When I browse my game list, some games (Street Fighter EX for example) the mp3 preview goes bezerk. It sounds like it's feedback and the volume just increases and then slowly fades away when I choose a different game or starts the current one.
Anyone else have this issue?
And secondly, the ambience sound doesn't fade out quick enough for me. (I'm using ZetaMAME32 http://mbox32.com/zeta/ ) so it's a stuck loop in the background when the loaded game starts. Only for the ambience though, not the preview sounds.
Edit: I can't get the "Emu_1 Custom background" to work either. I've tried with "bak.png" as well as just plain "bak". I solved this by copying my "bak.png" and renamed it "emubak.png", but this is a temporary workaround since this feature should work.
Emph
I dont think this is a GameEx issue. I had this problem. Are you using the MNG video previews. If so that is the problem . The Street Fighter and Star Gladiator ones dont work properly.
I ended up deleting them from the folder and just using screenshots for these games.
J
