font
20:32:12.8 12/28/2005: Creating Game Font
20:32:12.9 12/28/2005: Creating Game Font Standard Size
20:32:13.5 12/28/2005: Creating Font Black
20:32:13.6 12/28/2005: Creating Font Black Small
20:32:13.7 12/28/2005: Creating Game Font Faded
20:32:13.8 12/28/2005: Creating Title Font
20:32:14.0 12/28/2005: Fonts Created Succesfully
20:32:39.1 12/28/2005: Initialising Windows Media Player Component
20:32:39.2 12/28/2005: MAME Path is: C:\Mame32
20:32:39.2 12/28/2005: MAME EXE file is: Mame32.exe
20:32:39.2 12/28/2005: ROM Path is: C:\Mame32\roms
20:32:39.2 12/28/2005: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
20:32:39.2 12/28/2005: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
20:32:39.2 12/28/2005: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
20:32:39.2 12/28/2005: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
20:32:39.2 12/28/2005: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
20:32:39.2 12/28/2005: Loading Controls.ini map file
20:32:39.2 12/28/2005: Loading Custom Emulators
20:32:39.6 12/28/2005: Snap Path is: C:\Mame32\snap
20:32:39.6 12/28/2005: AVI Snap Path: Not Found
20:32:39.6 12/28/2005: Flyer Path is: C:\Mame32\flyers
20:32:39.6 12/28/2005: Cabinet Path is: C:\Mame32\cabinets
20:32:39.6 12/28/2005: Title Path is: C:\Mame32\titles
20:32:39.6 12/28/2005: Panel Path: Not Found
20:32:39.6 12/28/2005: Icon Path is: C:\Mame32\icons
20:32:39.6 12/28/2005: Marquee Path is: C:\Mame32\marquees
20:32:39.6 12/28/2005: MAME CMD options: -triplebuffer -nowindow -joy
20:32:39.6 12/28/2005: Attempting to load game list
20:32:39.7 12/28/2005: Loading last used Game List
20:32:39.7 12/28/2005: Setting Music Volume
20:32:39.7 12/28/2005: Creating DirectSound Device
20:32:39.7 12/28/2005: Trying: Primary Sound Driver
20:32:39.7 12/28/2005: Loading Sound Files
20:32:39.8 12/28/2005: DirectSound Device Created Successfully
20:32:39.8 12/28/2005: Creating ICONS
20:32:40.1 12/28/2005: Initialising DirectInput for Gamepad support
20:32:40.1 12/28/2005: Unable to create a joystick device
20:32:40.1 12/28/2005: Playing intro sound file
20:32:40.2 12/28/2005: Initializing MCE Remote
20:32:40.2 12/28/2005: Initialization OK! Starting GameEx!
20:32:40.2 12/28/2005: Testing Main Loop Once: Processing Frame
20:32:40.3 12/28/2005: ERRORS DETECTED: EXITING
20:32:40.3 12/28/2005: at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
20:32:40.3 12/28/2005: at Microsoft.DirectX.DirectDraw.Surface.Draw(Rectangle destRectangle, Surface sourceSurface, Rectangle srcRectangle, DrawFlags flags)
20:32:40.4 12/28/2005: at GameEx.GameEx.mainform.DisplayFrame()
Try using 16 bit Colour, some Graphics cards do this with GameEx if they run out of memory. Although my laptop uses a radeon mobility 7500c and works fine.
