Hi all
I have searched the forums and have not found anything that helps.
I am using FreeDo with the FreeDo_Loader I found here on this forum. I am also ruing it on Windows 7.
The issue I m having is that game ex does not load the rom, it just loads the emulator and thats it. because I get an asci error when I load the emu outside game ex i implimented the sendkeys {ENTER} to remove the dialogue box in Game EX,
I think this is the cause for the wrapper failing but there is no way for me to remove that pesky dialogue box because there is no correct asci drivers for windows 7.
The emulator works fine outside gamEX
config file
[Emulator_1]
System=Arcade
Category=Arcade
Emulator=Raine
Version=0.51.5
Rating=
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/raine.7z
RequiredFiles=
Website=http://rainemu.swishparty.co.uk/
Info=Raine is an arcade emulator which emulates some games which use M68000 or M68020 CPU's. The main focus is on emulating Taito and Jaleco games.
TITLETEXT=3DO
STARTPAGENAME=Panasonic 3DO
StartPageLogo=dvd
Command=FreeDo_Loader.exe "[RomPath]\[RomFile]"
ROMFilter=*.iso
Database=
ConfigFile=[Mapping Off] Exit (Process Close)
MAPFile=
RomPath=E:\Games\ROMs\3DO
SnapPath=E:\Games\emulated\3DO\Snaps
TitlePath=E:\Games\emulated\3DO\Titles
BoxPath=E:\Games\emulated\3DO\Boxes
CartPath=E:\Games\emulated\3DO\Cartridges
ManualPath=E:\Games\emulated\3DO\Manuals
ControlPanelPath=E:\Games\emulated\3DO\Controls
WorkingPath=E:\Games\emulated\3DO
MapKeys=True
WaitBeforeKeys=1500
SendKeys={ENTER}
ReplaceDash=True
ReplaceUnder=True
Capitals=False
RemoveBrackets=False
ShowDesktop=True
Debug=False
AlsoLaunch=
OLDatZip=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PlaySelectionMusic=False
SelectionMusicFolder=
PCGame=False
GamesIn7Zips=False
PlayInScreenSaver=False
ShowMostPlayed=True
RandomMostPlayed=True
CDCheck=False
CDCheckFile=
RomsInFolders=
InstructionsPath=
TVAdPath=
MusicPath=
ImageNotFound=
log file
12:19:00.1 24/03/2011: GameEx: Version 11.63: Starting Log
12:19:00.1 24/03/2011: Operating System Platform: Win32NT
12:19:00.1 24/03/2011: Operating System Name: Windows 7
12:19:00.1 24/03/2011: Operating System Version: 6.1.7600
12:19:00.1 24/03/2011: Aero running
12:19:00.1 24/03/2011: Initializing Vista/Windows 7 volume control
12:19:00.1 24/03/2011: Checking for versions of .net Framework installed
12:19:00.1 24/03/2011: .net Framework 2.0 Installed
12:19:00.1 24/03/2011: .net Framework 3.0 Installed
12:19:00.1 24/03/2011: .net Framework 3.5 Installed
12:19:00.1 24/03/2011: Intel® Core i3 CPU 540 @ 3.07GHz, 3575MB
12:19:00.1 24/03/2011: 3.07Ghz - 4 Cores or CPU's
12:19:00.1 24/03/2011: Running Randomize()
12:19:00.1 24/03/2011: Loading PlugIns
12:19:00.1 24/03/2011: Checking for applications to Launch On Startup
12:19:00.1 24/03/2011: Running Misc startup tasks
12:19:00.1 24/03/2011: Setting Menu types
12:19:00.1 24/03/2011: Opening Configuration File
12:19:00.1 24/03/2011: Getting Configuration Values
12:19:00.1 24/03/2011: Using Theme: Default - Dark Gloss
12:19:00.1 24/03/2011: Checking for alternate Image Directory for Theme: Default - Dark Gloss
12:19:00.1 24/03/2011: Launching HideOS.exe
12:19:00.1 24/03/2011: Initialising Video/MNG DLL's
12:19:00.1 24/03/2011: GameEx will check for media insertion (may affect performance)
12:19:00.1 24/03/2011: Hiding Taskbar
12:19:00.1 24/03/2011: Is Media Center running?
12:19:00.1 24/03/2011: Checking/Creating LCD Registry values
12:19:00.1 24/03/2011: Check Media Center Exit/Start Mode
12:19:00.1 24/03/2011: Media Center Mode 2
12:19:00.1 24/03/2011: Video previews on. Warning: Only recommended on modern systems
12:19:00.1 24/03/2011: Custom Game Device Input enabled: Getting custom codes
12:19:00.1 24/03/2011: Snap Delay set to: 7
12:19:00.1 24/03/2011: Get other settings
12:19:00.1 24/03/2011: Desktop set to Hide ICONS and set Background to Black
12:19:00.1 24/03/2011: Set: Find emulator artwork on best match basis
12:19:00.1 24/03/2011: Start work for Form
12:19:00.1 24/03/2011: Getting Original Screen Size
12:19:00.1 24/03/2011: Opening Database Connection
12:19:00.2 24/03/2011: Initializing Component
12:19:00.2 24/03/2011: Retrieving resolution setting
12:19:00.2 24/03/2011: MAME Path is: E:\Games\emulated\Mame32
12:19:00.2 24/03/2011: daphne Path is: E:\Games\emulated\Daphne
12:19:00.2 24/03/2011: daphne EXE file is: Daphne.exe
12:19:00.2 24/03/2011: Use daphne on. Daphne.exe will launch games
12:19:00.2 24/03/2011: Model 2 Path Path is: E:\Games\emulated\Model 2
12:19:00.2 24/03/2011: Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe
12:19:00.2 24/03/2011: Model 2 EXE file is: emulator_multicpu.exe
12:19:00.2 24/03/2011: Model 2 emulator with command line support detected
12:19:00.2 24/03/2011: Use Model 2 on. emulator_multicpu.exe will launch Sega Model 2 games
12:19:00.2 24/03/2011: ZiNc Path is: E:\Games\emulated\zinc
12:19:00.2 24/03/2011: ZiNc EXE file is: zinc.exe
12:19:00.2 24/03/2011: Use ZiNc on. zinc.exe will launch PSX games
12:19:00.2 24/03/2011: MAME EXE file is: MameUI32.exe
12:19:00.2 24/03/2011: ROM Path is: E:\Games\ROMs\Mame
12:19:00.2 24/03/2011: Catver.ini is located at: E:\GameEx\DATA\catver.ini
12:19:00.2 24/03/2011: controls.ini is located at: E:\GameEx\data\controls.ini
12:19:00.2 24/03/2011: History.dat is located at: E:\GameEx\DATA\history.dat
12:19:00.2 24/03/2011: nplayers.ini is located at: E:\GameEx\DATA\nplayers.ini
12:19:00.2 24/03/2011: command.dat is located at: E:\GameEx\DATA\command.dat
12:19:00.2 24/03/2011: MAMEinfo.dat is located at: E:\GameEx\DATA\mameinfo.dat
12:19:00.2 24/03/2011: Loading Controls.ini map file
12:19:00.2 24/03/2011: Snap Path is: E:\Games\emulated\Mame32\snap
12:19:00.2 24/03/2011: AVI Snap Path is: E:\Video\avisnap
12:19:00.2 24/03/2011: Flyer Path is: E:\Games\emulated\Mame32\flyers
12:19:00.2 24/03/2011: Cabinet Path is: E:\Games\emulated\Mame32\cabinets
12:19:00.2 24/03/2011: Cabinet 3D Path is: E:\Games\emulated\Mame32\cabinets
12:19:00.2 24/03/2011: Title Path is: E:\Games\emulated\Mame32\titles
12:19:00.2 24/03/2011: PCB Path is: E:\Games\emulated\Mame32\pcb
12:19:00.2 24/03/2011: Artwork Preview Path is: E:\Games\emulated\Mame32\artwork
12:19:00.2 24/03/2011: Panel Path is: E:\Games\emulated\Mame32\cpanel
12:19:00.2 24/03/2011: Manual Path: Not Found
12:19:00.2 24/03/2011: Icon Path is: E:\Games\emulated\Mame32\icons
12:19:00.2 24/03/2011: Marquee Path is: E:\Games\emulated\Mame32\marquees
12:19:00.2 24/03/2011: Loading Custom Emulators
12:19:00.2 24/03/2011: Loading Emulator 1: Panasonic 3DO
12:19:00.2 24/03/2011: Loading Emulator 2: [Console] Atari 2600 (MESS)
12:19:00.2 24/03/2011: Loading Emulator 3: [Console] Atari 5200 (MESS)
12:19:00.2 24/03/2011: Loading Emulator 4: [Console] Atari 7800 (MESS)
12:19:00.2 24/03/2011: Loading Emulator 5: [Console] Atari Jaguar (Virtual Jaguar)
12:19:00.2 24/03/2011: Loading Emulator 6: [Console] Coleco Vision (MESS)
12:19:00.2 24/03/2011: Loading Emulator 7: [Console] Mattel Intellivision (Nostalgia)
12:19:00.2 24/03/2011: Loading Emulator 8: [Console] NEC TurboGrafx-16 (MagicEngine)
12:19:00.2 24/03/2011: Loading Emulator 9: [Console] Nintendo N64 (Project64)
12:19:00.2 24/03/2011: Loading Emulator 10: [Console] Nintendo NES (Jnes)
12:19:00.2 24/03/2011: Loading Emulator 11: [Console] Nintendo SNES (ZSNES)
12:19:00.2 24/03/2011: Loading Emulator 12: [Console] Sega Dreamcast (nullDC)
12:19:00.2 24/03/2011: Loading Emulator 13: [Console] Sega Master System (Fusion)
12:19:00.2 24/03/2011: Loading Emulator 14: [Console] Sega Saturn (SSF)
12:19:00.2 24/03/2011: Loading Emulator 15: [Console] Sega Saturn (Yabause)
12:19:00.2 24/03/2011: Loading Emulator 16: [Console] SNK Neo-Geo (Nebula)
12:19:00.2 24/03/2011: Loading Emulator 17: [Console] Sony Playstation (ePSXe)
12:19:00.2 24/03/2011: Loading Emulator 18: [Handheld] Atari Lynx (Handy)
12:19:00.2 24/03/2011: Loading Emulator 19: [Handheld] Bandai WonderSwan (mednafen)
12:19:00.2 24/03/2011: Loading Emulator 20: [Handheld] Nintendo DS (DeSmuME)
12:19:00.2 24/03/2011: Loading Emulator 21: [Handheld] Nintendo Game Boy Advance (VisualBoyAdvance)
12:19:00.2 24/03/2011: Loading Emulator 22: [Handheld] Nintendo Game Boy Color (VisualBoyAdvance)
12:19:00.2 24/03/2011: Loading Emulator 23: [Handheld] Nintendo Virtual Boy (Red Dragon)
12:19:00.2 24/03/2011: Loading Emulator 24: [Handheld] Sega Game Gear (Fusion)
12:19:00.2 24/03/2011: Loading Emulator 25: [Handheld] SNK Neo-Geo Pocket (NeoPop)
12:19:00.2 24/03/2011: Loading Emulator 26: [HandHeld] Sony PSP (PCSP)
12:19:00.2 24/03/2011: Using 3D Alpha Blended Animations.
12:19:00.2 24/03/2011: Using General Font: Trebuchet MS
12:19:00.2 24/03/2011: Using Title Font: Trebuchet MS
12:19:00.3 24/03/2011: Initialising Direct3D
12:19:00.3 24/03/2011: Applying GameEx is Loading Image
12:19:00.4 24/03/2011: Setting Resolution to 1280x720 32 bit color
12:19:00.4 24/03/2011: Creating Surfaces
12:19:00.6 24/03/2011: Creating Primary Surface - Full Screen Mode
12:19:00.6 24/03/2011: Creating Back Buffer
12:19:00.6 24/03/2011: Loading graphic Surfaces
12:19:00.6 24/03/2011: Display is running at: 1280x720 32bit color, 60hz
12:19:00.6 24/03/2011: Creating Surfaces Flags
12:19:00.6 24/03/2011: Creating Surfaces Misc and Dialogs
12:19:00.6 24/03/2011: Creating Surfaces Volume
12:19:00.6 24/03/2011: Creating Surfaces Arrows
12:19:00.6 24/03/2011: Creating Surfaces GameEXlogo Text
12:19:00.6 24/03/2011: Creating Surfaces Toolbar
12:19:00.7 24/03/2011: Creating Surfaces Backgrounds
12:19:00.7 24/03/2011: Creating Surfaces Toolbar Controls
12:19:00.7 24/03/2011: Creating Surfaces GameEx Logo
12:19:00.7 24/03/2011: Creating Surface Unselected
12:19:00.7 24/03/2011: Creating Surfaces Snaps
12:19:00.7 24/03/2011: Creating Surfaces Menu and List Bars
12:19:00.7 24/03/2011: Creating Fonts
12:19:00.7 24/03/2011: Creating Game Font
12:19:00.8 24/03/2011: Creating Game Font Faded
12:19:00.8 24/03/2011: Creating Title Font
12:19:00.8 24/03/2011: Restoring Title Font From Cache
12:19:01.0 24/03/2011: Creating Font Black
12:19:01.1 24/03/2011: Creating Font Black Small
12:19:01.1 24/03/2011: Fonts Created Succesfully
12:19:01.1 24/03/2011: Initialising Bass Audio Library
12:19:01.1 24/03/2011: Creating instance of global keyboard hook
12:19:01.4 24/03/2011: Playing Startup Video on thread
12:19:01.4 24/03/2011: Attempting to load game list
12:19:01.5 24/03/2011: Applying Language/Text
12:19:01.5 24/03/2011: Text/Language: English
12:19:01.5 24/03/2011: MAME CMD options: -nowindow -joy -skip_gameinfo
12:19:01.5 24/03/2011: Loading last used Game List
12:19:01.5 24/03/2011: Creating DirectSound Device
12:19:01.5 24/03/2011: Trying: Primary Sound Driver
12:19:01.5 24/03/2011: Loading Sound Files
12:19:01.5 24/03/2011: DirectSound Device Created Successfully
12:19:01.5 24/03/2011: Creating ICONS
12:19:01.5 24/03/2011: Recreating ICONS
12:19:01.8 24/03/2011: Initialising DirectInput for Gamepad support
12:19:01.8 24/03/2011: Unable to create a joystick device
12:19:01.8 24/03/2011: Initializing MCE Remote
12:19:01.8 24/03/2011: Playing intro sound file
12:19:01.8 24/03/2011: Initialization OK! Starting GameEx!
12:19:01.8 24/03/2011: Testing Main Loop Once: Processing Frame
12:19:02.0 24/03/2011: Testing Main Loop Once: Main Loop ran successfully
12:19:07.8 24/03/2011: Validating: Emulator_1: Custom Background: E:\Games\emulated\3DO\Snaps
12:19:07.8 24/03/2011: Warning: Emulator_1: Custom Background Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_1: Snap Path: E:\Games\emulated\3DO\Snaps
12:19:07.8 24/03/2011: Warning: Emulator_1: Snap Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_1: Custom Art Path 1:
12:19:07.8 24/03/2011: Warning: Emulator_1: Custom Art Path 1 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_1: Custom Art Path 2:
12:19:07.8 24/03/2011: Warning: Emulator_1: Custom Art Path 2 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_1: Custom Art Path 3:
12:19:07.8 24/03/2011: Warning: Emulator_1: Custom Art Path 3 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_1: Custom Art Path 4:
12:19:07.8 24/03/2011: Warning: Emulator_1: Custom Art Path 4 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_1: Custom Art Path 5:
12:19:07.8 24/03/2011: Warning: Emulator_1: Custom Art Path 5 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_1: Control Panel Path: E:\Games\emulated\3DO\Controls
12:19:07.8 24/03/2011: Warning: Emulator_1: Control Panel Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_1: Instructions Path:
12:19:07.8 24/03/2011: Warning: Emulator_1: Instructions Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_1: Database:
12:19:07.8 24/03/2011: Warning: Emulator_1: Database Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_1: Title Snap Path: E:\Games\emulated\3DO\Titles
12:19:07.8 24/03/2011: Warning: Emulator_1: Title Snap Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_1: Box Art Path: E:\Games\emulated\3DO\Boxes
12:19:07.8 24/03/2011: Warning: Emulator_1: Box Art Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_1: Cart Art Path: E:\Games\emulated\3DO\Cartridges
12:19:07.8 24/03/2011: Warning: Emulator_1: Cart Art Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_1: Music Path:
12:19:07.8 24/03/2011: Warning: Emulator_1: Music Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_1: TV Ad Path:
12:19:07.8 24/03/2011: Warning: Emulator_1: TV Ad Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_1: Manual Path: E:\Games\emulated\3DO\Manuals
12:19:07.8 24/03/2011: Warning: Emulator_1: Manual Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_2: Custom Background: E:\Games\Assets\Atari 2600\Snaps
12:19:07.8 24/03/2011: Warning: Emulator_2: Custom Background Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_2: Snap Path: E:\Games\Assets\Atari 2600\Snaps
12:19:07.8 24/03/2011: Validating: Emulator_2: Custom Art Path 1:
12:19:07.8 24/03/2011: Warning: Emulator_2: Custom Art Path 1 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_2: Custom Art Path 2:
12:19:07.8 24/03/2011: Warning: Emulator_2: Custom Art Path 2 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_2: Custom Art Path 3:
12:19:07.8 24/03/2011: Warning: Emulator_2: Custom Art Path 3 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_2: Custom Art Path 4:
12:19:07.8 24/03/2011: Warning: Emulator_2: Custom Art Path 4 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_2: Custom Art Path 5:
12:19:07.8 24/03/2011: Warning: Emulator_2: Custom Art Path 5 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_2: Control Panel Path: E:\Games\Assets\Atari 2600\Controls
12:19:07.8 24/03/2011: Validating: Emulator_2: Instructions Path:
12:19:07.8 24/03/2011: Warning: Emulator_2: Instructions Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_2: Database: [Console] Atari 2600
12:19:07.8 24/03/2011: Validating: Emulator_2: Title Snap Path: E:\Games\Assets\Atari 2600\Titles
12:19:07.8 24/03/2011: Validating: Emulator_2: Box Art Path: E:\Games\Assets\Atari 2600\Boxes
12:19:07.8 24/03/2011: Validating: Emulator_2: Cart Art Path: E:\Games\Assets\Atari 2600\Cartridges
12:19:07.8 24/03/2011: Validating: Emulator_2: Music Path:
12:19:07.8 24/03/2011: Warning: Emulator_2: Music Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_2: TV Ad Path:
12:19:07.8 24/03/2011: Warning: Emulator_2: TV Ad Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_2: Manual Path: E:\Games\Assets\Atari 2600\Manuals
12:19:07.8 24/03/2011: Validating: Emulator_3: Custom Background: E:\Games\Assets\Atari 5200\Snaps
12:19:07.8 24/03/2011: Warning: Emulator_3: Custom Background Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_3: Snap Path: E:\Games\Assets\Atari 5200\Snaps
12:19:07.8 24/03/2011: Validating: Emulator_3: Custom Art Path 1:
12:19:07.8 24/03/2011: Warning: Emulator_3: Custom Art Path 1 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_3: Custom Art Path 2:
12:19:07.8 24/03/2011: Warning: Emulator_3: Custom Art Path 2 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_3: Custom Art Path 3:
12:19:07.8 24/03/2011: Warning: Emulator_3: Custom Art Path 3 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_3: Custom Art Path 4:
12:19:07.8 24/03/2011: Warning: Emulator_3: Custom Art Path 4 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_3: Custom Art Path 5:
12:19:07.8 24/03/2011: Warning: Emulator_3: Custom Art Path 5 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_3: Control Panel Path: E:\Games\Assets\Atari 5200\Controls
12:19:07.8 24/03/2011: Validating: Emulator_3: Instructions Path:
12:19:07.8 24/03/2011: Warning: Emulator_3: Instructions Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_3: Database: [Console] Atari 5200
12:19:07.8 24/03/2011: Validating: Emulator_3: Title Snap Path: E:\Games\Assets\Atari 5200\Titles
12:19:07.8 24/03/2011: Validating: Emulator_3: Box Art Path: E:\Games\Assets\Atari 5200\Boxes
12:19:07.8 24/03/2011: Validating: Emulator_3: Cart Art Path: E:\Games\Assets\Atari 5200\Cartridges
12:19:07.8 24/03/2011: Validating: Emulator_3: Music Path:
12:19:07.8 24/03/2011: Warning: Emulator_3: Music Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_3: TV Ad Path:
12:19:07.8 24/03/2011: Warning: Emulator_3: TV Ad Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_3: Manual Path: E:\Games\Assets\Atari 5200\Manuals
12:19:07.8 24/03/2011: Validating: Emulator_4: Custom Background: E:\Games\Assets\Atari 7800\Snaps
12:19:07.8 24/03/2011: Warning: Emulator_4: Custom Background Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_4: Snap Path: E:\Games\Assets\Atari 7800\Snaps
12:19:07.8 24/03/2011: Validating: Emulator_4: Custom Art Path 1:
12:19:07.8 24/03/2011: Warning: Emulator_4: Custom Art Path 1 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_4: Custom Art Path 2:
12:19:07.8 24/03/2011: Warning: Emulator_4: Custom Art Path 2 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_4: Custom Art Path 3:
12:19:07.8 24/03/2011: Warning: Emulator_4: Custom Art Path 3 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_4: Custom Art Path 4:
12:19:07.8 24/03/2011: Warning: Emulator_4: Custom Art Path 4 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_4: Custom Art Path 5:
12:19:07.8 24/03/2011: Warning: Emulator_4: Custom Art Path 5 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_4: Control Panel Path: E:\Games\Assets\Atari 7800\Controls
12:19:07.8 24/03/2011: Validating: Emulator_4: Instructions Path:
12:19:07.8 24/03/2011: Warning: Emulator_4: Instructions Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_4: Database: [Console] Atari 7800
12:19:07.8 24/03/2011: Validating: Emulator_4: Title Snap Path: E:\Games\Assets\Atari 7800\Titles
12:19:07.8 24/03/2011: Validating: Emulator_4: Box Art Path: E:\Games\Assets\Atari 7800\Boxes
12:19:07.8 24/03/2011: Validating: Emulator_4: Cart Art Path: E:\Games\Assets\Atari 7800\Cartridges
12:19:07.8 24/03/2011: Validating: Emulator_4: Music Path:
12:19:07.8 24/03/2011: Warning: Emulator_4: Music Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_4: TV Ad Path:
12:19:07.8 24/03/2011: Warning: Emulator_4: TV Ad Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_4: Manual Path: E:\Games\Assets\Atari 7800\Manuals
12:19:07.8 24/03/2011: Validating: Emulator_5: Custom Background: E:\Games\Assets\Atari Jaguar\Snaps
12:19:07.8 24/03/2011: Warning: Emulator_5: Custom Background Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_5: Snap Path: E:\Games\Assets\Atari Jaguar\Snaps
12:19:07.8 24/03/2011: Validating: Emulator_5: Custom Art Path 1:
12:19:07.8 24/03/2011: Warning: Emulator_5: Custom Art Path 1 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_5: Custom Art Path 2:
12:19:07.8 24/03/2011: Warning: Emulator_5: Custom Art Path 2 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_5: Custom Art Path 3:
12:19:07.8 24/03/2011: Warning: Emulator_5: Custom Art Path 3 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_5: Custom Art Path 4:
12:19:07.8 24/03/2011: Warning: Emulator_5: Custom Art Path 4 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_5: Custom Art Path 5:
12:19:07.8 24/03/2011: Warning: Emulator_5: Custom Art Path 5 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_5: Control Panel Path: E:\Games\Assets\Atari Jaguar\Controls
12:19:07.8 24/03/2011: Validating: Emulator_5: Instructions Path:
12:19:07.8 24/03/2011: Warning: Emulator_5: Instructions Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_5: Database: [Console] Atari Jaguar
12:19:07.8 24/03/2011: Validating: Emulator_5: Title Snap Path: E:\Games\Assets\Atari Jaguar\Titles
12:19:07.8 24/03/2011: Validating: Emulator_5: Box Art Path: E:\Games\Assets\Atari Jaguar\Boxes
12:19:07.8 24/03/2011: Validating: Emulator_5: Cart Art Path: E:\Games\Assets\Atari Jaguar\Cartridges
12:19:07.8 24/03/2011: Validating: Emulator_5: Music Path:
12:19:07.8 24/03/2011: Warning: Emulator_5: Music Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_5: TV Ad Path:
12:19:07.8 24/03/2011: Warning: Emulator_5: TV Ad Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_5: Manual Path: E:\Games\Assets\Atari Jaguar\Manuals
12:19:07.8 24/03/2011: Validating: Emulator_12: Custom Background: E:\Games\Assets\Sega Dreamcast\Snaps
12:19:07.8 24/03/2011: Warning: Emulator_12: Custom Background Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_12: Snap Path: E:\Games\Assets\Sega Dreamcast\Snaps
12:19:07.8 24/03/2011: Validating: Emulator_12: Custom Art Path 1:
12:19:07.8 24/03/2011: Warning: Emulator_12: Custom Art Path 1 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_12: Custom Art Path 2:
12:19:07.8 24/03/2011: Warning: Emulator_12: Custom Art Path 2 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_12: Custom Art Path 3:
12:19:07.8 24/03/2011: Warning: Emulator_12: Custom Art Path 3 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_12: Custom Art Path 4:
12:19:07.8 24/03/2011: Warning: Emulator_12: Custom Art Path 4 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_12: Custom Art Path 5:
12:19:07.8 24/03/2011: Warning: Emulator_12: Custom Art Path 5 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_12: Control Panel Path: E:\Games\Assets\Sega Dreamcast\Controls
12:19:07.8 24/03/2011: Validating: Emulator_12: Instructions Path:
12:19:07.8 24/03/2011: Warning: Emulator_12: Instructions Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_12: Database: [Console] Sega Dreamcast
12:19:07.8 24/03/2011: Validating: Emulator_12: Title Snap Path: E:\Games\Assets\Sega Dreamcast\Titles
12:19:07.8 24/03/2011: Validating: Emulator_12: Box Art Path: E:\Games\Assets\Sega Dreamcast\Boxes
12:19:07.8 24/03/2011: Validating: Emulator_12: Cart Art Path: E:\Games\Assets\Sega Dreamcast\Cartridges
12:19:07.8 24/03/2011: Validating: Emulator_12: Music Path:
12:19:07.8 24/03/2011: Warning: Emulator_12: Music Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_12: TV Ad Path:
12:19:07.8 24/03/2011: Warning: Emulator_12: TV Ad Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_12: Manual Path: E:\Games\Assets\Sega Dreamcast\Manuals
12:19:07.8 24/03/2011: Validating: Emulator_13: Custom Background: E:\Games\Assets\Sega Master System\Snaps
12:19:07.8 24/03/2011: Warning: Emulator_13: Custom Background Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_13: Snap Path: E:\Games\Assets\Sega Master System\Snaps
12:19:07.8 24/03/2011: Validating: Emulator_13: Custom Art Path 1:
12:19:07.8 24/03/2011: Warning: Emulator_13: Custom Art Path 1 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_13: Custom Art Path 2:
12:19:07.8 24/03/2011: Warning: Emulator_13: Custom Art Path 2 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_13: Custom Art Path 3:
12:19:07.8 24/03/2011: Warning: Emulator_13: Custom Art Path 3 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_13: Custom Art Path 4:
12:19:07.8 24/03/2011: Warning: Emulator_13: Custom Art Path 4 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_13: Custom Art Path 5:
12:19:07.8 24/03/2011: Warning: Emulator_13: Custom Art Path 5 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_13: Control Panel Path: E:\Games\Assets\Sega Master System\Controls
12:19:07.8 24/03/2011: Validating: Emulator_13: Instructions Path:
12:19:07.8 24/03/2011: Warning: Emulator_13: Instructions Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_13: Database: [Console] Sega Master System
12:19:07.8 24/03/2011: Validating: Emulator_13: Title Snap Path: E:\Games\Assets\Sega Master System\Titles
12:19:07.8 24/03/2011: Validating: Emulator_13: Box Art Path: E:\Games\Assets\Sega Master System\Boxes
12:19:07.8 24/03/2011: Validating: Emulator_13: Cart Art Path: E:\Games\Assets\Sega Master System\Cartridges
12:19:07.8 24/03/2011: Validating: Emulator_13: Music Path:
12:19:07.8 24/03/2011: Warning: Emulator_13: Music Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_13: TV Ad Path:
12:19:07.8 24/03/2011: Warning: Emulator_13: TV Ad Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_13: Manual Path: E:\Games\Assets\Sega Master System\Manuals
12:19:07.8 24/03/2011: Validating: Emulator_14: Custom Background: E:\Games\Assets\Sega Saturn\Snaps
12:19:07.8 24/03/2011: Warning: Emulator_14: Custom Background Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_14: Snap Path: E:\Games\Assets\Sega Saturn\Snaps
12:19:07.8 24/03/2011: Validating: Emulator_14: Custom Art Path 1:
12:19:07.8 24/03/2011: Warning: Emulator_14: Custom Art Path 1 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_14: Custom Art Path 2:
12:19:07.8 24/03/2011: Warning: Emulator_14: Custom Art Path 2 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_14: Custom Art Path 3:
12:19:07.8 24/03/2011: Warning: Emulator_14: Custom Art Path 3 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_14: Custom Art Path 4:
12:19:07.8 24/03/2011: Warning: Emulator_14: Custom Art Path 4 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_14: Custom Art Path 5:
12:19:07.8 24/03/2011: Warning: Emulator_14: Custom Art Path 5 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_14: Control Panel Path: E:\Games\Assets\Sega Saturn\Controls
12:19:07.8 24/03/2011: Validating: Emulator_14: Instructions Path:
12:19:07.8 24/03/2011: Warning: Emulator_14: Instructions Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_14: Database: [Console] Sega Saturn
12:19:07.8 24/03/2011: Validating: Emulator_14: Title Snap Path: E:\Games\Assets\Sega Saturn\Titles
12:19:07.8 24/03/2011: Validating: Emulator_14: Box Art Path: E:\Games\Assets\Sega Saturn\Boxes
12:19:07.8 24/03/2011: Validating: Emulator_14: Cart Art Path: E:\Games\Assets\Sega Saturn\Cartridges
12:19:07.8 24/03/2011: Validating: Emulator_14: Music Path:
12:19:07.8 24/03/2011: Warning: Emulator_14: Music Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_14: TV Ad Path:
12:19:07.8 24/03/2011: Warning: Emulator_14: TV Ad Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_14: Manual Path: E:\Games\Assets\Sega Saturn\Manuals
12:19:07.8 24/03/2011: Validating: Emulator_15: Custom Background: E:\Games\Assets\Sega Saturn\Snaps
12:19:07.8 24/03/2011: Warning: Emulator_15: Custom Background Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_15: Snap Path: E:\Games\Assets\Sega Saturn\Snaps
12:19:07.8 24/03/2011: Validating: Emulator_15: Custom Art Path 1:
12:19:07.8 24/03/2011: Warning: Emulator_15: Custom Art Path 1 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_15: Custom Art Path 2:
12:19:07.8 24/03/2011: Warning: Emulator_15: Custom Art Path 2 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_15: Custom Art Path 3:
12:19:07.8 24/03/2011: Warning: Emulator_15: Custom Art Path 3 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_15: Custom Art Path 4:
12:19:07.8 24/03/2011: Warning: Emulator_15: Custom Art Path 4 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_15: Custom Art Path 5:
12:19:07.8 24/03/2011: Warning: Emulator_15: Custom Art Path 5 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_15: Control Panel Path: E:\Games\Assets\Sega Saturn\Controls
12:19:07.8 24/03/2011: Validating: Emulator_15: Instructions Path:
12:19:07.8 24/03/2011: Warning: Emulator_15: Instructions Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_15: Database: [Console] Sega Saturn
12:19:07.8 24/03/2011: Validating: Emulator_15: Title Snap Path: E:\Games\Assets\Sega Saturn\Titles
12:19:07.8 24/03/2011: Validating: Emulator_15: Box Art Path: E:\Games\Assets\Sega Saturn\Boxes
12:19:07.8 24/03/2011: Validating: Emulator_15: Cart Art Path: E:\Games\Assets\Sega Saturn\Cartridges
12:19:07.8 24/03/2011: Validating: Emulator_15: Music Path:
12:19:07.8 24/03/2011: Warning: Emulator_15: Music Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_15: TV Ad Path:
12:19:07.8 24/03/2011: Warning: Emulator_15: TV Ad Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_15: Manual Path: E:\Games\Assets\Sega Saturn\Manuals
12:19:07.8 24/03/2011: Validating: Emulator_18: Custom Background: E:\Games\Assets\Atari Lynx\Snaps
12:19:07.8 24/03/2011: Warning: Emulator_18: Custom Background Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_18: Snap Path: E:\Games\Assets\Atari Lynx\Snaps
12:19:07.8 24/03/2011: Validating: Emulator_18: Custom Art Path 1:
12:19:07.8 24/03/2011: Warning: Emulator_18: Custom Art Path 1 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_18: Custom Art Path 2:
12:19:07.8 24/03/2011: Warning: Emulator_18: Custom Art Path 2 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_18: Custom Art Path 3:
12:19:07.8 24/03/2011: Warning: Emulator_18: Custom Art Path 3 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_18: Custom Art Path 4:
12:19:07.8 24/03/2011: Warning: Emulator_18: Custom Art Path 4 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_18: Custom Art Path 5:
12:19:07.8 24/03/2011: Warning: Emulator_18: Custom Art Path 5 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_18: Control Panel Path: E:\Games\Assets\Atari Lynx\Controls
12:19:07.8 24/03/2011: Validating: Emulator_18: Instructions Path:
12:19:07.8 24/03/2011: Warning: Emulator_18: Instructions Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_18: Database: [Handheld] Atari Lynx
12:19:07.8 24/03/2011: Validating: Emulator_18: Title Snap Path: E:\Games\Assets\Atari Lynx\Titles
12:19:07.8 24/03/2011: Validating: Emulator_18: Box Art Path: E:\Games\Assets\Atari Lynx\Boxes
12:19:07.8 24/03/2011: Validating: Emulator_18: Cart Art Path: E:\Games\Assets\Atari Lynx\Cartridges
12:19:07.8 24/03/2011: Validating: Emulator_18: Music Path:
12:19:07.8 24/03/2011: Warning: Emulator_18: Music Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_18: TV Ad Path:
12:19:07.8 24/03/2011: Warning: Emulator_18: TV Ad Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_18: Manual Path: E:\Games\Assets\Atari Lynx\Manuals
12:19:07.8 24/03/2011: Validating: Emulator_19: Custom Background: E:\Games\Assets\Bandai WonderSwan\Snaps
12:19:07.8 24/03/2011: Warning: Emulator_19: Custom Background Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_19: Snap Path: E:\Games\Assets\Bandai WonderSwan\Snaps
12:19:07.8 24/03/2011: Validating: Emulator_19: Custom Art Path 1:
12:19:07.8 24/03/2011: Warning: Emulator_19: Custom Art Path 1 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_19: Custom Art Path 2:
12:19:07.8 24/03/2011: Warning: Emulator_19: Custom Art Path 2 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_19: Custom Art Path 3:
12:19:07.8 24/03/2011: Warning: Emulator_19: Custom Art Path 3 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_19: Custom Art Path 4:
12:19:07.8 24/03/2011: Warning: Emulator_19: Custom Art Path 4 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_19: Custom Art Path 5:
12:19:07.8 24/03/2011: Warning: Emulator_19: Custom Art Path 5 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_19: Control Panel Path: E:\Games\Assets\Bandai WonderSwan\Controls
12:19:07.8 24/03/2011: Validating: Emulator_19: Instructions Path:
12:19:07.8 24/03/2011: Warning: Emulator_19: Instructions Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_19: Database: [Handheld] Bandai WonderSwan
12:19:07.8 24/03/2011: Validating: Emulator_19: Title Snap Path: E:\Games\Assets\Bandai WonderSwan\Titles
12:19:07.8 24/03/2011: Validating: Emulator_19: Box Art Path: E:\Games\Assets\Bandai WonderSwan\Boxes
12:19:07.8 24/03/2011: Validating: Emulator_19: Cart Art Path: E:\Games\Assets\Bandai WonderSwan\Cartridges
12:19:07.8 24/03/2011: Validating: Emulator_19: Music Path:
12:19:07.8 24/03/2011: Warning: Emulator_19: Music Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_19: TV Ad Path:
12:19:07.8 24/03/2011: Warning: Emulator_19: TV Ad Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_19: Manual Path: E:\Games\Assets\Bandai WonderSwan\Manuals
12:19:07.8 24/03/2011: Validating: Emulator_24: Custom Background: E:\Games\Assets\Sega Game Gear\Snaps
12:19:07.8 24/03/2011: Warning: Emulator_24: Custom Background Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_24: Snap Path: E:\Games\Assets\Sega Game Gear\Snaps
12:19:07.8 24/03/2011: Validating: Emulator_24: Custom Art Path 1:
12:19:07.8 24/03/2011: Warning: Emulator_24: Custom Art Path 1 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_24: Custom Art Path 2:
12:19:07.8 24/03/2011: Warning: Emulator_24: Custom Art Path 2 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_24: Custom Art Path 3:
12:19:07.8 24/03/2011: Warning: Emulator_24: Custom Art Path 3 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_24: Custom Art Path 4:
12:19:07.8 24/03/2011: Warning: Emulator_24: Custom Art Path 4 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_24: Custom Art Path 5:
12:19:07.8 24/03/2011: Warning: Emulator_24: Custom Art Path 5 Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_24: Control Panel Path: E:\Games\Assets\Sega Game Gear\Controls
12:19:07.8 24/03/2011: Validating: Emulator_24: Instructions Path:
12:19:07.8 24/03/2011: Warning: Emulator_24: Instructions Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_24: Database: [Handheld] Sega Game Gear
12:19:07.8 24/03/2011: Validating: Emulator_24: Title Snap Path: E:\Games\Assets\Sega Game Gear\Titles
12:19:07.8 24/03/2011: Validating: Emulator_24: Box Art Path: E:\Games\Assets\Sega Game Gear\Boxes
12:19:07.8 24/03/2011: Validating: Emulator_24: Cart Art Path: E:\Games\Assets\Sega Game Gear\Cartridges
12:19:07.8 24/03/2011: Validating: Emulator_24: Music Path:
12:19:07.8 24/03/2011: Warning: Emulator_24: Music Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_24: TV Ad Path:
12:19:07.8 24/03/2011: Warning: Emulator_24: TV Ad Path Does not exist
12:19:07.8 24/03/2011: Validating: Emulator_24: Manual Path: E:\Games\Assets\Sega Game Gear\Manuals
12:19:12.3 24/03/2011: Restoring Emulator from Cache
12:19:16.4 24/03/2011: Running: cmd.exe /c E: FreeDo_Loader.exe "E:\Games\ROMs\3DO\Gridders.iso"
12:19:16.6 24/03/2011: Shutting down display
12:19:29.8 24/03/2011: Exiting Game
12:19:29.8 24/03/2011: Closing Process
12:19:32.4 24/03/2011: Writing Stats
12:19:32.4 24/03/2011: 21 Consecutive Exceptions Occured
12:19:32.4 24/03/2011: Object reference not set to an instance of an object.
12:19:32.4 24/03/2011: at ag.r(Boolean A_0)
at ag.ad()
12:19:32.4 24/03/2011: Trying reinitialising the display after sleeping for 4 seconds
12:19:32.4 24/03/2011: Exception count will be dropped to 15
12:19:41.2 24/03/2011: Exiting GameEx!
12:19:41.2 24/03/2011: Saving Settings
12:19:42.7 24/03/2011: Disposing Plugins
12:19:42.7 24/03/2011: Closing database connection
12:19:42.8 24/03/2011: Checking for applications to Launch On Exit
12:19:42.8 24/03/2011: Media Center was not open when starting GameEx, so not launching
Last played file
E:
CD "E:\Games\emulated\3DO"
any help would be greatly appreciated
regards
Which version freedo are you using?I vaguely remember having this problem,I think I am using v1.9,anything over or under that didnt work for me on w7
And just like that it worked. Downloaded 1.9 from the devs home page and it just worked without issues.
You are definitley a super user.
I'm pretty sure this is due to the loader looking for a specific exe and the newer versions changed. So the loader needs updating or you can always try and rename the newer versions to FreeDo.exe in hopes that it may still work.
I remember something about asci layers,and them not being in W7,or if you had Nero installed you already had them...im not 100% on it i was getting pretty aggravated trying you use newer versions like 2.1 so I just settled on 1.9
Edited by Draco1962
